<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Devils Own Water&#x2F;Meth Injection Kit]]></title><description><![CDATA[<p dir="auto">I bought this kit for a snowmobile I had, but I sold it so I have no use for this kit anymore.  I bought the kit used and was told it was installed, but fluid has never been through it.  I hooked the pump up to a battery and verified that it spins over.</p>
<p dir="auto">The kit consists of:<br />
150 PSI Pump<br />
Check Valve<br />
Elbow<br />
M12 Jet with Seal<br />
Fuse Holder<br />
Relay<br />
Boost Switch<br />
Fitting to connect to tank<br />
Some Pressure and Vacuum Line</p>
<p dir="auto">It is basically this kit, but I believe it is the older 150 psi pump and it does not have the self sealing tank fitting. <a href="http://www.alcohol-injection.com/universal-stage-1-8.html" rel="nofollow ugc">http://www.alcohol-injection.com/universal-stage-1-8.html</a></p>
<p dir="auto">I also ordered some other jets from McMaster Carr, but the filters seem to be too long to screw into the elbow.  They will be included, so if you can get them to work you're golden.  Sizes are M2, M3, M4, M5</p>
<p dir="auto">I am looking to get $130 for it.  PM if interested.</p>
<p dir="auto"><img src="/assets/uploads/legacy/attachments/6175/IMGP5944.jpg" alt="IMGP5944.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://fargostreet.com/topic/18983/devils-own-water-meth-injection-kit</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 01:46:11 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/18983.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 06 Apr 2010 17:17:39 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Devils Own Water&#x2F;Meth Injection Kit on Wed, 28 Apr 2010 15:25:33 GMT]]></title><description><![CDATA[<p dir="auto">Now on ebay: <a href="http://cgi.ebay.com/ebaymotors/Devils-Own-Alcohol-Water-Methanol-Kit-Stage-1-_W0QQcmdZViewItemQQhashZitem2eacb63db2QQitemZ200466120114QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories" rel="nofollow ugc">http://cgi.ebay.com/ebaymotors/Devils-Own-Alcohol-Water-Methanol-Kit-Stage-1-_W0QQcmdZViewItemQQhashZitem2eacb63db2QQitemZ200466120114QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories</a></p>
]]></description><link>https://fargostreet.com/post/295622</link><guid isPermaLink="true">https://fargostreet.com/post/295622</guid><dc:creator><![CDATA[awd95mn]]></dc:creator><pubDate>Wed, 28 Apr 2010 15:25:33 GMT</pubDate></item></channel></rss>
