<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MAP BIR race]]></title><description><![CDATA[<p dir="auto">Getting ready for this race began on tuesday with a trip to Sioux Falls for a dyno session @ Speed Tech. A day and half later, my evo made 667 hp 530 TQ ( Yes, I said a day and half later...) After we unstrapped the car off the dyno I took it out and did a 1st-3rd gear rip and it spit and sputter. I said "F*** It, Ive been here too long and just dont care anymore" On thursday I took the care out and had to turn down the boost in order for it to run "OK"<br />
Come Saturday, I made many passes down the track starting with :<br />
11.5<br />
11.3<br />
11.2<br />
11.2<br />
11.1<br />
11.1</p>
<p dir="auto">I was given 2 warnings after about 6-7 runs for not having a cage. My main goal was to run 10's and that was not going to happen on that tuning.....There was no power. I then sought out Shane at DBperformance for some help he added NLTS (no lift to shift) and changed some other minor things to help make me reach my goal..I then met Scheides, an Evo ecu guru, who asked what my A/F ratio was " I said 10 to 1 " he then looked at my flash and said we needed to re-scale my injectors and some other minor quick changes. I then took him for a spin and he said "this should be good" My very next pass with out changing a thing went:<br />
1.752 60 foot Spining<br />
4.748<br />
71.57<br />
102.73 mph<br />
9.189<br />
10.888<br />
132.69 mph</p>
<p dir="auto">Right after that pass I was so pumped and knew I could make it run even quicker without turning up the boost..</p>
<p dir="auto">Next pass I NLTS ( no lifting the gas)</p>
<p dir="auto">1.743 60 spining<br />
4.635<br />
6.970<br />
107.76 mph<br />
8.983<br />
<strong>10.672</strong><br />
132.92</p>
<p dir="auto">I cant thank Shane and Scheides enough for the help!! he cut .5 sec off my time and gained 6 mph!:icon_salut:</p>
<p dir="auto">Now I wonder to myself how far off is 9.99? ... Maybe cage, slicks, 40psi boost...</p>
]]></description><link>https://fargostreet.com/topic/19415/map-bir-race</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 00:59:04 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/19415.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 28 Jun 2010 03:48:25 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MAP BIR race on Thu, 01 Jul 2010 03:43:47 GMT]]></title><description><![CDATA[<p dir="auto">yeah being a bigger power turbo car i would think it would pull ~35.... that is why i was curious if that was just a AWD thing or what</p>
<p dir="auto">regardless 130+ is moving good</p>
]]></description><link>https://fargostreet.com/post/301239</link><guid isPermaLink="true">https://fargostreet.com/post/301239</guid><dc:creator><![CDATA[zbrown]]></dc:creator><pubDate>Thu, 01 Jul 2010 03:43:47 GMT</pubDate></item><item><title><![CDATA[Reply to MAP BIR race on Wed, 30 Jun 2010 13:47:18 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">zbrown;312825 wrote:<br />
yeah slicks would drop you big time</p>
<p dir="auto">what i don't get is how come you are only pulling ~25mph the big end</p>
<p dir="auto">i would expect your 1/4 trap to be around 140 going off your 1/8</p>
<p dir="auto">is that what AWD or the evo gearing does??</p>
<p dir="auto">ha, and i am not ripping, just curious why that is <img src="https://fargostreet.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f642.png?v=40430adaedb" class="not-responsive emoji emoji-android emoji--slightly_smiling_face" style="height:23px;width:auto;vertical-align:middle" title=":)" alt="🙂" /></p>
<p dir="auto">I would need to check my logs to see if the ecu was pulling timing or picking up knock.. The car should pick up 30 on the top end..</p>
]]></description><link>https://fargostreet.com/post/301209</link><guid isPermaLink="true">https://fargostreet.com/post/301209</guid><dc:creator><![CDATA[aliengotpsi]]></dc:creator><pubDate>Wed, 30 Jun 2010 13:47:18 GMT</pubDate></item><item><title><![CDATA[Reply to MAP BIR race on Wed, 30 Jun 2010 04:08:32 GMT]]></title><description><![CDATA[<p dir="auto">yeah slicks would drop you big time</p>
]]></description><link>https://fargostreet.com/post/301200</link><guid isPermaLink="true">https://fargostreet.com/post/301200</guid><dc:creator><![CDATA[zbrown]]></dc:creator><pubDate>Wed, 30 Jun 2010 04:08:32 GMT</pubDate></item><item><title><![CDATA[Reply to MAP BIR race on Wed, 30 Jun 2010 02:21:53 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">aliengotpsi;312816 wrote:<br />
I think it weighs 3150 w me<br />
Shoulda weighed at BIR.  The scale was open.</p>
]]></description><link>https://fargostreet.com/post/301195</link><guid isPermaLink="true">https://fargostreet.com/post/301195</guid><dc:creator><![CDATA[2wheeler]]></dc:creator><pubDate>Wed, 30 Jun 2010 02:21:53 GMT</pubDate></item><item><title><![CDATA[Reply to MAP BIR race on Wed, 30 Jun 2010 01:02:54 GMT]]></title><description><![CDATA[<p dir="auto">That 10.6 run was on 32 psi. Nate you should check out <a href="http://evolutionm.net" rel="nofollow ugc">evolutionm.net</a></p>
]]></description><link>https://fargostreet.com/post/301193</link><guid isPermaLink="true">https://fargostreet.com/post/301193</guid><dc:creator><![CDATA[aliengotpsi]]></dc:creator><pubDate>Wed, 30 Jun 2010 01:02:54 GMT</pubDate></item><item><title><![CDATA[Reply to MAP BIR race on Wed, 30 Jun 2010 00:45:57 GMT]]></title><description><![CDATA[<p dir="auto">That makes me want to get another car...bad.</p>
]]></description><link>https://fargostreet.com/post/301192</link><guid isPermaLink="true">https://fargostreet.com/post/301192</guid><dc:creator><![CDATA[91nbtsi]]></dc:creator><pubDate>Wed, 30 Jun 2010 00:45:57 GMT</pubDate></item><item><title><![CDATA[Reply to MAP BIR race on Wed, 30 Jun 2010 00:37:41 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">zbrown;312813 wrote:<br />
yeah slicks would make a difference!  would you have to worry about breaking anything launching hard on them?</p>
<p dir="auto">Kevin, what does a car like yours weigh with you in it? 3300?</p>
<p dir="auto">I think slicks would get me some 1.5 60 foots. That would bring me down to 10.2's ish Ive alreayd broke a t-case from wheel hopping and have upgraded the diff.</p>
<p dir="auto">I think it weighs 3150 w me.....I will be trying for 10.5 or better at the next tintmaster race.. But im sure the traction will be worse.. I have falkin 615's at 17psi.. Is there a trick to make them stickier?</p>
]]></description><link>https://fargostreet.com/post/301191</link><guid isPermaLink="true">https://fargostreet.com/post/301191</guid><dc:creator><![CDATA[aliengotpsi]]></dc:creator><pubDate>Wed, 30 Jun 2010 00:37:41 GMT</pubDate></item><item><title><![CDATA[Reply to MAP BIR race on Wed, 30 Jun 2010 00:07:20 GMT]]></title><description><![CDATA[<p dir="auto">yeah slicks would make a difference!  would you have to worry about breaking anything launching hard on them?</p>
]]></description><link>https://fargostreet.com/post/301188</link><guid isPermaLink="true">https://fargostreet.com/post/301188</guid><dc:creator><![CDATA[zbrown]]></dc:creator><pubDate>Wed, 30 Jun 2010 00:07:20 GMT</pubDate></item><item><title><![CDATA[Reply to MAP BIR race on Tue, 29 Jun 2010 04:18:13 GMT]]></title><description><![CDATA[<p dir="auto">[ame]<a href="http://www.youtube.com/watch?v=ezPoHNwVqMQ%5B/ame%5D" rel="nofollow ugc">http://www.youtube.com/watch?v=ezPoHNwVqMQ[/ame]</a></p>
]]></description><link>https://fargostreet.com/post/301161</link><guid isPermaLink="true">https://fargostreet.com/post/301161</guid><dc:creator><![CDATA[aliengotpsi]]></dc:creator><pubDate>Tue, 29 Jun 2010 04:18:13 GMT</pubDate></item><item><title><![CDATA[Reply to MAP BIR race on Mon, 28 Jun 2010 22:18:32 GMT]]></title><description><![CDATA[<p dir="auto">Good job, congrats on getting there, car looked good.</p>
]]></description><link>https://fargostreet.com/post/301146</link><guid isPermaLink="true">https://fargostreet.com/post/301146</guid><dc:creator><![CDATA[inspector01]]></dc:creator><pubDate>Mon, 28 Jun 2010 22:18:32 GMT</pubDate></item><item><title><![CDATA[Reply to MAP BIR race on Mon, 28 Jun 2010 20:39:41 GMT]]></title><description><![CDATA[<p dir="auto">Nicely done, Alien!  Wish I would have been there to see this.</p>
]]></description><link>https://fargostreet.com/post/301141</link><guid isPermaLink="true">https://fargostreet.com/post/301141</guid><dc:creator><![CDATA[91nbtsi]]></dc:creator><pubDate>Mon, 28 Jun 2010 20:39:41 GMT</pubDate></item><item><title><![CDATA[Reply to MAP BIR race on Mon, 28 Jun 2010 19:32:52 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">aliengotpsi;312752 wrote:<br />
I think its at 30psi, Yes I got the boot!</p>
<p dir="auto">ha atleast they waited till you got it done</p>
<p dir="auto">no vids? someone has to have some vids</p>
]]></description><link>https://fargostreet.com/post/301139</link><guid isPermaLink="true">https://fargostreet.com/post/301139</guid><dc:creator><![CDATA[zbrown]]></dc:creator><pubDate>Mon, 28 Jun 2010 19:32:52 GMT</pubDate></item><item><title><![CDATA[Reply to MAP BIR race on Mon, 28 Jun 2010 17:44:36 GMT]]></title><description><![CDATA[<p dir="auto">thanks guys</p>
]]></description><link>https://fargostreet.com/post/301133</link><guid isPermaLink="true">https://fargostreet.com/post/301133</guid><dc:creator><![CDATA[aliengotpsi]]></dc:creator><pubDate>Mon, 28 Jun 2010 17:44:36 GMT</pubDate></item><item><title><![CDATA[Reply to MAP BIR race on Mon, 28 Jun 2010 17:18:18 GMT]]></title><description><![CDATA[<p dir="auto">Congrats Kevin</p>
]]></description><link>https://fargostreet.com/post/301132</link><guid isPermaLink="true">https://fargostreet.com/post/301132</guid><dc:creator><![CDATA[integra_gsr98]]></dc:creator><pubDate>Mon, 28 Jun 2010 17:18:18 GMT</pubDate></item><item><title><![CDATA[Reply to MAP BIR race on Mon, 28 Jun 2010 16:57:41 GMT]]></title><description><![CDATA[<p dir="auto">congrats Kevin....</p>
]]></description><link>https://fargostreet.com/post/301130</link><guid isPermaLink="true">https://fargostreet.com/post/301130</guid><dc:creator><![CDATA[btleier]]></dc:creator><pubDate>Mon, 28 Jun 2010 16:57:41 GMT</pubDate></item><item><title><![CDATA[Reply to MAP BIR race on Mon, 28 Jun 2010 16:14:31 GMT]]></title><description><![CDATA[<p dir="auto">Congrats on a great build Kevin!  Shane @ DB always goes the extra mile.  Highly recommended!</p>
]]></description><link>https://fargostreet.com/post/301128</link><guid isPermaLink="true">https://fargostreet.com/post/301128</guid><dc:creator><![CDATA[FG2]]></dc:creator><pubDate>Mon, 28 Jun 2010 16:14:31 GMT</pubDate></item><item><title><![CDATA[Reply to MAP BIR race on Mon, 28 Jun 2010 15:50:10 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">zbrown;312740 wrote:<br />
1/8 trap is impressive for sure</p>
<p dir="auto">did you get the boot eventually then?</p>
<p dir="auto">nice times, how much boost where you on then ~25?</p>
<p dir="auto">I think its at 30psi, Yes I got the boot!</p>
]]></description><link>https://fargostreet.com/post/301127</link><guid isPermaLink="true">https://fargostreet.com/post/301127</guid><dc:creator><![CDATA[aliengotpsi]]></dc:creator><pubDate>Mon, 28 Jun 2010 15:50:10 GMT</pubDate></item><item><title><![CDATA[Reply to MAP BIR race on Mon, 28 Jun 2010 12:45:11 GMT]]></title><description><![CDATA[<p dir="auto">Congrats Kevin!  It was good to see the car running so good.</p>
<p dir="auto"><img src="https://fargostreet.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f642.png?v=40430adaedb" class="not-responsive emoji emoji-android emoji--slightly_smiling_face" style="height:23px;width:auto;vertical-align:middle" title=":-)" alt="🙂" /></p>
]]></description><link>https://fargostreet.com/post/301122</link><guid isPermaLink="true">https://fargostreet.com/post/301122</guid><dc:creator><![CDATA[DaveH]]></dc:creator><pubDate>Mon, 28 Jun 2010 12:45:11 GMT</pubDate></item><item><title><![CDATA[Reply to MAP BIR race on Mon, 28 Jun 2010 12:35:46 GMT]]></title><description><![CDATA[<p dir="auto">Congrats Kevin!!! Awesome runs!</p>
]]></description><link>https://fargostreet.com/post/301121</link><guid isPermaLink="true">https://fargostreet.com/post/301121</guid><dc:creator><![CDATA[fallguy]]></dc:creator><pubDate>Mon, 28 Jun 2010 12:35:46 GMT</pubDate></item><item><title><![CDATA[Reply to MAP BIR race on Mon, 28 Jun 2010 05:26:08 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">Guy said congrats then ripped the sticker off his windshield so he couldn't run anymore. Kevin just smiled and said ok. lol<br />
Congrats again boss!</p>
]]></description><link>https://fargostreet.com/post/301119</link><guid isPermaLink="true">https://fargostreet.com/post/301119</guid><dc:creator><![CDATA[GoldyHatchPSI]]></dc:creator><pubDate>Mon, 28 Jun 2010 05:26:08 GMT</pubDate></item><item><title><![CDATA[Reply to MAP BIR race on Mon, 28 Jun 2010 04:45:19 GMT]]></title><description><![CDATA[<p dir="auto">1/8 trap is impressive for sure</p>
]]></description><link>https://fargostreet.com/post/301115</link><guid isPermaLink="true">https://fargostreet.com/post/301115</guid><dc:creator><![CDATA[zbrown]]></dc:creator><pubDate>Mon, 28 Jun 2010 04:45:19 GMT</pubDate></item><item><title><![CDATA[Reply to MAP BIR race on Mon, 28 Jun 2010 03:59:33 GMT]]></title><description><![CDATA[<p dir="auto">It was awesome seeing your car drop times! And nice meeting you that is one very nice machine you have.</p>
]]></description><link>https://fargostreet.com/post/301114</link><guid isPermaLink="true">https://fargostreet.com/post/301114</guid><dc:creator><![CDATA[funky_monkey58]]></dc:creator><pubDate>Mon, 28 Jun 2010 03:59:33 GMT</pubDate></item><item><title><![CDATA[Reply to MAP BIR race on Mon, 28 Jun 2010 03:51:40 GMT]]></title><description><![CDATA[<p dir="auto">Holy shit man, that's awesome! It's cool they were able to help you drop your times with quick changes. Congrats!</p>
]]></description><link>https://fargostreet.com/post/301113</link><guid isPermaLink="true">https://fargostreet.com/post/301113</guid><dc:creator><![CDATA[HandoEX]]></dc:creator><pubDate>Mon, 28 Jun 2010 03:51:40 GMT</pubDate></item></channel></rss>
