<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Help please!!!]]></title><description><![CDATA[<p dir="auto">Alright, i have a 1996 nissan 200sx that has never given me any engine trouble until now. The car trouble started out as overheating, which i quickly discovered to be the thermostat. It ran fine for about a day, then it started throwing 4 differnt codes, one was a coolant temp. sensor, tested it was bad so i replaced it, the second was a knock sensor, tested it it was just loose, 3rd is a maf sensor/circuit, checked it everything was fine, 4th is the IACV/AAC valve. The engine also surges when holding the accelerator steady. I checked the EAG valve and t seemed to be working fine, car smells like its running very lean, which makes me think its either a fuel delivery problem, or a vacuum leak. or possibly both. Anyone have any input for me cause im at a complete loss. Thank you.</p>
]]></description><link>https://fargostreet.com/topic/19258/help-please</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 17:46:07 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/19258.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 24 May 2010 02:37:10 GMT</pubDate><ttl>60</ttl></channel></rss>
