<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Cell Phone Problems]]></title><description><![CDATA[<p dir="auto">I just started at my new job at the wirelesscart in the mall. No one here knows how to changethe sanyo 8200 cell phone faceplates, even though we sell them. Does anyone know how to do this, or can someone look up ona different forum how to do it. I have searched for quite a while and found it unsuccessful.  ANy help would be greatly appreciated. We could get someone 5 dollars offa faceplate if you wanted. Jim, I know you can tackle this one.<br />
Thanks,<br />
Joel</p>
]]></description><link>https://fargostreet.com/topic/1792/cell-phone-problems</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 02:05:34 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/1792.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 27 Feb 2005 23:22:43 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Cell Phone Problems on Thu, 17 Mar 2005 23:52:49 GMT]]></title><description><![CDATA[<p dir="auto">Nice! Thanks!</p>
]]></description><link>https://fargostreet.com/post/35256</link><guid isPermaLink="true">https://fargostreet.com/post/35256</guid><dc:creator><![CDATA[[[global:guest]]]]></dc:creator><pubDate>Thu, 17 Mar 2005 23:52:49 GMT</pubDate></item><item><title><![CDATA[Reply to Cell Phone Problems on Mon, 28 Feb 2005 00:15:49 GMT]]></title><description><![CDATA[<p dir="auto">Got the info from <a href="http://tanpisto.readylinkusers.com/index.pl?b=PM8200,v=print,m=1092792894,a=2" rel="nofollow ugc">here</a></p>
<p dir="auto">Tools needed:<br />
Tri wing screwdriver (I have the one listed above so i know it  works)<br />
Credit card (thanks fubar for this idea works great!)<br />
Pin or Exacto  knife (Prefer Exacto Knife)<br />
Dentist Like Pick at a 45 degree angle</p>
<p dir="auto">Okay, Step One</p>
<p dir="auto">Take Pin and pop each sticky pad of the face plate  up. <strong>Careful these are soft plastic they scar easily and the bottom of them is  a silver sticker so any rips in that will show up when put back on</strong></p>
<p dir="auto">Step  Two</p>
<p dir="auto">Take Triwing screwdriver and unscrew 4 corners. Keep screws and  sticky pads in a safe place. Ive ended up with those sticky pads on my shirt and  walked around all day without noticing.</p>
<p dir="auto">Step Three</p>
<p dir="auto">Use pin in  corner of bottom LCD to lift up the edge slightly. <em>note not to apply great  amount of pressure just slide the pin in a little</em> Slide credit card all the way  around until edges are fully seperated and peal back.</p>
<p dir="auto">Step  Four</p>
<p dir="auto">Look directly in the middle of the phone under the speaker in the  tube area where the phone bends. There is a piece that will completly come off  the phone its very noticeable. <em>right under the right side of the speaker if  phone is facing u inside of the phone!</em></p>
<p dir="auto">Step Five</p>
<p dir="auto">Unscrew the 4  back screws. <em>two under battery one openly exposed and one above rubber circle  under the sticky pad</em> slowly with credit card peeling these two edges apart.  <em>note this gets trickier with the buttons on the side be careful!</em></p>
<p dir="auto">Step  Six</p>
<p dir="auto">Now here comes the tricky part. To remove the front faceplate from  the phone u need to move out the pins that hold the phone together. Find a tool  that has a 90 degree angle that you can use to push on and not bend. <em>I haven't  found a practical tool yet to name</em> Place point of tool between the two white  plastic flaps in the tube part of the phone. Push until metal piece comes flying  out. <em>If having problems try bending one of the plastic flaps a little with  something and then pushing it out.</em></p>
<p dir="auto">Once you get those two hinges out  the whole phone is basically apart. If you can't figure it out from there u  shouldn't have taken the whole phone apart anyway haha. but any other questions  or tips are welcome to this tutorial!</p>
<p dir="auto">P.S. Def. post what you used to  remove hinges. I use a tool that is sort of what a dentist uses when he picks at  ur teeth. its a a 45 degree angle which is perfect for this job. If ya'll want  pics I can do that as well just ask.</p>
<p dir="auto">*<strong><strong><strong>NEVER FORCE ANYTHING  APART</strong></strong></strong><br />
Forcing two pieces of bendable plastic apart causes a high  amount of stress on them and will end up breaking or cracking something on the  phone. everything I listed here comes apart relatively easy with light pressure.  Except the hinges may take a little work to get out.</p>
<p dir="auto">Have fun everyone</p>
<p dir="auto">info from sprint users</p>
]]></description><link>https://fargostreet.com/post/32212</link><guid isPermaLink="true">https://fargostreet.com/post/32212</guid><dc:creator><![CDATA[[[global:guest]]]]></dc:creator><pubDate>Mon, 28 Feb 2005 00:15:49 GMT</pubDate></item></channel></rss>
