<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Attention Euro owners&#x2F;fans]]></title><description><![CDATA[<p dir="auto">I'm assuming you guys know a lot more about the Audi A4 Quattro 2.0T (B7) than I do.</p>
<p dir="auto">What is the good/bad/other about this car?<br />
Is it reliable?</p>
<p dir="auto">How well does it take to mild mods (intake, bov, exhaust, etc...)?</p>
<p dir="auto">Is the ECU reflashable or are you required to go the AEM route?</p>
<p dir="auto">Thanks in advance.</p>
]]></description><link>https://fargostreet.com/topic/18236/attention-euro-owners-fans</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 07:01:59 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/18236.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 05 Nov 2009 13:00:45 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Attention Euro owners&#x2F;fans on Tue, 15 Dec 2009 07:34:09 GMT]]></title><description><![CDATA[<p dir="auto">FWIW, I don't have any electrical problems either. My car even has fairly high miles for the year.</p>
]]></description><link>https://fargostreet.com/post/284567</link><guid isPermaLink="true">https://fargostreet.com/post/284567</guid><dc:creator><![CDATA[amicheze]]></dc:creator><pubDate>Tue, 15 Dec 2009 07:34:09 GMT</pubDate></item><item><title><![CDATA[Reply to Attention Euro owners&#x2F;fans on Tue, 15 Dec 2009 07:17:13 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">GhettoFabulousCRX;296169 wrote:<br />
we have an A6 and a taureg,,, with eletrical problems. And they cost a ton to keep running.</p>
<p dir="auto">I had some electrical problems with my 88 Audi.  I plugged the defroster switch into the drivers seat-heater socket [or something like that].  The dash wiring harness started smoking.  It was exactly like watching a lit-fuse in a warner bros cartoon.. i watched smoke start to pour out of the center console... then watched it crawl across the dashboard, under the instrument cluster, over to where the main fuse panel was.  Luckily the seat-heater wiring was a separate assembly in the main harness routing, so i just unplugged it at both ends and did a little electrical tape surgery on the neighboring wires.</p>
<p dir="auto">I think audi should have put better fusing on the wires that melted their insulation.  But that was 20 years ago.  American and Japanese cars still hadn't heard of seat heaters, heated mirrors, heated door locks, and all of the other cool shit this car had.</p>
<p dir="auto">In any case, I haven't had any electrical problems to speak of in 80,000 miles of Passat ownership or 35,000 of A4 ownership.  The VCDS will tell you pretty quick what the car thinks is wrong with itself.  I'd say owning one is essential for owning an out-of-warranty VW/Audi product.</p>
]]></description><link>https://fargostreet.com/post/284566</link><guid isPermaLink="true">https://fargostreet.com/post/284566</guid><dc:creator><![CDATA[thrash]]></dc:creator><pubDate>Tue, 15 Dec 2009 07:17:13 GMT</pubDate></item><item><title><![CDATA[Reply to Attention Euro owners&#x2F;fans on Tue, 15 Dec 2009 07:00:13 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">PSiedTSi;296167 wrote:<br />
Not to bump a kind of up and down thread, but I figured it'd be better than starting a completely new one for basically the same thing.</p>
<p dir="auto">I'm looking at B5 S4/A4's, and a few B6 A4's. Anyone have any direct experience or advice? I know the 1.8T motor is pretty decent and I do plan to mod, atleast a K04(s). I know the S4 is a BITCH to work on, so I'm kinda lookin for one that has a newish clutch or aftermarket.</p>
<p dir="auto">The B6 is a much better car, but in 1.8T trim you have to be careful about what year you buy with respect to things like brake setup, body-painted valences and rockers, etc.</p>
<p dir="auto">The B5 S4 is a legendary car, but you have the pull the entire engine to replace the turbos.  I don't know if there's much rhyme or reason to when they fail and what causes it.  There are low mileage stock S4s that shat their K03s.  You're definitely better off buying a Stage3 S4 from someone else with all the quirks worked out unless you're modding-for-fun.  You'll certainly pay less.  Guys on the <a href="http://quattroworld.com" rel="nofollow ugc">quattroworld.com</a> S4 forum are always unloading their S4s so look there for what enthusiast-owned cars are going for [and what people do to them].</p>
<p dir="auto">The 1.8T turbo/engine failures tend to be from dipshits that didn't use real oil or didn't change it often enough.  The good news is that even dropping a yard motor into one of these things isn't a deal breaker, as that motor was reasonably common.</p>
<p dir="auto">The other good news about turbo failure is that K04s are cheaper than putting K03s back in <img src="https://fargostreet.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f642.png?v=40430adaedb" class="not-responsive emoji emoji-android emoji--slightly_smiling_face" style="height:23px;width:auto;vertical-align:middle" title=":)" alt="🙂" /></p>
<p dir="auto">IMO the B5 looks better exterior wise, but the B6 is the better car -- at least in A4 trim.</p>
<p dir="auto">If you go with a 1.8T, budget for K03 failure and plan to do the K04 upgrade at that time.  Also plan on replacing some coilpacks, and become friends with someone with a VCDS.</p>
<p dir="auto">I don't find these cars especially expensive to own if you can DIY and can use the internet.  I did the timing belt and all associated stuff [crank seals, water pump, tensioners, etc] on a 96 A4.  I spent a weekend on it and I'd never done a TB before.  You just rent the factory tools and follow the detailed instructions on the internet.  A timing belt job on any audi is at least $1k from a shop, but i think i did the whole deal for a few hundred bucks.</p>
<p dir="auto">You need a few goofy special tools [triple-square 12pt bits] to really start taking things apart, but i even got those in town from Berg.</p>
<p dir="auto">You might want to cross-shop the VW Passat from 2001.5 to whenever the new body style hit [2005?] -- the B5.5 generation Passat is a B5 A4 with a long wheel base.  HUGE interior room compared to the A4.  Same motors, gearboxes, quattro system, etc.  Repair manuals cover both cars, if that tells you anything <img src="https://fargostreet.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f642.png?v=40430adaedb" class="not-responsive emoji emoji-android emoji--slightly_smiling_face" style="height:23px;width:auto;vertical-align:middle" title=":)" alt="🙂" />  It can be hard to find one with the 4Motion + stick setup, but they're out there.</p>
<p dir="auto">The "model guide" on <a href="http://Audiworld.com" rel="nofollow ugc">Audiworld.com</a> under the "Resources" menu will help you understand the standard/optional equipment on year-to-year changes.  It can help you narrow down what years to look at.</p>
<p dir="auto">I bought a friend a 96 A4 quattro 5spd a few years back from Imports Plus for like $5k.  It's a very capable car for that money, and they've kept getting cheaper and cheaper since then.</p>
<p dir="auto">The B5 is getting old enough that you're going to want to look at replacing rubber in the suspension just as a matter of principle.  The suspension is complicated and expensive -- check out control arm kits on <a href="http://ecstuning.com" rel="nofollow ugc">ecstuning.com</a> to get an idea of what you're up against.  Doing the brakes is a little funny -- you screw the rear pistons back into the calipers while compressing them like normal.  This is because of the integral rear-parking brake.  Additionally, the parking brake is actuated by somethig akin to bowden cables, and when the front wheels spin they spray winter-road-shit all over those cables and the rear calipers.  Invariably the cables or the external actuators seize up.  It's pretty common to find non-functional e-brakes on older audis that have lived in winter climates.  Worse case is two new e-brake cables and new rear calipers.</p>
<p dir="auto">The fancy-ass auto-HVAC unit will tend to lose pixels / display elements with age.  Shokan and Force5 are audi recyclers that will sell you used HVAC units in known condition.</p>
<p dir="auto">It's probably worth doing a VCDS scan/reset of any car you're looking at, then driving it, then scanning it again.</p>
]]></description><link>https://fargostreet.com/post/284565</link><guid isPermaLink="true">https://fargostreet.com/post/284565</guid><dc:creator><![CDATA[thrash]]></dc:creator><pubDate>Tue, 15 Dec 2009 07:00:13 GMT</pubDate></item><item><title><![CDATA[Reply to Attention Euro owners&#x2F;fans on Tue, 15 Dec 2009 05:34:35 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">Jim;293158 wrote:<br />
Everybody that I know with an Audi has electrical problems.</p>
<p dir="auto">we have an A6 and a taureg,,, with eletrical problems. And they cost a ton to keep running.</p>
<p dir="auto">who is this eurofag anyways? meh</p>
]]></description><link>https://fargostreet.com/post/284555</link><guid isPermaLink="true">https://fargostreet.com/post/284555</guid><dc:creator><![CDATA[GhettoFabulousCRX]]></dc:creator><pubDate>Tue, 15 Dec 2009 05:34:35 GMT</pubDate></item><item><title><![CDATA[Reply to Attention Euro owners&#x2F;fans on Tue, 15 Dec 2009 04:37:42 GMT]]></title><description><![CDATA[<p dir="auto">Not to bump a kind of up and down thread, but I figured it'd be better than starting a completely new one for basically the same thing.</p>
]]></description><link>https://fargostreet.com/post/284553</link><guid isPermaLink="true">https://fargostreet.com/post/284553</guid><dc:creator><![CDATA[PSiedTSi]]></dc:creator><pubDate>Tue, 15 Dec 2009 04:37:42 GMT</pubDate></item><item><title><![CDATA[Reply to Attention Euro owners&#x2F;fans on Mon, 09 Nov 2009 05:00:50 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">Eurofan;293338 wrote:<br />
Do you honestly think anyone gives a flying fuck about your ford that you shit on daily????? How is that helping the OP in anyway???? Do me a favor and tie your hands behind your back when youre viewing threads. God people that ruin forums like this make me fucking angry inside. Just stop</p>
<p dir="auto">Maybe you shouldnt get so angry inside?</p>
]]></description><link>https://fargostreet.com/post/281757</link><guid isPermaLink="true">https://fargostreet.com/post/281757</guid><dc:creator><![CDATA[Bp-08]]></dc:creator><pubDate>Mon, 09 Nov 2009 05:00:50 GMT</pubDate></item><item><title><![CDATA[Reply to Attention Euro owners&#x2F;fans on Mon, 09 Nov 2009 02:12:27 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">Trafik Jamz;293327 wrote:<br />
Not to race, not to mod (extensively), etc...just to drive from home to work and back again and the occasional trip out of town.</p>
<p dir="auto">Haha.... BULLSHIT.</p>
]]></description><link>https://fargostreet.com/post/281740</link><guid isPermaLink="true">https://fargostreet.com/post/281740</guid><dc:creator><![CDATA[weshole]]></dc:creator><pubDate>Mon, 09 Nov 2009 02:12:27 GMT</pubDate></item><item><title><![CDATA[Reply to Attention Euro owners&#x2F;fans on Mon, 09 Nov 2009 00:30:53 GMT]]></title><description><![CDATA[<p dir="auto">Don't worry, the OP has been on this board long enough to weed out the bullshit and ignore/antagonize the idiots.</p>
]]></description><link>https://fargostreet.com/post/281734</link><guid isPermaLink="true">https://fargostreet.com/post/281734</guid><dc:creator><![CDATA[Trafik Jamz]]></dc:creator><pubDate>Mon, 09 Nov 2009 00:30:53 GMT</pubDate></item><item><title><![CDATA[Reply to Attention Euro owners&#x2F;fans on Mon, 09 Nov 2009 00:26:32 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">Bp-08;293243 wrote:<br />
once your car makes it to 230,000 miles on the original fuel pump, tranny, and motor, you can tell me how good euro cars are. My exploder did, and I beat the crap out of it. I was 15-16 when I had it neutral bombed it many times. All I ever had to fix on that on the 6 years we owned it bought it in 2000 and sold it in 06 or 07 was an cv boot because i tore it on a rock out hunting. My current car is at 216,000 and I just recently replaced the original thermostat. The tranny did go out but that was my fault at 180,000 miles. and its a ford.</p>
<p dir="auto">Do you honestly think anyone gives a flying fuck about your ford that you shit on daily????? How is that helping the OP in anyway???? Do me a favor and tie your hands behind your back when youre viewing threads. God people that ruin forums like this make me fucking angry inside. Just stop</p>
]]></description><link>https://fargostreet.com/post/281731</link><guid isPermaLink="true">https://fargostreet.com/post/281731</guid><dc:creator><![CDATA[Eurofan]]></dc:creator><pubDate>Mon, 09 Nov 2009 00:26:32 GMT</pubDate></item><item><title><![CDATA[Reply to Attention Euro owners&#x2F;fans on Mon, 09 Nov 2009 00:06:41 GMT]]></title><description><![CDATA[<p dir="auto">Sorry guys, I'm going to take the advice of thrash/jim/eurofan on this.  They seem to have a better feel for what is going to happen if I just buy the car to drive.  Not to race, not to mod (extensively), etc...just to drive from home to work and back again and the occasional trip out of town.</p>
]]></description><link>https://fargostreet.com/post/281720</link><guid isPermaLink="true">https://fargostreet.com/post/281720</guid><dc:creator><![CDATA[Trafik Jamz]]></dc:creator><pubDate>Mon, 09 Nov 2009 00:06:41 GMT</pubDate></item><item><title><![CDATA[Reply to Attention Euro owners&#x2F;fans on Mon, 09 Nov 2009 00:02:38 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">My 1999 Chevy 3/4 ton is at 268,XXX miles right now, that must mean that it is the best tuner car around....right?  My WRX broke a ring land at ~30,000 miles meaning it is utter horseshit I assume?</p>
]]></description><link>https://fargostreet.com/post/281719</link><guid isPermaLink="true">https://fargostreet.com/post/281719</guid><dc:creator><![CDATA[Trafik Jamz]]></dc:creator><pubDate>Mon, 09 Nov 2009 00:02:38 GMT</pubDate></item><item><title><![CDATA[Reply to Attention Euro owners&#x2F;fans on Sun, 08 Nov 2009 23:59:20 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">24valvenotak;293212 wrote:<br />
is it getting too crowded over there on the urabus bandwagon?</p>
<p dir="auto">Shit, I've been on the WRX bandwagon since 2001....</p>
]]></description><link>https://fargostreet.com/post/281718</link><guid isPermaLink="true">https://fargostreet.com/post/281718</guid><dc:creator><![CDATA[Trafik Jamz]]></dc:creator><pubDate>Sun, 08 Nov 2009 23:59:20 GMT</pubDate></item><item><title><![CDATA[Reply to Attention Euro owners&#x2F;fans on Sun, 08 Nov 2009 16:45:12 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">Eurofan;293194 wrote:<br />
<img src="http://i382.photobucket.com/albums/oo263/mymbonline7/davis.jpg" alt="legacy image" class=" img-fluid img-markdown" /></p>
<p dir="auto">These are the VMR 710's with a drop. Pure sex.</p>
<p dir="auto">looks like a VW....</p>
]]></description><link>https://fargostreet.com/post/281695</link><guid isPermaLink="true">https://fargostreet.com/post/281695</guid><dc:creator><![CDATA[zbrown]]></dc:creator><pubDate>Sun, 08 Nov 2009 16:45:12 GMT</pubDate></item><item><title><![CDATA[Reply to Attention Euro owners&#x2F;fans on Sun, 08 Nov 2009 04:42:17 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">I have over 200 thousand on my Mercedes The only parts that have been replaced are the Ignition switch and the starter.</p>
<p dir="auto">As for the Audi's I think its hit and miss,  i have heard both sides.  however,  my buddy,  yes the same guy Ichi was talking about has an a4 and had many electrical problems,  ABS,  Airbag readiness lights,  Cold start valve issues,  idle control issues,  window elevator breaking,   and vacuum system problems.  seems like he takes it to get repaired and within a month or two there's more shit to fix.  It's a nice car,  and fun to drive,  but it is a money pit repair wise.</p>
]]></description><link>https://fargostreet.com/post/281689</link><guid isPermaLink="true">https://fargostreet.com/post/281689</guid><dc:creator><![CDATA[Goodnbuzzd]]></dc:creator><pubDate>Sun, 08 Nov 2009 04:42:17 GMT</pubDate></item><item><title><![CDATA[Reply to Attention Euro owners&#x2F;fans on Sat, 07 Nov 2009 05:42:15 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">Jim;293268 wrote:<br />
Lol i think you're talking about VW guys<br />
<img src="http://i15.photobucket.com/albums/a392/weshole/stuff/STFU_jeez.jpg" alt="legacy image" class=" img-fluid img-markdown" /><br />
<img src="http://i15.photobucket.com/albums/a392/weshole/stuff/STFU_blahblahblah.gif" alt="legacy image" class=" img-fluid img-markdown" /></p>
]]></description><link>https://fargostreet.com/post/281668</link><guid isPermaLink="true">https://fargostreet.com/post/281668</guid><dc:creator><![CDATA[weshole]]></dc:creator><pubDate>Sat, 07 Nov 2009 05:42:15 GMT</pubDate></item><item><title><![CDATA[Reply to Attention Euro owners&#x2F;fans on Sat, 07 Nov 2009 03:39:32 GMT]]></title><description><![CDATA[<blockquote>
Lol i think you're talking about VW guys</p>
<p dir="auto">my apologies good sir... most commonly describing those dreaded VDub guys lol</p>
]]></description><link>https://fargostreet.com/post/281665</link><guid isPermaLink="true">https://fargostreet.com/post/281665</guid><dc:creator><![CDATA[blackcherryTSi]]></dc:creator><pubDate>Sat, 07 Nov 2009 03:39:32 GMT</pubDate></item><item><title><![CDATA[Reply to Attention Euro owners&#x2F;fans on Sat, 07 Nov 2009 00:49:12 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">blackcherryTSi;293260 wrote:<br />
like EVERY OTHER euro car.... atleast with the JDM'ers there is a wide variety of customizing.... not just the same old debadge,slam,stretch,tint song and dance</p>
<p dir="auto">Lol i think you're talking about VW guys</p>
]]></description><link>https://fargostreet.com/post/281661</link><guid isPermaLink="true">https://fargostreet.com/post/281661</guid><dc:creator><![CDATA[Jim]]></dc:creator><pubDate>Sat, 07 Nov 2009 00:49:12 GMT</pubDate></item><item><title><![CDATA[Reply to Attention Euro owners&#x2F;fans on Fri, 06 Nov 2009 23:11:40 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">thrash;293247 wrote:</p>
<ul>
<li>My 91 celica had 3 clutches in the time we owned it.  I let a friend borrow it and she shredded what was left of it, leaving her stranded on the highway in Seattle.</li>
</ul>
<p dir="auto">IIRC, on the Ferrari 355 you pull the engine out of the car every 15,000 miles to do an engine service.  Is it unreliable?  Should Ferrari owners drive ford explorers?</p>
<p dir="auto">Stop shitting in this thread -- it's a question about a specific car, not a solicitation for uninformed anecdotes.</p>
<p dir="auto">You cant blame the car for the clutches going out, thats something called being a shitty driver.</p>
<p dir="auto">And yes, yes they should.</p>
]]></description><link>https://fargostreet.com/post/281655</link><guid isPermaLink="true">https://fargostreet.com/post/281655</guid><dc:creator><![CDATA[Bp-08]]></dc:creator><pubDate>Fri, 06 Nov 2009 23:11:40 GMT</pubDate></item><item><title><![CDATA[Reply to Attention Euro owners&#x2F;fans on Fri, 06 Nov 2009 22:14:37 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">Eurofan;293193 wrote:<br />
To do cosmetic mods: h&amp;r lowering springs, Wheels (VMR 710's), debadge, and tint.</p>
<p dir="auto">like EVERY OTHER euro car.... atleast with the JDM'ers there is a wide variety of customizing.... not just the same old debadge,slam,stretch,tint song and dance</p>
]]></description><link>https://fargostreet.com/post/281653</link><guid isPermaLink="true">https://fargostreet.com/post/281653</guid><dc:creator><![CDATA[blackcherryTSi]]></dc:creator><pubDate>Fri, 06 Nov 2009 22:14:37 GMT</pubDate></item><item><title><![CDATA[Reply to Attention Euro owners&#x2F;fans on Fri, 06 Nov 2009 21:55:14 GMT]]></title><description><![CDATA[<p dir="auto">HAHAHA +1 to anyone who brags about a high miled explorer... that takes balls, right?</p>
]]></description><link>https://fargostreet.com/post/281650</link><guid isPermaLink="true">https://fargostreet.com/post/281650</guid><dc:creator><![CDATA[Kossick]]></dc:creator><pubDate>Fri, 06 Nov 2009 21:55:14 GMT</pubDate></item><item><title><![CDATA[Reply to Attention Euro owners&#x2F;fans on Fri, 06 Nov 2009 17:00:30 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><img src="http://thehealthblogger.com/wp-content/uploads/2008/07/cookie.jpg" alt="legacy image" class=" img-fluid img-markdown" /></p>
]]></description><link>https://fargostreet.com/post/281643</link><guid isPermaLink="true">https://fargostreet.com/post/281643</guid><dc:creator><![CDATA[amicheze]]></dc:creator><pubDate>Fri, 06 Nov 2009 17:00:30 GMT</pubDate></item><item><title><![CDATA[Reply to Attention Euro owners&#x2F;fans on Fri, 06 Nov 2009 15:36:20 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">h0 h0 h0!</p>
<p dir="auto">There is a 200,000 mile BMW in my garage right now.  3 of the 6 German cars I've owned were in the 200,000 mile range.</p>
<p dir="auto">I fondly remember the decidedly non-German cars that left me stranded though:</p>
<ul>
<li>
<p dir="auto">My 85 Bronco II's engine sputtered out and died and wouldn't refire.  I was driving it up a mountain and it just ran out of air or something.  After I had it towed back down the mountain, it started back up again.  Tow truck driver laughed at me.  Go Ford!</p>
</li>
<li>
<p dir="auto">My 70 Cutlass blew its engine, because I had the nerve to run it wide-open on the interstate for about 30 mins [it would only hit 90mph.. wtf kind of peice of shit is that?].</p>
</li>
<li>
<p dir="auto">My 91 celica had 3 clutches in the time we owned it.  I let a friend borrow it and she shredded what was left of it, leaving her stranded on the highway in Seattle.</p>
</li>
</ul>
<p dir="auto">I've done hundreds (if not thousands) of laps of BIR in high-miles BMWs.  Then I drive them back to Fargo when I'm all done.  I think the only on-track issue I had was throwing a belt.  Went to napa and threw on another one, and that was that.  I was back out for the next session.</p>
]]></description><link>https://fargostreet.com/post/281640</link><guid isPermaLink="true">https://fargostreet.com/post/281640</guid><dc:creator><![CDATA[thrash]]></dc:creator><pubDate>Fri, 06 Nov 2009 15:36:20 GMT</pubDate></item><item><title><![CDATA[Reply to Attention Euro owners&#x2F;fans on Fri, 06 Nov 2009 08:39:32 GMT]]></title><description><![CDATA[<p dir="auto">Shut up^^^</p>
]]></description><link>https://fargostreet.com/post/281637</link><guid isPermaLink="true">https://fargostreet.com/post/281637</guid><dc:creator><![CDATA[drift86]]></dc:creator><pubDate>Fri, 06 Nov 2009 08:39:32 GMT</pubDate></item><item><title><![CDATA[Reply to Attention Euro owners&#x2F;fans on Fri, 06 Nov 2009 08:13:07 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">thrash;293241 wrote:<br />
<img src="http://www.e-edit.co.uk/images/cry.gif" alt="legacy image" class=" img-fluid img-markdown" /></p>
<p dir="auto">once your car makes it to 230,000 miles on the original fuel pump, tranny, and motor, you can tell me how good euro cars are. My exploder did, and I beat the crap out of it. I was 15-16 when I had it neutral bombed it many times. All I ever had to fix on that on the 6 years we owned it bought it in 2000 and sold it in 06 or 07 was an cv boot because i tore it on a rock out hunting. My current car is at 216,000 and I just recently replaced the original thermostat. The tranny did go out but that was my fault at 180,000 miles. and its a ford.</p>
]]></description><link>https://fargostreet.com/post/281636</link><guid isPermaLink="true">https://fargostreet.com/post/281636</guid><dc:creator><![CDATA[Bp-08]]></dc:creator><pubDate>Fri, 06 Nov 2009 08:13:07 GMT</pubDate></item></channel></rss>
