<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Anybody knowledgable with painting a home wall with a roller?]]></title><description><![CDATA[<p dir="auto">I have applied 4 coats, and the last 2 coats were to try and get rid of the uneven look.  You can only see this unevenness from an angle with sunlight.  Looking at the wall straight on looks awesome and even.  It is NOT the sheetrock showing through.</p>
<p dir="auto">I was told to paint with a "W" technique, but it would appear I should have just gone straight up and down on the last coat?!?  I obviously need another coat, but I want it to be the last.</p>
<p dir="auto">I would appreciate advice from someone who knows about painting.</p>
<p dir="auto">Details:</p>
<p dir="auto">Used a nice quality roller<br />
Used high end paint from Peterson Paint<br />
Was well shaken and stirred</p>
<p dir="auto">Help <img src="https://fargostreet.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f61e.png?v=40430adaedb" class="not-responsive emoji emoji-android emoji--disappointed" style="height:23px;width:auto;vertical-align:middle" title=":(" alt="😞" /></p>
<p dir="auto"><img src="http://i27.photobucket.com/albums/c163/dc5k20/IMG_0099Large.jpg" alt="legacy image" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="http://i27.photobucket.com/albums/c163/dc5k20/IMG_0100Large.jpg" alt="legacy image" class=" img-fluid img-markdown" /></p>
<ul>
<li>Jason</li>
</ul>
]]></description><link>https://fargostreet.com/topic/17275/anybody-knowledgable-with-painting-a-home-wall-with-a-roller</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 01:16:56 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/17275.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 05 Jun 2009 02:18:41 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Anybody knowledgable with painting a home wall with a roller? on Sat, 06 Jun 2009 03:12:52 GMT]]></title><description><![CDATA[<p dir="auto">Looks like a nice house Jason!  I don't have anything to add to this, other than I have hated the few painting projects that I have done.  Good luck!</p>
]]></description><link>https://fargostreet.com/post/266309</link><guid isPermaLink="true">https://fargostreet.com/post/266309</guid><dc:creator><![CDATA[91nbtsi]]></dc:creator><pubDate>Sat, 06 Jun 2009 03:12:52 GMT</pubDate></item><item><title><![CDATA[Reply to Anybody knowledgable with painting a home wall with a roller? on Fri, 05 Jun 2009 23:38:01 GMT]]></title><description><![CDATA[<p dir="auto">Instead of using a tray it is much easier to use a 5 gallon bucket and a paitners grate that hangs from the bucket.  Pour around a 1/2 to 3/4 of a gallon into the bucket and then just spin the roller into the paint to dip it, you can put more if your need too but a 1/4 gallon is about the minimum needed.  Then use the grate to roll off some of the excess, the grate also helps to evenly spread the paint on the roller surface.  Like most of the other advise that has been given earleir keep the roller pretty wet and don't try to use every bit of paint on the roller.   What I like to do is get the roller plenty wet to the point of almost dripping and roll out a little square with it pretty thick to get the excess of then just use the paint on that thick square to "roll out" some more of the wall until the roller starts to dry a little then dip again.  It takes some getting used to but once you get the hang of it things go by pretty quickly and you tend to get some pretty good results.  You can also just use a straght up and down technique which for someone just starting out works probably best.  When you are done with one coat you should dip the crap out of the roller and hang it from the grate, then wrap the bucket in a garbage bag and tie it of.  With it in the bag like that you can let it sit overnight or longer if needed.  Take my advise as you will, but I painted at UND for 2 summers and can't begin to tell you how many rooms I rolled out.  I'm no expert by any means as there are many guys that will run circles around me.  Hope this helps.</p>
]]></description><link>https://fargostreet.com/post/266300</link><guid isPermaLink="true">https://fargostreet.com/post/266300</guid><dc:creator><![CDATA[awd95mn]]></dc:creator><pubDate>Fri, 05 Jun 2009 23:38:01 GMT</pubDate></item><item><title><![CDATA[Reply to Anybody knowledgable with painting a home wall with a roller? on Fri, 05 Jun 2009 22:56:11 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">Raider;277849 wrote:<br />
from all the painting I have done in my houses I always keep the roller wet and only go up and down....the "W" never worked for me...and never go over a area again after you have already painted it unless u need to remove a line and if so use very little pressure on the roller</p>
<p dir="auto">if you are cutting in the corners or another wall you want to cut with a heavy enough coat and then roll into the cut while still wet...its hard to do if only one person is painting</p>
<p dir="auto">I would have done the up and down method from the get go, but I was told NOT too....Then I ask around from here to Peterson Paint, and the info I got, was bad.  W didn't work for me either (obviously).  Thanks for your help.  I did figure out how to remove the brush strokes with the roller on my own (WOOT).  Thanks for the time and help!</p>
<p dir="auto">RE-Enema;277855 wrote:<br />
Some of the painters will throw their roller cover in the bucket of paint to let it soak.  When they are done painting they will put the cover back into the paint and leave it in there until they need it again.  Usually they are using 5gallon buckets.  It might be hard to do with a 1gallon bucket.</p>
<p dir="auto">So they obviously get it soaked to the core with paint.  I will try this method in the tray (let it sit for a few minutes one way, then rotate, then apply).  Thanks as well!</p>
]]></description><link>https://fargostreet.com/post/266292</link><guid isPermaLink="true">https://fargostreet.com/post/266292</guid><dc:creator><![CDATA[FG2]]></dc:creator><pubDate>Fri, 05 Jun 2009 22:56:11 GMT</pubDate></item><item><title><![CDATA[Reply to Anybody knowledgable with painting a home wall with a roller? on Fri, 05 Jun 2009 22:13:42 GMT]]></title><description><![CDATA[<p dir="auto"><strong>Waiting for 'Orange Box' Guru</strong></p>
]]></description><link>https://fargostreet.com/post/266289</link><guid isPermaLink="true">https://fargostreet.com/post/266289</guid><dc:creator><![CDATA[DelSlow]]></dc:creator><pubDate>Fri, 05 Jun 2009 22:13:42 GMT</pubDate></item><item><title><![CDATA[Reply to Anybody knowledgable with painting a home wall with a roller? on Fri, 05 Jun 2009 18:52:29 GMT]]></title><description><![CDATA[<p dir="auto">Some of the painters will throw their roller cover in the bucket of paint to let it soak.  When they are done painting they will put the cover back into the paint and leave it in there until they need it again.  Usually they are using 5gallon buckets.  It might be hard to do with a 1gallon bucket.</p>
]]></description><link>https://fargostreet.com/post/266271</link><guid isPermaLink="true">https://fargostreet.com/post/266271</guid><dc:creator><![CDATA[RE-Enema]]></dc:creator><pubDate>Fri, 05 Jun 2009 18:52:29 GMT</pubDate></item><item><title><![CDATA[Reply to Anybody knowledgable with painting a home wall with a roller? on Fri, 05 Jun 2009 18:09:40 GMT]]></title><description><![CDATA[<p dir="auto">from all the painting I have done in my houses I always keep the roller wet and only go up and down....the "W" never worked for me...and never go over a area again after you have already painted it unless u need to remove a line and if so use very little pressure on the roller</p>
]]></description><link>https://fargostreet.com/post/266265</link><guid isPermaLink="true">https://fargostreet.com/post/266265</guid><dc:creator><![CDATA[Raider]]></dc:creator><pubDate>Fri, 05 Jun 2009 18:09:40 GMT</pubDate></item><item><title><![CDATA[Reply to Anybody knowledgable with painting a home wall with a roller? on Fri, 05 Jun 2009 17:19:44 GMT]]></title><description><![CDATA[<p dir="auto">Thanks for the help guys.  I just called Peterson Paint as well, and they said the same thing.  Just do vertical swipes of WET roller (avoiding any lines), then rewet roller and move over a bit (overlap 2-3") and do it again.  He also said don't 'go back over the wall'.  I will apply a liberal coat and see where it leads me, and if I still struggle, I will bite the bullet and hire someone.</p>
<p dir="auto">Thanks to all for the helpful information.  I think this is the first thread for help I have seen that didn't turn into a 5 page disaster <img src="https://fargostreet.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f642.png?v=40430adaedb" class="not-responsive emoji emoji-android emoji--slightly_smiling_face" style="height:23px;width:auto;vertical-align:middle" title=":)" alt="🙂" /></p>
<p dir="auto">Take Care!</p>
<p dir="auto">Jason</p>
]]></description><link>https://fargostreet.com/post/266261</link><guid isPermaLink="true">https://fargostreet.com/post/266261</guid><dc:creator><![CDATA[FG2]]></dc:creator><pubDate>Fri, 05 Jun 2009 17:19:44 GMT</pubDate></item><item><title><![CDATA[Reply to Anybody knowledgable with painting a home wall with a roller? on Fri, 05 Jun 2009 17:07:06 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">FG2;277842 wrote:<br />
The home builder primes and paints the whole house one color, then they allow you to go in and paint walls accent colors/whatever before the flooring/trim/cabinets go in (which I did last weekend, and won't have access to it now until closing on June 19th). So I painted over their primer and 'standard' color, and all the other walls that I didn't paint over look great, so I'd assume it was primered, and correctly.</p>
<p dir="auto">I think my error is in the fact that when I used the roller, I would roll roll roll until the roller was left with zero paint. I would paint a ~4' x 4' area until the roller ran out, then go over everything after roller was dry to smooth it out...I am assuming that is wrong. I should go until the roller is starting to thin out, then apply more paint to the roller and keep doing that until I have the wall covered, then go over the whole wall to smooth out?</p>
<p dir="auto">Don't run the roller dry, keep it fairly wet all the time.  I've never gone over the whole wall afterward.</p>
]]></description><link>https://fargostreet.com/post/266260</link><guid isPermaLink="true">https://fargostreet.com/post/266260</guid><dc:creator><![CDATA[DaveH]]></dc:creator><pubDate>Fri, 05 Jun 2009 17:07:06 GMT</pubDate></item><item><title><![CDATA[Reply to Anybody knowledgable with painting a home wall with a roller? on Fri, 05 Jun 2009 16:52:38 GMT]]></title><description><![CDATA[<p dir="auto">The home builder primes and paints the whole house one color, then they allow you to go in and paint walls accent colors/whatever before the flooring/trim/cabinets go in (which I did last weekend, and won't have access to it now until closing on June 19th).  So I painted over their primer and 'standard' color, and all the other walls that I didn't paint over look great, so I'd assume it was primered, and correctly.</p>
]]></description><link>https://fargostreet.com/post/266258</link><guid isPermaLink="true">https://fargostreet.com/post/266258</guid><dc:creator><![CDATA[FG2]]></dc:creator><pubDate>Fri, 05 Jun 2009 16:52:38 GMT</pubDate></item><item><title><![CDATA[Reply to Anybody knowledgable with painting a home wall with a roller? on Fri, 05 Jun 2009 16:25:31 GMT]]></title><description><![CDATA[<p dir="auto">How many coats of primer did you use? Looks to me like the sheetrock just soaked up more paint in some spots than others..</p>
<p dir="auto">then again, it could be the way they put the texture on the wall..</p>
]]></description><link>https://fargostreet.com/post/266250</link><guid isPermaLink="true">https://fargostreet.com/post/266250</guid><dc:creator><![CDATA[RidinRails]]></dc:creator><pubDate>Fri, 05 Jun 2009 16:25:31 GMT</pubDate></item><item><title><![CDATA[Reply to Anybody knowledgable with painting a home wall with a roller? on Fri, 05 Jun 2009 15:40:53 GMT]]></title><description><![CDATA[<p dir="auto">I agree Jim, but there is some missing info to rule out other problems.  I am assuming that everthing prior to applying the paint was done correctly, but I still have to ask the question.  You would be amazed at the things I have seen "professionals" forget or not do.  I am not saying that he did this, but without all the information, I can only make a best guess.</p>
]]></description><link>https://fargostreet.com/post/266247</link><guid isPermaLink="true">https://fargostreet.com/post/266247</guid><dc:creator><![CDATA[RE-Enema]]></dc:creator><pubDate>Fri, 05 Jun 2009 15:40:53 GMT</pubDate></item><item><title><![CDATA[Reply to Anybody knowledgable with painting a home wall with a roller? on Fri, 05 Jun 2009 15:24:02 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">RE-Enema;277829 wrote:<br />
Did you use a primer?  Did you stir/shake the paint really well?  There is a lot of pigment in the dark colors and if it is not fully mixed it could be a problem.  If you did, it looks like the splotchy areas are where your roller ran dry.  Professional painters usually have their rollers soaked with paint like Colin said.  Rolling in a vertical W or V pattern up and down is the way the professionals do it.  Don't let the roller run dry.  Keep it saturated with paint.  I have seen some bad paint before, but that rarely happens.</p>
<p dir="auto">The other problem is the fact that there is natural light washing down the wall.  This is always a problem on projects and wall/drywall finishes.  It shows all mistakes and imperfections, compounded by a dark color.</p>
<p dir="auto">I do think that if you have done everything correctly (ie. primer, well mixed, right roller) that a heavy continuous coat should do the trick.  I am not a professional painter, but I have worked on many construction projects with professionals and had to deal with problems like yours.  My painting experience is more than 10 houses.  If you want to talk to a professional, I can give you some contacts.</p>
<p dir="auto">He's got some layers of paint down now though, I would think he would be able to as you said, apply a couple new coats of paint, making sure that the roller stays wet, and a small drying time.  I think the trick is to use more paint then you think you need on the brush / roller and the technique is to apply it to the point just before getting paint runs...</p>
]]></description><link>https://fargostreet.com/post/266246</link><guid isPermaLink="true">https://fargostreet.com/post/266246</guid><dc:creator><![CDATA[Jim]]></dc:creator><pubDate>Fri, 05 Jun 2009 15:24:02 GMT</pubDate></item><item><title><![CDATA[Reply to Anybody knowledgable with painting a home wall with a roller? on Fri, 05 Jun 2009 15:13:22 GMT]]></title><description><![CDATA[<p dir="auto">Did you use a primer?  Did you stir/shake the paint really well?  There is a lot of pigment in the dark colors and if it is not fully mixed it could be a problem.  If you did, it looks like the splotchy areas are where your roller ran dry.  Professional painters usually have their rollers soaked with paint like Colin said.  Rolling in a vertical W or V pattern up and down is the way the professionals do it.  Don't let the roller run dry.  Keep it saturated with paint.  I have seen some bad paint before, but that rarely happens.</p>
]]></description><link>https://fargostreet.com/post/266245</link><guid isPermaLink="true">https://fargostreet.com/post/266245</guid><dc:creator><![CDATA[RE-Enema]]></dc:creator><pubDate>Fri, 05 Jun 2009 15:13:22 GMT</pubDate></item><item><title><![CDATA[Reply to Anybody knowledgable with painting a home wall with a roller? on Fri, 05 Jun 2009 14:49:23 GMT]]></title><description><![CDATA[<p dir="auto">I've just painted a few times in my own house, so i'm no expert...  but what i've found is that if you are using a gloss or semi-gloss paint, you will need to keep more paint in the roller compared to using a flat paint. hard to tell from the pics, but the paint looks like a semi-gloss. try keeping the roller more saturated with paint and use less pressure. Your mileage may vary.</p>
<p dir="auto"><img src="https://fargostreet.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f61b.png?v=40430adaedb" class="not-responsive emoji emoji-android emoji--stuck_out_tongue" style="height:23px;width:auto;vertical-align:middle" title=":-p" alt="😛" /></p>
]]></description><link>https://fargostreet.com/post/266244</link><guid isPermaLink="true">https://fargostreet.com/post/266244</guid><dc:creator><![CDATA[DaveH]]></dc:creator><pubDate>Fri, 05 Jun 2009 14:49:23 GMT</pubDate></item><item><title><![CDATA[Reply to Anybody knowledgable with painting a home wall with a roller? on Fri, 05 Jun 2009 03:50:25 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">Jim;277737 wrote:<br />
You should try doing 2 coats, with like a 15-20 minute drying time inbetween instead of waiting the hour or two...</p>
<p dir="auto">Maybe somebody else can chime in...</p>
<p dir="auto">I tried this on the basement the day after fighting with the upstairs.  Similar result.</p>
<p dir="auto">Trafik Jamz;277740 wrote:<br />
I'd have to agree with Jim on this.  2 coats w/ a less dry time (and maybe try and not do the "W" pattern of the 2nd coat following the same line as the "W" of the 1st coat...hard to do, I know)</p>
<p dir="auto">Also, the paint <em>might</em> cure and get rid of the blotches over a few days...if you have time/patience you might just want to wait it out.</p>
<p dir="auto">I thought the same thing (as far as curing), but that was painted last weekend.  As for the "W", I did change area's for the "W" with different coats, but the last coat always showed up like in the picture.</p>
<p dir="auto">Colin;277741 wrote:<br />
i have painted many a wall, and I would say that your results look a lot like what happens when a glossy-er paint is applied over less glossy base with some uneven rolling.  If i were you, I would wait a day to see if it cures like chuck said, if not then go over the whole things in a V pattern with more paint than usual on your roller to apply a single "heavy" coat.  just under the "smearing" amount of paint.</p>
<p dir="auto">PS: sometimes its actually minor dips etc in your sheet rock that cause odd light reflections with semi-gloss paints. a flat paint might solve this.</p>
<p dir="auto">This paint is an eggshell, and is fairly flat...I have waited since last weekend hoping for a 'cure' and no help.  I may try the heavy 'V' pattern, but I first want to see if someone posts that is very experienced (ie - did/does it for a living), and can tell me for certain what I did wrong.</p>
<p dir="auto">Also, throughout the coats, the splotchy areas changed, eliminating the waves to a wall (Again, something I tried to tell myself was happening haha)</p>
<p dir="auto">Colin;277742 wrote:<br />
If you want help i'm around this weekend.</p>
<p dir="auto">Thank you very much for the information and offer to help.  The house won't be officially done being built until the 19th of June (closing day).  So it will be a few weeks yet before I can even get in there to fix it (They allow you to go in before the trim/cabinets/flooring is installed to do some accent painting....but only for one weekend...which was last weekend).  If I don't find someone that can tell me "Do this, and stop doing this, and that will fix your issue", I may just hire a painter.  I loath the look as of right now.....quick way to ruin a brand new home 'feel'.  <img src="https://fargostreet.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f61e.png?v=40430adaedb" class="not-responsive emoji emoji-android emoji--disappointed" style="height:23px;width:auto;vertical-align:middle" title=":(" alt="😞" /></p>
]]></description><link>https://fargostreet.com/post/266168</link><guid isPermaLink="true">https://fargostreet.com/post/266168</guid><dc:creator><![CDATA[FG2]]></dc:creator><pubDate>Fri, 05 Jun 2009 03:50:25 GMT</pubDate></item><item><title><![CDATA[Reply to Anybody knowledgable with painting a home wall with a roller? on Fri, 05 Jun 2009 03:16:29 GMT]]></title><description><![CDATA[<p dir="auto">If you want help i'm around this weekend.</p>
]]></description><link>https://fargostreet.com/post/266158</link><guid isPermaLink="true">https://fargostreet.com/post/266158</guid><dc:creator><![CDATA[Colin]]></dc:creator><pubDate>Fri, 05 Jun 2009 03:16:29 GMT</pubDate></item><item><title><![CDATA[Reply to Anybody knowledgable with painting a home wall with a roller? on Fri, 05 Jun 2009 03:15:53 GMT]]></title><description><![CDATA[<p dir="auto">i have painted many a wall, and I would say that your results look a lot like what happens when a glossy-er paint is applied over less glossy base with some uneven rolling.  If i were you, I would wait a day to see if it cures like chuck said, if not then go over the whole things in a V pattern with more paint than usual on your roller to apply a single "heavy" coat.  just under the "smearing" amount of paint.</p>
]]></description><link>https://fargostreet.com/post/266157</link><guid isPermaLink="true">https://fargostreet.com/post/266157</guid><dc:creator><![CDATA[Colin]]></dc:creator><pubDate>Fri, 05 Jun 2009 03:15:53 GMT</pubDate></item><item><title><![CDATA[Reply to Anybody knowledgable with painting a home wall with a roller? on Fri, 05 Jun 2009 03:05:00 GMT]]></title><description><![CDATA[<p dir="auto">I'd have to agree with Jim on this.  2 coats w/ a less dry time (and maybe try and not do the "W" pattern of the 2nd coat following the same line as the "W" of the 1st coat...hard to do, I know)</p>
]]></description><link>https://fargostreet.com/post/266156</link><guid isPermaLink="true">https://fargostreet.com/post/266156</guid><dc:creator><![CDATA[Trafik Jamz]]></dc:creator><pubDate>Fri, 05 Jun 2009 03:05:00 GMT</pubDate></item><item><title><![CDATA[Reply to Anybody knowledgable with painting a home wall with a roller? on Fri, 05 Jun 2009 02:50:27 GMT]]></title><description><![CDATA[<p dir="auto">You should try doing 2 coats, with like a 15-20 minute drying time inbetween instead of waiting the hour or two...</p>
]]></description><link>https://fargostreet.com/post/266153</link><guid isPermaLink="true">https://fargostreet.com/post/266153</guid><dc:creator><![CDATA[Jim]]></dc:creator><pubDate>Fri, 05 Jun 2009 02:50:27 GMT</pubDate></item><item><title><![CDATA[Reply to Anybody knowledgable with painting a home wall with a roller? on Fri, 05 Jun 2009 02:43:32 GMT]]></title><description><![CDATA[<p dir="auto">these are 'orange peel' textured walls, and I used a medium thick roller for 'semi smooth' walls.  Dry times were about....1 hour, maybe 2 max.</p>
<p dir="auto">Super frustrating</p>
]]></description><link>https://fargostreet.com/post/266150</link><guid isPermaLink="true">https://fargostreet.com/post/266150</guid><dc:creator><![CDATA[FG2]]></dc:creator><pubDate>Fri, 05 Jun 2009 02:43:32 GMT</pubDate></item><item><title><![CDATA[Reply to Anybody knowledgable with painting a home wall with a roller? on Fri, 05 Jun 2009 02:37:11 GMT]]></title><description><![CDATA[<p dir="auto">What were your drying times?  I had trouble with this when painting my store, but I switched paint and then quickly applied the two coats of paint with a short drying period in between and that fixed it... if you let it dry too long between coats it ends up looking funny at angles...</p>
<p dir="auto">I think the thickness of the rollers makes a difference too, depending on the texture on your walls... you want a smoother less fluffy one if theres no texture?</p>
<p dir="auto">I'm not a paint expert by any means though lol...</p>
]]></description><link>https://fargostreet.com/post/266149</link><guid isPermaLink="true">https://fargostreet.com/post/266149</guid><dc:creator><![CDATA[Jim]]></dc:creator><pubDate>Fri, 05 Jun 2009 02:37:11 GMT</pubDate></item></channel></rss>
