<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[s13 240sx build]]></title><description><![CDATA[<p dir="auto">Well, I finally started ordering parts for my car again.  Its been sitting in storage for about the last 2 years, due to being broke and in school.  I'm going for at least 450whp on e85, would like to see 500whp, but that might be a stretch.  I still need a whole grip of parts (and money) , but I think I have a pretty good start on it.  On to the parts list/pics....</p>
<p dir="auto">Powertrain<br />
Wiseco Pistons, 9.0 comp<br />
Eagle Rods<br />
ACL bearings<br />
ARP Main Studs<br />
ARP head studs<br />
JWT s1 camshafts<br />
Koyo Radiator<br />
Garrett GT3076R turbo, .82 a/r<br />
Tanabe Concept G catback<br />
Nismo motor mounts and trans mount<br />
centerforce dual friction clutch<br />
nismo 2way lsd<br />
c's short shifter<br />
dual 10" electric fans<br />
Walbro fuel pump<br />
JWT Cam Gears<br />
Xcessive Windage Tray w/ crank scraper<br />
ATI super damper crank pulley<br />
Xcessive Intake Mani w/q45 flange and SS throttle cable bracket<br />
Xcessive lowering motor mount brackets<br />
Cometic Head Gasket<br />
JGS turbo mani and oil lines<br />
AEM Fuel Rail<br />
BC springs and retainers<br />
supertech valve seals<br />
BC SS Valves, Std size</p>
<p dir="auto">Suspension:<br />
JIC flt-a2 coilovers<br />
cusco front tie bar<br />
Suspension Tech. F&amp;R sway bars<br />
spl tension rods w/ brake cooling air deflectors<br />
spl ruca<br />
sentra se-r brembo calipers<br />
r32 skyline rear calipers (might sell and get ksports front and rear instead)<br />
JIC front and rear strut bars<br />
autopower race roll bar<br />
tein tie rods<br />
TechnoToyTuning subframe collars<br />
Energy suspension poly bushings in the rest of the arms</p>
<p dir="auto">Exterior<br />
SSR Professor MS1 wheels 17x9,17x10 +24, 1/4" spacers on fronts<br />
(Yes, they are 4 lug!)<br />
front 255/40, rear 275/40<br />
ARP wheel studs<br />
Bomex front lip<br />
silvia sideskirts</p>
<p dir="auto">What I started with, about 5 years ago:<br />
<img src="http://i21.photobucket.com/albums/b293/revolutionz_s13/240/before.jpg" alt="legacy image" class=" img-fluid img-markdown" /></p>
<p dir="auto">Pulling old motor, tearing it down to send the block off, sanding it down for paint:<br />
<img src="http://i21.photobucket.com/albums/b293/revolutionz_s13/240/DSC00365.jpg" alt="legacy image" class=" img-fluid img-markdown" /><br />
<img src="http://i21.photobucket.com/albums/b293/revolutionz_s13/240/DSC00317.jpg" alt="legacy image" class=" img-fluid img-markdown" /><br />
<img src="http://i21.photobucket.com/albums/b293/revolutionz_s13/240/DSC00416.jpg" alt="legacy image" class=" img-fluid img-markdown" /><br />
<img src="http://i21.photobucket.com/albums/b293/revolutionz_s13/240/DSC00428.jpg" alt="legacy image" class=" img-fluid img-markdown" /><br />
<img src="http://i21.photobucket.com/albums/b293/revolutionz_s13/240/DSCN0541.jpg" alt="legacy image" class=" img-fluid img-markdown" /></p>
<p dir="auto">Block back from machine shop, car back from first attempt at paint, put on suspension parts, test fit wheels:<br />
<img src="http://i21.photobucket.com/albums/b293/revolutionz_s13/240/studded.jpg" alt="legacy image" class=" img-fluid img-markdown" /><br />
<img src="http://i21.photobucket.com/albums/b293/revolutionz_s13/240/DSCN1487.jpg" alt="legacy image" class=" img-fluid img-markdown" /><br />
<img src="http://i21.photobucket.com/albums/b293/revolutionz_s13/240/DSCN1491.jpg" alt="legacy image" class=" img-fluid img-markdown" /><br />
<img src="http://i21.photobucket.com/albums/b293/revolutionz_s13/240/DSCN1492.jpg" alt="legacy image" class=" img-fluid img-markdown" /><br />
<img src="http://i21.photobucket.com/albums/b293/revolutionz_s13/240/DSCN1501.jpg" alt="legacy image" class=" img-fluid img-markdown" /></p>
<p dir="auto">Bunch of the parts I have sitting in my bedroom, waiting to be bolted to something...(no longer have the emanage, sold it to get aem ems)<br />
<img src="http://i21.photobucket.com/albums/b293/revolutionz_s13/240/DSCN0391.jpg" alt="legacy image" class=" img-fluid img-markdown" /><br />
<img src="http://i21.photobucket.com/albums/b293/revolutionz_s13/240/DSCN0040.jpg" alt="legacy image" class=" img-fluid img-markdown" /></p>
<p dir="auto">Parts I'm planning on collecting over the winter:<br />
Vibrant intercooler<br />
Synapse Synchronic WG and BOV<br />
oil cooler<br />
One piece steel driveshaft<br />
ID 1000cc injectors<br />
Spec aluminum flywheel<br />
Spec Stage 3+ clutch<br />
Circuit sports clutch pivot<br />
AEM Coilpacks<br />
AEM twinfire<br />
AEM FPR<br />
AEM EMS<br />
AEM Wideband<br />
Aeroquip -6 Fuel lines<br />
Bosch 044 inline fuel pump (fed by in-tank walbro)<br />
Apexi boost controller<br />
Ksport 13" front and rear brakes</p>
<p dir="auto">I also have some work to do in the interior, and plan on stitch welding most of the car and possibly doing tubs in the front.</p>
<p dir="auto">Shooting to get it tuned next summer, and completely finished by next fall.  Still needs alot of work, but I'll be starting on the money sucking piece of metal this week, and I'll post updates as I make progress on this current monstrosity.</p>
]]></description><link>https://fargostreet.com/topic/19855/s13-240sx-build</link><generator>RSS for Node</generator><lastBuildDate>Wed, 27 May 2026 23:57:02 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/19855.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 02 Nov 2010 05:29:34 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to s13 240sx build on Mon, 17 Jan 2011 20:04:54 GMT]]></title><description><![CDATA[<p dir="auto">After doing some more reading, I think you guys are probably right.  I will order an aeromotive 340 with a boost-a-pump, which should be more than enough</p>
]]></description><link>https://fargostreet.com/post/306806</link><guid isPermaLink="true">https://fargostreet.com/post/306806</guid><dc:creator><![CDATA[revolutionz_s13]]></dc:creator><pubDate>Mon, 17 Jan 2011 20:04:54 GMT</pubDate></item><item><title><![CDATA[Reply to s13 240sx build on Mon, 17 Jan 2011 16:08:46 GMT]]></title><description><![CDATA[<p dir="auto">Ditch the surge tank idea and just get a big enough external  pump and sump the tank. If you don't want to sump the tank, mount another pump with the exitsting one in the tank.</p>
<p dir="auto">Surge tank isn't needed and a waste of time trying to build and fit.</p>
<p dir="auto">ps.  how many times have people had a Walbro pump fail.  I haven't known anyone yet.</p>
]]></description><link>https://fargostreet.com/post/306803</link><guid isPermaLink="true">https://fargostreet.com/post/306803</guid><dc:creator><![CDATA[XJHEAD]]></dc:creator><pubDate>Mon, 17 Jan 2011 16:08:46 GMT</pubDate></item><item><title><![CDATA[Reply to s13 240sx build on Mon, 17 Jan 2011 15:15:38 GMT]]></title><description><![CDATA[<p dir="auto">I have a problem with running multiple pumps, its just not safe.  I would rather run a boost a pump myself.  In fact the aero pump flows 400lph@ 17v, 60psi; and 330lph @17v; 90psi</p>
]]></description><link>https://fargostreet.com/post/306801</link><guid isPermaLink="true">https://fargostreet.com/post/306801</guid><dc:creator><![CDATA[Grr]]></dc:creator><pubDate>Mon, 17 Jan 2011 15:15:38 GMT</pubDate></item><item><title><![CDATA[Reply to s13 240sx build on Mon, 17 Jan 2011 04:43:46 GMT]]></title><description><![CDATA[<p dir="auto">my plan right now is to use the walbro to feed a surge tank, then run a bosch 044 from the surge tank. Im thinking i'll run a 50psi base, and the boost reference will bring it up accordingly, i figure roughly 80 psi max. the injectors at that pressure flow almost 1300cc. The 044 <em>should</em> be able to keep up with that. that aeromotive is a nice option though....</p>
]]></description><link>https://fargostreet.com/post/306794</link><guid isPermaLink="true">https://fargostreet.com/post/306794</guid><dc:creator><![CDATA[revolutionz_s13]]></dc:creator><pubDate>Mon, 17 Jan 2011 04:43:46 GMT</pubDate></item><item><title><![CDATA[Reply to s13 240sx build on Mon, 17 Jan 2011 02:00:27 GMT]]></title><description><![CDATA[<p dir="auto">I dont think you will have too much trouble with the injectors, but i agree you should have gotten 1200s anyway.  I suspect you will be out of pump with that walbro trying to run high pressure to compensate.<br />
Aeromotive is now releasing and will be tested in the coming weeks a drop in walbro replacement that is 340lph at 43.5psi vs the walbros 255.  It will be $180 and looks to be the answer for all the intank pump users.  I would be on the lookout for a bigger injector, maybe see if you can trade yours in on them if they are unused, and try to keep pressure down to 40psi or so base</p>
<p dir="auto"><img src="http://i514.photobucket.com/albums/t346/boostcrazy99/11140_42_Pump_Kit.jpg" alt="legacy image" class=" img-fluid img-markdown" /><br />
<img src="http://i514.photobucket.com/albums/t346/boostcrazy99/Aeromotive340_Walbro_comparo_FlowChart.jpg" alt="legacy image" class=" img-fluid img-markdown" /></p>
]]></description><link>https://fargostreet.com/post/306792</link><guid isPermaLink="true">https://fargostreet.com/post/306792</guid><dc:creator><![CDATA[Grr]]></dc:creator><pubDate>Mon, 17 Jan 2011 02:00:27 GMT</pubDate></item><item><title><![CDATA[Reply to s13 240sx build on Sun, 16 Jan 2011 23:59:51 GMT]]></title><description><![CDATA[<p dir="auto">They love high pressure and are stable and linear to 95% DC</p>
<p dir="auto">Same ones I have, idle awesome</p>
]]></description><link>https://fargostreet.com/post/306791</link><guid isPermaLink="true">https://fargostreet.com/post/306791</guid><dc:creator><![CDATA[zbrown]]></dc:creator><pubDate>Sun, 16 Jan 2011 23:59:51 GMT</pubDate></item><item><title><![CDATA[Reply to s13 240sx build on Sun, 16 Jan 2011 21:51:46 GMT]]></title><description><![CDATA[<p dir="auto">I dont know for sure what I'm gonna need for the spacers yet, I have to figure out good way to measure it so I get the right length so that the fuel rail sits parallel with the intake manifold. as far as adjusting the valves, its a little more of a pain in the ass with the supertech lifters, because they are shim under bucket, so after I measure everything, cams have to come all the way back out and the lifters have to be pulled out to put the shim into. which means i cant use your shims either. which sucks, because its about $60 for a set of shims from supertech.</p>
<p dir="auto">zbrown;318528 wrote:<br />
Good injector choice<br />
Thanks, although I'm starting to wonder if they will be big enough...it seems like i'm going to have to run them up to like 80psi to get them to flow enough fuel...</p>
]]></description><link>https://fargostreet.com/post/306786</link><guid isPermaLink="true">https://fargostreet.com/post/306786</guid><dc:creator><![CDATA[revolutionz_s13]]></dc:creator><pubDate>Sun, 16 Jan 2011 21:51:46 GMT</pubDate></item><item><title><![CDATA[Reply to s13 240sx build on Sun, 16 Jan 2011 21:01:12 GMT]]></title><description><![CDATA[<p dir="auto">Nate, What do you need for spacers for the Fuel rail? I might have something that could work for you. Good to see this thing getting somewhere.</p>
<p dir="auto">When you need it, I have the tools for adjusting the valves(unless you have bought one) as well as a bunch of shims.</p>
]]></description><link>https://fargostreet.com/post/306783</link><guid isPermaLink="true">https://fargostreet.com/post/306783</guid><dc:creator><![CDATA[KA-T_240]]></dc:creator><pubDate>Sun, 16 Jan 2011 21:01:12 GMT</pubDate></item><item><title><![CDATA[Reply to s13 240sx build on Sun, 16 Jan 2011 20:56:13 GMT]]></title><description><![CDATA[<p dir="auto">Good injector choice</p>
]]></description><link>https://fargostreet.com/post/306782</link><guid isPermaLink="true">https://fargostreet.com/post/306782</guid><dc:creator><![CDATA[zbrown]]></dc:creator><pubDate>Sun, 16 Jan 2011 20:56:13 GMT</pubDate></item><item><title><![CDATA[Reply to s13 240sx build on Sun, 16 Jan 2011 15:15:25 GMT]]></title><description><![CDATA[<p dir="auto">that thing is gonna be awesome man, good work</p>
]]></description><link>https://fargostreet.com/post/306777</link><guid isPermaLink="true">https://fargostreet.com/post/306777</guid><dc:creator><![CDATA[Grr]]></dc:creator><pubDate>Sun, 16 Jan 2011 15:15:25 GMT</pubDate></item><item><title><![CDATA[Reply to s13 240sx build on Sun, 16 Jan 2011 07:43:36 GMT]]></title><description><![CDATA[<p dir="auto">So finally had some time over the last couple weeks to get some more done again.  Started cleaning out the engine bay and taking out stuff I dont need anymore.  I cut out the battery tray too, that sucked ass. Also pulled the engine bay harness out so I can go through it and check all the wires to make sure they are good, and to add wires I need, and take out ones I dont.  I also got everything to start getting the motor more assembled.  I was like a 2nd christmas over the last week, a bunch of parts came  :icon_cheers:  I ran into a snag tonight, I need to get longer spacers made for the fuel rail, the ID1000 injectors + xcessive mani ends up with a much larger gap than what the spacers came with for the oem fuel rail.  Pics!</p>
<p dir="auto">Parts!<br />
<img src="http://i21.photobucket.com/albums/b293/revolutionz_s13/240/DSCN0076.jpg" alt="legacy image" class=" img-fluid img-markdown" /></p>
<p dir="auto">Cleanin a mess<br />
<img src="http://i21.photobucket.com/albums/b293/revolutionz_s13/240/IMAG0015.jpg" alt="legacy image" class=" img-fluid img-markdown" /></p>
<p dir="auto">Battery tray removed<br />
<img src="http://i21.photobucket.com/albums/b293/revolutionz_s13/240/IMAG0018.jpg" alt="legacy image" class=" img-fluid img-markdown" /></p>
<p dir="auto">A days carnage<br />
<img src="http://i21.photobucket.com/albums/b293/revolutionz_s13/240/133944_10150122056969187_617964186_7600186_1360484_o.jpg" alt="legacy image" class=" img-fluid img-markdown" /></p>
<p dir="auto">Puttin the motor together little by little<br />
<img src="http://i21.photobucket.com/albums/b293/revolutionz_s13/240/DSCN0077.jpg" alt="legacy image" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="http://i21.photobucket.com/albums/b293/revolutionz_s13/240/DSCN0078.jpg" alt="legacy image" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="http://i21.photobucket.com/albums/b293/revolutionz_s13/240/DSCN0079.jpg" alt="legacy image" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="http://i21.photobucket.com/albums/b293/revolutionz_s13/240/DSCN0080.jpg" alt="legacy image" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="http://i21.photobucket.com/albums/b293/revolutionz_s13/240/DSCN0081.jpg" alt="legacy image" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="http://i21.photobucket.com/albums/b293/revolutionz_s13/240/DSCN0082.jpg" alt="legacy image" class=" img-fluid img-markdown" /></p>
<p dir="auto">Its gettin there slowly but surely, needs lots more time and money tho  :icon_pale:   Feels good to be making progress again after a couple years of it sitting though. Comments, suggestions, and flames welcome  <img src="https://fargostreet.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f604.png?v=40430adaedb" class="not-responsive emoji emoji-android emoji--smile" style="height:23px;width:auto;vertical-align:middle" title=":D" alt="😄" /></p>
]]></description><link>https://fargostreet.com/post/306775</link><guid isPermaLink="true">https://fargostreet.com/post/306775</guid><dc:creator><![CDATA[revolutionz_s13]]></dc:creator><pubDate>Sun, 16 Jan 2011 07:43:36 GMT</pubDate></item><item><title><![CDATA[Reply to s13 240sx build on Wed, 29 Dec 2010 06:51:12 GMT]]></title><description><![CDATA[<p dir="auto">Looks very nice</p>
]]></description><link>https://fargostreet.com/post/306249</link><guid isPermaLink="true">https://fargostreet.com/post/306249</guid><dc:creator><![CDATA[Cobra Rob]]></dc:creator><pubDate>Wed, 29 Dec 2010 06:51:12 GMT</pubDate></item><item><title><![CDATA[Reply to s13 240sx build on Wed, 29 Dec 2010 03:13:06 GMT]]></title><description><![CDATA[<p dir="auto">Small bit of progress here. Got some more parts, a Skullworks oil block adapter, some AEM pencil coils, an Aeromotive A1000 FPR, and a set of Supertech cam followers (lifters). I sent the head to the machine shop for a 3angle valve job, and then proceed to assemble the head.  I also put the oil block adapter on and installed the Xcessive windage tray/crank scraper, and had to do only a slight amount of clearancing for the crankshaft. Im waiting for a couple more things, hopefully the longblock will be completely assembled in the next couple weeks.</p>
<p dir="auto">Pics!</p>
<p dir="auto"><img src="http://i21.photobucket.com/albums/b293/revolutionz_s13/240/DSCN0071.jpg" alt="legacy image" class=" img-fluid img-markdown" /><br />
<img src="http://i21.photobucket.com/albums/b293/revolutionz_s13/240/DSCN0067.jpg" alt="legacy image" class=" img-fluid img-markdown" /></p>
<p dir="auto">Oil block adapter:<br />
<img src="http://i21.photobucket.com/albums/b293/revolutionz_s13/240/DSCN0070.jpg" alt="legacy image" class=" img-fluid img-markdown" /></p>
<p dir="auto">Xcessive windage tray (pre trimming for clearance):<br />
<img src="http://i21.photobucket.com/albums/b293/revolutionz_s13/240/DSCN0057.jpg" alt="legacy image" class=" img-fluid img-markdown" /><br />
<img src="http://i21.photobucket.com/albums/b293/revolutionz_s13/240/DSCN0058.jpg" alt="legacy image" class=" img-fluid img-markdown" /><br />
<img src="http://i21.photobucket.com/albums/b293/revolutionz_s13/240/DSCN0060.jpg" alt="legacy image" class=" img-fluid img-markdown" /></p>
<p dir="auto">Just back from the machine shop, fresh ground valve seats:<br />
<img src="http://i21.photobucket.com/albums/b293/revolutionz_s13/240/DSCN0068.jpg" alt="legacy image" class=" img-fluid img-markdown" /></p>
<p dir="auto">Assembling the head:<br />
<img src="http://i21.photobucket.com/albums/b293/revolutionz_s13/240/DSCN0073.jpg" alt="legacy image" class=" img-fluid img-markdown" /><br />
<img src="http://i21.photobucket.com/albums/b293/revolutionz_s13/240/DSCN0072.jpg" alt="legacy image" class=" img-fluid img-markdown" /><br />
<img src="http://i21.photobucket.com/albums/b293/revolutionz_s13/240/DSCN0074.jpg" alt="legacy image" class=" img-fluid img-markdown" /></p>
]]></description><link>https://fargostreet.com/post/306242</link><guid isPermaLink="true">https://fargostreet.com/post/306242</guid><dc:creator><![CDATA[revolutionz_s13]]></dc:creator><pubDate>Wed, 29 Dec 2010 03:13:06 GMT</pubDate></item><item><title><![CDATA[Reply to s13 240sx build on Sat, 13 Nov 2010 16:17:53 GMT]]></title><description><![CDATA[<p dir="auto">My buddy has a stage 3+ in his corvette, it holds pretty good....alot of the KA guys run spec and like them</p>
]]></description><link>https://fargostreet.com/post/305352</link><guid isPermaLink="true">https://fargostreet.com/post/305352</guid><dc:creator><![CDATA[revolutionz_s13]]></dc:creator><pubDate>Sat, 13 Nov 2010 16:17:53 GMT</pubDate></item><item><title><![CDATA[Reply to s13 240sx build on Sat, 13 Nov 2010 07:51:48 GMT]]></title><description><![CDATA[<p dir="auto">from what I have seen, I suggest staying away from Spec clutches... I had a stage 2 and all it was is just a nice disk with a stock pressure plate...</p>
]]></description><link>https://fargostreet.com/post/305345</link><guid isPermaLink="true">https://fargostreet.com/post/305345</guid><dc:creator><![CDATA[dis_ill_usions]]></dc:creator><pubDate>Sat, 13 Nov 2010 07:51:48 GMT</pubDate></item><item><title><![CDATA[Reply to s13 240sx build on Thu, 11 Nov 2010 00:23:45 GMT]]></title><description><![CDATA[<p dir="auto">Very nice build indeed. Looking forward to seeing this one progress.</p>
]]></description><link>https://fargostreet.com/post/305298</link><guid isPermaLink="true">https://fargostreet.com/post/305298</guid><dc:creator><![CDATA[weshole]]></dc:creator><pubDate>Thu, 11 Nov 2010 00:23:45 GMT</pubDate></item><item><title><![CDATA[Reply to s13 240sx build on Wed, 10 Nov 2010 04:25:39 GMT]]></title><description><![CDATA[<p dir="auto">You'd be amazed at how much a little "cleaning" in the heads can accomplish.  I never had the cougar dynoed but the E7's I ported seemed to flow really well beyond the RPM range where most "stock" 302's fall flat on their face.  Keep up the good work, it looks so much better with the new paint and wheels, can't say I'm a fan of the wheel color tho.</p>
]]></description><link>https://fargostreet.com/post/305269</link><guid isPermaLink="true">https://fargostreet.com/post/305269</guid><dc:creator><![CDATA[capitlj]]></dc:creator><pubDate>Wed, 10 Nov 2010 04:25:39 GMT</pubDate></item><item><title><![CDATA[Reply to s13 240sx build on Tue, 09 Nov 2010 01:48:14 GMT]]></title><description><![CDATA[<p dir="auto">looks good man!</p>
]]></description><link>https://fargostreet.com/post/305207</link><guid isPermaLink="true">https://fargostreet.com/post/305207</guid><dc:creator><![CDATA[zbrown]]></dc:creator><pubDate>Tue, 09 Nov 2010 01:48:14 GMT</pubDate></item><item><title><![CDATA[Reply to s13 240sx build on Tue, 09 Nov 2010 01:28:10 GMT]]></title><description><![CDATA[<p dir="auto">Little update, did some work on the head over the weekend, took it all apart and smoothed out the intake runners and ports on the head a bit...didnt want to go too crazy since I dont have much experience, just wanted to smooth out the flashing from casting and take the roughness down a notch.  Waiting on a some valve seals and it will all go back together hopefully towards the end of this week.</p>
<p dir="auto">Intake mani runners before:<br />
<img src="http://i21.photobucket.com/albums/b293/revolutionz_s13/240/DSCN0046.jpg" alt="legacy image" class=" img-fluid img-markdown" /></p>
<p dir="auto">Intake port before:<br />
<img src="http://i21.photobucket.com/albums/b293/revolutionz_s13/240/DSCN0047.jpg" alt="legacy image" class=" img-fluid img-markdown" /></p>
<p dir="auto">Exhaust port before:<br />
<img src="http://i21.photobucket.com/albums/b293/revolutionz_s13/240/DSCN0048.jpg" alt="legacy image" class=" img-fluid img-markdown" /></p>
<p dir="auto">Intake mani runners after:<br />
<img src="http://i21.photobucket.com/albums/b293/revolutionz_s13/240/DSCN0049.jpg" alt="legacy image" class=" img-fluid img-markdown" /><br />
<img src="http://i21.photobucket.com/albums/b293/revolutionz_s13/240/DSCN0050.jpg" alt="legacy image" class=" img-fluid img-markdown" /></p>
<p dir="auto">Intake port after:<br />
<img src="http://i21.photobucket.com/albums/b293/revolutionz_s13/240/DSCN0051.jpg" alt="legacy image" class=" img-fluid img-markdown" /></p>
<p dir="auto">exhaust port after:<br />
<img src="http://i21.photobucket.com/albums/b293/revolutionz_s13/240/DSCN0052.jpg" alt="legacy image" class=" img-fluid img-markdown" /></p>
<p dir="auto">cylinder side of ports after:<br />
<img src="http://i21.photobucket.com/albums/b293/revolutionz_s13/240/DSCN0054.jpg" alt="legacy image" class=" img-fluid img-markdown" /></p>
]]></description><link>https://fargostreet.com/post/305206</link><guid isPermaLink="true">https://fargostreet.com/post/305206</guid><dc:creator><![CDATA[revolutionz_s13]]></dc:creator><pubDate>Tue, 09 Nov 2010 01:28:10 GMT</pubDate></item><item><title><![CDATA[Reply to s13 240sx build on Wed, 03 Nov 2010 17:33:34 GMT]]></title><description><![CDATA[<p dir="auto">Yummy!</p>
]]></description><link>https://fargostreet.com/post/305124</link><guid isPermaLink="true">https://fargostreet.com/post/305124</guid><dc:creator><![CDATA[ForestGreen]]></dc:creator><pubDate>Wed, 03 Nov 2010 17:33:34 GMT</pubDate></item><item><title><![CDATA[Reply to s13 240sx build on Wed, 03 Nov 2010 16:24:05 GMT]]></title><description><![CDATA[<p dir="auto">i wish i had a bunch of goodies like that laying around !!!</p>
]]></description><link>https://fargostreet.com/post/305123</link><guid isPermaLink="true">https://fargostreet.com/post/305123</guid><dc:creator><![CDATA[99civic]]></dc:creator><pubDate>Wed, 03 Nov 2010 16:24:05 GMT</pubDate></item><item><title><![CDATA[Reply to s13 240sx build on Wed, 03 Nov 2010 05:21:29 GMT]]></title><description><![CDATA[<p dir="auto">looks fun nate!!</p>
]]></description><link>https://fargostreet.com/post/305119</link><guid isPermaLink="true">https://fargostreet.com/post/305119</guid><dc:creator><![CDATA[King Ricer]]></dc:creator><pubDate>Wed, 03 Nov 2010 05:21:29 GMT</pubDate></item><item><title><![CDATA[Reply to s13 240sx build on Tue, 02 Nov 2010 18:03:51 GMT]]></title><description><![CDATA[<p dir="auto">Looks like fun!</p>
<p dir="auto">good choice on injectors!</p>
<p dir="auto">i like the 044 in series with the walbro too, supposed to work great</p>
]]></description><link>https://fargostreet.com/post/305097</link><guid isPermaLink="true">https://fargostreet.com/post/305097</guid><dc:creator><![CDATA[zbrown]]></dc:creator><pubDate>Tue, 02 Nov 2010 18:03:51 GMT</pubDate></item><item><title><![CDATA[Reply to s13 240sx build on Tue, 02 Nov 2010 15:19:07 GMT]]></title><description><![CDATA[<p dir="auto">planning pretty much for roadrace/auto-x and just an all around fun car.  I would like to take it to BIR when its done, and Im sure i'll make a few passes at sabin also...</p>
]]></description><link>https://fargostreet.com/post/305093</link><guid isPermaLink="true">https://fargostreet.com/post/305093</guid><dc:creator><![CDATA[revolutionz_s13]]></dc:creator><pubDate>Tue, 02 Nov 2010 15:19:07 GMT</pubDate></item></channel></rss>
