<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[FS: Supercharger, Direct Port Nitrous, Gauges, etc!]]></title><description><![CDATA[<p dir="auto">The Maxima has been sold.  Now it is time to sell the mods as well.</p>
<p dir="auto">I have A LOT of mods for this car.  I also have a lot of mods that are not car-specific.</p>
<p dir="auto">I also have a lot of stock parts too.</p>
<p dir="auto">The original list can be seen here:<a href="http://forums.maxima.org/4th-generation-classifieds-1995-1999/589048-fs-want-mods-s-c-nos-much-more.html" rel="nofollow ugc">http://forums.maxima.org/4th-generation-classifieds-1995-1999/589048-fs-want-mods-s-c-nos-much-more.html</a><br />
Some parts are also listed on Fargo/Moorhead Craigslist.</p>
<p dir="auto">V2 Stillen SC kit (Compressor with 10psi (3.1”) pulley, Mounting plate, Blitz BOV, charge plumbing, Oil return adapter, oil supply Tee and supply line, aux fuel pump, Vortech FMU, K/N Pancake filter, many bolts and other adapters/plates) I am the 2nd owner. 1st owner used for approx 5K miles. I used for another approx 5K miles. It has the original idler pulley that neither myself or the previous owner had any issues with. Never melted a pulley or threw a belt. Blower is in like new condition in terms of sound and performance. The main charge pipe was cut up by the previous owner to incorporate an intercooler. I had the charge pipe TIG'd back together so it is basically in its original configuration. Sadly, this kit has been sitting dormant for most of its life. I will include the Stillen manual and the old “Maxima V2 SC install for dummies” printout. ($2200)</p>
<p dir="auto">3.6” SC pulley, original pulley shipped with SC kit. ($25)</p>
<p dir="auto">Complete custom-built direct-port NOS fogger system. Jetted for approx 80-100 hp. Comes with 10# NOS bottle w/ high flow adapter, fuel and nitrous solenoids, High flow SS braided nitrous line. The 6 stainless NOS fogger nozzles, distribution blocks, solenoids and SS lines are already plumbed and mounted on the 4th gen intake manifold that I will be including in the sale. You won’t have to bend a single hard line, weld/drill/tap the manifold or build brackets for the solenoids – just swap your manifold out with this one. It all fit under my stock hood without rubbing the insulation. I will include my relay and switches. Can also include my wireless steering wheel button setup if you want. ($650)</p>
<p dir="auto">Snow Performance Stage II Boost Cooler Water/Methanol injection system. Includes jug, plumbing with quick connects, nozzle, high pressure pump and adjustable rising rate manifold pressure switch. Used it for maybe about 4 jugs worth of spraying. Never ran pump dry. Worked perfect every time. Pulled it out of the car once I found an unleaded race-gas wholesale supplier. ($150)</p>
<p dir="auto">DMH Performance E-cutout (2.5" diameter) remote control exhaust bypass with 2-way rocker switch (only had it installed for a couple months) ($75)</p>
<p dir="auto">5.5 Gen dual tip, variable flow muffler ($35)</p>
<p dir="auto">Innovate LM-1 Wideband O2 Controller/gauge with sensor ($100)</p>
<p dir="auto">Black powdercoated Aluminum bezel for SAFCII and 3 gauges ($15)</p>
<p dir="auto">Mechanical Nitrous pressure gauge ($20)</p>
<p dir="auto">Defi Mechanical Illuminated Boost gauge ($40)</p>
<p dir="auto">Defi Electronic Illuminated Fuel Pressure gauge ($50) <strong>SOLD</strong></p>
<p dir="auto">Autometer LED narrow band O2 Gauge ($40)</p>
<p dir="auto">4 - 17” X 7” Eagle Alloy 6 spoke rims (114.5X5 lug pattern, 40mm offset) with tires<br />
<a href="http://forums.maxima.org/wheels-tires/589042-fs-mint-17x7-rims-225-45-17-tires.html" rel="nofollow ugc">http://forums.maxima.org/wheels-tires/589042-fs-mint-17x7-rims-225-45-17-tires.html</a></p>
<p dir="auto">Used VQ30DE motor that was never installed in my car. Was purchased from a distributor that also provided me with leak-down test pass paperwork from that motor. I still have the PDF so I can send it if you are interested. I purchased it to replace the broken down motor but never got that far. (I paid $780, asking $400 - shoot an offer)</p>
<p dir="auto">A32 MAF ($45)</p>
<p dir="auto">6-red top injectors (use for about 30K miles) ($60)</p>
<p dir="auto">6 purple top injectors (purchased them used and they worked perfectly. Idled dead smooth) ($120)</p>
<p dir="auto">6 coil packs that all worked 100% ($120)</p>
<p dir="auto">Clutch Net 6-puck sprung hub clutch with pressure plate. (4k miles) ($120)</p>
<p dir="auto">Genuine Nissan Starter that I purchased from the stealership, great condition, 20K miles on it at most ($40)</p>
]]></description><link>https://fargostreet.com/topic/16990/fs-supercharger-direct-port-nitrous-gauges-etc</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 07:32:09 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/16990.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 04 May 2009 13:59:00 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to FS: Supercharger, Direct Port Nitrous, Gauges, etc! on Mon, 04 May 2009 21:32:58 GMT]]></title><description><![CDATA[<p dir="auto">Defi FP Gauge has been sold.</p>
]]></description><link>https://fargostreet.com/post/261692</link><guid isPermaLink="true">https://fargostreet.com/post/261692</guid><dc:creator><![CDATA[sleepermaxima]]></dc:creator><pubDate>Mon, 04 May 2009 21:32:58 GMT</pubDate></item><item><title><![CDATA[Reply to FS: Supercharger, Direct Port Nitrous, Gauges, etc! on Mon, 04 May 2009 15:36:22 GMT]]></title><description><![CDATA[<p dir="auto">By request: pics of the LM-1 that I took yesterday - sensor still works</p>
<p dir="auto"><img src="/assets/uploads/legacy/attachments/5597/WBO2-1.JPG" alt="WBO2-1.JPG" class=" img-fluid img-markdown" /><br />
<img src="/assets/uploads/legacy/attachments/5598/WBO2-2.JPG" alt="WBO2-2.JPG" class=" img-fluid img-markdown" /></p>
]]></description><link>https://fargostreet.com/post/261659</link><guid isPermaLink="true">https://fargostreet.com/post/261659</guid><dc:creator><![CDATA[sleepermaxima]]></dc:creator><pubDate>Mon, 04 May 2009 15:36:22 GMT</pubDate></item><item><title><![CDATA[Reply to FS: Supercharger, Direct Port Nitrous, Gauges, etc! on Mon, 04 May 2009 14:37:37 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">SPANISH-RICE;273233 wrote:<br />
pics of the defi guages?</p>
<p dir="auto">All I have is a pic of the FP gauge at the moment.  The Boost looks just like it and is in perfect condition.  I can get a pic of it this evening if you want. Just let me know.</p>
<p dir="auto"><img src="/assets/uploads/legacy/attachments/5596/DefiFP.JPG" alt="DefiFP.JPG" class=" img-fluid img-markdown" /></p>
]]></description><link>https://fargostreet.com/post/261655</link><guid isPermaLink="true">https://fargostreet.com/post/261655</guid><dc:creator><![CDATA[sleepermaxima]]></dc:creator><pubDate>Mon, 04 May 2009 14:37:37 GMT</pubDate></item><item><title><![CDATA[Reply to FS: Supercharger, Direct Port Nitrous, Gauges, etc! on Mon, 04 May 2009 14:32:24 GMT]]></title><description><![CDATA[<p dir="auto">pics of the defi guages?</p>
]]></description><link>https://fargostreet.com/post/261653</link><guid isPermaLink="true">https://fargostreet.com/post/261653</guid><dc:creator><![CDATA[SPANISH-RICE]]></dc:creator><pubDate>Mon, 04 May 2009 14:32:24 GMT</pubDate></item></channel></rss>
