<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[pc&#x2F;network help]]></title><description><![CDATA[<p dir="auto">I want to change a few things at my house and was wondering the best way of doing it.  Here is what I have...4 desktops and 1 labtop....I want to print wireless from any pc and share external hardrive across the network...I know it would be easy if I left a host pc on but I shut my pc's off when done.</p>
<p dir="auto">so if I went with a new  Multi-Functional Wireless Router with x2 USB Plug-N-Share hard drive function and Print Server Function would this be the best thing to do?</p>
<p dir="auto">Thanks<br />
Kelly</p>
]]></description><link>https://fargostreet.com/topic/18222/pc-network-help</link><generator>RSS for Node</generator><lastBuildDate>Wed, 27 May 2026 23:56:09 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/18222.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 03 Nov 2009 17:46:33 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to pc&#x2F;network help on Wed, 11 Nov 2009 13:42:41 GMT]]></title><description><![CDATA[<p dir="auto">Wireless printers are cheap now too, btw. Mine was under $200 when I got it a year ago. That way you don't have to worry about setting up a print server, it's one less cable you need to use, and you don't have to worry about manually setting a static IP.</p>
<p dir="auto">That with NAS is probably the easiest route.</p>
]]></description><link>https://fargostreet.com/post/281947</link><guid isPermaLink="true">https://fargostreet.com/post/281947</guid><dc:creator><![CDATA[amicheze]]></dc:creator><pubDate>Wed, 11 Nov 2009 13:42:41 GMT</pubDate></item><item><title><![CDATA[Reply to pc&#x2F;network help on Wed, 11 Nov 2009 09:09:33 GMT]]></title><description><![CDATA[<p dir="auto">here's probably the simplest way:<br />
printer with ethernet capabilities<br />
router with wireless<br />
set the printer to a static ip</p>
<p dir="auto">everyone can print and no machine needs to be left running except the router, maybe the printer (which will likely have a sleep mode).</p>
<p dir="auto">if you want network storage, there are many other options you could use. my house uses a gentoo-based server (which also functions as an rsync server!) with smbfs for windows-friendly usage.</p>
<p dir="auto">obviously, like thompson and thrash have illustrated, your network can get far more complicated, but a network with wireless using non-broadcast sid and mac restrictions is sufficient for almost any home.</p>
]]></description><link>https://fargostreet.com/post/281943</link><guid isPermaLink="true">https://fargostreet.com/post/281943</guid><dc:creator><![CDATA[out there]]></dc:creator><pubDate>Wed, 11 Nov 2009 09:09:33 GMT</pubDate></item><item><title><![CDATA[Reply to pc&#x2F;network help on Mon, 09 Nov 2009 15:48:16 GMT]]></title><description><![CDATA[<p dir="auto">I think I am going to go this route for my home setup</p>
<p dir="auto">Dlink DNS-323 NAS storage enclosure</p>
]]></description><link>https://fargostreet.com/post/281768</link><guid isPermaLink="true">https://fargostreet.com/post/281768</guid><dc:creator><![CDATA[Raider]]></dc:creator><pubDate>Mon, 09 Nov 2009 15:48:16 GMT</pubDate></item><item><title><![CDATA[Reply to pc&#x2F;network help on Wed, 04 Nov 2009 04:01:56 GMT]]></title><description><![CDATA[<p dir="auto">needs more fiber</p>
]]></description><link>https://fargostreet.com/post/281486</link><guid isPermaLink="true">https://fargostreet.com/post/281486</guid><dc:creator><![CDATA[dubbsy]]></dc:creator><pubDate>Wed, 04 Nov 2009 04:01:56 GMT</pubDate></item><item><title><![CDATA[Reply to pc&#x2F;network help on Wed, 04 Nov 2009 03:16:58 GMT]]></title><description><![CDATA[<p dir="auto">Here is my home network.  It works.  Haha.</p>
<p dir="auto"><img src="http://www.imperial.org/~nick/tmp/HomeNetwork.jpg" alt="legacy image" class=" img-fluid img-markdown" /></p>
]]></description><link>https://fargostreet.com/post/281483</link><guid isPermaLink="true">https://fargostreet.com/post/281483</guid><dc:creator><![CDATA[integra_gsr98]]></dc:creator><pubDate>Wed, 04 Nov 2009 03:16:58 GMT</pubDate></item><item><title><![CDATA[Reply to pc&#x2F;network help on Tue, 03 Nov 2009 20:11:43 GMT]]></title><description><![CDATA[<p dir="auto">something you might want to look at for your "always on" PC is <a href="http://en.wikipedia.org/wiki/Windows_Home_Server" rel="nofollow ugc">http://en.wikipedia.org/wiki/Windows_Home_Server</a></p>
<p dir="auto">It does a number of things you probably want</p>
<ul>
<li>file and print sharing</li>
<li>auto-backup all of your machines</li>
<li>lets you add new disks via USB or whatever and uses the space automatically</li>
<li>does file-level replication so that if a disk fails you don't lose that data</li>
</ul>
<p dir="auto">You can get a pre-made box that has WHS already on it, or you can buy just the software and put it on a machine you already have.</p>
<p dir="auto">Wireless will absolutely be slower than wired connections, but for accessing the internet you won't notice.  The big scenario where you will want wired connections is moving video files or ISO images from machine to machine, or streaming them for viewing/burning.  If you don't do a lot of this, or don't mind if it takes a while, wireless will be fine.</p>
<p dir="auto"><strong>You can probably stop reading here, but i'll continue on if you're curious:</strong></p>
<p dir="auto">One thing I would recommend doing is having an intermediate device between your customer premise equipment [i.e. your cable modem or dsl modem] and your actual PCs.  The equipment that the cable and telco's usually provide typically isn't very good, and you may get into the situation of needing to power cycle that stuff now and then to re-train a connection.  This was especially true with Qwest's ActionTec garbage.</p>
<p dir="auto">Essentially, you want to configure the vendor supplied CPE to be as stupid as possible.  You want it to forward all traffic more or less unmodifed to a <em>good</em> routing device that you can specify and control, and you want <em>that</em> device to do your internal DHCP.  That way if you need to powercycle your modem you don't knock out parts of your internal network.</p>
<p dir="auto">Finally, i tend to disable the on-board wi-fi capability in the vendor supplied modem/router, since i want my wifi-usage to be on the "internal" network and again, the vendor supplied stuff usually isn't any good.  Most consumer wireless access points are also a bit flaky, and so again, don't run your wired gear through them.</p>
<p dir="auto">So my overall picture is<br />
DSL modem -&gt; 2-NIC PC running OpenBSD -&gt; gig-E switch -&gt; my internal PCs, and my internal wireless access point, (which only acts as a wireless bridge for laptops).  All the PCs are plugged into wall plates that lead back to the gig-E switch.  My media room has a smaller 5 port gig-E switch that is chained off of the main switch.</p>
<p dir="auto">In my setup, the OpenBSD machine does everything for the internal network, such that power cycling the DSL modem [or shutting it off and removing it] has no affect on internal network traffic, host resolution, etc.  You could just as well use a netgear integrated switch/router/access point if you found one that had the features you wanted and showed sufficient reliability.  The PC i'm using I got over 10 years ago and it has never missed a beat.  It typically goes a few hundred days of continuous uptime before I patch and reboot it.</p>
<p dir="auto">Wired Gig-E helps a lot if you'll be moving or streaming video files around your home network; it's effectively faster than the hard drives the data is being read from / written to in most cases.</p>
]]></description><link>https://fargostreet.com/post/281434</link><guid isPermaLink="true">https://fargostreet.com/post/281434</guid><dc:creator><![CDATA[thrash]]></dc:creator><pubDate>Tue, 03 Nov 2009 20:11:43 GMT</pubDate></item><item><title><![CDATA[Reply to pc&#x2F;network help on Tue, 03 Nov 2009 19:59:37 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">Raider;293035 wrote:<br />
I have no way of running cable to all the points where the pc's are located so it has to be wireless so my speeds will suffer anyway correct?</p>
<p dir="auto">Yup. Not to mention that using a USB external HDD will be slow anyway. I have a 1TB USB external HDD and I think I only get an average of like 14mb/s actual transfer rate.</p>
]]></description><link>https://fargostreet.com/post/281433</link><guid isPermaLink="true">https://fargostreet.com/post/281433</guid><dc:creator><![CDATA[amicheze]]></dc:creator><pubDate>Tue, 03 Nov 2009 19:59:37 GMT</pubDate></item><item><title><![CDATA[Reply to pc&#x2F;network help on Tue, 03 Nov 2009 18:55:13 GMT]]></title><description><![CDATA[<p dir="auto">my main pc will be connected to the router by ethernet for all the main downloading but I want to be able to access the external HD from any pc in the house...I have no way of running cable to all the points where the pc's are located so it has to be wireless so my speeds will suffer anyway correct?</p>
]]></description><link>https://fargostreet.com/post/281429</link><guid isPermaLink="true">https://fargostreet.com/post/281429</guid><dc:creator><![CDATA[Raider]]></dc:creator><pubDate>Tue, 03 Nov 2009 18:55:13 GMT</pubDate></item><item><title><![CDATA[Reply to pc&#x2F;network help on Tue, 03 Nov 2009 18:42:02 GMT]]></title><description><![CDATA[<p dir="auto">My house network is 100% overkill so I have no way of actually chiming in here.</p>
<p dir="auto">Take the enterprise home...  at least that's what I did.  HAHA.</p>
]]></description><link>https://fargostreet.com/post/281427</link><guid isPermaLink="true">https://fargostreet.com/post/281427</guid><dc:creator><![CDATA[integra_gsr98]]></dc:creator><pubDate>Tue, 03 Nov 2009 18:42:02 GMT</pubDate></item><item><title><![CDATA[Reply to pc&#x2F;network help on Tue, 03 Nov 2009 18:40:41 GMT]]></title><description><![CDATA[<p dir="auto">I'm not Jim, but I'd use a print/file server type setup with a box constantly running.</p>
]]></description><link>https://fargostreet.com/post/281425</link><guid isPermaLink="true">https://fargostreet.com/post/281425</guid><dc:creator><![CDATA[PSiedTSi]]></dc:creator><pubDate>Tue, 03 Nov 2009 18:40:41 GMT</pubDate></item><item><title><![CDATA[Reply to pc&#x2F;network help on Tue, 03 Nov 2009 18:27:31 GMT]]></title><description><![CDATA[<p dir="auto">Jim how would you do it?</p>
]]></description><link>https://fargostreet.com/post/281423</link><guid isPermaLink="true">https://fargostreet.com/post/281423</guid><dc:creator><![CDATA[Raider]]></dc:creator><pubDate>Tue, 03 Nov 2009 18:27:31 GMT</pubDate></item><item><title><![CDATA[Reply to pc&#x2F;network help on Tue, 03 Nov 2009 17:58:43 GMT]]></title><description><![CDATA[<p dir="auto">That should work fine, don't expect stellar performance in terms of data transfer though.</p>
]]></description><link>https://fargostreet.com/post/281421</link><guid isPermaLink="true">https://fargostreet.com/post/281421</guid><dc:creator><![CDATA[Jim]]></dc:creator><pubDate>Tue, 03 Nov 2009 17:58:43 GMT</pubDate></item><item><title><![CDATA[Reply to pc&#x2F;network help on Tue, 03 Nov 2009 17:57:22 GMT]]></title><description><![CDATA[<p dir="auto">That should work just fine I'd imagine.</p>
<p dir="auto">GSR/Dubbsy/Jim wanna chime in on this?</p>
]]></description><link>https://fargostreet.com/post/281419</link><guid isPermaLink="true">https://fargostreet.com/post/281419</guid><dc:creator><![CDATA[Trafik Jamz]]></dc:creator><pubDate>Tue, 03 Nov 2009 17:57:22 GMT</pubDate></item></channel></rss>
