<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[For Sale - PROSPORT Electric Boost&#x2F;Vac Gauge]]></title><description><![CDATA[<p dir="auto">This gauge has never been installed and is new in the box. I powered it up to test and that is it. These are the really neat looking gauges that look black/blank when off, and then light up with an "opening ceremony" when the ignition is turned on.</p>
<p dir="auto">52mm Electrical Boost/Vacuum Gauge with Sensor<br />
Blue Back Lighting<br />
<img src="http://prosportgauges.com/images/products/display/SuperBlueBoostpic.1.jpg" alt="legacy image" class=" img-fluid img-markdown" /><br />
Sells new for $55 + shipping<br />
Asking $50 shipped</p>
<p dir="auto"><img src="http://prosportgauges.com/images/site/Categories/Blue%20Performance/install1.jpg" alt="legacy image" class=" img-fluid img-markdown" /></p>
<p dir="auto"><a href="WWW.PROSPORTGAUGES.COM">WWW.PROSPORTGAUGES.COM</a></p>
<p dir="auto">Watch this video:</p>
<p dir="auto">[ame]<a href="http://www.youtube.com/watch?v=Z0WVHJemtYQ%5B/ame%5D" rel="nofollow ugc">http://www.youtube.com/watch?v=Z0WVHJemtYQ[/ame]</a></p>
]]></description><link>https://fargostreet.com/topic/16752/for-sale-prosport-electric-boost-vac-gauge</link><generator>RSS for Node</generator><lastBuildDate>Wed, 27 May 2026 23:50:19 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/16752.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 06 Apr 2009 02:34:16 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to For Sale - PROSPORT Electric Boost&#x2F;Vac Gauge on Thu, 09 Apr 2009 14:37:46 GMT]]></title><description><![CDATA[<p dir="auto">sure<br />
PM sent</p>
]]></description><link>https://fargostreet.com/post/258581</link><guid isPermaLink="true">https://fargostreet.com/post/258581</guid><dc:creator><![CDATA[ChrisNelson]]></dc:creator><pubDate>Thu, 09 Apr 2009 14:37:46 GMT</pubDate></item><item><title><![CDATA[Reply to For Sale - PROSPORT Electric Boost&#x2F;Vac Gauge on Thu, 09 Apr 2009 06:02:30 GMT]]></title><description><![CDATA[<p dir="auto">so do you take paypal?</p>
]]></description><link>https://fargostreet.com/post/258563</link><guid isPermaLink="true">https://fargostreet.com/post/258563</guid><dc:creator><![CDATA[dodee929]]></dc:creator><pubDate>Thu, 09 Apr 2009 06:02:30 GMT</pubDate></item><item><title><![CDATA[Reply to For Sale - PROSPORT Electric Boost&#x2F;Vac Gauge on Thu, 09 Apr 2009 05:30:54 GMT]]></title><description><![CDATA[<p dir="auto">It is a sensor that sends a signal to the gauge. Uses the sender instead of a mechanical line.</p>
<p dir="auto">Makes it so you don't have to run a vacuum hose all the way into the engine compartment.</p>
]]></description><link>https://fargostreet.com/post/258561</link><guid isPermaLink="true">https://fargostreet.com/post/258561</guid><dc:creator><![CDATA[ChrisNelson]]></dc:creator><pubDate>Thu, 09 Apr 2009 05:30:54 GMT</pubDate></item><item><title><![CDATA[Reply to For Sale - PROSPORT Electric Boost&#x2F;Vac Gauge on Thu, 09 Apr 2009 04:56:59 GMT]]></title><description><![CDATA[<p dir="auto">what exactly is the sender for??</p>
]]></description><link>https://fargostreet.com/post/258553</link><guid isPermaLink="true">https://fargostreet.com/post/258553</guid><dc:creator><![CDATA[dodee929]]></dc:creator><pubDate>Thu, 09 Apr 2009 04:56:59 GMT</pubDate></item><item><title><![CDATA[Reply to For Sale - PROSPORT Electric Boost&#x2F;Vac Gauge on Thu, 09 Apr 2009 04:34:18 GMT]]></title><description><![CDATA[<p dir="auto">Here is a picture of a used one I found on the internet to give you an example of the sender and the gauge:</p>
<p dir="auto"><img src="http://i19.ebayimg.com/01/i/001/40/8c/30fe_1.JPG" alt="legacy image" class=" img-fluid img-markdown" /></p>
]]></description><link>https://fargostreet.com/post/258545</link><guid isPermaLink="true">https://fargostreet.com/post/258545</guid><dc:creator><![CDATA[ChrisNelson]]></dc:creator><pubDate>Thu, 09 Apr 2009 04:34:18 GMT</pubDate></item><item><title><![CDATA[Reply to For Sale - PROSPORT Electric Boost&#x2F;Vac Gauge on Thu, 09 Apr 2009 04:31:49 GMT]]></title><description><![CDATA[<p dir="auto">New In Box, Parts List:<br />
52mm Boost/Vac Gauge<br />
Gauge Wire Harness (Power, Ground, Illum., Sensor)<br />
Mounting Bracket &amp; Hardware<br />
Visor<br />
Vacuum Line "T"<br />
Vacuum Line Sender (Plug into any vac line)<br />
Extra Vacuum Line<br />
PROSPORT Stickers</p>
<p dir="auto">Basically you tap into any vacuum line with the supplied T and extra line then send 1 wire into the cab where your gauge is and hook it up to the gauge.</p>
<p dir="auto">The gauge has power and ground, and the sender has a power and ground. Hook all those wires up then connect the green wire from the sensor to the gauge and it's all done.</p>
<p dir="auto">probably the easiest style boost gauge ever invented. <img src="https://fargostreet.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f642.png?v=40430adaedb" class="not-responsive emoji emoji-android emoji--slightly_smiling_face" style="height:23px;width:auto;vertical-align:middle" title=":)" alt="🙂" /></p>
]]></description><link>https://fargostreet.com/post/258544</link><guid isPermaLink="true">https://fargostreet.com/post/258544</guid><dc:creator><![CDATA[ChrisNelson]]></dc:creator><pubDate>Thu, 09 Apr 2009 04:31:49 GMT</pubDate></item><item><title><![CDATA[Reply to For Sale - PROSPORT Electric Boost&#x2F;Vac Gauge on Thu, 09 Apr 2009 04:12:09 GMT]]></title><description><![CDATA[<p dir="auto">i was told that the boost level is all done by electronics and not by vacuum lines on this gauge or is it?? and does it come with the Tubing kit, T-Adaptor, Electric Sender, quick connect pigtail wiring, Visor, Decal and Instructions)</p>
]]></description><link>https://fargostreet.com/post/258540</link><guid isPermaLink="true">https://fargostreet.com/post/258540</guid><dc:creator><![CDATA[dodee929]]></dc:creator><pubDate>Thu, 09 Apr 2009 04:12:09 GMT</pubDate></item><item><title><![CDATA[Reply to For Sale - PROSPORT Electric Boost&#x2F;Vac Gauge on Thu, 09 Apr 2009 02:25:11 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">PSiedTSi;270087 wrote:<br />
I had a post typed out right after he posted that. I changed my mind to see if anyone else would call him out on that.</p>
<p dir="auto">Haha me too</p>
]]></description><link>https://fargostreet.com/post/258515</link><guid isPermaLink="true">https://fargostreet.com/post/258515</guid><dc:creator><![CDATA[Bp-08]]></dc:creator><pubDate>Thu, 09 Apr 2009 02:25:11 GMT</pubDate></item><item><title><![CDATA[Reply to For Sale - PROSPORT Electric Boost&#x2F;Vac Gauge on Thu, 09 Apr 2009 02:07:50 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">SPANISH-RICE;270049 wrote:<br />
what do you mean? all you need is 12v</p>
<p dir="auto">I had a post typed out right after he posted that. I changed my mind to see if anyone else would call him out on that.</p>
]]></description><link>https://fargostreet.com/post/258508</link><guid isPermaLink="true">https://fargostreet.com/post/258508</guid><dc:creator><![CDATA[PSiedTSi]]></dc:creator><pubDate>Thu, 09 Apr 2009 02:07:50 GMT</pubDate></item><item><title><![CDATA[Reply to For Sale - PROSPORT Electric Boost&#x2F;Vac Gauge on Thu, 09 Apr 2009 01:23:54 GMT]]></title><description><![CDATA[<p dir="auto">haha, yea, that's what I was thinkin...</p>
]]></description><link>https://fargostreet.com/post/258493</link><guid isPermaLink="true">https://fargostreet.com/post/258493</guid><dc:creator><![CDATA[ChrisNelson]]></dc:creator><pubDate>Thu, 09 Apr 2009 01:23:54 GMT</pubDate></item><item><title><![CDATA[Reply to For Sale - PROSPORT Electric Boost&#x2F;Vac Gauge on Wed, 08 Apr 2009 22:09:07 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">dodee929;269898 wrote:<br />
i found out that this will not work in my car due to that it's an 88 so the electronics aren't equipped well enough sorry</p>
<p dir="auto">what do you mean? all you need is 12v</p>
]]></description><link>https://fargostreet.com/post/258470</link><guid isPermaLink="true">https://fargostreet.com/post/258470</guid><dc:creator><![CDATA[SPANISH-RICE]]></dc:creator><pubDate>Wed, 08 Apr 2009 22:09:07 GMT</pubDate></item><item><title><![CDATA[Reply to For Sale - PROSPORT Electric Boost&#x2F;Vac Gauge on Wed, 08 Apr 2009 21:34:20 GMT]]></title><description><![CDATA[<p dir="auto">I am pretty sure that it is the standard blue series, not blue/white.</p>
<p dir="auto">I looked at the receipt and it said "Super Blue".</p>
]]></description><link>https://fargostreet.com/post/258463</link><guid isPermaLink="true">https://fargostreet.com/post/258463</guid><dc:creator><![CDATA[ChrisNelson]]></dc:creator><pubDate>Wed, 08 Apr 2009 21:34:20 GMT</pubDate></item><item><title><![CDATA[Reply to For Sale - PROSPORT Electric Boost&#x2F;Vac Gauge on Wed, 08 Apr 2009 19:28:18 GMT]]></title><description><![CDATA[<p dir="auto">Is this the blue performance series or the blue/white performance series?</p>
]]></description><link>https://fargostreet.com/post/258434</link><guid isPermaLink="true">https://fargostreet.com/post/258434</guid><dc:creator><![CDATA[925JL925]]></dc:creator><pubDate>Wed, 08 Apr 2009 19:28:18 GMT</pubDate></item><item><title><![CDATA[Reply to For Sale - PROSPORT Electric Boost&#x2F;Vac Gauge on Wed, 08 Apr 2009 04:53:26 GMT]]></title><description><![CDATA[<p dir="auto">i found out that this will not work in my car due to that it's an 88 so the electronics aren't equipped well enough sorry</p>
]]></description><link>https://fargostreet.com/post/258320</link><guid isPermaLink="true">https://fargostreet.com/post/258320</guid><dc:creator><![CDATA[dodee929]]></dc:creator><pubDate>Wed, 08 Apr 2009 04:53:26 GMT</pubDate></item><item><title><![CDATA[Reply to For Sale - PROSPORT Electric Boost&#x2F;Vac Gauge on Tue, 07 Apr 2009 06:29:13 GMT]]></title><description><![CDATA[<p dir="auto">if you still have it on friday i want this for i will have money to buy it.. do you take paypal???</p>
]]></description><link>https://fargostreet.com/post/258182</link><guid isPermaLink="true">https://fargostreet.com/post/258182</guid><dc:creator><![CDATA[dodee929]]></dc:creator><pubDate>Tue, 07 Apr 2009 06:29:13 GMT</pubDate></item><item><title><![CDATA[Reply to For Sale - PROSPORT Electric Boost&#x2F;Vac Gauge on Mon, 06 Apr 2009 20:03:21 GMT]]></title><description><![CDATA[<p dir="auto">great gauges i love mine.</p>
]]></description><link>https://fargostreet.com/post/258127</link><guid isPermaLink="true">https://fargostreet.com/post/258127</guid><dc:creator><![CDATA[SPANISH-RICE]]></dc:creator><pubDate>Mon, 06 Apr 2009 20:03:21 GMT</pubDate></item></channel></rss>
