<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[honda parts]]></title><description><![CDATA[<p dir="auto">Wanna get some of the stuff I don't need out of the garage, will be updating as i sort through it more. Open to offers.</p>
<p dir="auto">EG/DC B series T bracket - $50<br />
EG/DC B series mounts (have one or more of each) - $15 each<br />
Hasport EG AT to MT mount - $75<br />
EG D series T bracket - $40<br />
OBX Cam Gears (brand new) - $75<br />
DC Sports oil cap (blue) - $10<br />
DC Ceramic B series 4-1 header (banged up painted black) - $40<br />
B Series oil pans (some a little dented) - $20/each<br />
B series oil pan with fitting for return line - $40<br />
Aluminum IC piping made by SLS w/ Tial BOV (like new) - $300<br />
B series Vtec VC (has 2 -12an fittings in the front, powdercoated black, come with 4 steel braided hoses with -12 fittings for a catch can, very good shape) - $150<br />
EG front strut assembly (coil sleeves, lowering springs, strut fork) - $50/pair<br />
EG calipers - $20/each<br />
DA Upper Control arms with camber kit (needs ball joint boots) - $60<br />
Hydro B series clutches - Make Offer<br />
DA Cargo cover (very good shape) - $50<br />
CRX Si Door panels (89+ some small seatbelt marks) - $50<br />
CRX Door glass - $50/pair<br />
CRX Gauge Cluster hood - $30<br />
GSR Head (possible bent valves) - $250<br />
EG Radiator w/ fan - $50<br />
EG Shift linkage - $50/each<br />
EG Wire harness (non-vtec) - $50/each<br />
GSR Intake Manis - $30<br />
AEBS GSR Intake Mani - $100<br />
Arias 9-1 81mm Pistons - $150<br />
CP 9-1 81mm Pistons (3) - $75<br />
B16 T belt (new, OEM honda) - $50<br />
LS/Vtec (new HG, ARP headstuds, Golden Eagle LS/Vtec kit, new t-belt, new water pump, Hondata IM Gasket, full long block (complete IM, etc.)) - $1000<br />
LS Hydro Trans (01, mint shape, low miles) - $400</p>
<p dir="auto">If someone wants i'll sell the LS/vtec, trans, clutch, flywheel, mounts and t bracket for $1500</p>
]]></description><link>https://fargostreet.com/topic/20499/honda-parts</link><generator>RSS for Node</generator><lastBuildDate>Wed, 27 May 2026 23:41:32 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/20499.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 26 Jul 2011 15:05:15 GMT</pubDate><ttl>60</ttl></channel></rss>
