<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Twin scroll turbo on non-twin scroll manifold]]></title><description><![CDATA[<p dir="auto">Any pros or cons to running it this way? Its a fairly small turbo thats going to be on a stock dseries.</p>
]]></description><link>https://fargostreet.com/topic/17276/twin-scroll-turbo-on-non-twin-scroll-manifold</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 04:21:12 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/17276.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 05 Jun 2009 02:19:02 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Twin scroll turbo on non-twin scroll manifold on Sun, 07 Jun 2009 00:45:12 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">inspector01;277916 wrote:<br />
I don't think it really matters what you do with it, because if it is like any of your other projects, it will never actually get finished.......</p>
<p dir="auto">Oh zing it cuts so deep.</p>
]]></description><link>https://fargostreet.com/post/266375</link><guid isPermaLink="true">https://fargostreet.com/post/266375</guid><dc:creator><![CDATA[Bryce]]></dc:creator><pubDate>Sun, 07 Jun 2009 00:45:12 GMT</pubDate></item><item><title><![CDATA[Reply to Twin scroll turbo on non-twin scroll manifold on Sat, 06 Jun 2009 14:27:18 GMT]]></title><description><![CDATA[<p dir="auto">^^ oh snap</p>
]]></description><link>https://fargostreet.com/post/266336</link><guid isPermaLink="true">https://fargostreet.com/post/266336</guid><dc:creator><![CDATA[DrifterExtreme]]></dc:creator><pubDate>Sat, 06 Jun 2009 14:27:18 GMT</pubDate></item><item><title><![CDATA[Reply to Twin scroll turbo on non-twin scroll manifold on Sat, 06 Jun 2009 13:23:11 GMT]]></title><description><![CDATA[<p dir="auto">I don't think it really matters what you do with it, because if it is like any of your other projects, it will never actually get finished.......</p>
]]></description><link>https://fargostreet.com/post/266332</link><guid isPermaLink="true">https://fargostreet.com/post/266332</guid><dc:creator><![CDATA[inspector01]]></dc:creator><pubDate>Sat, 06 Jun 2009 13:23:11 GMT</pubDate></item><item><title><![CDATA[Reply to Twin scroll turbo on non-twin scroll manifold on Fri, 05 Jun 2009 23:36:21 GMT]]></title><description><![CDATA[<p dir="auto">yumm, sinktrap</p>
]]></description><link>https://fargostreet.com/post/266298</link><guid isPermaLink="true">https://fargostreet.com/post/266298</guid><dc:creator><![CDATA[SPANISH-RICE]]></dc:creator><pubDate>Fri, 05 Jun 2009 23:36:21 GMT</pubDate></item><item><title><![CDATA[Reply to Twin scroll turbo on non-twin scroll manifold on Fri, 05 Jun 2009 23:27:04 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">SPANISH-RICE;277853 wrote:<br />
wouldnt it technically spool up a little sooner being as the housing is technically smaller than a single scroll? just wouldnt flow as much?</p>
<p dir="auto">depends on the turbine housing, and the motor,manifold, dp, etc.</p>
<p dir="auto">but the divided turbo's can get away with running larger a/r turbine housings, sense the velocity is kept higher due to the divided manifold,and the split pulse helps spool alot.</p>
<p dir="auto">will putting a divided turbo on a non- divided work YES, should you do it. um no.</p>
<p dir="auto">want a cheap as shit divided manifold. do this.</p>
<p dir="auto">take a factory z6 header cut the flange off the bottom section and weld runners to a turbo flange up above the header. there you go a divided top mount for dirt cheap.</p>
]]></description><link>https://fargostreet.com/post/266296</link><guid isPermaLink="true">https://fargostreet.com/post/266296</guid><dc:creator><![CDATA[DrifterExtreme]]></dc:creator><pubDate>Fri, 05 Jun 2009 23:27:04 GMT</pubDate></item><item><title><![CDATA[Reply to Twin scroll turbo on non-twin scroll manifold on Fri, 05 Jun 2009 18:46:42 GMT]]></title><description><![CDATA[<p dir="auto">wouldnt it technically spool up a little sooner being as the housing is technically smaller than a single scroll? just wouldnt flow as much?</p>
]]></description><link>https://fargostreet.com/post/266269</link><guid isPermaLink="true">https://fargostreet.com/post/266269</guid><dc:creator><![CDATA[SPANISH-RICE]]></dc:creator><pubDate>Fri, 05 Jun 2009 18:46:42 GMT</pubDate></item><item><title><![CDATA[Reply to Twin scroll turbo on non-twin scroll manifold on Fri, 05 Jun 2009 08:08:50 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">KA-T_240;277743 wrote:<br />
Just do it.</p>
<p dir="auto">I am.</p>
<p dir="auto">aliengotpsi;277755 wrote:<br />
maybe port the turbo ?</p>
<p dir="auto">How well do cast turbine housing take to porting? I don't feel like ruining a perfectly good housing cause its divided.</p>
<p dir="auto">DelSlow;277770 wrote:<br />
Just do it, its only going to spool a littler later and not make as much power. As that 'bar' is in the way just acting as resistance.</p>
<p dir="auto">Thats what I was thinking but wouldn't the exhaust gases pretty much split evenly between the scrolls even tho the manifold isn't a twin scroll?</p>
<p dir="auto">zbrown;277780 wrote:<br />
i agree See my reply to aliengotpsi. lol</p>
]]></description><link>https://fargostreet.com/post/266230</link><guid isPermaLink="true">https://fargostreet.com/post/266230</guid><dc:creator><![CDATA[thurmanmerman]]></dc:creator><pubDate>Fri, 05 Jun 2009 08:08:50 GMT</pubDate></item><item><title><![CDATA[Reply to Twin scroll turbo on non-twin scroll manifold on Fri, 05 Jun 2009 04:53:17 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">i agree</p>
]]></description><link>https://fargostreet.com/post/266196</link><guid isPermaLink="true">https://fargostreet.com/post/266196</guid><dc:creator><![CDATA[zbrown]]></dc:creator><pubDate>Fri, 05 Jun 2009 04:53:17 GMT</pubDate></item><item><title><![CDATA[Reply to Twin scroll turbo on non-twin scroll manifold on Fri, 05 Jun 2009 04:37:23 GMT]]></title><description><![CDATA[<p dir="auto">Just do it, its only going to spool a littler later and not make as much power. As that 'bar' is in the way just acting as resistance.</p>
]]></description><link>https://fargostreet.com/post/266186</link><guid isPermaLink="true">https://fargostreet.com/post/266186</guid><dc:creator><![CDATA[DelSlow]]></dc:creator><pubDate>Fri, 05 Jun 2009 04:37:23 GMT</pubDate></item><item><title><![CDATA[Reply to Twin scroll turbo on non-twin scroll manifold on Fri, 05 Jun 2009 04:20:55 GMT]]></title><description><![CDATA[<p dir="auto">maybe port the turbo ?</p>
]]></description><link>https://fargostreet.com/post/266171</link><guid isPermaLink="true">https://fargostreet.com/post/266171</guid><dc:creator><![CDATA[aliengotpsi]]></dc:creator><pubDate>Fri, 05 Jun 2009 04:20:55 GMT</pubDate></item><item><title><![CDATA[Reply to Twin scroll turbo on non-twin scroll manifold on Fri, 05 Jun 2009 03:23:17 GMT]]></title><description><![CDATA[<p dir="auto">Just do it.</p>
]]></description><link>https://fargostreet.com/post/266159</link><guid isPermaLink="true">https://fargostreet.com/post/266159</guid><dc:creator><![CDATA[KA-T_240]]></dc:creator><pubDate>Fri, 05 Jun 2009 03:23:17 GMT</pubDate></item></channel></rss>
