<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Amp Help?]]></title><description><![CDATA[<p dir="auto">C:\Documents and Settings\jacobwishinsky\Desktop\Current (How my sub is wired now).mht</p>
<p dir="auto">Lets try this? I need to wire a RE audio sx15" D4 to a 4 channel amp? Any way?</p>
]]></description><link>https://fargostreet.com/topic/19180/amp-help</link><generator>RSS for Node</generator><lastBuildDate>Wed, 27 May 2026 22:40:22 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/19180.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 10 May 2010 20:00:51 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Amp Help? on Sun, 06 Jun 2010 20:06:00 GMT]]></title><description><![CDATA[<p dir="auto"><a href="http://www.crutchfield.com/S-lePPiWvmUon/learn/learningcenter/car/subwoofers_wiring.html" rel="nofollow ugc">http://www.crutchfield.com/S-lePPiWvmUon/learn/learningcenter/car/subwoofers_wiring.html</a></p>
]]></description><link>https://fargostreet.com/post/299998</link><guid isPermaLink="true">https://fargostreet.com/post/299998</guid><dc:creator><![CDATA[theoblivious]]></dc:creator><pubDate>Sun, 06 Jun 2010 20:06:00 GMT</pubDate></item><item><title><![CDATA[Reply to Amp Help? on Tue, 11 May 2010 21:04:11 GMT]]></title><description><![CDATA[<p dir="auto">Hey chuck is there a way to test my amp. I just feel like the front bridge channels arn't putting out the same watts compared to the rear bridge channels.</p>
]]></description><link>https://fargostreet.com/post/297563</link><guid isPermaLink="true">https://fargostreet.com/post/297563</guid><dc:creator><![CDATA[wishinsky]]></dc:creator><pubDate>Tue, 11 May 2010 21:04:11 GMT</pubDate></item><item><title><![CDATA[Reply to Amp Help? on Tue, 11 May 2010 04:51:40 GMT]]></title><description><![CDATA[<p dir="auto">Yeah...I am going to sell all this stuff and start over fresh. It's always nice knowing your the original owner. Well after i get a couple paychecks in my wallet when school gets out (20th) i will hopefully be able to give you a a good grand, grand and a half or so. And we can figure out a really good setup to put in the stang.</p>
]]></description><link>https://fargostreet.com/post/297528</link><guid isPermaLink="true">https://fargostreet.com/post/297528</guid><dc:creator><![CDATA[wishinsky]]></dc:creator><pubDate>Tue, 11 May 2010 04:51:40 GMT</pubDate></item><item><title><![CDATA[Reply to Amp Help? on Tue, 11 May 2010 02:02:06 GMT]]></title><description><![CDATA[<p dir="auto">I'll hook you up should you decide to sell off and start over.</p>
]]></description><link>https://fargostreet.com/post/297507</link><guid isPermaLink="true">https://fargostreet.com/post/297507</guid><dc:creator><![CDATA[Trafik Jamz]]></dc:creator><pubDate>Tue, 11 May 2010 02:02:06 GMT</pubDate></item><item><title><![CDATA[Reply to Amp Help? on Tue, 11 May 2010 02:01:46 GMT]]></title><description><![CDATA[<p dir="auto">do what you want man...its your stuff.</p>
]]></description><link>https://fargostreet.com/post/297506</link><guid isPermaLink="true">https://fargostreet.com/post/297506</guid><dc:creator><![CDATA[Trafik Jamz]]></dc:creator><pubDate>Tue, 11 May 2010 02:01:46 GMT</pubDate></item><item><title><![CDATA[Reply to Amp Help? on Mon, 10 May 2010 22:33:39 GMT]]></title><description><![CDATA[<p dir="auto">Yeah and my Type R's i had in a parallel series.... Well this sub don't fit in the car anyways so if i sell it do you recommend me selling the amp to and buying all new again? Or should i keep the amp and just get 2 subs so i can use both the bridged channels? Cuz i will probably buy some 8's or 10's from you once i start working full time in a week.</p>
]]></description><link>https://fargostreet.com/post/297483</link><guid isPermaLink="true">https://fargostreet.com/post/297483</guid><dc:creator><![CDATA[wishinsky]]></dc:creator><pubDate>Mon, 10 May 2010 22:33:39 GMT</pubDate></item><item><title><![CDATA[Reply to Amp Help? on Mon, 10 May 2010 22:25:56 GMT]]></title><description><![CDATA[<p dir="auto">Dual 2 ohm sub IIRC.  The amp probably doesn't like being @ 2 ohm mono on that sub (they tend to stay pretty low in their impedance, especially the way that box is designed)...the Type R's you had before probably didn't run that low which is why they worked.....</p>
]]></description><link>https://fargostreet.com/post/297481</link><guid isPermaLink="true">https://fargostreet.com/post/297481</guid><dc:creator><![CDATA[Trafik Jamz]]></dc:creator><pubDate>Mon, 10 May 2010 22:25:56 GMT</pubDate></item><item><title><![CDATA[Reply to Amp Help? on Mon, 10 May 2010 22:21:38 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">Trafik Jamz;309100 wrote:<br />
<strong>Bridge Channels 1&amp;2 together and hook them up to ONE voice coil<br />
Bridge Channels 3%4 together and hook them up to the other voice coil</strong></p>
<p dir="auto">Set gains EXACTLY the same on each (no higher than 2/3 of max...EVER) ...set Low Pass Filter to ~90hz</p>
<p dir="auto">When i do what you said above it kicks my amp into protect once i turn the volume up and it ain't even loud....i am at like 1/3 gain.</p>
]]></description><link>https://fargostreet.com/post/297480</link><guid isPermaLink="true">https://fargostreet.com/post/297480</guid><dc:creator><![CDATA[wishinsky]]></dc:creator><pubDate>Mon, 10 May 2010 22:21:38 GMT</pubDate></item><item><title><![CDATA[Reply to Amp Help? on Mon, 10 May 2010 22:18:30 GMT]]></title><description><![CDATA[<p dir="auto">yeah, i was at school and having troubles. It said the pic was to big as well.</p>
<p dir="auto">I am just wondering if there is any way to use all the channels on that amp i bought from you and using only 1 sub.</p>
]]></description><link>https://fargostreet.com/post/297479</link><guid isPermaLink="true">https://fargostreet.com/post/297479</guid><dc:creator><![CDATA[wishinsky]]></dc:creator><pubDate>Mon, 10 May 2010 22:18:30 GMT</pubDate></item><item><title><![CDATA[Reply to Amp Help? on Mon, 10 May 2010 22:17:00 GMT]]></title><description><![CDATA[<p dir="auto">Bridge Channels 1&amp;2 together and hook them up to ONE voice coil<br />
Bridge Channels 3%4 together and hook them up to the other voice coil</p>
]]></description><link>https://fargostreet.com/post/297477</link><guid isPermaLink="true">https://fargostreet.com/post/297477</guid><dc:creator><![CDATA[Trafik Jamz]]></dc:creator><pubDate>Mon, 10 May 2010 22:17:00 GMT</pubDate></item><item><title><![CDATA[Reply to Amp Help? on Mon, 10 May 2010 22:15:06 GMT]]></title><description><![CDATA[<p dir="auto">Learn how to post pics....then I'll help.</p>
]]></description><link>https://fargostreet.com/post/297476</link><guid isPermaLink="true">https://fargostreet.com/post/297476</guid><dc:creator><![CDATA[Trafik Jamz]]></dc:creator><pubDate>Mon, 10 May 2010 22:15:06 GMT</pubDate></item></channel></rss>
