<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Clunking noise in front end while turning...]]></title><description><![CDATA[<p dir="auto">Alright, I have an '87 MKIII, and just recently, I have noticed that when I take a corner at a decent speed, there is a slight clunk in what I think is the drivers front.  It clunks once while turning one way, and will not clunk until I turn the other way.  It also clunks (still, just once) if I hit a decent bump.  I am thinking it might be a sway bar end link, but I also found something else that it could be, also on the sway bar...<br />
<img src="http://i892.photobucket.com/albums/ac129/Shouter/2011-04-17221045.jpg" alt="legacy image" class=" img-fluid img-markdown" /><br />
One bolt is broken off on the sway bar mount on the passenger side! FML</p>
]]></description><link>https://fargostreet.com/topic/20268/clunking-noise-in-front-end-while-turning...</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 00:55:39 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/20268.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 18 Apr 2011 15:08:55 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Clunking noise in front end while turning... on Mon, 18 Apr 2011 19:32:54 GMT]]></title><description><![CDATA[<p dir="auto">Ok, I have a hoist also so it shouldnt be too bad.  Hopefully that fixes the problem, it sure is annoying.</p>
]]></description><link>https://fargostreet.com/post/309427</link><guid isPermaLink="true">https://fargostreet.com/post/309427</guid><dc:creator><![CDATA[Shouter351]]></dc:creator><pubDate>Mon, 18 Apr 2011 19:32:54 GMT</pubDate></item><item><title><![CDATA[Reply to Clunking noise in front end while turning... on Mon, 18 Apr 2011 16:01:20 GMT]]></title><description><![CDATA[<p dir="auto">Odds are this is the problem. I just had a civic with the identical issue at work. It was easy to drill out but then again, I was on a hoist.</p>
]]></description><link>https://fargostreet.com/post/309414</link><guid isPermaLink="true">https://fargostreet.com/post/309414</guid><dc:creator><![CDATA[weshole]]></dc:creator><pubDate>Mon, 18 Apr 2011 16:01:20 GMT</pubDate></item></channel></rss>
