<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Winter garage sale]]></title><description><![CDATA[<p dir="auto">13in Enkei 4x114? mesh wheels - <strong>$250</strong><br />
Crx center vent w/ clock - $25<br />
Crx Gauge cluster surround - $25<br />
CRX Si door panels - $50<br />
Crx door glass (both sides) - $50<br />
Aebs GSR Intake Mani (has all sensors and fuel rail) - $150<br />
DA upper control arms with adj ball joints - $100<br />
DA cargo cover - $50<br />
OB1 P72 (GSR) - $150<br />
B16 timing belt (new oem)- $50<br />
GSR head (bent valves) (comes with vc, intake mani, fuel rail, vtec solenoid, cams (with blox cam gears) - $400<br />
ITR Valves (new)- $150<br />
Blox valve springs - $150<br />
T3 to DSM adapter flange - $25<br />
Universal oil cooler setup - $50<br />
15" steelies 4x100 - $50<br />
JDM CRX steering wheel - <strong>$125</strong><br />
LS Pistons - $40<br />
D series t brackets - $40/each<br />
CRX shift linkage - $75<br />
EG shift linkage - $75<br />
H23 valve covers - $20/ea<br />
PR4 - $25<br />
PR5 - $25<br />
90-91 Civic Si pass seat - $50<br />
88-89 corner lights - $25<br />
CRX Si wheels (tires are pretty wore) - $200<br />
B series IM shaft (male/female) - $50<br />
GSR shift linkage - $75<br />
Z6 engine harness - $75<br />
Z6 IM, fuel rail, inj - $75<br />
RC 440cc Injectors - $100</p>
<p dir="auto">04 wrx drivers fog bezel - $20<br />
93-96 Impreza hood - $50<br />
Impreza pass front door - $50<br />
Amber sidemarkers - $30<br />
Amber turn signals 99-01 - $30<br />
93-96 headlight - $30<br />
Front mudflaps - $25<br />
RS fog brackets - $25<br />
Heatwrapped downpipe - $100<br />
02-03 wrx rear tophats - $50</p>
<p dir="auto"><strong>NEW STUFF 2/17</strong><br />
y8 trans, needs main bearing - $100<br />
HF mani - $25<br />
DSM o2 housing - $10<br />
DSM coil pack 1g turbo - $10<br />
D and B series TBs - $20<br />
Catch can - $30<br />
OBD2 d series starter - $30<br />
OBD2 P72 ecu - $100<br />
P06 ECU - $50 each<br />
Y8 alt - $30<br />
Z6 oil pan with pickup - $30<br />
EG cluster auto 112k - $25<br />
B16 cams with gears - $30/each<br />
ITR throttle body - $50<br />
EG rad with fan, b series hoses - $50<br />
Random mounts - $10 each<br />
EG Ex calipers with brackets - $40<br />
D series flywheel with clutch bolts - $15<br />
starter - $30<br />
Alt - $30<br />
Eg front suspension - $40<br />
Shift linkage - $50 each<br />
Stock springs - $10<br />
eg headlights - $50<br />
Tach with shift light - $40<br />
New LS water pump - $30<br />
LS head with cams and vc - $50<br />
B series vtec vc with fittings - $50<br />
Type R boost gauge - $10<br />
V3 amp 200x2 watt - $20<br />
GSR headbolts - $20<br />
Like new LS dizzy obd0 - $50<br />
New OBD1 gsr dizzy - $125<br />
GSR t bracket - $50<br />
Arias 9 to 1 pistons - $150<br />
DC header - $150<br />
GSR timing belt - $25<br />
New blox cam gears - $100<br />
JDM civic floor mats - offer<br />
CRX SiR seats - offer</p>
]]></description><link>https://fargostreet.com/topic/20027/winter-garage-sale</link><generator>RSS for Node</generator><lastBuildDate>Wed, 27 May 2026 23:41:30 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/20027.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 05 Jan 2011 04:35:28 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Winter garage sale on Wed, 20 Apr 2011 22:35:01 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">BlackEJ8;321237 wrote:<br />
How bout a b-series spark plug cover?</p>
<p dir="auto">nope... i have 1 and wouldn't ever sell it.. seems like they are getting to be a pain to find</p>
]]></description><link>https://fargostreet.com/post/309504</link><guid isPermaLink="true">https://fargostreet.com/post/309504</guid><dc:creator><![CDATA[bubba]]></dc:creator><pubDate>Wed, 20 Apr 2011 22:35:01 GMT</pubDate></item><item><title><![CDATA[Reply to Winter garage sale on Wed, 20 Apr 2011 12:53:04 GMT]]></title><description><![CDATA[<p dir="auto">How bout a b-series spark plug cover?</p>
]]></description><link>https://fargostreet.com/post/309485</link><guid isPermaLink="true">https://fargostreet.com/post/309485</guid><dc:creator><![CDATA[BlackEJ8]]></dc:creator><pubDate>Wed, 20 Apr 2011 12:53:04 GMT</pubDate></item><item><title><![CDATA[Reply to Winter garage sale on Wed, 20 Apr 2011 03:30:58 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">hondacivicchris;321192 wrote:<br />
do you got a stock d15 or 16 non vtec</p>
<p dir="auto">nope, just b series motors..</p>
<p dir="auto">have ls block and head, b16 head, gsr head, itr head....</p>
]]></description><link>https://fargostreet.com/post/309472</link><guid isPermaLink="true">https://fargostreet.com/post/309472</guid><dc:creator><![CDATA[bubba]]></dc:creator><pubDate>Wed, 20 Apr 2011 03:30:58 GMT</pubDate></item><item><title><![CDATA[Reply to Winter garage sale on Tue, 19 Apr 2011 07:34:37 GMT]]></title><description><![CDATA[<p dir="auto">do you got a stock d15 or 16 non vtec</p>
]]></description><link>https://fargostreet.com/post/309440</link><guid isPermaLink="true">https://fargostreet.com/post/309440</guid><dc:creator><![CDATA[hondacivicchris]]></dc:creator><pubDate>Tue, 19 Apr 2011 07:34:37 GMT</pubDate></item><item><title><![CDATA[Reply to Winter garage sale on Mon, 04 Apr 2011 20:50:20 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">gszzzzx;320557 wrote:<br />
still got the gsr ecu?? stock id guess??150 lowest ya go?? lmk</p>
<p dir="auto">$100 if u buy it this week</p>
]]></description><link>https://fargostreet.com/post/308824</link><guid isPermaLink="true">https://fargostreet.com/post/308824</guid><dc:creator><![CDATA[bubba]]></dc:creator><pubDate>Mon, 04 Apr 2011 20:50:20 GMT</pubDate></item><item><title><![CDATA[Reply to Winter garage sale on Mon, 04 Apr 2011 04:32:57 GMT]]></title><description><![CDATA[<p dir="auto">still got the gsr ecu?? stock id guess??150 lowest ya go?? lmk</p>
]]></description><link>https://fargostreet.com/post/308806</link><guid isPermaLink="true">https://fargostreet.com/post/308806</guid><dc:creator><![CDATA[gszzzzx]]></dc:creator><pubDate>Mon, 04 Apr 2011 04:32:57 GMT</pubDate></item><item><title><![CDATA[Reply to Winter garage sale on Sat, 19 Mar 2011 00:12:45 GMT]]></title><description><![CDATA[<p dir="auto">I just remembered that the corners on sedans are different than the coupe/hatch corners, I need sedan corners. <img src="https://fargostreet.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f642.png?v=40430adaedb" class="not-responsive emoji emoji-android emoji--slightly_smiling_face" style="height:23px;width:auto;vertical-align:middle" title=":)" alt="🙂" /><br />
If they're for a sedan just shoot me a price.<br />
Thanks.</p>
]]></description><link>https://fargostreet.com/post/308361</link><guid isPermaLink="true">https://fargostreet.com/post/308361</guid><dc:creator><![CDATA[ichibankilla]]></dc:creator><pubDate>Sat, 19 Mar 2011 00:12:45 GMT</pubDate></item><item><title><![CDATA[Reply to Winter garage sale on Fri, 18 Mar 2011 22:59:45 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">ichibankilla;320106 wrote:<br />
You wouldn't happen to have a set of EG corner lights would you?</p>
<p dir="auto">Yessir... I believe one broken tab tho</p>
]]></description><link>https://fargostreet.com/post/308358</link><guid isPermaLink="true">https://fargostreet.com/post/308358</guid><dc:creator><![CDATA[blackcherryTSi]]></dc:creator><pubDate>Fri, 18 Mar 2011 22:59:45 GMT</pubDate></item><item><title><![CDATA[Reply to Winter garage sale on Fri, 18 Mar 2011 20:30:30 GMT]]></title><description><![CDATA[<p dir="auto">You wouldn't happen to have a set of EG corner lights would you?</p>
]]></description><link>https://fargostreet.com/post/308355</link><guid isPermaLink="true">https://fargostreet.com/post/308355</guid><dc:creator><![CDATA[ichibankilla]]></dc:creator><pubDate>Fri, 18 Mar 2011 20:30:30 GMT</pubDate></item><item><title><![CDATA[Reply to Winter garage sale on Wed, 16 Mar 2011 14:12:35 GMT]]></title><description><![CDATA[<p dir="auto">bump, need this stuff gone</p>
]]></description><link>https://fargostreet.com/post/308314</link><guid isPermaLink="true">https://fargostreet.com/post/308314</guid><dc:creator><![CDATA[bubba]]></dc:creator><pubDate>Wed, 16 Mar 2011 14:12:35 GMT</pubDate></item><item><title><![CDATA[Reply to Winter garage sale on Tue, 15 Mar 2011 04:22:49 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">95_gsr_swap;319899 wrote:<br />
bubba getting rid of all the gsr stuff.....</p>
<p dir="auto">going all motor...</p>
]]></description><link>https://fargostreet.com/post/308279</link><guid isPermaLink="true">https://fargostreet.com/post/308279</guid><dc:creator><![CDATA[bubba]]></dc:creator><pubDate>Tue, 15 Mar 2011 04:22:49 GMT</pubDate></item><item><title><![CDATA[Reply to Winter garage sale on Mon, 07 Mar 2011 05:09:36 GMT]]></title><description><![CDATA[<p dir="auto">bubba getting rid of all the gsr stuff.....</p>
]]></description><link>https://fargostreet.com/post/308152</link><guid isPermaLink="true">https://fargostreet.com/post/308152</guid><dc:creator><![CDATA[95_gsr_swap]]></dc:creator><pubDate>Mon, 07 Mar 2011 05:09:36 GMT</pubDate></item><item><title><![CDATA[Reply to Winter garage sale on Wed, 16 Feb 2011 17:30:40 GMT]]></title><description><![CDATA[<p dir="auto">BUMP, lots of new stuff and pics coming soon</p>
]]></description><link>https://fargostreet.com/post/307505</link><guid isPermaLink="true">https://fargostreet.com/post/307505</guid><dc:creator><![CDATA[bubba]]></dc:creator><pubDate>Wed, 16 Feb 2011 17:30:40 GMT</pubDate></item><item><title><![CDATA[Reply to Winter garage sale on Wed, 12 Jan 2011 22:49:34 GMT]]></title><description><![CDATA[<p dir="auto">More new stuff and updates..</p>
]]></description><link>https://fargostreet.com/post/306673</link><guid isPermaLink="true">https://fargostreet.com/post/306673</guid><dc:creator><![CDATA[bubba]]></dc:creator><pubDate>Wed, 12 Jan 2011 22:49:34 GMT</pubDate></item><item><title><![CDATA[Reply to Winter garage sale on Tue, 11 Jan 2011 17:40:31 GMT]]></title><description><![CDATA[<p dir="auto">new stuff added, some prices changed..</p>
<p dir="auto">make offers, package deals...</p>
]]></description><link>https://fargostreet.com/post/306610</link><guid isPermaLink="true">https://fargostreet.com/post/306610</guid><dc:creator><![CDATA[bubba]]></dc:creator><pubDate>Tue, 11 Jan 2011 17:40:31 GMT</pubDate></item><item><title><![CDATA[Reply to Winter garage sale on Wed, 05 Jan 2011 14:15:31 GMT]]></title><description><![CDATA[<p dir="auto">What spring does the wg have?</p>
]]></description><link>https://fargostreet.com/post/306472</link><guid isPermaLink="true">https://fargostreet.com/post/306472</guid><dc:creator><![CDATA[drift86]]></dc:creator><pubDate>Wed, 05 Jan 2011 14:15:31 GMT</pubDate></item></channel></rss>
