<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Shop?]]></title><description><![CDATA[<p dir="auto">I have a '65 mustang with a 4.7 L 289 that is having some issues. Meaning, it completely lost its balls. I have taken it to at least 3 different mechanics in fargo and it has not gotten any better. Ford helped a little bit, but I still have trouble getting to 65MPH or breaking the rear end loose at all.</p>
<p dir="auto">Does anyone know a good place to take it who would know about classic V8s? It isn't really that modified, just has a new cooling system, headers, shelby style side exit exhaust, an edelbrock hi-rise intake manifold, and a holley 650 carb, if that helps at all.  I'm kind of sick of not being able to drive it how I want to.</p>
]]></description><link>https://fargostreet.com/topic/19201/shop</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 01:09:31 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/19201.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 13 May 2010 15:20:56 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Shop? on Thu, 13 May 2010 22:24:53 GMT]]></title><description><![CDATA[<p dir="auto">If its still intact (all original) internally, theres a good chance that the unleaded low octane fuel has done a number on your valve seats. They are soft and get beat to shit with the hot temps todays low octane creates in your combustion chamber. That "could" explain the loss of power over time. Worn camshaft could as well. It would be interesting to see your set up to determine your issue.</p>
]]></description><link>https://fargostreet.com/post/297806</link><guid isPermaLink="true">https://fargostreet.com/post/297806</guid><dc:creator><![CDATA[weshole]]></dc:creator><pubDate>Thu, 13 May 2010 22:24:53 GMT</pubDate></item><item><title><![CDATA[Reply to Shop? on Thu, 13 May 2010 22:10:37 GMT]]></title><description><![CDATA[<p dir="auto">Check the compression and turn down the fuel a little bit</p>
]]></description><link>https://fargostreet.com/post/297803</link><guid isPermaLink="true">https://fargostreet.com/post/297803</guid><dc:creator><![CDATA[PSiedTSi]]></dc:creator><pubDate>Thu, 13 May 2010 22:10:37 GMT</pubDate></item><item><title><![CDATA[Reply to Shop? on Thu, 13 May 2010 19:46:03 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">Bp-08;309406 wrote:<br />
Thats your problem, but really I think your running her a little rich.<br />
I know it's a small engine, but it has gotten significantly worse. I just wanted it back to normal.</p>
<p dir="auto">And yes. I am sure that the 650 is a bit big. But that was what I installed when I was 16, so that is what I have to work with.</p>
<p dir="auto">Ruthless351, If you have the time, I would greatly appreciate if you took a look at it. If that is the problem, tuning would save me a lot of money and time. Or if you know a place to take it to get tuned, that would work as well.</p>
]]></description><link>https://fargostreet.com/post/297788</link><guid isPermaLink="true">https://fargostreet.com/post/297788</guid><dc:creator><![CDATA[NDSUEm2]]></dc:creator><pubDate>Thu, 13 May 2010 19:46:03 GMT</pubDate></item><item><title><![CDATA[Reply to Shop? on Thu, 13 May 2010 18:49:23 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">NDSUEm2;309372 wrote:<br />
I have a '65 mustang with a** 4.7 L 289** that is having some issues. Meaning, it completely lost its balls. I have taken it to at least 3 different mechanics in fargo and it has not gotten any better. Ford helped a little bit, but I still have trouble getting to 65MPH or breaking the rear end loose at all.</p>
<p dir="auto">Thats your problem, but really I think your running her a little rich.</p>
]]></description><link>https://fargostreet.com/post/297783</link><guid isPermaLink="true">https://fargostreet.com/post/297783</guid><dc:creator><![CDATA[Bp-08]]></dc:creator><pubDate>Thu, 13 May 2010 18:49:23 GMT</pubDate></item><item><title><![CDATA[Reply to Shop? on Thu, 13 May 2010 18:42:34 GMT]]></title><description><![CDATA[<p dir="auto">Talk to Mike (Wa2fastcamaro), i think thats his screen name still.  Hes good with old v8's maybe he can help you out.</p>
]]></description><link>https://fargostreet.com/post/297777</link><guid isPermaLink="true">https://fargostreet.com/post/297777</guid><dc:creator><![CDATA[CivicEX7777777]]></dc:creator><pubDate>Thu, 13 May 2010 18:42:34 GMT</pubDate></item><item><title><![CDATA[Reply to Shop? on Thu, 13 May 2010 17:50:07 GMT]]></title><description><![CDATA[<p dir="auto">I've played with some carbed mustangs before. Dont you think a 650 is kinda big for that set up?</p>
]]></description><link>https://fargostreet.com/post/297765</link><guid isPermaLink="true">https://fargostreet.com/post/297765</guid><dc:creator><![CDATA[ruthless351]]></dc:creator><pubDate>Thu, 13 May 2010 17:50:07 GMT</pubDate></item><item><title><![CDATA[Reply to Shop? on Thu, 13 May 2010 15:32:07 GMT]]></title><description><![CDATA[<p dir="auto">not using points, I am not sure about the carb work because it has been in and out of shops, but I kind of doubt it. The carb works well enough to drive it and that's about it. I also doubt that the valves have been adjusted, but I don't have any idea. I'm just running 87 pump gas and running seafoam through it every once in a while.</p>
<p dir="auto">Other problems that came to mind- mild leak between the water pump and thermostat and the black. I also usually go through at least one starter solenoid a summer.</p>
]]></description><link>https://fargostreet.com/post/297752</link><guid isPermaLink="true">https://fargostreet.com/post/297752</guid><dc:creator><![CDATA[NDSUEm2]]></dc:creator><pubDate>Thu, 13 May 2010 15:32:07 GMT</pubDate></item><item><title><![CDATA[Reply to Shop? on Thu, 13 May 2010 15:24:09 GMT]]></title><description><![CDATA[<p dir="auto">Any carb work lately, what fuel are you using, adjusted valves, points distributor?</p>
]]></description><link>https://fargostreet.com/post/297751</link><guid isPermaLink="true">https://fargostreet.com/post/297751</guid><dc:creator><![CDATA[Bookem]]></dc:creator><pubDate>Thu, 13 May 2010 15:24:09 GMT</pubDate></item></channel></rss>
