<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[1997 Honda Civic EX Coupe 5 spd Needs engine]]></title><description><![CDATA[<p dir="auto">Joel Witthoeft<br />
Moorhead, MN<br />
701-388-4seven9two</p>
<p dir="auto">1997 Honda Civic<br />
EX(sunroof)<br />
Manual Trans<br />
147k<br />
Power Locks and windows<br />
Compustar astro start<br />
Purchased this car from a customer of mine. The guy before him put Si Blades on it, other than that is completely stock with the stock y8 still in it. The car has very little rust on it. what you see in the picture is all of it, there is nothing else on the car that has rust. The bottom side of the car has a heavy undercoat I assume is aftermarket.<br />
To be nice the car would need:<br />
front bumper<br />
drivers side skirt<br />
This is a ND car which means no salt, which means less rust.<br />
In the last 4 years(when my customer owned it) it has had a new battery, new blower motor, new catalytic converter and flex pipe, Postcat 02 sensor, front and rear brakes, and many other things that I forgot already. The guy was by no means a "car guy" and just wanted a good reliable car. The guy neglected to change/check oil and spun the bearings, seizing the motor. I drained the oil and there are copper flakes in the old engine oil, and the crank will not turn. Here are some pics. I am currently on the search for a good y7 or y8 block. If I find one, I will be making this thing run again, but If I can sell it quick for 800 bucks, I will take the money now. Wheels are Si blades with brand new regency all season tires. No haggling, if you don't have 800 bucks, don't bother contacting me.<br />
<img src="http://img.photobucket.com/albums/v294/atmospere_adikt/2012-06-27_16-32-17_678.jpg" alt="legacy image" class=" img-fluid img-markdown" /><br />
<img src="http://img.photobucket.com/albums/v294/atmospere_adikt/2012-06-27_16-31-59_793.jpg" alt="legacy image" class=" img-fluid img-markdown" /><br />
<img src="http://img.photobucket.com/albums/v294/atmospere_adikt/2012-06-27_16-31-52_709.jpg" alt="legacy image" class=" img-fluid img-markdown" /><br />
<img src="http://img.photobucket.com/albums/v294/atmospere_adikt/2012-06-27_16-31-37_721.jpg" alt="legacy image" class=" img-fluid img-markdown" /><br />
<img src="http://img.photobucket.com/albums/v294/atmospere_adikt/2012-06-27_16-31-29_875.jpg" alt="legacy image" class=" img-fluid img-markdown" /><br />
<img src="http://img.photobucket.com/albums/v294/atmospere_adikt/2012-06-27_16-31-13_164.jpg" alt="legacy image" class=" img-fluid img-markdown" /></p>
]]></description><link>https://fargostreet.com/topic/20904/1997-honda-civic-ex-coupe-5-spd-needs-engine</link><generator>RSS for Node</generator><lastBuildDate>Wed, 27 May 2026 21:39:21 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/20904.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 27 Jun 2012 22:41:12 GMT</pubDate><ttl>60</ttl></channel></rss>
