<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[FS or trade. 95 Mustang w LS1 swap.]]></title><description><![CDATA[<p dir="auto">Located in Williston, ND.  Email: <a href="mailto:iownedu@hotmail.com" rel="nofollow ugc">iownedu@hotmail.com</a><br />
I am abandoning this project, easy finish for someone.<br />
It needs to be measures for a driveshaft and then order. An aluminum one is about $500 max.<br />
The ECU and wiring harness need to be put in, simple plug and play with the power wires etc all labeled. I sent off the wiring harness to be modified for this application to the tune of $800.<br />
Then the power wires for all the guages are all setup, all you will have to hook up is the wires that go to the sensors.<br />
The rear pipe of the driver side header needs to be modified to clear the steering shaft, then obviously install the steering shaft.</p>
<p dir="auto">I think that is really about it other than small odds and ends like radiator plumbing and a tranny cooler. Exhaust also needs to be put on, have headers, mufflers and xpipe.</p>
<p dir="auto">Here are the mods.</p>
<p dir="auto">AJE Tubular cross member, motor mounts, tubular a-arms, coilover setup, upper camber plates. $1300</p>
<p dir="auto">LS1 and a 4l60e auto trans $4000</p>
<p dir="auto">LS6 Intake/Cam $500</p>
<p dir="auto">Autometer guages $900</p>
<p dir="auto">Kooks Headers $750</p>
<p dir="auto">Walbro 255 intank $110</p>
<p dir="auto">2 Flowmaster 40 series mufflers and an xpipe $350</p>
<p dir="auto">Steering rack offset bushings $50</p>
<p dir="auto">Flaming river manual steering rack $310</p>
<p dir="auto">Flaming River slim steering shaft (to clear headers) $420</p>
<p dir="auto">Aftermarket throttle body (cant remember brand) $300</p>
<p dir="auto">Probably forgetting alot of things</p>
<p dir="auto">Anyway with the purchase of the car I have almost $11k into it as it sits.</p>
<p dir="auto">Ill take $7200, cars with this setup are known to break 11's rock stock motor.</p>
<p dir="auto"><img src="http://i33.photobucket.com/albums/d75/matpatte/SNC13494.jpg" alt="legacy image" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="http://i33.photobucket.com/albums/d75/matpatte/SNC13489.jpg" alt="legacy image" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="http://i33.photobucket.com/albums/d75/matpatte/SNC13488.jpg" alt="legacy image" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="http://i33.photobucket.com/albums/d75/matpatte/SNC13484.jpg" alt="legacy image" class=" img-fluid img-markdown" /><br />
This was before the Flaming river rack was installed.</p>
<p dir="auto"><img src="http://i33.photobucket.com/albums/d75/matpatte/SNC13471.jpg" alt="legacy image" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="http://i33.photobucket.com/albums/d75/matpatte/SNC13467.jpg" alt="legacy image" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="http://i33.photobucket.com/albums/d75/matpatte/6.jpg" alt="legacy image" class=" img-fluid img-markdown" /></p>
]]></description><link>https://fargostreet.com/topic/18096/fs-or-trade.-95-mustang-w-ls1-swap.</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 14:19:39 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/18096.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 07 Oct 2009 19:30:35 GMT</pubDate><ttl>60</ttl></channel></rss>
