<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[96 Stratus Overcharging]]></title><description><![CDATA[<p dir="auto">My friend has a 96 Stratus 5spd w/ 2.0 engine. She was having troubles with it and took it to a mechanic to find that it is overcharging (about 17volts).</p>
<p dir="auto">The voltage regulator is held within the ECM. So they figure it is the ECM that is bad and needs to be replaced.</p>
<p dir="auto">Can anyone confirm this? and also, there is a firm suspension and w/ out firm suspension ECU. Does anyone know the difference and what happens if i use the wrong one?</p>
<p dir="auto">thanks</p>
]]></description><link>https://fargostreet.com/topic/1821/96-stratus-overcharging</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 12:31:23 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/1821.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 03 Mar 2005 22:10:55 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to 96 Stratus Overcharging on Fri, 04 Mar 2005 03:33:23 GMT]]></title><description><![CDATA[<p dir="auto">what idiot thought that was a good place for a voltage regulator? LOL<br />
probably the same idiot that put the battery in the bumper of the stratus.</p>
<p dir="auto">now i know why i like working on honda's and despise anything american.</p>
]]></description><link>https://fargostreet.com/post/32884</link><guid isPermaLink="true">https://fargostreet.com/post/32884</guid><dc:creator><![CDATA[legacy-user-131]]></dc:creator><pubDate>Fri, 04 Mar 2005 03:33:23 GMT</pubDate></item><item><title><![CDATA[Reply to 96 Stratus Overcharging on Fri, 04 Mar 2005 01:06:33 GMT]]></title><description><![CDATA[<p dir="auto">Sounds right.  My Mazda does the same trick and I've heard it would require a ECM replacement to fix such an issue.</p>
]]></description><link>https://fargostreet.com/post/32847</link><guid isPermaLink="true">https://fargostreet.com/post/32847</guid><dc:creator><![CDATA[mym6]]></dc:creator><pubDate>Fri, 04 Mar 2005 01:06:33 GMT</pubDate></item></channel></rss>
