<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[K20 swaps]]></title><description><![CDATA[<p dir="auto">I've been checking these out and trying to read up on them a little bit. A k20a head/k24 block in a crx or hatchie with n20 woudl definitly be a dream. For how new K20's are, they have been going fairly cheap on ebay. Tranny and all for right around 1700 usually. No one in fargo moorhead has done one of these yet. Anyone thought about doing one or know anything about them. IMO, this swap is the new b16.</p>
]]></description><link>https://fargostreet.com/topic/1655/k20-swaps</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 10:31:09 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/1655.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 13 Feb 2005 14:47:43 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to K20 swaps on Tue, 15 Feb 2005 19:38:45 GMT]]></title><description><![CDATA[<p dir="auto">joel did you go to school?</p>
]]></description><link>https://fargostreet.com/post/30406</link><guid isPermaLink="true">https://fargostreet.com/post/30406</guid><dc:creator><![CDATA[Jim]]></dc:creator><pubDate>Tue, 15 Feb 2005 19:38:45 GMT</pubDate></item><item><title><![CDATA[Reply to K20 swaps on Tue, 15 Feb 2005 17:55:24 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">paul_V wrote:<br />
If I had the money to do a K swap, I'd be all over it.  THe only thing that's keeping me away from the K right now is that I have too many spare B-series parts to even give up on the Bseries lineup.  Everyone thinks that the K20 swaps are expensive because they're thinking of the JDM type R transplants.  You can find the k20a2 type S transplants locally for around the same price as the current b18c1 right now.  YOu don't get the little bit of bump in compression and more aggresive cams, but that can all come later.  With 200hp stock on the k20a2 it's not bad.  I'm guessing that'll be around 170 something that actually goes to the ground.  In the 170 range, you're gonna be pretty quick in the 1320, probably the same as a hatch with an h22, but with more potential<br />
im sure with normal e/h/i you could put down less than 13 no problem.</p>
]]></description><link>https://fargostreet.com/post/30354</link><guid isPermaLink="true">https://fargostreet.com/post/30354</guid><dc:creator><![CDATA[Joel]]></dc:creator><pubDate>Tue, 15 Feb 2005 17:55:24 GMT</pubDate></item><item><title><![CDATA[Reply to K20 swaps on Tue, 15 Feb 2005 17:28:15 GMT]]></title><description><![CDATA[<p dir="auto">If I had the money to do a K swap, I'd be all over it.  THe only thing that's keeping me away from the K right now is that I have too many spare B-series parts to even give up on the Bseries lineup.  Everyone thinks that the K20 swaps are expensive because they're thinking of the JDM type R transplants.  You can find the k20a2 type S transplants locally for around the same price as the current b18c1 right now.  YOu don't get the little bit of bump in compression and more aggresive cams, but that can all come later.  With 200hp stock on the k20a2 it's not bad.  I'm guessing that'll be around 170 something that actually goes to the ground.  In the 170 range, you're gonna be pretty quick in the 1320, probably the same as a hatch with an h22, but with more potential</p>
]]></description><link>https://fargostreet.com/post/30328</link><guid isPermaLink="true">https://fargostreet.com/post/30328</guid><dc:creator><![CDATA[[[global:guest]]]]></dc:creator><pubDate>Tue, 15 Feb 2005 17:28:15 GMT</pubDate></item><item><title><![CDATA[Reply to K20 swaps on Mon, 14 Feb 2005 00:22:07 GMT]]></title><description><![CDATA[<p dir="auto">The only thing for the K series that would make the overall cost worth it would be going with an all motor setup.  The cylinder heads are amazing on these motors.  Supposedly stock they flow almost as well as a heavily ported b series head.</p>
]]></description><link>https://fargostreet.com/post/29957</link><guid isPermaLink="true">https://fargostreet.com/post/29957</guid><dc:creator><![CDATA[integra_gsr98]]></dc:creator><pubDate>Mon, 14 Feb 2005 00:22:07 GMT</pubDate></item><item><title><![CDATA[Reply to K20 swaps on Mon, 14 Feb 2005 00:15:23 GMT]]></title><description><![CDATA[<p dir="auto">All it comes down to is bragging rates to say you have a K20 swap.  If it was all about power/performance you could easily build something to run faster and make more power for the $$.</p>
]]></description><link>https://fargostreet.com/post/29956</link><guid isPermaLink="true">https://fargostreet.com/post/29956</guid><dc:creator><![CDATA[PSI2HI]]></dc:creator><pubDate>Mon, 14 Feb 2005 00:15:23 GMT</pubDate></item><item><title><![CDATA[Reply to K20 swaps on Sun, 13 Feb 2005 23:42:53 GMT]]></title><description><![CDATA[<p dir="auto">If i remember correctly, don't hte K series motors use pretty high compression?</p>
<p dir="auto">Joel why are you even thinking about this, you've got youself in to the probe already, a dirt bike, the vigor, the last thing you need is another unfinished project!</p>
<p dir="auto">Get one of em done!</p>
<p dir="auto">The K Series motors as stated above are hella expensive, and not something that you can just drop in.  Also, the last thing you'd want is to throw a big shot of N2O on a high compression motor... honda motor or not, they are only so strong</p>
]]></description><link>https://fargostreet.com/post/29944</link><guid isPermaLink="true">https://fargostreet.com/post/29944</guid><dc:creator><![CDATA[Jim]]></dc:creator><pubDate>Sun, 13 Feb 2005 23:42:53 GMT</pubDate></item><item><title><![CDATA[Reply to K20 swaps on Sun, 13 Feb 2005 23:36:57 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">spoolude wrote:<br />
its also 10x more money then a rebuilt b16</p>
<p dir="auto">hardly, but just as Nick said they're new, and will continue to go down in price when they become more readily available.  Not many motors that you can make N/A figures like the k20/k24 can.</p>
]]></description><link>https://fargostreet.com/post/29939</link><guid isPermaLink="true">https://fargostreet.com/post/29939</guid><dc:creator><![CDATA[btleier]]></dc:creator><pubDate>Sun, 13 Feb 2005 23:36:57 GMT</pubDate></item><item><title><![CDATA[Reply to K20 swaps on Sun, 13 Feb 2005 23:34:07 GMT]]></title><description><![CDATA[<p dir="auto">It's also 10 years newer.  People need to realize that.<br />
Your run of the mill B16 was produced between 1990-2000.  That's 10 years worth of motors sitting out there.</p>
<p dir="auto">The K series motors have only been out for 2-3 years now which is why cost is high.  You don't just run into them at junk yards.</p>
]]></description><link>https://fargostreet.com/post/29938</link><guid isPermaLink="true">https://fargostreet.com/post/29938</guid><dc:creator><![CDATA[integra_gsr98]]></dc:creator><pubDate>Sun, 13 Feb 2005 23:34:07 GMT</pubDate></item><item><title><![CDATA[Reply to K20 swaps on Sun, 13 Feb 2005 22:03:59 GMT]]></title><description><![CDATA[<blockquote>
the k20/k24 is 10x the motor the b16 ever was.<br />
]]></description><link>https://fargostreet.com/post/29924</link><guid isPermaLink="true">https://fargostreet.com/post/29924</guid><dc:creator><![CDATA[[[global:guest]]]]></dc:creator><pubDate>Sun, 13 Feb 2005 22:03:59 GMT</pubDate></item><item><title><![CDATA[Reply to K20 swaps on Sun, 13 Feb 2005 21:55:11 GMT]]></title><description><![CDATA[<p dir="auto">the k20/k24 is 10x the motor the b16 ever was.</p>
]]></description><link>https://fargostreet.com/post/29921</link><guid isPermaLink="true">https://fargostreet.com/post/29921</guid><dc:creator><![CDATA[btleier]]></dc:creator><pubDate>Sun, 13 Feb 2005 21:55:11 GMT</pubDate></item><item><title><![CDATA[Reply to K20 swaps on Sun, 13 Feb 2005 18:53:12 GMT]]></title><description><![CDATA[<p dir="auto">Uhm.  K20 swap by the time it is all said and done would cost a TON.  Most people are paying between 4 and 5k for a swap @ a minimum.</p>
<p dir="auto">Remember for a k20 swap you need the following:</p>
<p dir="auto">K Series Motor<br />
K Series Trans<br />
RSX Shifter Assembly<br />
RSX Shifter Cables<br />
Mount Kit<br />
Custom Radiator<br />
Custom Fuel Rail<br />
Aftermarket FPR<br />
Custom Wiring Harness w/ Custom ECU (transponder key delete, etc)<br />
Custom Intake<br />
And usually a Custom Header, although I believe the TSX header fits in the EG engine bay.</p>
<p dir="auto">I would definately be more than willing to do the swap for someone.  Would definately be a fun new challenge.</p>
]]></description><link>https://fargostreet.com/post/29899</link><guid isPermaLink="true">https://fargostreet.com/post/29899</guid><dc:creator><![CDATA[integra_gsr98]]></dc:creator><pubDate>Sun, 13 Feb 2005 18:53:12 GMT</pubDate></item><item><title><![CDATA[Reply to K20 swaps on Sun, 13 Feb 2005 17:02:20 GMT]]></title><description><![CDATA[<p dir="auto">That is pretty damn cheap for a K series.  Those motors have way more potential.  I personally am looking to making my newly acquired Civic into some sort of junkyard turbo set-up off of my Talon.  Having two turbo cars is going to be shit.</p>
]]></description><link>https://fargostreet.com/post/29884</link><guid isPermaLink="true">https://fargostreet.com/post/29884</guid><dc:creator><![CDATA[[[global:guest]]]]></dc:creator><pubDate>Sun, 13 Feb 2005 17:02:20 GMT</pubDate></item><item><title><![CDATA[Reply to K20 swaps on Sun, 13 Feb 2005 16:19:55 GMT]]></title><description><![CDATA[<p dir="auto">i think it sounds like a good idea. you could maybe make k20 swaps the new in thing. go for it.</p>
]]></description><link>https://fargostreet.com/post/29879</link><guid isPermaLink="true">https://fargostreet.com/post/29879</guid><dc:creator><![CDATA[legacy-user-544]]></dc:creator><pubDate>Sun, 13 Feb 2005 16:19:55 GMT</pubDate></item></channel></rss>
