<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[TPMS sensors]]></title><description><![CDATA[<p dir="auto">I bought some wheels that came with these TPMS sensors they worked for about a month but then the error light started flashing, anyone ever deal with these things before, they are specifically  for a Nissan Altima, has anyone  ever heard anything about resetting these? Or should i just let em go on ebay?</p>
]]></description><link>https://fargostreet.com/topic/19267/tpms-sensors</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 12:28:10 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/19267.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 25 May 2010 02:56:15 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to TPMS sensors on Thu, 03 Jun 2010 17:52:10 GMT]]></title><description><![CDATA[<p dir="auto">Ahh man, should have checked this yesterday, I just had the wheels remounted..should have mentioned it...they looked ok, but we all know how that works, should turn out ok, going to try and reset them today</p>
]]></description><link>https://fargostreet.com/post/299675</link><guid isPermaLink="true">https://fargostreet.com/post/299675</guid><dc:creator><![CDATA[Mazdaboy]]></dc:creator><pubDate>Thu, 03 Jun 2010 17:52:10 GMT</pubDate></item><item><title><![CDATA[Reply to TPMS sensors on Thu, 27 May 2010 23:37:20 GMT]]></title><description><![CDATA[<p dir="auto">One thing that I just ran into was a Honda where the TMPS went off roughly a month after ownership of the aftermarket wheels. The sensors themselves went bad...well, 4 sensors later (and a couple years later) we determined the wheels were actually leaking moisture, causing the sensors to corrode. Super rare, but ask them to check that while mounting just to be safe. By the time we figured it out, it was past warranty for the rims.</p>
]]></description><link>https://fargostreet.com/post/299077</link><guid isPermaLink="true">https://fargostreet.com/post/299077</guid><dc:creator><![CDATA[Sven]]></dc:creator><pubDate>Thu, 27 May 2010 23:37:20 GMT</pubDate></item><item><title><![CDATA[Reply to TPMS sensors on Wed, 26 May 2010 21:10:09 GMT]]></title><description><![CDATA[<p dir="auto">Nope actually, most places will do that kind of thing anyway when mounting new tires, its nescessary when doing rotations.</p>
]]></description><link>https://fargostreet.com/post/299004</link><guid isPermaLink="true">https://fargostreet.com/post/299004</guid><dc:creator><![CDATA[capitlj]]></dc:creator><pubDate>Wed, 26 May 2010 21:10:09 GMT</pubDate></item><item><title><![CDATA[Reply to TPMS sensors on Wed, 26 May 2010 17:28:52 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">capitlj;310470 wrote:<br />
There isn't that many different sensors so I think the ones you have will work with your car however if you never had them programmed that's what the error is.  It requires a special tool but pretty much any tire shop should be able to make short work of that.</p>
<p dir="auto">Thanks, I was thinking this as well, I cant imagine that these things run on too many separate frequencies, when I get the tires remounted I'll ask around about them. They came with the wheel and tire set I bought used and since my car utilizes the function, There really isn't any disadvantage to put a little effort into getting the little things to work properly.</p>
]]></description><link>https://fargostreet.com/post/298975</link><guid isPermaLink="true">https://fargostreet.com/post/298975</guid><dc:creator><![CDATA[Mazdaboy]]></dc:creator><pubDate>Wed, 26 May 2010 17:28:52 GMT</pubDate></item><item><title><![CDATA[Reply to TPMS sensors on Tue, 25 May 2010 10:59:43 GMT]]></title><description><![CDATA[<p dir="auto">There isn't that many different sensors so I think the ones you have will work with your car however if you never had them programmed that's what the error is.  It requires a special tool but pretty much any tire shop should be able to make short work of that.</p>
]]></description><link>https://fargostreet.com/post/298847</link><guid isPermaLink="true">https://fargostreet.com/post/298847</guid><dc:creator><![CDATA[capitlj]]></dc:creator><pubDate>Tue, 25 May 2010 10:59:43 GMT</pubDate></item><item><title><![CDATA[Reply to TPMS sensors on Tue, 25 May 2010 04:28:38 GMT]]></title><description><![CDATA[<p dir="auto">You said they are specifically or a Nissan Altima so i assume you drive an altima as well.  If you dont then it's obvious why they aren't working...but yes, one has probably died or you need them reset...unfortunately for a Nissan you more then likely have to go to the dealer to have the sensors reset.</p>
]]></description><link>https://fargostreet.com/post/298838</link><guid isPermaLink="true">https://fargostreet.com/post/298838</guid><dc:creator><![CDATA[Puppet Master]]></dc:creator><pubDate>Tue, 25 May 2010 04:28:38 GMT</pubDate></item><item><title><![CDATA[Reply to TPMS sensors on Tue, 25 May 2010 03:35:07 GMT]]></title><description><![CDATA[<p dir="auto">If you have a blinking light this means 1 of 2 things bad sensor or you need to get one reprogrammed they can do this at any dealership</p>
]]></description><link>https://fargostreet.com/post/298834</link><guid isPermaLink="true">https://fargostreet.com/post/298834</guid><dc:creator><![CDATA[svxAL]]></dc:creator><pubDate>Tue, 25 May 2010 03:35:07 GMT</pubDate></item></channel></rss>
