<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[FS&amp;gt;95 Eagle Talon]]></title><description><![CDATA[<p dir="auto">Im pondering either selling or parting out. Would prefer to sell complete. Everything is there to make 500+whp on pump and 700whp on Racegas (may need the head ported to accomplish). Just needs a good dyno tune session.</p>
<p dir="auto">The bad.<br />
Roof has some wrinkles in it from a CF hood flying up.<br />
Front bumper has a small tear in it at the bottom.<br />
One quarter panel has a good key mark, touched up but needs refinishing.<br />
Rear camber needs adjustment, inner side of tires wearing a little more.</p>
<p dir="auto">Mods</p>
<p dir="auto">9:1 6 bolt motor. Wiseco Pistons, Eagle Rods. Oil squirters and Balance shafts removed. Low mileage on this. Full ARP Hardware, New oil pump/water pump/timing belt blah blah. Everything is done the right way.<br />
Stock late 1g head (better coolant passages than early)<br />
HKS 272 Cams<br />
Fidanza Adjustable Cam Gears<br />
NT Water pipe (for compressor cover clearance)<br />
Crowers Valve Springs/Retainers<br />
SS Valves (cant remember brand)<br />
Magnus Intake Manny w Nitrous bungs<br />
Ported Throttle Body<br />
Spearco 2-216 FMIC<br />
HKS BOV<br />
MBC<br />
Flywheel Scattershield<br />
Driveshaft loop<br />
6 point cage<br />
5 point harness (everything is there for MOD ET class at DFT)<br />
LSD Rearend<br />
Forgeline Competion Wheels (14lbs each if I recall, 16x8)<br />
Drilled/slotted Brake Rotors all around<br />
Camber kits<br />
Prothane Motors mounts<br />
Shep stage 4 Tranny<br />
Fluidyne Radiator w slimline fans<br />
DSMlink v2<br />
Wideband (hooked to ecu for logging)<br />
ACT 2900 clutch<br />
ACT Flywheel<br />
Taboo Clutch fork (try finding one of these)<br />
SS Clutch Line<br />
DNP t4 Equal length manifold<br />
BB T67<br />
4" Intake (filter in front of passenger tire in bumper)<br />
Oil Cooler (in front of driver tire in bumper)<br />
Moroso Battery box in back w cutoff out back<br />
B&amp;M Short Shifter<br />
1150cc FIC Injectors<br />
Dual Intake Walbro 255 Fuel Pumps<br />
Tokico HP Shocks w H&amp;R Springs<br />
97 Talon Front bumper<br />
Cometic Head Gasket<br />
ARP A1 Headstuds<br />
GM MAF w MAFT<br />
Fuellab Fuel Filter<br />
Aeromotive FPR<br />
Autometer Ultralite Guages (boost, fuel press, egt, oil press, water temp)<br />
RRE Catch Can<br />
P. Steering eliminated<br />
A/C Eliminated<br />
MSD Plug Wires<br />
Tinted Tailights</p>
<p dir="auto">Probly forgetting ALOT of stuff.</p>
<p dir="auto">Like I said, Id prefer to not part this out.<br />
$15k. REDUCED TO $13k.<br />
Reason for selling. Possibly moving out of state.</p>
<p dir="auto"><img src="http://i33.photobucket.com/albums/d75/matpatte/DSC_0086resized.jpg" alt="legacy image" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="http://i33.photobucket.com/albums/d75/matpatte/DSC_0088resized.jpg" alt="legacy image" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="http://i33.photobucket.com/albums/d75/matpatte/DSCN1109.jpg" alt="legacy image" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="http://i33.photobucket.com/albums/d75/matpatte/SNC13137.jpg" alt="legacy image" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="http://i33.photobucket.com/albums/d75/matpatte/SNC13135.jpg" alt="legacy image" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="http://i33.photobucket.com/albums/d75/matpatte/SNC11794-1.jpg" alt="legacy image" class=" img-fluid img-markdown" /></p>
]]></description><link>https://fargostreet.com/topic/16135/fs-gt-95-eagle-talon</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 02:06:58 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/16135.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 20 Jan 2009 23:30:27 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to FS&amp;gt;95 Eagle Talon on Mon, 26 Jan 2009 20:25:30 GMT]]></title><description><![CDATA[<p dir="auto">Reduced to $13k.</p>
]]></description><link>https://fargostreet.com/post/246009</link><guid isPermaLink="true">https://fargostreet.com/post/246009</guid><dc:creator><![CDATA[95TsiAWD]]></dc:creator><pubDate>Mon, 26 Jan 2009 20:25:30 GMT</pubDate></item><item><title><![CDATA[Reply to FS&amp;gt;95 Eagle Talon on Fri, 23 Jan 2009 04:50:41 GMT]]></title><description><![CDATA[<p dir="auto">sweet ass car, wish i could afford it</p>
]]></description><link>https://fargostreet.com/post/245427</link><guid isPermaLink="true">https://fargostreet.com/post/245427</guid><dc:creator><![CDATA[crowmagnum]]></dc:creator><pubDate>Fri, 23 Jan 2009 04:50:41 GMT</pubDate></item><item><title><![CDATA[Reply to FS&amp;gt;95 Eagle Talon on Wed, 21 Jan 2009 21:26:12 GMT]]></title><description><![CDATA[<p dir="auto">If you do part it out I may be interested in some stuff.</p>
]]></description><link>https://fargostreet.com/post/245167</link><guid isPermaLink="true">https://fargostreet.com/post/245167</guid><dc:creator><![CDATA[kylush]]></dc:creator><pubDate>Wed, 21 Jan 2009 21:26:12 GMT</pubDate></item><item><title><![CDATA[Reply to FS&amp;gt;95 Eagle Talon on Wed, 21 Jan 2009 18:23:40 GMT]]></title><description><![CDATA[<p dir="auto">man, this makes my love for dsm's start to brew up again!! i love the blue and black..... o and btw check out the sign in the top left corner of the last pic. thought that was pretty funny...</p>
]]></description><link>https://fargostreet.com/post/245110</link><guid isPermaLink="true">https://fargostreet.com/post/245110</guid><dc:creator><![CDATA[blackcherryTSi]]></dc:creator><pubDate>Wed, 21 Jan 2009 18:23:40 GMT</pubDate></item><item><title><![CDATA[Reply to FS&amp;gt;95 Eagle Talon on Wed, 21 Jan 2009 00:46:47 GMT]]></title><description><![CDATA[<p dir="auto">thats a sick car! wish i could aford it</p>
]]></description><link>https://fargostreet.com/post/244994</link><guid isPermaLink="true">https://fargostreet.com/post/244994</guid><dc:creator><![CDATA[GnArKiLl]]></dc:creator><pubDate>Wed, 21 Jan 2009 00:46:47 GMT</pubDate></item></channel></rss>
