<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MAPerformance Drag Evo &#x2F; 916whp 604wtq &#x2F; Stock ECU]]></title><description><![CDATA[<p dir="auto">Thought I would share with you guys what we accomplished at work today.  We are excited to have rebroken the record, but either way just a nasty Evo build.</p>
<hr />
<p dir="auto">It's been a long journey, but I believe we've reclaimed the highest horsepower stock ECU record <img src="https://fargostreet.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f642.png?v=40430adaedb" class="not-responsive emoji emoji-android emoji--slightly_smiling_face" style="height:23px;width:auto;vertical-align:middle" title=":)" alt="🙂" />  We don't expect this to last long as we've got some stiff competition out there, but this was only 37psi and although its cliche, there's a lot left in it <img src="https://fargostreet.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f609.png?v=40430adaedb" class="not-responsive emoji emoji-android emoji--wink" style="height:23px;width:auto;vertical-align:middle" title=";)" alt="😉" />  We'll be out at BIR this weekend to see what she can do (albeit on stock suspension and street tires for now), yet another reason to attend our <a href="http://forums.evolutionm.net/modern-automotive-performance/495504-maperformance-2nd-annual-sport-compact-proving-grounds-june-26-27-brainerd-mn.html" rel="nofollow ugc">Proving Grounds</a> event!</p>
<p dir="auto"><strong>Build Details</strong></p>
<p dir="auto">MAP Stage 2 2.4L Shortblock</p>
<ul>
<li>OEM 100mm Crankshaft</li>
<li>Wiseco HD Pistons</li>
<li>ACL Race Bearings</li>
<li>MAP Spec Howard's Rods<br />
MAP Stage 5 Cylinder Head<br />
GSC S3 Camshafts<br />
Fidanza Cam Gears<br />
Precision Turbo Billet 76mm Ball Bearing Turbocharger<br />
Speed Density with AEM 5 Bar (Special thanks to Scheides for all of your help!)<br />
Sparktech Coil on Plug<br />
AEM CDI Ignition Box / Wideband / Gauges<br />
ETS 5" Front Mount Intercooler<br />
Fuel Injector Clinic 2150cc Injectors (E98 Fuel)<br />
Magnus V5 Cast Intake Manifold &amp; Fuel Rail<br />
OEM replacement parts supplied by <a href="http://mitsubishiparts.net" rel="nofollow ugc">mitsubishiparts.net</a><br />
QuarterMaster Twin Plate Clutch (2010 Revised Version)<br />
Torque Solution Motor Mounts<br />
Mishimoto Aluminum Radiator<br />
Turbosmart Raceport BOV / 45mm Wastegates / eBoost2 / AFPR</li>
</ul>
<p dir="auto"><strong>Stock ECU Developers / Innovators</strong></p>
<p dir="auto">As always we can't say enough about how thankful we are to the stock ECU gurus that made this a possibility.  If I try to name all of you I will most certainly leave someone out unintentionally, so I hope that addressing the group as a whole will sufficiently convey our gratitude <img src="https://fargostreet.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f609.png?v=40430adaedb" class="not-responsive emoji emoji-android emoji--wink" style="height:23px;width:auto;vertical-align:middle" title=";)" alt="😉" />  If ever there is anything we can do to further advance the capabilities of the stock ECU please don't hesitate to let us know!</p>
<p dir="auto">Click the image below for a larger view!</p>
<p dir="auto"><a href="http://www.maperformance.com/products/misc/Evo_6-24-2010.jpg" rel="nofollow ugc"><img src="http://www.maperformance.com/products/misc/Evo_6-24-2010_sm.jpg" alt="legacy image" class=" img-fluid img-markdown" /></a></p>
<p dir="auto">Thank you to our sponsors, this wouldn't be possible without you!</p>
<p dir="auto"><img src="http://maperformance.com/marketing/acllogo.jpg" alt="legacy image" class=" img-fluid img-markdown" /><img src="http://maperformance.com/marketing/aemlogo.jpg" alt="legacy image" class=" img-fluid img-markdown" /><img src="http://maperformance.com/marketing/etslogo.jpg" alt="legacy image" class=" img-fluid img-markdown" /><br />
<img src="http://maperformance.com/marketing/ficlogo.jpg" alt="legacy image" class=" img-fluid img-markdown" /><img src="http://maperformance.com/marketing/fidanzalogo.jpg" alt="legacy image" class=" img-fluid img-markdown" /><img src="http://maperformance.com/marketing/gsclogo.jpg" alt="legacy image" class=" img-fluid img-markdown" /><br />
<img src="http://maperformance.com/marketing/howardscamslogo.jpg" alt="legacy image" class=" img-fluid img-markdown" /><img src="http://maperformance.com/marketing/magnuslogo.jpg" alt="legacy image" class=" img-fluid img-markdown" /><img src="http://maperformance.com/marketing/mishimotologo.jpg" alt="legacy image" class=" img-fluid img-markdown" /><br />
<img src="http://maperformance.com/marketing/brucetituslogo.jpg" alt="legacy image" class=" img-fluid img-markdown" /><img src="http://www.maperformance.com/marketing/precisionlogo.jpg" alt="legacy image" class=" img-fluid img-markdown" /><img src="http://www.maperformance.com/marketing/quartermasterlogo.jpg" alt="legacy image" class=" img-fluid img-markdown" /><br />
<img src="http://maperformance.com/marketing/sparktechlogo.jpg" alt="legacy image" class=" img-fluid img-markdown" /><img src="http://maperformance.com/marketing/torquesolutionlogo.jpg" alt="legacy image" class=" img-fluid img-markdown" /><img src="http://www.maperformance.com/marketing/turbosmartlogo.jpg" alt="legacy image" class=" img-fluid img-markdown" /><br />
<img src="http://maperformance.com/marketing/wisecologo.jpg" alt="legacy image" class=" img-fluid img-markdown" /></p>
]]></description><link>https://fargostreet.com/topic/19405/maperformance-drag-evo-916whp-604wtq-stock-ecu</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 01:11:30 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/19405.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 24 Jun 2010 22:57:09 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MAPerformance Drag Evo &#x2F; 916whp 604wtq &#x2F; Stock ECU on Mon, 28 Jun 2010 22:51:02 GMT]]></title><description><![CDATA[<p dir="auto">it didn't go any faster then what you saw.  we were on the phone today working on getting a trans coming.  still lots of work to go on this project.</p>
]]></description><link>https://fargostreet.com/post/301148</link><guid isPermaLink="true">https://fargostreet.com/post/301148</guid><dc:creator><![CDATA[btleier]]></dc:creator><pubDate>Mon, 28 Jun 2010 22:51:02 GMT</pubDate></item><item><title><![CDATA[Reply to MAPerformance Drag Evo &#x2F; 916whp 604wtq &#x2F; Stock ECU on Mon, 28 Jun 2010 22:22:17 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">btleier;312754 wrote:<br />
spinning.... obviously lots of kinks to work out.  right now still on tires not meant for the power, stock suspension.</p>
<p dir="auto">we definitely have some work to do yet.</p>
<p dir="auto">So what did it end up running?? I think i saw some low 11s, but not sure if it did better.</p>
]]></description><link>https://fargostreet.com/post/301147</link><guid isPermaLink="true">https://fargostreet.com/post/301147</guid><dc:creator><![CDATA[inspector01]]></dc:creator><pubDate>Mon, 28 Jun 2010 22:22:17 GMT</pubDate></item><item><title><![CDATA[Reply to MAPerformance Drag Evo &#x2F; 916whp 604wtq &#x2F; Stock ECU on Mon, 28 Jun 2010 16:55:22 GMT]]></title><description><![CDATA[<p dir="auto">spinning.... obviously lots of kinks to work out.  right now still on tires not meant for the power, stock suspension.</p>
]]></description><link>https://fargostreet.com/post/301129</link><guid isPermaLink="true">https://fargostreet.com/post/301129</guid><dc:creator><![CDATA[btleier]]></dc:creator><pubDate>Mon, 28 Jun 2010 16:55:22 GMT</pubDate></item><item><title><![CDATA[Reply to MAPerformance Drag Evo &#x2F; 916whp 604wtq &#x2F; Stock ECU on Mon, 28 Jun 2010 12:46:44 GMT]]></title><description><![CDATA[<p dir="auto">I saw the car make a pass on Sat, I couldn't tell if it was spinning when it came up on boost, or was the clutch slipping?</p>
]]></description><link>https://fargostreet.com/post/301123</link><guid isPermaLink="true">https://fargostreet.com/post/301123</guid><dc:creator><![CDATA[DaveH]]></dc:creator><pubDate>Mon, 28 Jun 2010 12:46:44 GMT</pubDate></item><item><title><![CDATA[Reply to MAPerformance Drag Evo &#x2F; 916whp 604wtq &#x2F; Stock ECU on Mon, 28 Jun 2010 11:53:27 GMT]]></title><description><![CDATA[<p dir="auto">wtb a ride, congrats</p>
]]></description><link>https://fargostreet.com/post/301120</link><guid isPermaLink="true">https://fargostreet.com/post/301120</guid><dc:creator><![CDATA[assasain]]></dc:creator><pubDate>Mon, 28 Jun 2010 11:53:27 GMT</pubDate></item><item><title><![CDATA[Reply to MAPerformance Drag Evo &#x2F; 916whp 604wtq &#x2F; Stock ECU on Fri, 25 Jun 2010 13:05:14 GMT]]></title><description><![CDATA[<p dir="auto">Congrats!  Looks stout.</p>
]]></description><link>https://fargostreet.com/post/301052</link><guid isPermaLink="true">https://fargostreet.com/post/301052</guid><dc:creator><![CDATA[DaveH]]></dc:creator><pubDate>Fri, 25 Jun 2010 13:05:14 GMT</pubDate></item><item><title><![CDATA[Reply to MAPerformance Drag Evo &#x2F; 916whp 604wtq &#x2F; Stock ECU on Fri, 25 Jun 2010 00:28:22 GMT]]></title><description><![CDATA[<p dir="auto">just saw the vid on facebook. thing is gonna be fun to see on saturday</p>
]]></description><link>https://fargostreet.com/post/301037</link><guid isPermaLink="true">https://fargostreet.com/post/301037</guid><dc:creator><![CDATA[Joel]]></dc:creator><pubDate>Fri, 25 Jun 2010 00:28:22 GMT</pubDate></item><item><title><![CDATA[Reply to MAPerformance Drag Evo &#x2F; 916whp 604wtq &#x2F; Stock ECU on Thu, 24 Jun 2010 23:01:26 GMT]]></title><description><![CDATA[<p dir="auto"><strong>Youtube Video</strong></p>
<p dir="auto">[ame="<a href="http://www.youtube.com/watch?v=m0eevGuvSFs" rel="nofollow ugc">http://www.youtube.com/watch?v=m0eevGuvSFs</a>"]<a href="http://www.youtube.com/watch?v=m0eevGuvSFs%5B/ame%5D" rel="nofollow ugc">http://www.youtube.com/watch?v=m0eevGuvSFs[/ame]</a></p>
]]></description><link>https://fargostreet.com/post/301030</link><guid isPermaLink="true">https://fargostreet.com/post/301030</guid><dc:creator><![CDATA[btleier]]></dc:creator><pubDate>Thu, 24 Jun 2010 23:01:26 GMT</pubDate></item></channel></rss>
