<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[aem ems]]></title><description><![CDATA[<p dir="auto">"bad ecu definition file" when trying to connect</p>
<p dir="auto">tried two different laptops, three different installs of pro, serial and usb ports...</p>
<p dir="auto">it will cycle through coms and recognize the ecu and version but fails to establish a connection</p>
<p dir="auto">someone make this go away</p>
]]></description><link>https://fargostreet.com/topic/17346/aem-ems</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 12:19:41 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/17346.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 14 Jun 2009 12:08:57 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to aem ems on Thu, 18 Jun 2009 04:29:01 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">24valvenotak;279653 wrote:<br />
yea i was swearing up and down i had to use an older version, turned out the latest one works.. but now im hearing that switching to the newer version screws with a few things...</p>
<p dir="auto">That's only happening when they update the firmware from 1.11 to 1.19. It's something in the cal conversion I think. Just don't update the firmware until you're on the dyno ready to tune?</p>
]]></description><link>https://fargostreet.com/post/268075</link><guid isPermaLink="true">https://fargostreet.com/post/268075</guid><dc:creator><![CDATA[PSiedTSi]]></dc:creator><pubDate>Thu, 18 Jun 2009 04:29:01 GMT</pubDate></item><item><title><![CDATA[Reply to aem ems on Thu, 18 Jun 2009 03:57:21 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">91nbtsi;279232 wrote:<br />
Ha.  Mitch, I thought you tried 3 different installs of AEMPro?  Glad you got it working!</p>
<p dir="auto">yea i was swearing up and down i had to use an older version, turned out the latest one works.. but now im hearing that switching to the newer version screws with a few things...</p>
]]></description><link>https://fargostreet.com/post/268065</link><guid isPermaLink="true">https://fargostreet.com/post/268065</guid><dc:creator><![CDATA[24valvenotak]]></dc:creator><pubDate>Thu, 18 Jun 2009 03:57:21 GMT</pubDate></item><item><title><![CDATA[Reply to aem ems on Tue, 16 Jun 2009 01:16:10 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">PSiedTSi;279229 wrote:<br />
Problem solved. Upgraded AEMPro and it worked on the first try.</p>
<p dir="auto">Ha.  Mitch, I thought you tried 3 different installs of AEMPro?  Glad you got it working!</p>
]]></description><link>https://fargostreet.com/post/267644</link><guid isPermaLink="true">https://fargostreet.com/post/267644</guid><dc:creator><![CDATA[91nbtsi]]></dc:creator><pubDate>Tue, 16 Jun 2009 01:16:10 GMT</pubDate></item><item><title><![CDATA[Reply to aem ems on Tue, 16 Jun 2009 00:32:47 GMT]]></title><description><![CDATA[<p dir="auto">Problem solved. Upgraded AEMPro and it worked on the first try.</p>
]]></description><link>https://fargostreet.com/post/267641</link><guid isPermaLink="true">https://fargostreet.com/post/267641</guid><dc:creator><![CDATA[PSiedTSi]]></dc:creator><pubDate>Tue, 16 Jun 2009 00:32:47 GMT</pubDate></item><item><title><![CDATA[Reply to aem ems on Mon, 15 Jun 2009 03:52:03 GMT]]></title><description><![CDATA[<p dir="auto">i would bet the last time i had it connected was two years minimum.  if that counts as out of the blue then yup ha.</p>
<p dir="auto">not only am i worried about having to buy another one but i dont have a backup cal.  yea.  weak.  means i cant even start it with a new one.</p>
<p dir="auto">edit/ you asshats wrote all that before i finished two sentences?</p>
]]></description><link>https://fargostreet.com/post/267534</link><guid isPermaLink="true">https://fargostreet.com/post/267534</guid><dc:creator><![CDATA[24valvenotak]]></dc:creator><pubDate>Mon, 15 Jun 2009 03:52:03 GMT</pubDate></item><item><title><![CDATA[Reply to aem ems on Mon, 15 Jun 2009 03:43:41 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">91nbtsi;279118 wrote:<br />
I am pretty sure if it is running at all, there is still a cal on it. Not sure on the connectivity issue. Good luck, Mitch.</p>
<p dir="auto">Right, but if we have to hardflash the chip without being able to connect, won't that delete the cal on the PROM?</p>
]]></description><link>https://fargostreet.com/post/267533</link><guid isPermaLink="true">https://fargostreet.com/post/267533</guid><dc:creator><![CDATA[PSiedTSi]]></dc:creator><pubDate>Mon, 15 Jun 2009 03:43:41 GMT</pubDate></item><item><title><![CDATA[Reply to aem ems on Mon, 15 Jun 2009 03:39:14 GMT]]></title><description><![CDATA[<p dir="auto">I am pretty sure if it is running at all, there is still a cal on it.  Not sure on the connectivity issue.  Good luck, Mitch.</p>
]]></description><link>https://fargostreet.com/post/267530</link><guid isPermaLink="true">https://fargostreet.com/post/267530</guid><dc:creator><![CDATA[91nbtsi]]></dc:creator><pubDate>Mon, 15 Jun 2009 03:39:14 GMT</pubDate></item><item><title><![CDATA[Reply to aem ems on Mon, 15 Jun 2009 02:48:21 GMT]]></title><description><![CDATA[<p dir="auto">Sucks,  what happened that started this?  You just connected and got the error out of the blue?  I was upgrading the firmware a few years ago with a USB adapter that went fubar and wasted the chip. AEM is good about sending out replacement chips quickly.</p>
]]></description><link>https://fargostreet.com/post/267514</link><guid isPermaLink="true">https://fargostreet.com/post/267514</guid><dc:creator><![CDATA[DaveH]]></dc:creator><pubDate>Mon, 15 Jun 2009 02:48:21 GMT</pubDate></item><item><title><![CDATA[Reply to aem ems on Sun, 14 Jun 2009 23:34:18 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">integra_gsr98;279085 wrote:<br />
How are you going to downgrade the firmware if you can't connect via serial? <img src="https://fargostreet.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f642.png?v=40430adaedb" class="not-responsive emoji emoji-android emoji--slightly_smiling_face" style="height:23px;width:auto;vertical-align:middle" title=":)" alt="🙂" /></p>
<p dir="auto">EPROM burner. Obviously thats last resort, after speaking with AEM. I don't think he even has a map saved anymore.</p>
]]></description><link>https://fargostreet.com/post/267498</link><guid isPermaLink="true">https://fargostreet.com/post/267498</guid><dc:creator><![CDATA[PSiedTSi]]></dc:creator><pubDate>Sun, 14 Jun 2009 23:34:18 GMT</pubDate></item><item><title><![CDATA[Reply to aem ems on Sun, 14 Jun 2009 23:26:48 GMT]]></title><description><![CDATA[<p dir="auto">How are you going to downgrade the firmware if you can't connect via serial? <img src="https://fargostreet.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f642.png?v=40430adaedb" class="not-responsive emoji emoji-android emoji--slightly_smiling_face" style="height:23px;width:auto;vertical-align:middle" title=":)" alt="🙂" /></p>
]]></description><link>https://fargostreet.com/post/267497</link><guid isPermaLink="true">https://fargostreet.com/post/267497</guid><dc:creator><![CDATA[integra_gsr98]]></dc:creator><pubDate>Sun, 14 Jun 2009 23:26:48 GMT</pubDate></item><item><title><![CDATA[Reply to aem ems on Sun, 14 Jun 2009 21:05:39 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">91nbtsi;279075 wrote:<br />
Just call AEM and see what they have to say. I have never had that error. Sounds like it might be a hardware issue.</p>
<p dir="auto">I found a bunch of instances of not being able to connect on the forums and most of them were solved with the EPROM chip not being seated well enough.</p>
<p dir="auto">Mitch said something about you having to downgrade the firmware to get it to work before? It is on old firmware v1.11, but came with v1.03. I downloaded the newest version of AEMPro, and will try to give that a shot today. Then see what AEM has to say.</p>
]]></description><link>https://fargostreet.com/post/267488</link><guid isPermaLink="true">https://fargostreet.com/post/267488</guid><dc:creator><![CDATA[PSiedTSi]]></dc:creator><pubDate>Sun, 14 Jun 2009 21:05:39 GMT</pubDate></item><item><title><![CDATA[Reply to aem ems on Sun, 14 Jun 2009 20:28:04 GMT]]></title><description><![CDATA[<p dir="auto">Just call AEM and see what they have to say.  I have never had that error.  Sounds like it might be a hardware issue.</p>
]]></description><link>https://fargostreet.com/post/267487</link><guid isPermaLink="true">https://fargostreet.com/post/267487</guid><dc:creator><![CDATA[91nbtsi]]></dc:creator><pubDate>Sun, 14 Jun 2009 20:28:04 GMT</pubDate></item><item><title><![CDATA[Reply to aem ems on Sun, 14 Jun 2009 18:10:25 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">funky_monkey58;279070 wrote:<br />
What are you using to connect? I have had good luck so far with my radioshack usb to serial adapter. But you have to make sure that you have serial selected as a connection port.</p>
<p dir="auto">Other wise make sure you have power and ground at the correct pins.</p>
<p dir="auto">Should clarify too that the car has had the AEM for 2-3 years, so he has connected to it before.</p>
<p dir="auto">As for what he's using to connect, look at the first post. "tried two different laptops, three different installs of pro, <strong>serial and usb ports</strong>..." aka he has a laptop with a serial port, as well as a usb to serial adaptor that has worked before.</p>
<p dir="auto">We checked the PROM chip as well, but it seemed snug still. If all else fails, I do have a burner to reburn the firmware, but then we are SOL with ZERO maps for the car.</p>
]]></description><link>https://fargostreet.com/post/267484</link><guid isPermaLink="true">https://fargostreet.com/post/267484</guid><dc:creator><![CDATA[PSiedTSi]]></dc:creator><pubDate>Sun, 14 Jun 2009 18:10:25 GMT</pubDate></item><item><title><![CDATA[Reply to aem ems on Sun, 14 Jun 2009 17:41:38 GMT]]></title><description><![CDATA[<p dir="auto">What are you using to connect? I have had good luck so far with my radioshack usb to serial adapter. But you have to make sure that you have serial selected as a connection port.</p>
]]></description><link>https://fargostreet.com/post/267482</link><guid isPermaLink="true">https://fargostreet.com/post/267482</guid><dc:creator><![CDATA[funky_monkey58]]></dc:creator><pubDate>Sun, 14 Jun 2009 17:41:38 GMT</pubDate></item><item><title><![CDATA[Reply to aem ems on Sun, 14 Jun 2009 14:30:04 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">weshole;279063 wrote:<br />
What's Nate have to say? Give him a holla.</p>
<p dir="auto">already been down that road</p>
]]></description><link>https://fargostreet.com/post/267477</link><guid isPermaLink="true">https://fargostreet.com/post/267477</guid><dc:creator><![CDATA[24valvenotak]]></dc:creator><pubDate>Sun, 14 Jun 2009 14:30:04 GMT</pubDate></item><item><title><![CDATA[Reply to aem ems on Sun, 14 Jun 2009 14:24:18 GMT]]></title><description><![CDATA[<p dir="auto">What's Nate have to say? Give him a holla.</p>
]]></description><link>https://fargostreet.com/post/267475</link><guid isPermaLink="true">https://fargostreet.com/post/267475</guid><dc:creator><![CDATA[weshole]]></dc:creator><pubDate>Sun, 14 Jun 2009 14:24:18 GMT</pubDate></item><item><title><![CDATA[Reply to aem ems on Sun, 14 Jun 2009 13:00:10 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">integra_gsr98;279057 wrote:<br />
Call AEM on Monday Mitch.</p>
<p dir="auto">booo</p>
]]></description><link>https://fargostreet.com/post/267471</link><guid isPermaLink="true">https://fargostreet.com/post/267471</guid><dc:creator><![CDATA[24valvenotak]]></dc:creator><pubDate>Sun, 14 Jun 2009 13:00:10 GMT</pubDate></item><item><title><![CDATA[Reply to aem ems on Sun, 14 Jun 2009 12:55:52 GMT]]></title><description><![CDATA[<p dir="auto">Call AEM on Monday Mitch.</p>
]]></description><link>https://fargostreet.com/post/267469</link><guid isPermaLink="true">https://fargostreet.com/post/267469</guid><dc:creator><![CDATA[integra_gsr98]]></dc:creator><pubDate>Sun, 14 Jun 2009 12:55:52 GMT</pubDate></item></channel></rss>
