<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[(2) 12&amp;quot; Kicker Comps + Vibe Amp]]></title><description><![CDATA[<p dir="auto">I got 2 12" kicker comps with a 1000 watt Vibe amp</p>
<p dir="auto">It is a bridgeable 2 channel amp<br />
Fully adjustable high/low pass crossover</p>
<p dir="auto">150$ for it all</p>
<p dir="auto">Still hooked up so you can come listen to before buying.</p>
<p dir="auto"><img src="/assets/uploads/legacy/attachments/6167/Amp%201.jpg" alt="Amp 1.jpg" class=" img-fluid img-markdown" /><br />
<img src="/assets/uploads/legacy/attachments/6168/amp%202.jpg" alt="amp 2.jpg" class=" img-fluid img-markdown" /><br />
<img src="/assets/uploads/legacy/attachments/6169/subs%201.jpg" alt="subs 1.jpg" class=" img-fluid img-markdown" /><br />
<img src="/assets/uploads/legacy/attachments/6170/subs%202.jpg" alt="subs 2.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://fargostreet.com/topic/18973/2-12-quot-kicker-comps-vibe-amp</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 03:17:57 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/18973.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 05 Apr 2010 22:15:31 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to (2) 12&amp;quot; Kicker Comps + Vibe Amp on Tue, 06 Apr 2010 14:44:43 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">Bp-08;305325 wrote:<br />
how many 15 amp fuses<br />
It comes with 2X15amp fuses. That equates to roughly 300 watts.</p>
]]></description><link>https://fargostreet.com/post/293708</link><guid isPermaLink="true">https://fargostreet.com/post/293708</guid><dc:creator><![CDATA[weshole]]></dc:creator><pubDate>Tue, 06 Apr 2010 14:44:43 GMT</pubDate></item><item><title><![CDATA[Reply to (2) 12&amp;quot; Kicker Comps + Vibe Amp on Tue, 06 Apr 2010 12:31:31 GMT]]></title><description><![CDATA[<p dir="auto">how many 15 amp fuses</p>
]]></description><link>https://fargostreet.com/post/293702</link><guid isPermaLink="true">https://fargostreet.com/post/293702</guid><dc:creator><![CDATA[Bp-08]]></dc:creator><pubDate>Tue, 06 Apr 2010 12:31:31 GMT</pubDate></item><item><title><![CDATA[Reply to (2) 12&amp;quot; Kicker Comps + Vibe Amp on Tue, 06 Apr 2010 10:22:51 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">torbs;305310 wrote:<br />
How many Amps worth of fuses the amplifier got?</p>
<pre><code>* 2 x 200 Watts RMS at 4 Ohms
* 2 x 500 Watts Max at 4 Ohms
* 1 x 800 Watts Max at 4 Ohms Bridged
* 2 x 375 Watts at 2 Ohms
* MOSFET Switches Maintain Rated Power Over A Wide Range of Battery Voltages
* Stiffly Regulated PWM-Type Power Supplies
* Variable Input Level Controls for Each Pair of Cannels
* Variable High &amp; Low Pass Crossover Controls
* High-Efficiency, Heavy Aluminum Heatsink
* Remote Subwoofer Bass Control
* Electronic Crossover Network
* Bass Boost Circuit
* Bridgeable at 4 Ohms
* 2 Ohm Stereo Stable
* Tri-Mode Capable
* Gold RCA Inputs
* Line Outs for Left &amp; Right Channels
* Power &amp; Protection LED Indicators
* Advanced Protection Circuitry
* Soft Turn On/Off
* Frequency Response: 15 Hz-35 kHz
* S/N Ratio: 90 dB
* Dimensions: 10.25"W x 2"H x 15"L
</code></pre>
<p dir="auto">15amps fuses, and i read in forums that a lot of people put 30 amps fuses in them.</p>
]]></description><link>https://fargostreet.com/post/293700</link><guid isPermaLink="true">https://fargostreet.com/post/293700</guid><dc:creator><![CDATA[00tibby00]]></dc:creator><pubDate>Tue, 06 Apr 2010 10:22:51 GMT</pubDate></item><item><title><![CDATA[Reply to (2) 12&amp;quot; Kicker Comps + Vibe Amp on Tue, 06 Apr 2010 10:14:23 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">Parker;305316 wrote:<br />
So is this the amp and subs that were supposed to be in that car I bought? Huh?</p>
<p dir="auto">nope, the guy previously that had the car must have took the subs and amp, you did buy it for 500 less then the asking price, reasonable to me he said as is, and you said ok.</p>
]]></description><link>https://fargostreet.com/post/293699</link><guid isPermaLink="true">https://fargostreet.com/post/293699</guid><dc:creator><![CDATA[00tibby00]]></dc:creator><pubDate>Tue, 06 Apr 2010 10:14:23 GMT</pubDate></item><item><title><![CDATA[Reply to (2) 12&amp;quot; Kicker Comps + Vibe Amp on Tue, 06 Apr 2010 05:40:55 GMT]]></title><description><![CDATA[<p dir="auto">So is this the amp and subs that were supposed to be in that car I bought? Huh?</p>
]]></description><link>https://fargostreet.com/post/293693</link><guid isPermaLink="true">https://fargostreet.com/post/293693</guid><dc:creator><![CDATA[Parker]]></dc:creator><pubDate>Tue, 06 Apr 2010 05:40:55 GMT</pubDate></item><item><title><![CDATA[Reply to (2) 12&amp;quot; Kicker Comps + Vibe Amp on Tue, 06 Apr 2010 05:20:14 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">i will check and get back to that tomorrow.</p>
]]></description><link>https://fargostreet.com/post/293692</link><guid isPermaLink="true">https://fargostreet.com/post/293692</guid><dc:creator><![CDATA[00tibby00]]></dc:creator><pubDate>Tue, 06 Apr 2010 05:20:14 GMT</pubDate></item><item><title><![CDATA[Reply to (2) 12&amp;quot; Kicker Comps + Vibe Amp on Tue, 06 Apr 2010 03:30:46 GMT]]></title><description><![CDATA[<p dir="auto">How many Amps worth of fuses the amplifier got?</p>
]]></description><link>https://fargostreet.com/post/293687</link><guid isPermaLink="true">https://fargostreet.com/post/293687</guid><dc:creator><![CDATA[torbs]]></dc:creator><pubDate>Tue, 06 Apr 2010 03:30:46 GMT</pubDate></item></channel></rss>
