<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[1991 Civic lx]]></title><description><![CDATA[<p dir="auto">Well time has come to move on to a different car, with that said the civic has to go. I'm hoping for a quick sale so the price is firm and reasonable given the condition of the car.</p>
<p dir="auto">VIN - 1HGED3555M053539<br />
1991 Honda Civic LX<br />
130,000 miles (just off hand will update with correct milage)<br />
4 door sedan<br />
D16a6 swapped<br />
5 speed SI trans</p>
<p dir="auto">Mods: everything engine/turbo wise that was done has 6-7K miles on it.</p>
<p dir="auto">Engine:</p>
<ul>
<li>D16a6 swap</li>
<li>boomslang dpfi to mpfi obd1 harness (can be converted back to stock with a stock harness no wiring required)</li>
<li>Vitara /LS rod combo (roughly 7.1:1 compression)</li>
<li>Stock SI head, intake manifold, throttle body</li>
<li>Delta 272 cam (regrind)</li>
<li>Oem Honda gaskets and seals</li>
<li>Act extreme pressure plate W/ reman. factory style disc (works great)</li>
<li>New axles (parts store brand)</li>
<li>New alternator and battery</li>
<li>running crome pro on a chipped P06</li>
<li>3 bar map sensor</li>
<li>new full length radiator</li>
<li>ungraded p/s cooler</li>
<li>powder coated valve cover (wrinkle black)</li>
</ul>
<p dir="auto">Suspension/brakes:</p>
<ul>
<li>Tein basic coilovers ( seem to clunk on harsh bumps, can be rebuild)</li>
<li>Full Integra GSR rear disk swap with blox rear LCA's in black.</li>
<li>(uninstalled) powder coated front DA integra uprights and hubs, new rotors, pads, calipers. Only needs wheel bearings and assembly.</li>
<li>energy shifter bushings</li>
<li>4 wheel alignment</li>
</ul>
<p dir="auto">Turbo: Running 15-18 lbs</p>
<ul>
<li>Factory Sr20 T25 turbo ( has shaft play but still works great considering it's age)</li>
<li>Moddified srt-4  fmic with 2" inlet/outlets</li>
<li>1.75" hot side mild steel charge piping (powder coated wrinkle black)</li>
<li>2" aluminum cold side charge piping (powder coated wrinkle black)</li>
<li>silicon couplers all around with quality hose clamps</li>
<li>custom turbo manifold for quick spool (1.4" runners, merge collector, t25 based)</li>
<li>2.5" turbo back exhaust with magnaflow muffler. 4 peice exhaust for easy servicing</li>
<li>all oem nissan gaskets on the turbo/exhaust</li>
<li>680cc?? injectors (unknown brand and size. were bought second hand and machined to fit, work great and have zero issues)</li>
</ul>
<p dir="auto">exterior:</p>
<ul>
<li>oem steel wheels with hubcaps and ok tires (sleeper)</li>
<li>Civic VX wheels with winterforce tires for winter</li>
<li>Rust, LOL</li>
</ul>
<p dir="auto">Interior:</p>
<ul>
<li>Stock blue interior</li>
<li>has a grant steering wheel installed currently but i do have the oem cruise control wheel also, fully functioning.</li>
<li>oem wrx boost gauge installed on column</li>
<li>Re audio speakers all around</li>
<li>Panasonic deck (sucks but works)</li>
</ul>
<p dir="auto">Pictures:</p>
<p dir="auto"><img src="http://i71.photobucket.com/albums/i123/mattgroshong/mattscivic4door001.jpg" alt="legacy image" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="http://i71.photobucket.com/albums/i123/mattgroshong/mattscivic4door003.jpg" alt="legacy image" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="http://i71.photobucket.com/albums/i123/mattgroshong/mattscivic4door002.jpg" alt="legacy image" class=" img-fluid img-markdown" /></p>
<p dir="auto">LS rods<br />
<img src="http://i71.photobucket.com/albums/i123/mattgroshong/D16a6enginepics004.jpg" alt="legacy image" class=" img-fluid img-markdown" /></p>
<p dir="auto">Turbo manifold<br />
<img src="http://i71.photobucket.com/albums/i123/mattgroshong/D16a6enginepics035.jpg" alt="legacy image" class=" img-fluid img-markdown" /></p>
<p dir="auto">intercooler<br />
<img src="http://i71.photobucket.com/albums/i123/mattgroshong/D16a6enginepics031.jpg" alt="legacy image" class=" img-fluid img-markdown" /></p>
<p dir="auto">engine<br />
<img src="http://i71.photobucket.com/albums/i123/mattgroshong/pics006-1.jpg" alt="legacy image" class=" img-fluid img-markdown" /></p>
<p dir="auto"><strong>Price: $2500 FIRM</strong></p>
<p dir="auto">The bad:</p>
<ul>
<li>rust, It has rust and is only going to get worse unless taken care of. It hasn't bothered me but it is one of the big negatives of the car.</li>
<li>Rear end collision, this car was rear ended hard and as a result the passenger rear door is misaligned and is hard to shut but stays shut. Will need frame work but i was quoted between $500-700 to fix it.</li>
<li>Truck is held shut, The truck latch finally gave may this winter at the coldest time. wouldn't stay shut so i tied it shut with a rope. (ghetto but works)</li>
</ul>
<p dir="auto">Contact:</p>
<p dir="auto">Matt Groshong<br />
701-238-4855<br />
call after 4:30 pm please or text w/e if i don't answer leave a message and i will call back.</p>
<p dir="auto">I'm sure i'm missing some stuff but if you come look at it you will not be disappointing.</p>
]]></description><link>https://fargostreet.com/topic/20527/1991-civic-lx</link><generator>RSS for Node</generator><lastBuildDate>Wed, 27 May 2026 23:45:24 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/20527.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 11 Aug 2011 03:56:39 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to 1991 Civic lx on Sat, 20 Aug 2011 20:09:51 GMT]]></title><description><![CDATA[<p dir="auto">Sold</p>
]]></description><link>https://fargostreet.com/post/312618</link><guid isPermaLink="true">https://fargostreet.com/post/312618</guid><dc:creator><![CDATA[DrifterExtreme]]></dc:creator><pubDate>Sat, 20 Aug 2011 20:09:51 GMT</pubDate></item><item><title><![CDATA[Reply to 1991 Civic lx on Sat, 20 Aug 2011 07:44:40 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">DrifterExtreme;324370 wrote:<br />
Nice one up torbs, you da man.</p>
<p dir="auto">I'm not sayin, but I'm jus sayin. GL on sale <img src="https://fargostreet.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f642.png?v=40430adaedb" class="not-responsive emoji emoji-android emoji--slightly_smiling_face" style="height:23px;width:auto;vertical-align:middle" title=":)" alt="🙂" /></p>
]]></description><link>https://fargostreet.com/post/312615</link><guid isPermaLink="true">https://fargostreet.com/post/312615</guid><dc:creator><![CDATA[torbs]]></dc:creator><pubDate>Sat, 20 Aug 2011 07:44:40 GMT</pubDate></item><item><title><![CDATA[Reply to 1991 Civic lx on Sat, 20 Aug 2011 01:05:36 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">torbs;324369 wrote:<br />
My sedan is still going with 206k+ on it...bout 14k of which has been boosted on a 50 trim. <img src="https://fargostreet.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f642.png?v=40430adaedb" class="not-responsive emoji emoji-android emoji--slightly_smiling_face" style="height:23px;width:auto;vertical-align:middle" title=":)" alt="🙂" /> Jus sayin</p>
<p dir="auto">Nice one up torbs, you da man.</p>
]]></description><link>https://fargostreet.com/post/312611</link><guid isPermaLink="true">https://fargostreet.com/post/312611</guid><dc:creator><![CDATA[DrifterExtreme]]></dc:creator><pubDate>Sat, 20 Aug 2011 01:05:36 GMT</pubDate></item><item><title><![CDATA[Reply to 1991 Civic lx on Fri, 19 Aug 2011 17:25:15 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">DrifterExtreme;324347 wrote:<br />
Heath answered this pretty spot on. But show me one stock turbo d series that has any real miles on it? They don't exist as they blow up from being wholly under built for regular turbo duty.</p>
<p dir="auto">My sedan is still going with 206k+ on it...bout 14k of which has been boosted on a 50 trim. <img src="https://fargostreet.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f642.png?v=40430adaedb" class="not-responsive emoji emoji-android emoji--slightly_smiling_face" style="height:23px;width:auto;vertical-align:middle" title=":)" alt="🙂" /> Jus sayin</p>
]]></description><link>https://fargostreet.com/post/312610</link><guid isPermaLink="true">https://fargostreet.com/post/312610</guid><dc:creator><![CDATA[torbs]]></dc:creator><pubDate>Fri, 19 Aug 2011 17:25:15 GMT</pubDate></item><item><title><![CDATA[Reply to 1991 Civic lx on Thu, 18 Aug 2011 01:32:44 GMT]]></title><description><![CDATA[<p dir="auto">Nice fab work matt</p>
]]></description><link>https://fargostreet.com/post/312591</link><guid isPermaLink="true">https://fargostreet.com/post/312591</guid><dc:creator><![CDATA[zbrown]]></dc:creator><pubDate>Thu, 18 Aug 2011 01:32:44 GMT</pubDate></item><item><title><![CDATA[Reply to 1991 Civic lx on Wed, 17 Aug 2011 22:47:35 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">Quada;324334 wrote:<br />
why did you build the motor if you just put a t25 on it? were you planning to upgrade in the future?</p>
<p dir="auto">Heath answered this pretty spot on. But show me one stock turbo d series that has any real miles on it? They don't exist as they blow up from being wholly under built for regular turbo duty.</p>
]]></description><link>https://fargostreet.com/post/312588</link><guid isPermaLink="true">https://fargostreet.com/post/312588</guid><dc:creator><![CDATA[DrifterExtreme]]></dc:creator><pubDate>Wed, 17 Aug 2011 22:47:35 GMT</pubDate></item><item><title><![CDATA[Reply to 1991 Civic lx on Wed, 17 Aug 2011 13:12:38 GMT]]></title><description><![CDATA[<p dir="auto">Good luck with the sale matt! This is one of my all time favorite builds. So clean.</p>
]]></description><link>https://fargostreet.com/post/312578</link><guid isPermaLink="true">https://fargostreet.com/post/312578</guid><dc:creator><![CDATA[SPANISH-RICE]]></dc:creator><pubDate>Wed, 17 Aug 2011 13:12:38 GMT</pubDate></item><item><title><![CDATA[Reply to 1991 Civic lx on Wed, 17 Aug 2011 12:42:09 GMT]]></title><description><![CDATA[<p dir="auto">Did you miss the part where he said he built it to be a daily driver. So it needed to have some level of reliability? Have you seen stock D series rods?</p>
]]></description><link>https://fargostreet.com/post/312576</link><guid isPermaLink="true">https://fargostreet.com/post/312576</guid><dc:creator><![CDATA[GarageAlchemist]]></dc:creator><pubDate>Wed, 17 Aug 2011 12:42:09 GMT</pubDate></item><item><title><![CDATA[Reply to 1991 Civic lx on Wed, 17 Aug 2011 08:02:06 GMT]]></title><description><![CDATA[<p dir="auto">why did you build the motor if you just put a t25 on it? were you planning to upgrade in the future?</p>
]]></description><link>https://fargostreet.com/post/312575</link><guid isPermaLink="true">https://fargostreet.com/post/312575</guid><dc:creator><![CDATA[Quada]]></dc:creator><pubDate>Wed, 17 Aug 2011 08:02:06 GMT</pubDate></item><item><title><![CDATA[Reply to 1991 Civic lx on Wed, 17 Aug 2011 02:36:23 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">DrifterExtreme;324329 wrote:<br />
To be honest i have no idea as this has never been on a dyno. I can tell you i ran low 14's at 100-105 mph with horrible launches (fail). I would guess 160-180 hp maybe but the power band is not typical turbo Honda. It is more mid range then top end as i built this as a daily driver not a race car.</p>
<p dir="auto">i'll second that, the power isn't all sitting at the top of the rev range, very useable power with quick spool-up. The car is a hoot to drive.</p>
]]></description><link>https://fargostreet.com/post/312572</link><guid isPermaLink="true">https://fargostreet.com/post/312572</guid><dc:creator><![CDATA[GarageAlchemist]]></dc:creator><pubDate>Wed, 17 Aug 2011 02:36:23 GMT</pubDate></item><item><title><![CDATA[Reply to 1991 Civic lx on Wed, 17 Aug 2011 02:08:55 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">harm;324322 wrote:<br />
Any idea how much power it's actually making?</p>
<p dir="auto">To be honest i have no idea as this has never been on a dyno. I can tell you i ran low 14's at 100-105 mph with horrible launches (fail). I would guess 160-180 hp maybe but the power band is not typical turbo Honda. It is more mid range then top end as i built this as a daily driver not a race car.</p>
]]></description><link>https://fargostreet.com/post/312570</link><guid isPermaLink="true">https://fargostreet.com/post/312570</guid><dc:creator><![CDATA[DrifterExtreme]]></dc:creator><pubDate>Wed, 17 Aug 2011 02:08:55 GMT</pubDate></item><item><title><![CDATA[Reply to 1991 Civic lx on Wed, 17 Aug 2011 00:41:43 GMT]]></title><description><![CDATA[<p dir="auto">Any idea how much power it's actually making?</p>
]]></description><link>https://fargostreet.com/post/312563</link><guid isPermaLink="true">https://fargostreet.com/post/312563</guid><dc:creator><![CDATA[harm]]></dc:creator><pubDate>Wed, 17 Aug 2011 00:41:43 GMT</pubDate></item><item><title><![CDATA[Reply to 1991 Civic lx on Mon, 15 Aug 2011 21:54:49 GMT]]></title><description><![CDATA[<p dir="auto">glws crazy sleeper</p>
]]></description><link>https://fargostreet.com/post/312541</link><guid isPermaLink="true">https://fargostreet.com/post/312541</guid><dc:creator><![CDATA[99civic]]></dc:creator><pubDate>Mon, 15 Aug 2011 21:54:49 GMT</pubDate></item><item><title><![CDATA[Reply to 1991 Civic lx on Mon, 15 Aug 2011 21:49:08 GMT]]></title><description><![CDATA[<p dir="auto">Bump</p>
]]></description><link>https://fargostreet.com/post/312539</link><guid isPermaLink="true">https://fargostreet.com/post/312539</guid><dc:creator><![CDATA[DrifterExtreme]]></dc:creator><pubDate>Mon, 15 Aug 2011 21:49:08 GMT</pubDate></item><item><title><![CDATA[Reply to 1991 Civic lx on Thu, 11 Aug 2011 05:14:21 GMT]]></title><description><![CDATA[<p dir="auto">Don't forget, it's running 17psi <img src="https://fargostreet.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f642.png?v=40430adaedb" class="not-responsive emoji emoji-android emoji--slightly_smiling_face" style="height:23px;width:auto;vertical-align:middle" title=":)" alt="🙂" /></p>
<p dir="auto">free bump</p>
]]></description><link>https://fargostreet.com/post/312493</link><guid isPermaLink="true">https://fargostreet.com/post/312493</guid><dc:creator><![CDATA[torbs]]></dc:creator><pubDate>Thu, 11 Aug 2011 05:14:21 GMT</pubDate></item></channel></rss>
