<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Loose Distributor]]></title><description><![CDATA[<p dir="auto">So i set the timing to top dead center where it is supposed to be and i give it a little gas and when it goes back to idle the timing has changed and is now idling faster. If i tap the distributor it goes back to normal. There seems to be a loose fit where the distributor goes into the bottom plate or something... My neighbor says this plate is probably just worn out and needs to be replaced. Any ideas?</p>
]]></description><link>https://fargostreet.com/topic/17714/loose-distributor</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 01:14:19 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/17714.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 06 Aug 2009 17:35:20 GMT</pubDate><ttl>60</ttl></channel></rss>
