<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[FS: AMS Small Battery Kit for Evo $200]]></title><description><![CDATA[<p dir="auto">Used for about a year.  Needed to go to a bigger battery as I drive my car year round and it will often sit outside.  This saves wait and clears room for aftermarket intercooler piping.</p>
<p dir="auto"><strong>Good condition $200</strong> - Will need to purchase your own battery posts.</p>
<p dir="auto"><img src="http://www.amsperformance.com/cart/images/P/AMS_Mitsubishi_EVO_VIII-IX_Small_Battery_Kit_500x375.jpg" alt="legacy image" class=" img-fluid img-markdown" /></p>
<p dir="auto">The information as taken directly from AMS website:</p>
<p dir="auto">The AMS EVO VII/VIII/IX Small Battery Kit replaces your heavy factory battery with a lightweight race battery. This kit significantly reduces weight and frees up space for our free flowing upper intercooler pipe. Our high quality components guarantee long life and the battery itself will have no trouble starting your vehicle in harsh conditions. The tray included is TIG welded by hand using high grade aluminum and the battery is topped off with a CNC'd AMS tie down plate. All factory mounting points are used making installation simple. While it can be used in cars with mild stereo upgrades it’s not ideal for high output stereo systems.</p>
<p dir="auto">Features<br />
Effortless install uses factory mounting points<br />
Entire kit weighs 15lbs. lowering overall weight<br />
High quality, long life, car starts every time<br />
Custom AMS battery tie down plate<br />
Kit Includes<br />
AMS small battery<br />
Aluminum AMS battery tie down plate<br />
Zinc plated tie down hooks to prevent rusting over time<br />
Nylon washers to keep the hardware from scratching the anodized tie down plate<br />
Durable non slip battery pad to keep the battery in place and protected<br />
Wing nuts for an easy install and removal<br />
Adjustable for use with almost all small batteries<br />
Specifications<br />
680 cranking amps<br />
Short circuit current over 1800A<br />
25 minute reserve capacity with 25amp load<br />
Length 7 1/16"<br />
Width 2 15/16"<br />
Height 7 3/16"<br />
Weight 14.6 lbs<br />
Applications<br />
Mitsubishi Evolution 7, 8, 9<br />
GSR, MR, RS and SE</p>
]]></description><link>https://fargostreet.com/topic/19909/fs-ams-small-battery-kit-for-evo-200</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 03:50:16 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/19909.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 22 Nov 2010 20:38:36 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to FS: AMS Small Battery Kit for Evo $200 on Wed, 05 Jan 2011 17:17:37 GMT]]></title><description><![CDATA[<p dir="auto">no one needs something like this?  I'd like to clear it out of the garage!</p>
]]></description><link>https://fargostreet.com/post/306474</link><guid isPermaLink="true">https://fargostreet.com/post/306474</guid><dc:creator><![CDATA[btleier]]></dc:creator><pubDate>Wed, 05 Jan 2011 17:17:37 GMT</pubDate></item></channel></rss>
