<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[WTB B-series motor]]></title><description><![CDATA[<p dir="auto">Probably picking up a cheap 91 CRX Si shell with some B-series parts in it ready for a motor. It has a B16 ECU already so id like a B16 if anyone has one or knows of someone with one... im going to need a wiring harness for it too cause the guy tugged the engine out and took that with him... left the ECU though lol.</p>
<p dir="auto">Ill take a B16A1 or A2  <img src="https://fargostreet.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f604.png?v=40430adaedb" class="not-responsive emoji emoji-android emoji--smile" style="height:23px;width:auto;vertical-align:middle" title=":D" alt="😄" /><br />
B18A1 or a B18C1... I beleive thats the GSR motor right? I need pretty much everything minus the ECU if its a B16. Ill have motor mounts and shift linkage so I can just drop it in and wire it all up.</p>
<p dir="auto">Also anyone here done a swap like this, and is interested in helping me out?</p>
<p dir="auto">Thanks!<br />
Flowcus</p>
]]></description><link>https://fargostreet.com/topic/254/wtb-b-series-motor</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 02:42:07 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/254.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 03 Aug 2004 02:58:16 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to WTB B-series motor on Sat, 07 Aug 2004 22:25:17 GMT]]></title><description><![CDATA[<p dir="auto">Hope you get that Crx Rob.  Hows it looking?</p>
]]></description><link>https://fargostreet.com/post/2366</link><guid isPermaLink="true">https://fargostreet.com/post/2366</guid><dc:creator><![CDATA[Bryce]]></dc:creator><pubDate>Sat, 07 Aug 2004 22:25:17 GMT</pubDate></item><item><title><![CDATA[Reply to WTB B-series motor on Wed, 04 Aug 2004 02:03:29 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">josh_isakson wrote:<br />
Another setup you could try that would get you more HP/TQ and is less common is a CRV-Tec. Its a B20 Shortblock with a GSR Head. It's not possible to run a straight B20 either, due to the long intake manifold, it would pop out of the hood. If you decide to run a CRV-Tec I would recommend that you resleeve it.</p>
<p dir="auto">CRV-Tec will be faster than ITR(c5) or GSR(c1)</p>
<p dir="auto">but thats just my .02 cents</p>
<p dir="auto">Because resleeving is so cheap.  You're still stuck with a notoriously weak crank, and if you resleeve it why would you put in stock pistons and rods.  There's another 1000 bucks w/ bearings.  Then once you do that and you go buy your new oil pump, water pump, timing belt, dowel pins, oil feed for the cylinder head, head gasket, etc you're not very cost effective.</p>
<p dir="auto">Stick w/ the B16 if you want one that is local, otherwise my vote would be for an LS swap.  Once that's finished you can always add a VTEC head later.</p>
]]></description><link>https://fargostreet.com/post/2274</link><guid isPermaLink="true">https://fargostreet.com/post/2274</guid><dc:creator><![CDATA[integra_gsr98]]></dc:creator><pubDate>Wed, 04 Aug 2004 02:03:29 GMT</pubDate></item><item><title><![CDATA[Reply to WTB B-series motor on Tue, 03 Aug 2004 23:27:34 GMT]]></title><description><![CDATA[<p dir="auto">Actually im extreamly interested in that B16... Could you give me a list of whats done... or better yet call me 701-371-3468 id like to come check it out. The car is pretty much ready for the swap it has the shift linkage, mounts, ECU, but needs a harness. Im waiting for pics on it before buying it but if I do ill definately work a deal on that engine.</p>
<p dir="auto">Peace!<br />
Rob</p>
]]></description><link>https://fargostreet.com/post/2271</link><guid isPermaLink="true">https://fargostreet.com/post/2271</guid><dc:creator><![CDATA[Flowcus]]></dc:creator><pubDate>Tue, 03 Aug 2004 23:27:34 GMT</pubDate></item><item><title><![CDATA[Reply to WTB B-series motor on Tue, 03 Aug 2004 18:52:27 GMT]]></title><description><![CDATA[<p dir="auto">Well Tufte we might be very interested in your setup. Just curious if its OBD-1 or what kind of setup you have? Harness as well?</p>
]]></description><link>https://fargostreet.com/post/2268</link><guid isPermaLink="true">https://fargostreet.com/post/2268</guid><dc:creator><![CDATA[[[global:guest]]]]></dc:creator><pubDate>Tue, 03 Aug 2004 18:52:27 GMT</pubDate></item><item><title><![CDATA[Reply to WTB B-series motor on Tue, 03 Aug 2004 18:36:30 GMT]]></title><description><![CDATA[<p dir="auto">yes... the mighty mouse!</p>
]]></description><link>https://fargostreet.com/post/2267</link><guid isPermaLink="true">https://fargostreet.com/post/2267</guid><dc:creator><![CDATA[24valvenotak]]></dc:creator><pubDate>Tue, 03 Aug 2004 18:36:30 GMT</pubDate></item><item><title><![CDATA[Reply to WTB B-series motor on Tue, 03 Aug 2004 18:31:46 GMT]]></title><description><![CDATA[<p dir="auto">Another setup you could try that would get you more HP/TQ and is less common is a CRV-Tec. Its a B20 Shortblock with a GSR Head. It's not possible to run a straight B20 either, due to the long intake manifold, it would pop out of the hood. If you decide to run a CRV-Tec I would recommend that you resleeve it.</p>
]]></description><link>https://fargostreet.com/post/2266</link><guid isPermaLink="true">https://fargostreet.com/post/2266</guid><dc:creator><![CDATA[[[global:guest]]]]></dc:creator><pubDate>Tue, 03 Aug 2004 18:31:46 GMT</pubDate></item><item><title><![CDATA[Reply to WTB B-series motor on Tue, 03 Aug 2004 17:09:31 GMT]]></title><description><![CDATA[<p dir="auto">I have a B16A longblock w/ hydro trans, DC header, ITR intake manifold, BM FPR, Hypertech clutch, yada yada.  I wanna get rid of it as i have no use or want for it.  Willing to deal....</p>
<p dir="auto">Nick</p>
]]></description><link>https://fargostreet.com/post/2264</link><guid isPermaLink="true">https://fargostreet.com/post/2264</guid><dc:creator><![CDATA[PSI2HI]]></dc:creator><pubDate>Tue, 03 Aug 2004 17:09:31 GMT</pubDate></item><item><title><![CDATA[Reply to WTB B-series motor on Tue, 03 Aug 2004 16:43:31 GMT]]></title><description><![CDATA[<p dir="auto">I have always ordered motors from hmotorsonline or jhpusa.</p>
]]></description><link>https://fargostreet.com/post/2263</link><guid isPermaLink="true">https://fargostreet.com/post/2263</guid><dc:creator><![CDATA[integra_gsr98]]></dc:creator><pubDate>Tue, 03 Aug 2004 16:43:31 GMT</pubDate></item><item><title><![CDATA[Reply to WTB B-series motor on Tue, 03 Aug 2004 14:17:21 GMT]]></title><description><![CDATA[<p dir="auto">Brink, GSR knows what he's doing when it comes to these type of Motor's. As much as I'd like to give the guy some s*** (just kidding) you should probally enquire about his services in your swap. Nick do you know of any good places that we could look for a good price on a long block B16A2/B18 (not a c5) since we are both in the process of looking at CRX's right now and would both maybe enlist in your services.</p>
]]></description><link>https://fargostreet.com/post/2261</link><guid isPermaLink="true">https://fargostreet.com/post/2261</guid><dc:creator><![CDATA[[[global:guest]]]]></dc:creator><pubDate>Tue, 03 Aug 2004 14:17:21 GMT</pubDate></item><item><title><![CDATA[Reply to WTB B-series motor on Tue, 03 Aug 2004 05:29:46 GMT]]></title><description><![CDATA[<p dir="auto">Done the swap.  Would be willing to do it for $$$ provided everything is there and you don't help.  <img src="https://fargostreet.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f642.png?v=40430adaedb" class="not-responsive emoji emoji-android emoji--slightly_smiling_face" style="height:23px;width:auto;vertical-align:middle" title=":)" alt="🙂" /></p>
]]></description><link>https://fargostreet.com/post/2250</link><guid isPermaLink="true">https://fargostreet.com/post/2250</guid><dc:creator><![CDATA[integra_gsr98]]></dc:creator><pubDate>Tue, 03 Aug 2004 05:29:46 GMT</pubDate></item><item><title><![CDATA[Reply to WTB B-series motor on Tue, 03 Aug 2004 04:46:02 GMT]]></title><description><![CDATA[<p dir="auto">get a b18c5</p>
]]></description><link>https://fargostreet.com/post/2249</link><guid isPermaLink="true">https://fargostreet.com/post/2249</guid><dc:creator><![CDATA[NickB]]></dc:creator><pubDate>Tue, 03 Aug 2004 04:46:02 GMT</pubDate></item></channel></rss>
