<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Is there anyone who can align a truck with custom wheels?]]></title><description><![CDATA[<p dir="auto">Got a 2000 F150, just did a whole bunch of suspension work to it, and needs to be aligned. already took it to tires plus and they couldn't because of the wheels. I do not have the stock wheels, and the wheels and tires on it now make so there is no lip on the outside of the rim to clamp a normal alignment tool. Anyone who has a machine that will work with them, or do i need to find a set of factory wheels to do it?</p>
]]></description><link>https://fargostreet.com/topic/17197/is-there-anyone-who-can-align-a-truck-with-custom-wheels</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 04:49:01 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/17197.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 27 May 2009 21:54:13 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Is there anyone who can align a truck with custom wheels? on Fri, 29 May 2009 22:15:42 GMT]]></title><description><![CDATA[<p dir="auto">I thought you were done with Fargostreet?</p>
]]></description><link>https://fargostreet.com/post/265173</link><guid isPermaLink="true">https://fargostreet.com/post/265173</guid><dc:creator><![CDATA[DelSlow]]></dc:creator><pubDate>Fri, 29 May 2009 22:15:42 GMT</pubDate></item><item><title><![CDATA[Reply to Is there anyone who can align a truck with custom wheels? on Fri, 29 May 2009 07:38:57 GMT]]></title><description><![CDATA[<p dir="auto">we had a truck like that when i worked at a dodge dealer. we just took a truck off the lot and took the wheels off of it to do the alignment. you could try the ford dealership. if they are in a good mood they might be able to pull some strings and less work for you. i think we charged the guy a rotate plus the alignment. just an idea</p>
]]></description><link>https://fargostreet.com/post/265132</link><guid isPermaLink="true">https://fargostreet.com/post/265132</guid><dc:creator><![CDATA[black2g]]></dc:creator><pubDate>Fri, 29 May 2009 07:38:57 GMT</pubDate></item><item><title><![CDATA[Reply to Is there anyone who can align a truck with custom wheels? on Thu, 28 May 2009 02:09:44 GMT]]></title><description><![CDATA[<p dir="auto">I work over at the United Auto Tech Center on 32nd. We should be able to do that. We have the adapters to grab the lip or the outside of the rim.</p>
]]></description><link>https://fargostreet.com/post/264888</link><guid isPermaLink="true">https://fargostreet.com/post/264888</guid><dc:creator><![CDATA[ruthless351]]></dc:creator><pubDate>Thu, 28 May 2009 02:09:44 GMT</pubDate></item><item><title><![CDATA[Reply to Is there anyone who can align a truck with custom wheels? on Thu, 28 May 2009 01:58:22 GMT]]></title><description><![CDATA[<p dir="auto">United Auto Tech Center off 13th ave in WF.</p>
]]></description><link>https://fargostreet.com/post/264884</link><guid isPermaLink="true">https://fargostreet.com/post/264884</guid><dc:creator><![CDATA[PSI2HI]]></dc:creator><pubDate>Thu, 28 May 2009 01:58:22 GMT</pubDate></item><item><title><![CDATA[Reply to Is there anyone who can align a truck with custom wheels? on Wed, 27 May 2009 22:07:09 GMT]]></title><description><![CDATA[<p dir="auto">Try Advanced Alignment over by the old Wal-Mart.</p>
]]></description><link>https://fargostreet.com/post/264856</link><guid isPermaLink="true">https://fargostreet.com/post/264856</guid><dc:creator><![CDATA[fanaticrockford]]></dc:creator><pubDate>Wed, 27 May 2009 22:07:09 GMT</pubDate></item></channel></rss>
