<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[squeeky serpentine belt]]></title><description><![CDATA[<p dir="auto">can it just be tightened?  Or does it have to be replaced?  The cracks dont look that deep or close together......This is on a 2002 suzuki aerio.  I need to know by friday afternoon so someone please answer quick!  Thanks</p>
]]></description><link>https://fargostreet.com/topic/2066/squeeky-serpentine-belt</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 17:45:34 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/2066.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 25 Mar 2005 05:21:58 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to squeeky serpentine belt on Tue, 29 Mar 2005 16:17:22 GMT]]></title><description><![CDATA[<p dir="auto">If I remember correctly, when I worked at my old Suzuki dealership.  There may have been a revised pulley and belt for the early Aerio's.  Don't use belt dressing....it's only a temp fix and usually slings crap all over your engine bay.</p>
<p dir="auto">More than likely, with a 2002 model......just get a belt.  If it has more than 3 cracks per inch...it's time.  Not only does a cracked belt not hold as well, it also dries out after time.  Making it squeal.</p>
<p dir="auto">Wiz</p>
]]></description><link>https://fargostreet.com/post/38095</link><guid isPermaLink="true">https://fargostreet.com/post/38095</guid><dc:creator><![CDATA[Wizard]]></dc:creator><pubDate>Tue, 29 Mar 2005 16:17:22 GMT</pubDate></item><item><title><![CDATA[Reply to squeeky serpentine belt on Tue, 29 Mar 2005 03:51:02 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">jct_4628 wrote:<br />
it was a bad fuel pump</p>
<p dir="auto">Is that driven off the belt?????????????????????????????</p>
]]></description><link>https://fargostreet.com/post/37903</link><guid isPermaLink="true">https://fargostreet.com/post/37903</guid><dc:creator><![CDATA[XJHEAD]]></dc:creator><pubDate>Tue, 29 Mar 2005 03:51:02 GMT</pubDate></item><item><title><![CDATA[Reply to squeeky serpentine belt on Tue, 29 Mar 2005 03:40:08 GMT]]></title><description><![CDATA[<p dir="auto">it was a bad fuel pump</p>
]]></description><link>https://fargostreet.com/post/37882</link><guid isPermaLink="true">https://fargostreet.com/post/37882</guid><dc:creator><![CDATA[jct_4628]]></dc:creator><pubDate>Tue, 29 Mar 2005 03:40:08 GMT</pubDate></item><item><title><![CDATA[Reply to squeeky serpentine belt on Tue, 29 Mar 2005 03:07:02 GMT]]></title><description><![CDATA[<p dir="auto">First off never use belt dressing on a serpentimne belt, it wont help. It wasn't designed for a flat belt. Second, if the belt is squealing, then it may be an accesory pulley or an idler/tensioner pulley. Remove the belt and check all pulleys for roughness or excessive play. I've seen many belts (even serpentine belts) squeal. But it is usually caused by a bad pulley or bearing.</p>
]]></description><link>https://fargostreet.com/post/37834</link><guid isPermaLink="true">https://fargostreet.com/post/37834</guid><dc:creator><![CDATA[weshole]]></dc:creator><pubDate>Tue, 29 Mar 2005 03:07:02 GMT</pubDate></item><item><title><![CDATA[Reply to squeeky serpentine belt on Tue, 29 Mar 2005 02:12:38 GMT]]></title><description><![CDATA[<p dir="auto">I had the same kinda problem but the belt was getting wet because a garud got ripped off</p>
]]></description><link>https://fargostreet.com/post/37810</link><guid isPermaLink="true">https://fargostreet.com/post/37810</guid><dc:creator><![CDATA[pjm710]]></dc:creator><pubDate>Tue, 29 Mar 2005 02:12:38 GMT</pubDate></item><item><title><![CDATA[Reply to squeeky serpentine belt on Mon, 28 Mar 2005 02:17:45 GMT]]></title><description><![CDATA[<p dir="auto">i would agree some belt dressing will help</p>
]]></description><link>https://fargostreet.com/post/37611</link><guid isPermaLink="true">https://fargostreet.com/post/37611</guid><dc:creator><![CDATA[brokedsm]]></dc:creator><pubDate>Mon, 28 Mar 2005 02:17:45 GMT</pubDate></item><item><title><![CDATA[Reply to squeeky serpentine belt on Fri, 25 Mar 2005 05:42:18 GMT]]></title><description><![CDATA[<p dir="auto">good advise</p>
]]></description><link>https://fargostreet.com/post/36918</link><guid isPermaLink="true">https://fargostreet.com/post/36918</guid><dc:creator><![CDATA[My NOva]]></dc:creator><pubDate>Fri, 25 Mar 2005 05:42:18 GMT</pubDate></item><item><title><![CDATA[Reply to squeeky serpentine belt on Fri, 25 Mar 2005 05:40:15 GMT]]></title><description><![CDATA[<p dir="auto">IMO, I don't think I've ever heard a serpantine belt squeal... (only slip when people try to make boost with the blowers)</p>
<p dir="auto">(and when you asked me I didn't realize it was on a different car.. thought it was the blazer and we just replaced that not that long ago.)<br />
...but, maybe it is the belt..  dunno.</p>
<p dir="auto">when does it squeal..  idle or under load?</p>
<p dir="auto">if it's at idle OR under load, I would be leary of an accessory bearing going out (or idler/tensioner).<br />
if it's only under load, could possibly be the belt I guess.</p>
<p dir="auto">What I'd do if if were me is pull the belt off the motor and turn the accessories by hand.  If it's an accessory/idler/tensioner issue it would very likely make it's self apparent then.</p>
]]></description><link>https://fargostreet.com/post/36917</link><guid isPermaLink="true">https://fargostreet.com/post/36917</guid><dc:creator><![CDATA[dubbsy]]></dc:creator><pubDate>Fri, 25 Mar 2005 05:40:15 GMT</pubDate></item><item><title><![CDATA[Reply to squeeky serpentine belt on Fri, 25 Mar 2005 05:26:33 GMT]]></title><description><![CDATA[<p dir="auto">dude if it squeks go to and auto parts store and pick up a spray can of belt dressing should work, or buy a new belt for it no more then 12-15 bucks</p>
]]></description><link>https://fargostreet.com/post/36915</link><guid isPermaLink="true">https://fargostreet.com/post/36915</guid><dc:creator><![CDATA[My NOva]]></dc:creator><pubDate>Fri, 25 Mar 2005 05:26:33 GMT</pubDate></item></channel></rss>
