<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Built in Fuzzbusters?]]></title><description><![CDATA[<p dir="auto">I am looking for a fuzz buster, that could be integrated into the dash. My wife's old Lexus had one and was a factory option, I liked the way it acted and was seamless.</p>
<p dir="auto">Any recommendations?</p>
]]></description><link>https://fargostreet.com/topic/17329/built-in-fuzzbusters</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 07:02:08 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/17329.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 11 Jun 2009 19:51:37 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Built in Fuzzbusters? on Sun, 14 Jun 2009 05:29:12 GMT]]></title><description><![CDATA[<p dir="auto">I can check and see if I can get V1's...I always forget about them</p>
]]></description><link>https://fargostreet.com/post/267449</link><guid isPermaLink="true">https://fargostreet.com/post/267449</guid><dc:creator><![CDATA[Trafik Jamz]]></dc:creator><pubDate>Sun, 14 Jun 2009 05:29:12 GMT</pubDate></item><item><title><![CDATA[Reply to Built in Fuzzbusters? on Fri, 12 Jun 2009 17:34:07 GMT]]></title><description><![CDATA[<p dir="auto">Thanks for your help thrash, Chuck has already assisted me and since he can do installation I will be going through him.</p>
]]></description><link>https://fargostreet.com/post/267290</link><guid isPermaLink="true">https://fargostreet.com/post/267290</guid><dc:creator><![CDATA[FloppedDaNuts]]></dc:creator><pubDate>Fri, 12 Jun 2009 17:34:07 GMT</pubDate></item><item><title><![CDATA[Reply to Built in Fuzzbusters? on Fri, 12 Jun 2009 17:24:37 GMT]]></title><description><![CDATA[<p dir="auto">If you're looking at something for a CAN-BUS VAG car (like the R8), you can even do one better with a Valentine1.</p>
<p dir="auto"><img src="http://techreactions.com/images/v1.bmp" alt="legacy image" class=" img-fluid img-markdown" /><br />
(from <a href="http://techreactions.com/default.aspx" rel="nofollow ugc">http://techreactions.com/default.aspx</a>, but i think i've seen a better/different one before)</p>
<p dir="auto">People have figured out how to build an adapter for the V1 remote display to the Audi FIS [the little LCD between your speedo and tacho].</p>
<p dir="auto">Viola -- factory radar detector <img src="https://fargostreet.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f642.png?v=40430adaedb" class="not-responsive emoji emoji-android emoji--slightly_smiling_face" style="height:23px;width:auto;vertical-align:middle" title=":)" alt="🙂" /></p>
<p dir="auto">the thing holding me back from a radar is to get the best actual protection, the answer is V1 hands down [plus a laser jammer, ala the Laser Park Pro].  But the V1 isn't a concealed / distributed system.  I don't want anything stuck to my windshield.  Passport SRX puts a network of sensors all over the car and has split the system into its constituent parts.  Much more "permanant" install.  But, the sensors should be as high as possible, ideally, and so the radar performance is somewhat compromised.</p>
<p dir="auto">If Mike Valentine would make a box that is as good as his current box, but it was cut up in the following way</p>
<ul>
<li>sensor mounted on back side of rear-view mirror for for-ward looking radar</li>
<li>sensor mounted on 3rd brake light for rear-looking radar</li>
<li>button/knob interface panel that can be mounted anywhere in the car</li>
<li>display panel that can be mounted anywhere in the car</li>
<li>laser sensors for front and rear licence plate areas</li>
<li>data output port for interfacing to external displays and sending laser warning signals [to interface with an LPP or other jamming device]</li>
</ul>
<p dir="auto">Then I'd probably buy one <img src="https://fargostreet.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f642.png?v=40430adaedb" class="not-responsive emoji emoji-android emoji--slightly_smiling_face" style="height:23px;width:auto;vertical-align:middle" title=":)" alt="🙂" /></p>
]]></description><link>https://fargostreet.com/post/267289</link><guid isPermaLink="true">https://fargostreet.com/post/267289</guid><dc:creator><![CDATA[thrash]]></dc:creator><pubDate>Fri, 12 Jun 2009 17:24:37 GMT</pubDate></item><item><title><![CDATA[Reply to Built in Fuzzbusters? on Fri, 12 Jun 2009 17:12:26 GMT]]></title><description><![CDATA[<p dir="auto">I bet your wishing you woulda had that fuzz buster now huh? Lol</p>
]]></description><link>https://fargostreet.com/post/267282</link><guid isPermaLink="true">https://fargostreet.com/post/267282</guid><dc:creator><![CDATA[SPANISH-RICE]]></dc:creator><pubDate>Fri, 12 Jun 2009 17:12:26 GMT</pubDate></item><item><title><![CDATA[Reply to Built in Fuzzbusters? on Fri, 12 Jun 2009 07:10:47 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">T ! N;278785 wrote:<br />
Check out the Valentine 1. It comes with a dash friendly display..</p>
<p dir="auto"><a href="http://www.valentine1.com/" rel="nofollow ugc">http://www.valentine1.com/</a></p>
<p dir="auto">so you can read english</p>
]]></description><link>https://fargostreet.com/post/267211</link><guid isPermaLink="true">https://fargostreet.com/post/267211</guid><dc:creator><![CDATA[Rexwagon]]></dc:creator><pubDate>Fri, 12 Jun 2009 07:10:47 GMT</pubDate></item><item><title><![CDATA[Reply to Built in Fuzzbusters? on Fri, 12 Jun 2009 06:52:40 GMT]]></title><description><![CDATA[<p dir="auto">^The "dash friendly" display is not included. Its like an extra $50</p>
]]></description><link>https://fargostreet.com/post/267208</link><guid isPermaLink="true">https://fargostreet.com/post/267208</guid><dc:creator><![CDATA[KA-T_240]]></dc:creator><pubDate>Fri, 12 Jun 2009 06:52:40 GMT</pubDate></item><item><title><![CDATA[Reply to Built in Fuzzbusters? on Fri, 12 Jun 2009 05:02:38 GMT]]></title><description><![CDATA[<p dir="auto">Check out the Valentine 1.  It comes with a dash friendly display..</p>
]]></description><link>https://fargostreet.com/post/267201</link><guid isPermaLink="true">https://fargostreet.com/post/267201</guid><dc:creator><![CDATA[legacy-user-33]]></dc:creator><pubDate>Fri, 12 Jun 2009 05:02:38 GMT</pubDate></item><item><title><![CDATA[Reply to Built in Fuzzbusters? on Thu, 11 Jun 2009 23:59:20 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">trafik jamz;278729 wrote:<br />
k-40 makes one of the best discreet mount radar detectors i've seen.  I can check my sources and see if i can get them for you if you like.</p>
<p dir="auto">k-40 ftw!</p>
]]></description><link>https://fargostreet.com/post/267162</link><guid isPermaLink="true">https://fargostreet.com/post/267162</guid><dc:creator><![CDATA[D S ohM]]></dc:creator><pubDate>Thu, 11 Jun 2009 23:59:20 GMT</pubDate></item><item><title><![CDATA[Reply to Built in Fuzzbusters? on Thu, 11 Jun 2009 23:19:29 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">Trafik Jamz;278729 wrote:<br />
K-40 makes one of the best discreet mount radar detectors I've seen.  I can check my sources and see if I can get them for you if you like.</p>
<p dir="auto">Chuck helped me out, and we had a good talk over the phone. Thanks again Chuck!</p>
]]></description><link>https://fargostreet.com/post/267159</link><guid isPermaLink="true">https://fargostreet.com/post/267159</guid><dc:creator><![CDATA[FloppedDaNuts]]></dc:creator><pubDate>Thu, 11 Jun 2009 23:19:29 GMT</pubDate></item><item><title><![CDATA[Reply to Built in Fuzzbusters? on Thu, 11 Jun 2009 22:57:40 GMT]]></title><description><![CDATA[<p dir="auto">Get a V1. Place at top of windshield, and hardwire it.</p>
]]></description><link>https://fargostreet.com/post/267156</link><guid isPermaLink="true">https://fargostreet.com/post/267156</guid><dc:creator><![CDATA[KA-T_240]]></dc:creator><pubDate>Thu, 11 Jun 2009 22:57:40 GMT</pubDate></item><item><title><![CDATA[Reply to Built in Fuzzbusters? on Thu, 11 Jun 2009 22:02:47 GMT]]></title><description><![CDATA[<p dir="auto">K-40 makes one of the best discreet mount radar detectors I've seen.  I can check my sources and see if I can get them for you if you like.</p>
]]></description><link>https://fargostreet.com/post/267145</link><guid isPermaLink="true">https://fargostreet.com/post/267145</guid><dc:creator><![CDATA[Trafik Jamz]]></dc:creator><pubDate>Thu, 11 Jun 2009 22:02:47 GMT</pubDate></item><item><title><![CDATA[Reply to Built in Fuzzbusters? on Thu, 11 Jun 2009 21:26:49 GMT]]></title><description><![CDATA[<p dir="auto">peanut butter is awesome.</p>
]]></description><link>https://fargostreet.com/post/267140</link><guid isPermaLink="true">https://fargostreet.com/post/267140</guid><dc:creator><![CDATA[Parker]]></dc:creator><pubDate>Thu, 11 Jun 2009 21:26:49 GMT</pubDate></item><item><title><![CDATA[Reply to Built in Fuzzbusters? on Thu, 11 Jun 2009 21:12:41 GMT]]></title><description><![CDATA[<p dir="auto">I like the factory ones. Their clean</p>
]]></description><link>https://fargostreet.com/post/267137</link><guid isPermaLink="true">https://fargostreet.com/post/267137</guid><dc:creator><![CDATA[SPANISH-RICE]]></dc:creator><pubDate>Thu, 11 Jun 2009 21:12:41 GMT</pubDate></item><item><title><![CDATA[Reply to Built in Fuzzbusters? on Thu, 11 Jun 2009 20:57:55 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">FloppedDaNuts;278702 wrote:<br />
I am looking for a fuzz buster, that could be integrated into the dash. My wife's old Lexus had one and was a factory option</p>
<p dir="auto">really?</p>
]]></description><link>https://fargostreet.com/post/267129</link><guid isPermaLink="true">https://fargostreet.com/post/267129</guid><dc:creator><![CDATA[24valvenotak]]></dc:creator><pubDate>Thu, 11 Jun 2009 20:57:55 GMT</pubDate></item></channel></rss>
