<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[dtc #2 in obdo b16a]]></title><description><![CDATA[<p dir="auto">as the title says a friend has #2 code in his crx. i cant find on alldata what it means. any ideas????</p>
]]></description><link>https://fargostreet.com/topic/16522/dtc-2-in-obdo-b16a</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 02:40:53 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/16522.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 04 Mar 2009 15:51:34 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to dtc #2 in obdo b16a on Wed, 04 Mar 2009 17:14:15 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">SPANISH-RICE;264365 wrote:<br />
Google owns you</p>
<p dir="auto">word... I think pretty much every Honda forum has a sticky of the engine codes...</p>
]]></description><link>https://fargostreet.com/post/252798</link><guid isPermaLink="true">https://fargostreet.com/post/252798</guid><dc:creator><![CDATA[bubba]]></dc:creator><pubDate>Wed, 04 Mar 2009 17:14:15 GMT</pubDate></item><item><title><![CDATA[Reply to dtc #2 in obdo b16a on Wed, 04 Mar 2009 16:41:43 GMT]]></title><description><![CDATA[<p dir="auto">Google owns you</p>
]]></description><link>https://fargostreet.com/post/252790</link><guid isPermaLink="true">https://fargostreet.com/post/252790</guid><dc:creator><![CDATA[SPANISH-RICE]]></dc:creator><pubDate>Wed, 04 Mar 2009 16:41:43 GMT</pubDate></item><item><title><![CDATA[Reply to dtc #2 in obdo b16a on Wed, 04 Mar 2009 15:58:19 GMT]]></title><description><![CDATA[<p dir="auto"><a href="http://honda-tech.com" rel="nofollow ugc">honda-tech.com</a> NEWB</p>
<p dir="auto">Code 1 - O2 Sensor - Code 2 is for the one down on the cat. Which was not used in the US.<br />
MAP, TDC &amp; CYL (along others) helps determine the Pulse Width (PW) in which fuel is injected. With the MAP having the most control, out of all other sensors.</p>
<p dir="auto">Testing requires a voltmeter.<br />
The voltage on a properly working sensor should sweep between .1 to .9 volts 2-3 times a second @ 2500 rpm. Peeps with A/F Ratio meters, will see the reading moving/dancing around all the time. This means everything is working all right</p>
<p dir="auto">Unheated O2 sensor have to heat up, and maintain 600+ degrees F in order to work properly. Until that temp is reached, the ECU sends out .45V, until it reaches operating temp. When temp is reached, the O2 sensor will send out .5V. Telling the ECU it's up to operating temp, and can now go into "Closed Loop" operation. That is, if all the "other" conditions are met too, like water temp, etc....</p>
<p dir="auto">Voltages:</p>
<p dir="auto">Lean - .1 volts<br />
stoich - .5 volts<br />
Rich - .9 volts<br />
O2 sensors do not wear out... they fail due to contamination.</p>
<p dir="auto">Silcon Depostits (from using gasket sealents that are not O2 safe)<br />
Solvents, Lubricants, Cleaners, Adhesives<br />
Gasoline Additives<br />
Lead<br />
Carbon Deposits (rich condition)<br />
Engine Oil (burning or spilling)<br />
Anti-Freeze (blown head gasket)<br />
Clogged External Air Vents (dirt, ect...)<br />
Running Lean (too much heat)<br />
ECU damage can occure using the wrong sensor, due to the execessive current draw requirements of non-stock sensor.</p>
]]></description><link>https://fargostreet.com/post/252783</link><guid isPermaLink="true">https://fargostreet.com/post/252783</guid><dc:creator><![CDATA[gsrEK]]></dc:creator><pubDate>Wed, 04 Mar 2009 15:58:19 GMT</pubDate></item></channel></rss>
