<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[twins build]]></title><description><![CDATA[<p dir="auto">Figured I would share the twins i am building</p>
<p dir="auto">I tow rather heavy at times, and with my current larger single i get surge at lower RPM when i try to use any power.......that pisses me off......</p>
<p dir="auto">it is great above 70mph, i can cool and run 45psi continous thenEGTs run a little high for my liking too when towing not under full power.... it just sits at 1100-1200* whether i am at 10psi or 45psi</p>
<p dir="auto">so i am doing a smaller set of twins, should be VERY responsive, and tow like a mother at any speed</p>
<p dir="auto">current turbo i have been running is a BW s300, 65mm billet Ti compressor, 67mm turbine, 14cm wastegated housing.....</p>
<p dir="auto">i will carry that over to be my primary (almost identical to the BD super B special)</p>
<p dir="auto">secondary is a holset he341, it is off the 03-04.5 CR dodges.... smallest turbo ever outfitted on the dodges....</p>
<p dir="auto">so first thing.... dont buy crappy studs as i learned on a budies VGT setup..... so i went to JD and ordered exactly what i wanted in grade 8 <img src="http://i152.photobucket.com/albums/s167/rotary1307cc/2011-10-17_09-20-51_533.jpg" alt="legacy image" class=" img-fluid img-markdown" /></p>
<p dir="auto">what a stock 341 looks like<img src="http://i262.photobucket.com/albums/ii103/5bravo9/GEDC0289.jpg" alt="legacy image" class=" img-fluid img-markdown" /></p>
<p dir="auto">first thing is to open that WG up, it is critical since this will be bypassing exhaust around the secondary turbine<br />
<img src="http://i152.photobucket.com/albums/s167/rotary1307cc/2011-09-15_17-44-44_991.jpg" alt="legacy image" class=" img-fluid img-markdown" /><img src="http://i152.photobucket.com/albums/s167/rotary1307cc/2011-09-15_18-33-22_984.jpg" alt="legacy image" class=" img-fluid img-markdown" /><img src="http://i152.photobucket.com/albums/s167/rotary1307cc/2011-09-15_18-34-13_929.jpg" alt="legacy image" class=" img-fluid img-markdown" />....</p>
<p dir="auto">hotside stuff is sch. 40 3".... and a heavy flange from buddies downpipe he didnt need<br />
<img src="http://i152.photobucket.com/albums/s167/rotary1307cc/2011-10-15_15-43-14_718.jpg" alt="legacy image" class=" img-fluid img-markdown" /></p>
<p dir="auto">and how to go from round to square with heavy wall....<br />
<img src="http://i152.photobucket.com/albums/s167/rotary1307cc/2011-10-19_08-20-30_187.jpg" alt="legacy image" class=" img-fluid img-markdown" /><img src="http://i152.photobucket.com/albums/s167/rotary1307cc/2011-10-19_08-26-51_39.jpg" alt="legacy image" class=" img-fluid img-markdown" /><img src="http://i152.photobucket.com/albums/s167/rotary1307cc/2011-10-21_08-12-26_823.jpg" alt="legacy image" class=" img-fluid img-markdown" /><img src="http://i152.photobucket.com/albums/s167/rotary1307cc/2011-10-22_17-38-03_203.jpg" alt="legacy image" class=" img-fluid img-markdown" />...</p>
<p dir="auto">I tig'd it so it should be strong, will add a brace to support the turbo from the block aswell<br />
<img src="http://i152.photobucket.com/albums/s167/rotary1307cc/2011-11-13_14-06-05_94.jpg" alt="legacy image" class=" img-fluid img-markdown" />...</p>
<p dir="auto">modded 341 compressor cover<br />
<img src="http://i152.photobucket.com/albums/s167/rotary1307cc/2011-11-13_16-38-50_716.jpg" alt="legacy image" class=" img-fluid img-markdown" /><img src="http://i152.photobucket.com/albums/s167/rotary1307cc/2011-11-13_16-40-00_741.jpg" alt="legacy image" class=" img-fluid img-markdown" /></p>
<p dir="auto">as of now<img src="http://i152.photobucket.com/albums/s167/rotary1307cc/2011-11-13_16-41-37_324.jpg" alt="legacy image" class=" img-fluid img-markdown" /></p>
<p dir="auto">I am interested and excited to see how they act, will have more pics</p>
]]></description><link>https://fargostreet.com/topic/20673/twins-build</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 03:02:03 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/20673.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 14 Nov 2011 02:33:01 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to twins build on Sat, 11 Feb 2012 01:17:11 GMT]]></title><description><![CDATA[<p dir="auto">Lol, don't get married or you lose all opportunity to even use a rubber</p>
]]></description><link>https://fargostreet.com/post/314476</link><guid isPermaLink="true">https://fargostreet.com/post/314476</guid><dc:creator><![CDATA[zbrown]]></dc:creator><pubDate>Sat, 11 Feb 2012 01:17:11 GMT</pubDate></item><item><title><![CDATA[Reply to twins build on Fri, 10 Feb 2012 23:37:33 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">zbrown;326232 wrote:<br />
The rubber was bothering me</p>
<p dir="auto">That's what she said.</p>
]]></description><link>https://fargostreet.com/post/314474</link><guid isPermaLink="true">https://fargostreet.com/post/314474</guid><dc:creator><![CDATA[PSiedTSi]]></dc:creator><pubDate>Fri, 10 Feb 2012 23:37:33 GMT</pubDate></item><item><title><![CDATA[Reply to twins build on Fri, 10 Feb 2012 23:26:27 GMT]]></title><description><![CDATA[<p dir="auto">Update, I just changed the intake up.  The rubber was bothering me</p>
<p dir="auto">It is a AFE pro dry filter, 5" plumbing</p>
<p dir="auto">It whistled loud before, probably too much now</p>
<p dir="auto"><img src="http://i152.photobucket.com/albums/s167/rotary1307cc/2012-02-01_16-24-47_241.jpg" alt="legacy image" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="http://i152.photobucket.com/albums/s167/rotary1307cc/2012-02-01_16-24-35_228.jpg" alt="legacy image" class=" img-fluid img-markdown" /></p>
]]></description><link>https://fargostreet.com/post/314473</link><guid isPermaLink="true">https://fargostreet.com/post/314473</guid><dc:creator><![CDATA[zbrown]]></dc:creator><pubDate>Fri, 10 Feb 2012 23:26:27 GMT</pubDate></item><item><title><![CDATA[Reply to twins build on Sun, 29 Jan 2012 17:39:12 GMT]]></title><description><![CDATA[<p dir="auto">so i still had the original balljoints in this thing, and i am not going to rid of it ever so i decided to stick some good stuff in there</p>
<p dir="auto">yes probably the most boring $700 worth of parts, but they sure are beefy</p>
<p dir="auto">big enough that i could not install them with my ball joint press</p>
<p dir="auto">and you can even rebuild these without removing them</p>
<p dir="auto">very nice quality IMO</p>
<p dir="auto"><img src="http://i152.photobucket.com/albums/s167/rotary1307cc/2012-01-27_11-08-04_935.jpg" alt="legacy image" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="http://i152.photobucket.com/albums/s167/rotary1307cc/2012-01-28_09-11-52_633.jpg" alt="legacy image" class=" img-fluid img-markdown" /></p>
]]></description><link>https://fargostreet.com/post/314373</link><guid isPermaLink="true">https://fargostreet.com/post/314373</guid><dc:creator><![CDATA[zbrown]]></dc:creator><pubDate>Sun, 29 Jan 2012 17:39:12 GMT</pubDate></item><item><title><![CDATA[Reply to twins build on Sun, 29 Jan 2012 17:38:47 GMT]]></title><description><![CDATA[<p dir="auto">thanks guys!</p>
<p dir="auto">and yeah, a diesel shop out here would be bank right now</p>
<p dir="auto">as long as you could make it smoke you would be making $$$$$$$$, lol</p>
]]></description><link>https://fargostreet.com/post/314372</link><guid isPermaLink="true">https://fargostreet.com/post/314372</guid><dc:creator><![CDATA[zbrown]]></dc:creator><pubDate>Sun, 29 Jan 2012 17:38:47 GMT</pubDate></item><item><title><![CDATA[Reply to twins build on Thu, 26 Jan 2012 03:56:44 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">integra_gsr98;326101 wrote:<br />
You need to open a diesel shop over there in oil country and take all of the oil riggers money....</p>
<p dir="auto">X2 For real. That would be a lucrative place to put a performance shop at the moment.</p>
]]></description><link>https://fargostreet.com/post/314344</link><guid isPermaLink="true">https://fargostreet.com/post/314344</guid><dc:creator><![CDATA[Bassplayer]]></dc:creator><pubDate>Thu, 26 Jan 2012 03:56:44 GMT</pubDate></item><item><title><![CDATA[Reply to twins build on Thu, 26 Jan 2012 02:28:19 GMT]]></title><description><![CDATA[<p dir="auto">You need to open a diesel shop over there in oil country and take all of the oil riggers money....</p>
]]></description><link>https://fargostreet.com/post/314342</link><guid isPermaLink="true">https://fargostreet.com/post/314342</guid><dc:creator><![CDATA[integra_gsr98]]></dc:creator><pubDate>Thu, 26 Jan 2012 02:28:19 GMT</pubDate></item><item><title><![CDATA[Reply to twins build on Wed, 25 Jan 2012 16:47:09 GMT]]></title><description><![CDATA[<p dir="auto">Nice Build. sounds great in video</p>
]]></description><link>https://fargostreet.com/post/314333</link><guid isPermaLink="true">https://fargostreet.com/post/314333</guid><dc:creator><![CDATA[Turbo-d16]]></dc:creator><pubDate>Wed, 25 Jan 2012 16:47:09 GMT</pubDate></item><item><title><![CDATA[Reply to twins build on Mon, 16 Jan 2012 02:20:40 GMT]]></title><description><![CDATA[<p dir="auto">That is so sweet. Nice build Zac</p>
]]></description><link>https://fargostreet.com/post/314228</link><guid isPermaLink="true">https://fargostreet.com/post/314228</guid><dc:creator><![CDATA[legacy-user-3898]]></dc:creator><pubDate>Mon, 16 Jan 2012 02:20:40 GMT</pubDate></item><item><title><![CDATA[Reply to twins build on Mon, 16 Jan 2012 00:23:52 GMT]]></title><description><![CDATA[<p dir="auto">Daaamn. Do want turbo diesel.</p>
]]></description><link>https://fargostreet.com/post/314227</link><guid isPermaLink="true">https://fargostreet.com/post/314227</guid><dc:creator><![CDATA[Bassplayer]]></dc:creator><pubDate>Mon, 16 Jan 2012 00:23:52 GMT</pubDate></item><item><title><![CDATA[Reply to twins build on Sun, 15 Jan 2012 23:48:58 GMT]]></title><description><![CDATA[<p dir="auto">holy balls, ear orgasm.  i need to see this thing in fargo again soon</p>
]]></description><link>https://fargostreet.com/post/314226</link><guid isPermaLink="true">https://fargostreet.com/post/314226</guid><dc:creator><![CDATA[Grr]]></dc:creator><pubDate>Sun, 15 Jan 2012 23:48:58 GMT</pubDate></item><item><title><![CDATA[Reply to twins build on Sun, 15 Jan 2012 22:40:58 GMT]]></title><description><![CDATA[<p dir="auto">and here is a vid</p>
<p dir="auto"><a href="http://www.youtube.com/watch?v=xJkFczQgz7o" rel="nofollow ugc">http://www.youtube.com/watch?v=xJkFczQgz7o</a></p>
]]></description><link>https://fargostreet.com/post/314224</link><guid isPermaLink="true">https://fargostreet.com/post/314224</guid><dc:creator><![CDATA[zbrown]]></dc:creator><pubDate>Sun, 15 Jan 2012 22:40:58 GMT</pubDate></item><item><title><![CDATA[Reply to twins build on Sun, 15 Jan 2012 22:40:12 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">DaveH;325979 wrote:<br />
Very cool!  Do you have any dyno sheets from the old setup?  It would be cool to dyno it now and compare.  <img src="https://fargostreet.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f604.png?v=40430adaedb" class="not-responsive emoji emoji-android emoji--smile" style="height:23px;width:auto;vertical-align:middle" title=":D" alt="😄" /></p>
<p dir="auto">yeah never any dyno beforeit is alot hotter now with the bigger pump though so it really isnt fairbut i do know that if i had done just the twins and nothing else it would of brought about an extra 300ftlbs in WAY sooner</p>
]]></description><link>https://fargostreet.com/post/314223</link><guid isPermaLink="true">https://fargostreet.com/post/314223</guid><dc:creator><![CDATA[zbrown]]></dc:creator><pubDate>Sun, 15 Jan 2012 22:40:12 GMT</pubDate></item><item><title><![CDATA[Reply to twins build on Sun, 15 Jan 2012 14:50:13 GMT]]></title><description><![CDATA[<p dir="auto">Very cool!  Do you have any dyno sheets from the old setup?  It would be cool to dyno it now and compare.  <img src="https://fargostreet.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f604.png?v=40430adaedb" class="not-responsive emoji emoji-android emoji--smile" style="height:23px;width:auto;vertical-align:middle" title=":D" alt="😄" /></p>
]]></description><link>https://fargostreet.com/post/314220</link><guid isPermaLink="true">https://fargostreet.com/post/314220</guid><dc:creator><![CDATA[DaveH]]></dc:creator><pubDate>Sun, 15 Jan 2012 14:50:13 GMT</pubDate></item><item><title><![CDATA[Reply to twins build on Sun, 15 Jan 2012 12:18:18 GMT]]></title><description><![CDATA[<p dir="auto">That's sweet man</p>
]]></description><link>https://fargostreet.com/post/314219</link><guid isPermaLink="true">https://fargostreet.com/post/314219</guid><dc:creator><![CDATA[Joel]]></dc:creator><pubDate>Sun, 15 Jan 2012 12:18:18 GMT</pubDate></item><item><title><![CDATA[Reply to twins build on Sun, 15 Jan 2012 01:51:49 GMT]]></title><description><![CDATA[<p dir="auto">Big thanks to Dave H! (again)</p>
<p dir="auto">he got me a new turbo my hands in a week! great, just great</p>
<p dir="auto">I traded my 64/68/14 for a new 66/73/.91 from dave</p>
<p dir="auto">i felt i just needed some more turbine on the primary because drive pressure stayed nice and around 1:1 until i started adding fuel then it made a nice uphill</p>
<p dir="auto">with the new turbo I cant imagine it working any better, boost is instant, and it builds and holds 53psi of boost with 54psi of drive pressure.  Moves out very nicely, and it tows like a N14 now</p>
<p dir="auto">I cannot get it to surge no matter what i try, I should of done this much sooner</p>
<p dir="auto">here you can see the difference in the 68 and 73 turbine, the 73 looks much easier flowing, with a clip cast or cut into it</p>
<p dir="auto"><img src="http://i152.photobucket.com/albums/s167/rotary1307cc/2012-01-12_17-30-44_38.jpg" alt="legacy image" class=" img-fluid img-markdown" /></p>
<p dir="auto">also i had to change the hotpipe up some for a T4 flange, i got an extended flange and man that was slick for making an easy to remove and install brace.  I feel it turned out fantastic</p>
<p dir="auto"><img src="http://i152.photobucket.com/albums/s167/rotary1307cc/2012-01-12_21-26-45_954.jpg" alt="legacy image" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="http://i152.photobucket.com/albums/s167/rotary1307cc/2012-01-12_21-27-09_987.jpg" alt="legacy image" class=" img-fluid img-markdown" /></p>
<p dir="auto">new crossover pipe</p>
<p dir="auto"><img src="http://i152.photobucket.com/albums/s167/rotary1307cc/2012-01-12_20-51-41_76.jpg" alt="legacy image" class=" img-fluid img-markdown" /></p>
<p dir="auto">and the finished pics</p>
<p dir="auto"><img src="http://i152.photobucket.com/albums/s167/rotary1307cc/2012-01-14_14-47-47_929.jpg" alt="legacy image" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="http://i152.photobucket.com/albums/s167/rotary1307cc/2012-01-14_14-46-25_758.jpg" alt="legacy image" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="http://i152.photobucket.com/albums/s167/rotary1307cc/2012-01-14_14-49-59_921.jpg" alt="legacy image" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="http://i152.photobucket.com/albums/s167/rotary1307cc/2012-01-14_14-52-04_345.jpg" alt="legacy image" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="http://i152.photobucket.com/albums/s167/rotary1307cc/2012-01-14_14-46-10_886.jpg" alt="legacy image" class=" img-fluid img-markdown" /></p>
<p dir="auto">easier than stock to get to the oil filter</p>
<p dir="auto"><img src="http://i152.photobucket.com/albums/s167/rotary1307cc/2012-01-14_14-51-31_378.jpg" alt="legacy image" class=" img-fluid img-markdown" /></p>
<p dir="auto">happy dodge</p>
<p dir="auto"><img src="http://i152.photobucket.com/albums/s167/rotary1307cc/2012-01-07_14-50-29_102.jpg" alt="legacy image" class=" img-fluid img-markdown" /></p>
<p dir="auto">and a little bit of rice, haha</p>
<p dir="auto"><img src="http://i152.photobucket.com/albums/s167/rotary1307cc/2012-01-05_13-42-51_371.jpg" alt="legacy image" class=" img-fluid img-markdown" /></p>
]]></description><link>https://fargostreet.com/post/314216</link><guid isPermaLink="true">https://fargostreet.com/post/314216</guid><dc:creator><![CDATA[zbrown]]></dc:creator><pubDate>Sun, 15 Jan 2012 01:51:49 GMT</pubDate></item><item><title><![CDATA[Reply to twins build on Sun, 15 Jan 2012 01:49:22 GMT]]></title><description><![CDATA[<p dir="auto">thanks guys!</p>
<p dir="auto">yes the pickup has about 8 gallons of bedliner on it, lol</p>
<p dir="auto">starts fine without the grids, i usually have it plugged in at home though. started in fargo at 0* without problems though.  I dont have my timing advance much so that helps as does keeping the stock compression ratio</p>
<p dir="auto">and all my stuff is old, cheap, and slow..... truth</p>
]]></description><link>https://fargostreet.com/post/314215</link><guid isPermaLink="true">https://fargostreet.com/post/314215</guid><dc:creator><![CDATA[zbrown]]></dc:creator><pubDate>Sun, 15 Jan 2012 01:49:22 GMT</pubDate></item><item><title><![CDATA[Reply to twins build on Fri, 06 Jan 2012 15:51:38 GMT]]></title><description><![CDATA[<p dir="auto">Nice welds, you've got skills!</p>
]]></description><link>https://fargostreet.com/post/314152</link><guid isPermaLink="true">https://fargostreet.com/post/314152</guid><dc:creator><![CDATA[TomTom]]></dc:creator><pubDate>Fri, 06 Jan 2012 15:51:38 GMT</pubDate></item><item><title><![CDATA[Reply to twins build on Mon, 02 Jan 2012 04:32:17 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">Quada;325877 wrote:<br />
Wow that looks good, man! Is your whole truck Rhino-lined?</p>
<p dir="auto">Indeed haven't you seen it?  He uses it to pull the 7 to the right side of the state so we can drool over it.</p>
]]></description><link>https://fargostreet.com/post/314120</link><guid isPermaLink="true">https://fargostreet.com/post/314120</guid><dc:creator><![CDATA[capitlj]]></dc:creator><pubDate>Mon, 02 Jan 2012 04:32:17 GMT</pubDate></item><item><title><![CDATA[Reply to twins build on Mon, 02 Jan 2012 01:01:18 GMT]]></title><description><![CDATA[<p dir="auto">How well does she start in the cold without the grid stuff?</p>
]]></description><link>https://fargostreet.com/post/314119</link><guid isPermaLink="true">https://fargostreet.com/post/314119</guid><dc:creator><![CDATA[funky_monkey58]]></dc:creator><pubDate>Mon, 02 Jan 2012 01:01:18 GMT</pubDate></item><item><title><![CDATA[Reply to twins build on Mon, 02 Jan 2012 00:23:52 GMT]]></title><description><![CDATA[<p dir="auto">Wow that looks good, man! Is your whole truck Rhino-lined?</p>
]]></description><link>https://fargostreet.com/post/314118</link><guid isPermaLink="true">https://fargostreet.com/post/314118</guid><dc:creator><![CDATA[Quada]]></dc:creator><pubDate>Mon, 02 Jan 2012 00:23:52 GMT</pubDate></item><item><title><![CDATA[Reply to twins build on Thu, 29 Dec 2011 14:36:08 GMT]]></title><description><![CDATA[<p dir="auto">Ok first of all the Borgeson steering box is wow, money well spent</p>
<p dir="auto">and the response on the twins is CRAZY, and the sounds are crazy, haha</p>
<p dir="auto">i havent pushed it past about half throttle but there it comes up to 35psi like a light switch, EGTs never above 1000* yet</p>
<p dir="auto">the wastegate on the smaller secondary turbo cracks at around 15psi...... up to around 25psi the primary and secondary are running about 50/50 for boost</p>
<p dir="auto">I havent been above that much but above 25psi it moves more to around 2/3 of the boost supported by the primary</p>
<p dir="auto">see what it does when the head is seated good... but for now it is killer</p>
<p dir="auto">here are some pics</p>
<p dir="auto">yes i was one Tbolt clamp short, and i dont have a bend necessary to fab the intake yet</p>
<p dir="auto">here is just a shot of the crossover with the bung i put in it</p>
<p dir="auto"><img src="http://i152.photobucket.com/albums/s167/rotary1307cc/2011-12-27_12-23-26_114.jpg" alt="legacy image" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="http://i152.photobucket.com/albums/s167/rotary1307cc/2011-12-28_14-18-45_599.jpg" alt="legacy image" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="http://i152.photobucket.com/albums/s167/rotary1307cc/2011-12-28_14-17-54_997.jpg" alt="legacy image" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="http://i152.photobucket.com/albums/s167/rotary1307cc/2011-12-28_14-15-24_728.jpg" alt="legacy image" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="http://i152.photobucket.com/albums/s167/rotary1307cc/2011-12-28_14-15-37_343.jpg" alt="legacy image" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="http://i152.photobucket.com/albums/s167/rotary1307cc/2011-12-28_12-06-26_923.jpg" alt="legacy image" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="http://i152.photobucket.com/albums/s167/rotary1307cc/2011-12-28_12-04-57_598.jpg" alt="legacy image" class=" img-fluid img-markdown" /></p>
<p dir="auto">and i reworked the harness a lot and cleaned that up, ABS crap is gone, grid BS gone, fuel heater BS gone, battery in back, fuel solenoid bs gone</p>
<p dir="auto">you can actually change the fuel filter with ease now</p>
<p dir="auto"><img src="http://i152.photobucket.com/albums/s167/rotary1307cc/2011-12-28_12-05-59_79.jpg" alt="legacy image" class=" img-fluid img-markdown" /></p>
]]></description><link>https://fargostreet.com/post/314107</link><guid isPermaLink="true">https://fargostreet.com/post/314107</guid><dc:creator><![CDATA[zbrown]]></dc:creator><pubDate>Thu, 29 Dec 2011 14:36:08 GMT</pubDate></item><item><title><![CDATA[Reply to twins build on Tue, 27 Dec 2011 14:14:49 GMT]]></title><description><![CDATA[<p dir="auto">Ok was at a stand still for a good while waiting for my head to get done.</p>
<p dir="auto">finally got that, they did a good job, i can nearly see my reflection in the deck surface</p>
<p dir="auto">motor is assembled, in, and running...... have one retorque done too</p>
<p dir="auto">ill get some vids and pics of everything complete and some analysis of how it feels when i can push it some when the head is good and seated</p>
<p dir="auto">I had said that i was going to keep it under 10psi till i got some heat cycles and retorques, but the dang thing comes up to 20psi with hardly any fuel now, such a crazy difference</p>
<p dir="auto">with the studs it seems most either have the rocker stands milled down or the valve covers ground to get the valve covers to fit.  I took a different approach</p>
<p dir="auto">as such</p>
<p dir="auto"><img src="http://i152.photobucket.com/albums/s167/rotary1307cc/2011-12-25_16-20-07_849.jpg" alt="legacy image" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="http://i152.photobucket.com/albums/s167/rotary1307cc/2011-12-25_19-17-53_6.jpg" alt="legacy image" class=" img-fluid img-markdown" /></p>
<p dir="auto">and the thing already has Luke's links all around on the front end with a box stabilizer so when it was apart i spent the $$ on a Borgeson box and shaft</p>
<p dir="auto">thing goes down the road cherry now</p>
<p dir="auto"><img src="http://i152.photobucket.com/albums/s167/rotary1307cc/2011-12-01_09-52-11_455.jpg" alt="legacy image" class=" img-fluid img-markdown" /></p>
]]></description><link>https://fargostreet.com/post/314096</link><guid isPermaLink="true">https://fargostreet.com/post/314096</guid><dc:creator><![CDATA[zbrown]]></dc:creator><pubDate>Tue, 27 Dec 2011 14:14:49 GMT</pubDate></item><item><title><![CDATA[Reply to twins build on Tue, 27 Dec 2011 14:13:40 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">funky_monkey58;325541 wrote:<br />
Fucking sweet dude!</p>
<p dir="auto">thanks man</p>
]]></description><link>https://fargostreet.com/post/314095</link><guid isPermaLink="true">https://fargostreet.com/post/314095</guid><dc:creator><![CDATA[zbrown]]></dc:creator><pubDate>Tue, 27 Dec 2011 14:13:40 GMT</pubDate></item></channel></rss>
