<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[dead car...should be a simple fix??]]></title><description><![CDATA[<p dir="auto">Ok background first.....my blazer has been acting weird (what a suprise)....Every now and then when I punch it, it will cut out for a second then come back and work normal.  It has done that maybe 5 times in the last few weeks.  Today it did it again, but it wont come back.</p>
<p dir="auto">Current situation......car is in the parking lot.  When I turn the key it cranks, but wont start.  I can keep it cranking but nothing happens.  I have had suggestions to check the cap and rotor, the distributer cap, and the coil.  Any ideas?</p>
]]></description><link>https://fargostreet.com/topic/1875/dead-car...should-be-a-simple-fix</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 03:06:37 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/1875.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 09 Mar 2005 03:11:04 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to dead car...should be a simple fix?? on Thu, 10 Mar 2005 02:41:03 GMT]]></title><description><![CDATA[<p dir="auto">holy fucking shit....Nova was the only one right!</p>
]]></description><link>https://fargostreet.com/post/33894</link><guid isPermaLink="true">https://fargostreet.com/post/33894</guid><dc:creator><![CDATA[[[global:guest]]]]></dc:creator><pubDate>Thu, 10 Mar 2005 02:41:03 GMT</pubDate></item><item><title><![CDATA[Reply to dead car...should be a simple fix?? on Thu, 10 Mar 2005 02:11:10 GMT]]></title><description><![CDATA[<p dir="auto">well that is good news then.</p>
]]></description><link>https://fargostreet.com/post/33885</link><guid isPermaLink="true">https://fargostreet.com/post/33885</guid><dc:creator><![CDATA[[[global:guest]]]]></dc:creator><pubDate>Thu, 10 Mar 2005 02:11:10 GMT</pubDate></item><item><title><![CDATA[Reply to dead car...should be a simple fix?? on Thu, 10 Mar 2005 01:09:40 GMT]]></title><description><![CDATA[<p dir="auto">It was a fuse......fawk</p>
]]></description><link>https://fargostreet.com/post/33870</link><guid isPermaLink="true">https://fargostreet.com/post/33870</guid><dc:creator><![CDATA[jct_4628]]></dc:creator><pubDate>Thu, 10 Mar 2005 01:09:40 GMT</pubDate></item><item><title><![CDATA[Reply to dead car...should be a simple fix?? on Wed, 09 Mar 2005 21:48:18 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">jct_4628 wrote:<br />
1995....look at my sig hehehe</p>
<p dir="auto">no, it says that your bike is a 95..  not the blazer. <img src="https://fargostreet.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f609.png?v=40430adaedb" class="not-responsive emoji emoji-android emoji--wink" style="height:23px;width:auto;vertical-align:middle" title=";)" alt="😉" /></p>
]]></description><link>https://fargostreet.com/post/33816</link><guid isPermaLink="true">https://fargostreet.com/post/33816</guid><dc:creator><![CDATA[dubbsy]]></dc:creator><pubDate>Wed, 09 Mar 2005 21:48:18 GMT</pubDate></item><item><title><![CDATA[Reply to dead car...should be a simple fix?? on Wed, 09 Mar 2005 21:14:29 GMT]]></title><description><![CDATA[<p dir="auto">Check Ur Fuses Allmost All Chevys Have A Main Engine Fuses That Will Let It Crank And Crank And Not Fire Up</p>
]]></description><link>https://fargostreet.com/post/33811</link><guid isPermaLink="true">https://fargostreet.com/post/33811</guid><dc:creator><![CDATA[My NOva]]></dc:creator><pubDate>Wed, 09 Mar 2005 21:14:29 GMT</pubDate></item><item><title><![CDATA[Reply to dead car...should be a simple fix?? on Wed, 09 Mar 2005 20:43:18 GMT]]></title><description><![CDATA[<p dir="auto">you can also spray some starting fluid in the intake if it fires you have a fuel problem. also check out <a href="http://blazinlow.com/" rel="nofollow ugc">http://blazinlow.com/</a></p>
]]></description><link>https://fargostreet.com/post/33807</link><guid isPermaLink="true">https://fargostreet.com/post/33807</guid><dc:creator><![CDATA[fanaticrockford]]></dc:creator><pubDate>Wed, 09 Mar 2005 20:43:18 GMT</pubDate></item><item><title><![CDATA[Reply to dead car...should be a simple fix?? on Wed, 09 Mar 2005 19:56:33 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">jake wrote:<br />
Again, what year is your Blazer?  I'm assuming 4.3 V6.  Vortec or TBI?</p>
<p dir="auto">Jake1995....look at my sig hehehe</p>
]]></description><link>https://fargostreet.com/post/33803</link><guid isPermaLink="true">https://fargostreet.com/post/33803</guid><dc:creator><![CDATA[jct_4628]]></dc:creator><pubDate>Wed, 09 Mar 2005 19:56:33 GMT</pubDate></item><item><title><![CDATA[Reply to dead car...should be a simple fix?? on Wed, 09 Mar 2005 18:56:22 GMT]]></title><description><![CDATA[<p dir="auto">Again, what year is your Blazer?  I'm assuming 4.3 V6.  Vortec or TBI?</p>
<p dir="auto">You should hear your fuel pump (a little whining noise in the fuel tank).  The pump should run for a few seconds when you first turn on the key, and then go again after cranking for a while.  If you want to check the fuel pressure, there should be a schrader valve (looks like a tire valve stem) on the fuel rail up by the injectors.  If you don't have a fuel pressure gage, you can put a rag over the valve and poke the center with a screwdriver.  It will squirt like crazy if there's any fuel pressure in the system.</p>
<p dir="auto">Jake</p>
]]></description><link>https://fargostreet.com/post/33789</link><guid isPermaLink="true">https://fargostreet.com/post/33789</guid><dc:creator><![CDATA[jake]]></dc:creator><pubDate>Wed, 09 Mar 2005 18:56:22 GMT</pubDate></item><item><title><![CDATA[Reply to dead car...should be a simple fix?? on Wed, 09 Mar 2005 16:05:56 GMT]]></title><description><![CDATA[<p dir="auto">thats a chevy engine for ya....pretty sure ur not gettin any fuel tho.....bring it to a shop.</p>
]]></description><link>https://fargostreet.com/post/33742</link><guid isPermaLink="true">https://fargostreet.com/post/33742</guid><dc:creator><![CDATA[[[global:guest]]]]></dc:creator><pubDate>Wed, 09 Mar 2005 16:05:56 GMT</pubDate></item><item><title><![CDATA[Reply to dead car...should be a simple fix?? on Wed, 09 Mar 2005 15:06:35 GMT]]></title><description><![CDATA[<p dir="auto">so I just went out (9:00 am) to check if I had spark.  As far as I can tell all my plugs are right between the engine and the firewall.  So I cant even fucking get my hand back there to get the plug wires off.  Why the fuck did I take a job that depends on my pos?  Any ideas fs?</p>
]]></description><link>https://fargostreet.com/post/33720</link><guid isPermaLink="true">https://fargostreet.com/post/33720</guid><dc:creator><![CDATA[jct_4628]]></dc:creator><pubDate>Wed, 09 Mar 2005 15:06:35 GMT</pubDate></item><item><title><![CDATA[Reply to dead car...should be a simple fix?? on Wed, 09 Mar 2005 13:41:35 GMT]]></title><description><![CDATA[<p dir="auto">so, how do I tell if its the fuel pump?  And if it is, do you all think you could talk me through a home replacement?  I need my car for work, so please respond fast!  You guys rule!</p>
]]></description><link>https://fargostreet.com/post/33704</link><guid isPermaLink="true">https://fargostreet.com/post/33704</guid><dc:creator><![CDATA[jct_4628]]></dc:creator><pubDate>Wed, 09 Mar 2005 13:41:35 GMT</pubDate></item><item><title><![CDATA[Reply to dead car...should be a simple fix?? on Wed, 09 Mar 2005 05:49:11 GMT]]></title><description><![CDATA[<p dir="auto">I had the same thing happen to my Blazer and it was the fuel pump going out.  It isn't that bad for it to be fixed mine costed $600 because I got a whole new gas tank at the same time.</p>
]]></description><link>https://fargostreet.com/post/33679</link><guid isPermaLink="true">https://fargostreet.com/post/33679</guid><dc:creator><![CDATA[[[global:guest]]]]></dc:creator><pubDate>Wed, 09 Mar 2005 05:49:11 GMT</pubDate></item><item><title><![CDATA[Reply to dead car...should be a simple fix?? on Wed, 09 Mar 2005 05:38:44 GMT]]></title><description><![CDATA[<blockquote>
700-800 .....yeah right go buy a AC Delco Fuel pump and have it installed somehwere else..</p>
<p dir="auto">The guy that bought my blazer had the pump go out and it cost him $7xx.00 some bucks for the OEM as I stated.</p>
<p dir="auto">I've priced out the pumps before I really don't think you're gonna do it for under 500 bucks parts and labor.  BUT, who knows if that is even the issue.</p>
]]></description><link>https://fargostreet.com/post/33677</link><guid isPermaLink="true">https://fargostreet.com/post/33677</guid><dc:creator><![CDATA[btleier]]></dc:creator><pubDate>Wed, 09 Mar 2005 05:38:44 GMT</pubDate></item><item><title><![CDATA[Reply to dead car...should be a simple fix?? on Wed, 09 Mar 2005 04:51:59 GMT]]></title><description><![CDATA[<p dir="auto">What year Blazer is it?</p>
<p dir="auto">Check to see if you have spark, and listen to hear if your fuel pump is running when you turn the key on</p>
<p dir="auto">My first guess would be the ignition module (under the dist. cap and rotor ~ new for around $30-$40)</p>
<p dir="auto">They usually cut out temporarily at high loads or high RPM (due to heat), and eventually go out totally</p>
]]></description><link>https://fargostreet.com/post/33670</link><guid isPermaLink="true">https://fargostreet.com/post/33670</guid><dc:creator><![CDATA[jake]]></dc:creator><pubDate>Wed, 09 Mar 2005 04:51:59 GMT</pubDate></item><item><title><![CDATA[Reply to dead car...should be a simple fix?? on Wed, 09 Mar 2005 04:29:02 GMT]]></title><description><![CDATA[<p dir="auto">700-800 .....yeah right go buy a AC Delco Fuel pump and have it installed somehwere else..</p>
]]></description><link>https://fargostreet.com/post/33667</link><guid isPermaLink="true">https://fargostreet.com/post/33667</guid><dc:creator><![CDATA[[[global:guest]]]]></dc:creator><pubDate>Wed, 09 Mar 2005 04:29:02 GMT</pubDate></item><item><title><![CDATA[Reply to dead car...should be a simple fix?? on Wed, 09 Mar 2005 04:01:28 GMT]]></title><description><![CDATA[<p dir="auto">blazers are notorious for fuel pumps going out after 100k......  say your prayers cause you're gonna spend 700-800 bucks if you have the dealership replace with an oem pump.</p>
]]></description><link>https://fargostreet.com/post/33658</link><guid isPermaLink="true">https://fargostreet.com/post/33658</guid><dc:creator><![CDATA[btleier]]></dc:creator><pubDate>Wed, 09 Mar 2005 04:01:28 GMT</pubDate></item><item><title><![CDATA[Reply to dead car...should be a simple fix?? on Wed, 09 Mar 2005 03:26:27 GMT]]></title><description><![CDATA[<p dir="auto">yeah sounds like something with the FPR ( fuel pressure regulator)</p>
]]></description><link>https://fargostreet.com/post/33656</link><guid isPermaLink="true">https://fargostreet.com/post/33656</guid><dc:creator><![CDATA[[[global:guest]]]]></dc:creator><pubDate>Wed, 09 Mar 2005 03:26:27 GMT</pubDate></item><item><title><![CDATA[Reply to dead car...should be a simple fix?? on Wed, 09 Mar 2005 03:18:54 GMT]]></title><description><![CDATA[<p dir="auto">besides those i'd make sure it's getting gas</p>
]]></description><link>https://fargostreet.com/post/33653</link><guid isPermaLink="true">https://fargostreet.com/post/33653</guid><dc:creator><![CDATA[legacy-user-131]]></dc:creator><pubDate>Wed, 09 Mar 2005 03:18:54 GMT</pubDate></item></channel></rss>
