<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[choosing a travel trailer]]></title><description><![CDATA[<p dir="auto">What are some must have's you guys have run into? looking for something 3000-3500 lbs. Going to be towing with 13 Pilot with 4500lb max cap. Will have trailer brake controller as well. I assume to get anything decently sized I am going to need to do a pop-up which is fine. Going to try to watch the paper/craigslist this fall and "steal" one. Any advice or leads on one would be awesome. Would like room to sleep 4-6 adults, and A/C</p>
]]></description><link>https://fargostreet.com/topic/21065/choosing-a-travel-trailer</link><generator>RSS for Node</generator><lastBuildDate>Wed, 27 May 2026 23:55:07 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/21065.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 29 Jul 2013 15:53:00 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to choosing a travel trailer on Tue, 06 Aug 2013 03:48:21 GMT]]></title><description><![CDATA[<p dir="auto">make sure you get plenty of water, gray and black tanks...  nothing worse than having the black tank fill up on you.  :-0</p>
]]></description><link>https://fargostreet.com/post/316408</link><guid isPermaLink="true">https://fargostreet.com/post/316408</guid><dc:creator><![CDATA[DaveH]]></dc:creator><pubDate>Tue, 06 Aug 2013 03:48:21 GMT</pubDate></item><item><title><![CDATA[Reply to choosing a travel trailer on Fri, 02 Aug 2013 20:02:05 GMT]]></title><description><![CDATA[<p dir="auto">going to be doing a mixture of both dry camping and hookups. mainly dry camping at brainerd, other than that, we will have hook ups. some sort of shower and toilet. cooking is not necessary as I usually try to grill everything. if its a pop up i'd like the ability to park motorcycle or 4 wheeler on top or pull it behind in a pup trailer.</p>
]]></description><link>https://fargostreet.com/post/316407</link><guid isPermaLink="true">https://fargostreet.com/post/316407</guid><dc:creator><![CDATA[Joel]]></dc:creator><pubDate>Fri, 02 Aug 2013 20:02:05 GMT</pubDate></item><item><title><![CDATA[Reply to choosing a travel trailer on Fri, 02 Aug 2013 18:07:41 GMT]]></title><description><![CDATA[<p dir="auto">4,500lbs will add up pretty quick in any type of travel trailer.  You should be looking for 3,500lb dry weight trailers.</p>
]]></description><link>https://fargostreet.com/post/316406</link><guid isPermaLink="true">https://fargostreet.com/post/316406</guid><dc:creator><![CDATA[MisterCMK]]></dc:creator><pubDate>Fri, 02 Aug 2013 18:07:41 GMT</pubDate></item><item><title><![CDATA[Reply to choosing a travel trailer on Mon, 29 Jul 2013 20:28:23 GMT]]></title><description><![CDATA[<p dir="auto">How far are you going to travel?  What amenities are important to you?  Do you want to dry camp or are you going to have hookups?</p>
]]></description><link>https://fargostreet.com/post/316398</link><guid isPermaLink="true">https://fargostreet.com/post/316398</guid><dc:creator><![CDATA[MisterCMK]]></dc:creator><pubDate>Mon, 29 Jul 2013 20:28:23 GMT</pubDate></item></channel></rss>
