<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Tire Pressure?]]></title><description><![CDATA[<p dir="auto">Do you guys know what the tire pressure should be for Kumho Ecsta 712s?  205/40/17</p>
]]></description><link>https://fargostreet.com/topic/2173/tire-pressure</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 18:23:42 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/2173.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 02 Apr 2005 18:40:21 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Tire Pressure? on Sat, 02 Apr 2005 21:47:24 GMT]]></title><description><![CDATA[<blockquote>
If the tire doesn't say what pressure to run, you just what ever the stock pressure is.<br />
95% of all cars, according to the manufacturer, the advised tire pressure is 35 psi. Look on the inside of the driverside door, it usually says right there.</p>
<p dir="auto">This is what I would keep it at on a non drag radial/racing slick tire on a passanger car.</p>
]]></description><link>https://fargostreet.com/post/39226</link><guid isPermaLink="true">https://fargostreet.com/post/39226</guid><dc:creator><![CDATA[94NDTA]]></dc:creator><pubDate>Sat, 02 Apr 2005 21:47:24 GMT</pubDate></item><item><title><![CDATA[Reply to Tire Pressure? on Sat, 02 Apr 2005 21:09:49 GMT]]></title><description><![CDATA[<p dir="auto">The tire will have a max pressure written on the sidewall...thats usually what you can go by, but obviously staying under it.  You cant really go by the cars "stock" tire pressure because thats only if your using the recommended tires that go on the stock wheels.  But when I had my low-pros I used that pressure as a base and went up from there till I was at where I felt comfortable</p>
]]></description><link>https://fargostreet.com/post/39225</link><guid isPermaLink="true">https://fargostreet.com/post/39225</guid><dc:creator><![CDATA[TsiTom]]></dc:creator><pubDate>Sat, 02 Apr 2005 21:09:49 GMT</pubDate></item><item><title><![CDATA[Reply to Tire Pressure? on Sat, 02 Apr 2005 20:46:54 GMT]]></title><description><![CDATA[<p dir="auto">If the tire doesn't say what pressure to run, you just what ever the stock pressure is.</p>
]]></description><link>https://fargostreet.com/post/39216</link><guid isPermaLink="true">https://fargostreet.com/post/39216</guid><dc:creator><![CDATA[treimche]]></dc:creator><pubDate>Sat, 02 Apr 2005 20:46:54 GMT</pubDate></item><item><title><![CDATA[Reply to Tire Pressure? on Sat, 02 Apr 2005 19:57:40 GMT]]></title><description><![CDATA[<p dir="auto">Id say you'd be really safe at about 35</p>
]]></description><link>https://fargostreet.com/post/39205</link><guid isPermaLink="true">https://fargostreet.com/post/39205</guid><dc:creator><![CDATA[TsiTom]]></dc:creator><pubDate>Sat, 02 Apr 2005 19:57:40 GMT</pubDate></item><item><title><![CDATA[Reply to Tire Pressure? on Sat, 02 Apr 2005 19:44:21 GMT]]></title><description><![CDATA[<p dir="auto">i had those exact tires about 3 years ago i think its 40 but it also says on the tire... all tires have it on them you just have to look</p>
]]></description><link>https://fargostreet.com/post/39204</link><guid isPermaLink="true">https://fargostreet.com/post/39204</guid><dc:creator><![CDATA[Big-D]]></dc:creator><pubDate>Sat, 02 Apr 2005 19:44:21 GMT</pubDate></item><item><title><![CDATA[Reply to Tire Pressure? on Sat, 02 Apr 2005 19:12:52 GMT]]></title><description><![CDATA[<p dir="auto">It should be on the tire itself what max pressure should be at.</p>
]]></description><link>https://fargostreet.com/post/39198</link><guid isPermaLink="true">https://fargostreet.com/post/39198</guid><dc:creator><![CDATA[weshole]]></dc:creator><pubDate>Sat, 02 Apr 2005 19:12:52 GMT</pubDate></item><item><title><![CDATA[Reply to Tire Pressure? on Sat, 02 Apr 2005 18:41:57 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">awd95mn wrote:<br />
Do you guys know what the tire pressure should be for Kumho Ecsta 712s?  205/40/17<br />
........35?</p>
]]></description><link>https://fargostreet.com/post/39192</link><guid isPermaLink="true">https://fargostreet.com/post/39192</guid><dc:creator><![CDATA[94NDTA]]></dc:creator><pubDate>Sat, 02 Apr 2005 18:41:57 GMT</pubDate></item></channel></rss>
