<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[NEW releases from Cobb]]></title><description><![CDATA[<p dir="auto">COBB Tuning has just released a few new products for their 2010 lineup. First up is the COBB XLE BPV (BOV), this item has just recently been released to their COBB dealer network.  It had previously only been available through COBB tuning directly for retail customers.  This is a long awaited release from COBB and I’m sure they’ll be really popular. The XLE BPV features a few different modes for their user to configure depending on how they’d like them to perform.  In addition to this they’re adjustable in piston preload depending on your vehicles requirements.</p>
<p dir="auto">Note-This item has various vehicle applications and listings, which are listed below.</p>
<pre><code>            The next item is the COBB Tuning adjustable endlinks for the 08+ WRX and STi.  These rear endlinks are CAD designed CNC units which have an anodized finish and PTFE surface where friction is present.  They feature heim joints at each end which are threaded to allow precise adjustments in length which eliminates unwanted preload for the sway bar.  The spherical bearings enable the sway bar to work with maximum efficiency for precise handling and feedback.
            The last item is the COBB 3” FP Turbo Inlet Hose for Mitsubishi EVO X.  These inlets are designed to work in conjunction with Forced Performance 3” turbo applications.  These hoses are designed to move large volumes of air quickly and smoothly, they have 4 plies of steel-reinforcement to prevent collapse while their silicone construction eliminates the OEM style accordion construction but still remains compliant for the engines natural movement under load.
</code></pre>
<p dir="auto"><img src="http://i32.photobucket.com/albums/d8/tntmstr/BypassValve.png" alt="legacy image" class=" img-fluid img-markdown" /></p>
<p dir="auto">The COBB Tuning XLE Bypass Valve is available for:</p>
<pre><code>* 2006-2009 Mazdaspeed3
* 2006-2007 Mazdaspeed6
* Nissan GT-R
* 2002-2007 WRXs
* 2008-2010 WRX
* 2004-2007 STI
* 2008-2010 STI
* 2005-2009 Legacy GT
* 2009 Impreza 2.5 GT
* 2006-2008 Forester XT
</code></pre>
<p dir="auto">712650 - BOV for '02-'07 WRX, '06-'08 FXT and ALL STi - Retail Price      $295</p>
<p dir="auto">724650 - BOV for '08+ WRX and '05-'09 LGT - Retail Price                          $295</p>
<p dir="auto">771650  - BOV for Mazdaspeed 3 and 6 - Retail Price                                 $295</p>
<p dir="auto">7C1650 - Dual BOV kit for R35 GT-R - Retail Price                                         $595</p>
<p dir="auto"><img src="http://i32.photobucket.com/albums/d8/tntmstr/Endlinks.jpg" alt="legacy image" class=" img-fluid img-markdown" /></p>
<p dir="auto">COBB Tuning Adjustable Rear Antiswaybar Endlinks for the 2008+ STI are threaded to easily remove all preload from the bar and provides consistent handling balance in right and left turns. The construction of these endlinks start with carbon steel bearing rod ends utilizing a PTFE (Polytetrafluoroethylene) self lubricating corrosion resistant coating. The CAD designed and CNC machined spindles are 6061-T6 aluminum and hard anodized for a long lasting finish. Our endlinks were designed and assembled in-house for optimal strength, performance and durability. Adjustment is as easy as loosening the jamb nuts and turning the spindle to lengthen or shorten the endlink while installed on the car.</p>
<p dir="auto">915400 - COBB Rear Adjustable Endlinks for 08+ Subaru STI and WRX Retail Price          $165.00</p>
<p dir="auto"><img src="http://i32.photobucket.com/albums/d8/tntmstr/turboinlet.png" alt="legacy image" class=" img-fluid img-markdown" /></p>
<p dir="auto">The COBB Tuning 3” FP Turbo Inlet Hose is designed for use with Forced Performance 3" turbos. The bulge design of the COBB Inlet Hose increases the cross-section to 3.5” to maximize air flow delivered directly to your 3" Forced<br />
Performance turbocharger, providing much more efficient power and response. The smooth inner walls of the COBB Turbo Inlet taper gradually at both ends and reduce the air turbulence that occurs in the factory accordion style inlet.</p>
<p dir="auto">752002BL - (Stealth Blue) Retail Price                   $115.00</p>
<p dir="auto">752002BK- (Stealth Black) Retail Price                  $115.00</p>
]]></description><link>https://fargostreet.com/topic/19519/new-releases-from-cobb</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 03:51:59 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/19519.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 27 Jul 2010 16:34:47 GMT</pubDate><ttl>60</ttl></channel></rss>
