<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Lots of Honda and Subaru stuff...]]></title><description><![CDATA[<p dir="auto">Pics upon request as there is alot of stuff</p>
<p dir="auto">Honda:</p>
<p dir="auto">D16y7 5 speed tranny (works good no grinds)- 75$<br />
D16y8 5 speed tranny (3rd gear grind)- 50$<br />
D16z6 stock oil pan- 5$<br />
D16 axles (less then 1000 miles)- 75$<br />
B series intermediate shaft (male x female)- 25$<br />
D16z6 intake manifold w/ throttle body &amp; fuel rail (x2)- 25$/each<br />
DNA Motoring strut tower bars front and back (red)- 25$<br />
D16y8 Valve cover (x2)- 25$/each<br />
OBD1 ecu to OBD2 jumper harness- 25$<br />
OBD2 ecu to OBD1 jumper harness- 25$<br />
Stock z6 throttle body w/ newer map and tps- 15$<br />
Stock HF exhaust manifold- 5$<br />
Stock y8 cam gear- 1$<br />
B series AEM fuel rail (truck bed liner spray painted)- 25$<br />
Almost brand new aftermarket 68mm tb w/map &amp; tps- 100$<br />
OBD2 Gsr ecu (p72)- 30$<br />
Brand new Golden Eagle pro series D16 fuel rail (black)- 100$<br />
Blox stage 2 y8 cam w/ stock y8 cam- 150$for both<br />
Innovative rear mount in eg- 50$<br />
Autometer pro comp ultra lite oil psi gauge (electrical/no sender) 25$<br />
Autometer pro comp ultra lite a/f ratio gauge- 10$<br />
New Eg civic front ball joints (lower) TRW part# 104216- 25$ for both<br />
D16 vtec solenoid- 5$<br />
Hasport 3 post driver mount- 50$<br />
3- misc rear t brackets (all d i believe)- 5$each<br />
Tial wastegate springs 1-yellow 1-green- 2$each<br />
Stock B series 3 bolt driver mount with red energy inserts- 25$<br />
Ebay tranny and rear mounts for hydro eg d series- 25$<br />
D series skunk2 pro intake manifold (bare)- 150$<br />
STR billit 68mm throttle body w/tps &amp; map- 100$<br />
13" rims w/ 22"x 8" slicks 4x100 (lots of life left)- 250$</p>
<p dir="auto">Subaru:<br />
Helix High flow catted 3" downpipe- offer<br />
BPM Tmic (THICK) w/ silicon y pipe- offer<br />
Greddy catch can (no lines)- 25$<br />
Stock 04-05 wrx tmic- 75$<br />
Grimmspeed 3 port BCS 02-05 wrx- 100$<br />
NRG quick release wheel w/ NRG hub- 300$<br />
K&amp;N drop in filter- 10$<br />
02+ gauge surround pod (two spots for gauges)- 30$<br />
04-05 wrx momo air bag (red inside)- 100$<br />
Wrx red momo shift knob- 30$<br />
Cobb intake pipe w/ filter &amp; maf- 100$<br />
IHI vf-30 turbo (no shaftplay)- 200$<br />
Perkins turbo part # 2674A402 (no shaft play)- 200$</p>
<p dir="auto">Text (218) 731 5017 is preffered... can ship or meet up depending on location THANKS</p>
]]></description><link>https://fargostreet.com/topic/20630/lots-of-honda-and-subaru-stuff...</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 02:07:44 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/20630.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 10 Oct 2011 12:17:51 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Lots of Honda and Subaru stuff... on Fri, 02 Dec 2011 17:17:23 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">Bassplayer;325546 wrote:<br />
Do you happen to have a Fuel pressure regulator at all? I might be wrong but I remember a for sale ad awhile ago with one.</p>
<p dir="auto">i have an adjustable obx style one for y8 style fuel rail and a couple stock regular style ones</p>
]]></description><link>https://fargostreet.com/post/313788</link><guid isPermaLink="true">https://fargostreet.com/post/313788</guid><dc:creator><![CDATA[blackcherryTSi]]></dc:creator><pubDate>Fri, 02 Dec 2011 17:17:23 GMT</pubDate></item><item><title><![CDATA[Reply to Lots of Honda and Subaru stuff... on Fri, 02 Dec 2011 17:09:32 GMT]]></title><description><![CDATA[<p dir="auto">Do you happen to have a Fuel pressure regulator at all? I might be wrong but I remember a for sale ad awhile ago with one.</p>
]]></description><link>https://fargostreet.com/post/313787</link><guid isPermaLink="true">https://fargostreet.com/post/313787</guid><dc:creator><![CDATA[Bassplayer]]></dc:creator><pubDate>Fri, 02 Dec 2011 17:09:32 GMT</pubDate></item><item><title><![CDATA[Reply to Lots of Honda and Subaru stuff... on Fri, 02 Dec 2011 04:43:38 GMT]]></title><description><![CDATA[<p dir="auto">Bump! Will change more when I get to a computer but for now</p>
<p dir="auto">Slicks- 200$Obo<br />
Blox y8 stage 2 cam- 100$<br />
NRG wheel and quick release hub- 200$<br />
Huge BPM tmic- 200$<br />
Subaru GM 3 port BCS- 50$</p>
]]></description><link>https://fargostreet.com/post/313786</link><guid isPermaLink="true">https://fargostreet.com/post/313786</guid><dc:creator><![CDATA[blackcherryTSi]]></dc:creator><pubDate>Fri, 02 Dec 2011 04:43:38 GMT</pubDate></item></channel></rss>
