<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Plug Gap]]></title><description><![CDATA[<p dir="auto">I am finally putting my BPR7ES plugs in my talon...what should i gap em at?</p>
]]></description><link>https://fargostreet.com/topic/2381/plug-gap</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 09:03:10 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/2381.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 18 Apr 2005 22:54:40 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Plug Gap on Tue, 19 Apr 2005 18:20:32 GMT]]></title><description><![CDATA[<p dir="auto">thanks guys!</p>
]]></description><link>https://fargostreet.com/post/42599</link><guid isPermaLink="true">https://fargostreet.com/post/42599</guid><dc:creator><![CDATA[PSiedTSi]]></dc:creator><pubDate>Tue, 19 Apr 2005 18:20:32 GMT</pubDate></item><item><title><![CDATA[Reply to Plug Gap on Tue, 19 Apr 2005 17:46:42 GMT]]></title><description><![CDATA[<p dir="auto">As everyone else has said, run around .028".  I had to run down to .022" on 35psi and 8000rpm to get my car not to blow the spark out.   But, until you are running that much boost and stuff, keep it at around .028".</p>
]]></description><link>https://fargostreet.com/post/42592</link><guid isPermaLink="true">https://fargostreet.com/post/42592</guid><dc:creator><![CDATA[91nbtsi]]></dc:creator><pubDate>Tue, 19 Apr 2005 17:46:42 GMT</pubDate></item><item><title><![CDATA[Reply to Plug Gap on Tue, 19 Apr 2005 15:12:56 GMT]]></title><description><![CDATA[<p dir="auto">Run .028 and you will be fine.<br />
On my integra on pump gas and low boost I run .028-.030 and on race gas and 30+ psi I run .025.</p>
]]></description><link>https://fargostreet.com/post/42574</link><guid isPermaLink="true">https://fargostreet.com/post/42574</guid><dc:creator><![CDATA[integra_gsr98]]></dc:creator><pubDate>Tue, 19 Apr 2005 15:12:56 GMT</pubDate></item><item><title><![CDATA[Reply to Plug Gap on Tue, 19 Apr 2005 07:23:26 GMT]]></title><description><![CDATA[<p dir="auto">see how far you can make the gap and then try running it and see what happens.</p>
]]></description><link>https://fargostreet.com/post/42558</link><guid isPermaLink="true">https://fargostreet.com/post/42558</guid><dc:creator><![CDATA[amicheze]]></dc:creator><pubDate>Tue, 19 Apr 2005 07:23:26 GMT</pubDate></item><item><title><![CDATA[Reply to Plug Gap on Tue, 19 Apr 2005 05:25:12 GMT]]></title><description><![CDATA[<p dir="auto">15psi pump gas</p>
]]></description><link>https://fargostreet.com/post/42534</link><guid isPermaLink="true">https://fargostreet.com/post/42534</guid><dc:creator><![CDATA[PSiedTSi]]></dc:creator><pubDate>Tue, 19 Apr 2005 05:25:12 GMT</pubDate></item><item><title><![CDATA[Reply to Plug Gap on Tue, 19 Apr 2005 05:16:46 GMT]]></title><description><![CDATA[<p dir="auto">.028</p>
<p dir="auto">How much boost are you running and is it just pump gas?</p>
]]></description><link>https://fargostreet.com/post/42530</link><guid isPermaLink="true">https://fargostreet.com/post/42530</guid><dc:creator><![CDATA[95TsiAWD]]></dc:creator><pubDate>Tue, 19 Apr 2005 05:16:46 GMT</pubDate></item><item><title><![CDATA[Reply to Plug Gap on Tue, 19 Apr 2005 02:26:20 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">Fargo wrote:<br />
Keep opening them up till they blow out.....</p>
]]></description><link>https://fargostreet.com/post/42505</link><guid isPermaLink="true">https://fargostreet.com/post/42505</guid><dc:creator><![CDATA[XJHEAD]]></dc:creator><pubDate>Tue, 19 Apr 2005 02:26:20 GMT</pubDate></item><item><title><![CDATA[Reply to Plug Gap on Tue, 19 Apr 2005 02:25:31 GMT]]></title><description><![CDATA[<blockquote>
no more than .32.  actually, the reason that you want the smaller gap is because you want a pretty small spark.  why?  i can't remember... but a big gap (+.35) can result in pretty nasty misfiring, i know from experience.<br />
if you use a platinum plug, they've been known to misfire.  why?  because the combustion chamber is REALLY hot, platinum and iridium stay hotter longer than copper and may cause misfiring to occur.<br />
Don't go higher because cars with high cyl pressure will blow out the spark.</p>
]]></description><link>https://fargostreet.com/post/42504</link><guid isPermaLink="true">https://fargostreet.com/post/42504</guid><dc:creator><![CDATA[94NDTA]]></dc:creator><pubDate>Tue, 19 Apr 2005 02:25:31 GMT</pubDate></item><item><title><![CDATA[Reply to Plug Gap on Tue, 19 Apr 2005 02:01:13 GMT]]></title><description><![CDATA[<p dir="auto">no more than .32.  actually, the reason that you want the smaller gap is because you want a pretty small spark.  why?  i can't remember... but a big gap (+.35) can result in pretty nasty misfiring, i know from experience.<br />
if you use a platinum plug, they've been known to misfire.  why?  because the combustion chamber is REALLY hot, platinum and iridium stay hotter longer than copper and may cause misfiring to occur.</p>
]]></description><link>https://fargostreet.com/post/42501</link><guid isPermaLink="true">https://fargostreet.com/post/42501</guid><dc:creator><![CDATA[out there]]></dc:creator><pubDate>Tue, 19 Apr 2005 02:01:13 GMT</pubDate></item><item><title><![CDATA[Reply to Plug Gap on Tue, 19 Apr 2005 01:43:21 GMT]]></title><description><![CDATA[<p dir="auto">Keep opening them up till they blow out....</p>
]]></description><link>https://fargostreet.com/post/42499</link><guid isPermaLink="true">https://fargostreet.com/post/42499</guid><dc:creator><![CDATA[XJHEAD]]></dc:creator><pubDate>Tue, 19 Apr 2005 01:43:21 GMT</pubDate></item><item><title><![CDATA[Reply to Plug Gap on Tue, 19 Apr 2005 01:34:27 GMT]]></title><description><![CDATA[<p dir="auto">yeah i got it at like .029</p>
]]></description><link>https://fargostreet.com/post/42498</link><guid isPermaLink="true">https://fargostreet.com/post/42498</guid><dc:creator><![CDATA[PSiedTSi]]></dc:creator><pubDate>Tue, 19 Apr 2005 01:34:27 GMT</pubDate></item><item><title><![CDATA[Reply to Plug Gap on Tue, 19 Apr 2005 01:32:10 GMT]]></title><description><![CDATA[<p dir="auto">.35 is basically the max I would use on any FI or N20 application.</p>
]]></description><link>https://fargostreet.com/post/42496</link><guid isPermaLink="true">https://fargostreet.com/post/42496</guid><dc:creator><![CDATA[94NDTA]]></dc:creator><pubDate>Tue, 19 Apr 2005 01:32:10 GMT</pubDate></item><item><title><![CDATA[Reply to Plug Gap on Mon, 18 Apr 2005 23:26:01 GMT]]></title><description><![CDATA[<p dir="auto">i mean .028-.030....yeah but im running boost and that big of spark will blow out</p>
]]></description><link>https://fargostreet.com/post/42480</link><guid isPermaLink="true">https://fargostreet.com/post/42480</guid><dc:creator><![CDATA[PSiedTSi]]></dc:creator><pubDate>Mon, 18 Apr 2005 23:26:01 GMT</pubDate></item><item><title><![CDATA[Reply to Plug Gap on Mon, 18 Apr 2005 23:14:26 GMT]]></title><description><![CDATA[<p dir="auto">.060-.064 should give a nice big spark.</p>
]]></description><link>https://fargostreet.com/post/42479</link><guid isPermaLink="true">https://fargostreet.com/post/42479</guid><dc:creator><![CDATA[pin]]></dc:creator><pubDate>Mon, 18 Apr 2005 23:14:26 GMT</pubDate></item><item><title><![CDATA[Reply to Plug Gap on Mon, 18 Apr 2005 23:04:42 GMT]]></title><description><![CDATA[<p dir="auto">i found .030-.028...does that sound right?</p>
]]></description><link>https://fargostreet.com/post/42476</link><guid isPermaLink="true">https://fargostreet.com/post/42476</guid><dc:creator><![CDATA[PSiedTSi]]></dc:creator><pubDate>Mon, 18 Apr 2005 23:04:42 GMT</pubDate></item></channel></rss>
