<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Clutch squeak]]></title><description><![CDATA[<p dir="auto">I was wondering if anybody might know the cause of a squeak I've got on my 97 Civic CX.  I'm wondering if it might be from the throwout bearing.  It squeaks continously until I put a little pressure on the clutch pedal then it goes away.  Any ideas?</p>
]]></description><link>https://fargostreet.com/topic/257/clutch-squeak</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 12:17:04 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/257.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 04 Aug 2004 17:47:32 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Clutch squeak on Fri, 06 Aug 2004 21:06:22 GMT]]></title><description><![CDATA[<p dir="auto">So it just needs some lube?  Is that the deal?</p>
]]></description><link>https://fargostreet.com/post/2354</link><guid isPermaLink="true">https://fargostreet.com/post/2354</guid><dc:creator><![CDATA[Schwanger]]></dc:creator><pubDate>Fri, 06 Aug 2004 21:06:22 GMT</pubDate></item><item><title><![CDATA[Reply to Clutch squeak on Fri, 06 Aug 2004 20:13:57 GMT]]></title><description><![CDATA[<p dir="auto">I'll back ya up....its the throwout bearing the same thing happened to me in my old car.</p>
]]></description><link>https://fargostreet.com/post/2348</link><guid isPermaLink="true">https://fargostreet.com/post/2348</guid><dc:creator><![CDATA[[[global:guest]]]]></dc:creator><pubDate>Fri, 06 Aug 2004 20:13:57 GMT</pubDate></item><item><title><![CDATA[Reply to Clutch squeak on Fri, 06 Aug 2004 05:58:19 GMT]]></title><description><![CDATA[<p dir="auto">mine needed to be greased and it made a poopy sound at idle</p>
]]></description><link>https://fargostreet.com/post/2336</link><guid isPermaLink="true">https://fargostreet.com/post/2336</guid><dc:creator><![CDATA[24valvenotak]]></dc:creator><pubDate>Fri, 06 Aug 2004 05:58:19 GMT</pubDate></item><item><title><![CDATA[Reply to Clutch squeak on Thu, 05 Aug 2004 13:10:17 GMT]]></title><description><![CDATA[<p dir="auto">I thought it might be the throwout bearing going bad but it does the exact opposite of what you would expect it to do.  Normally when your throwout bearing goes bad it makes a horrible grinding noise when you push the clutch in, mine stops making noise when you push it in.</p>
]]></description><link>https://fargostreet.com/post/2322</link><guid isPermaLink="true">https://fargostreet.com/post/2322</guid><dc:creator><![CDATA[Schwanger]]></dc:creator><pubDate>Thu, 05 Aug 2004 13:10:17 GMT</pubDate></item><item><title><![CDATA[Reply to Clutch squeak on Thu, 05 Aug 2004 01:24:05 GMT]]></title><description><![CDATA[<p dir="auto">maybe it needs adjusting?  it sounds like perhaps there's a lack of tension somewhere</p>
]]></description><link>https://fargostreet.com/post/2307</link><guid isPermaLink="true">https://fargostreet.com/post/2307</guid><dc:creator><![CDATA[out there]]></dc:creator><pubDate>Thu, 05 Aug 2004 01:24:05 GMT</pubDate></item><item><title><![CDATA[Reply to Clutch squeak on Wed, 04 Aug 2004 23:06:40 GMT]]></title><description><![CDATA[<p dir="auto">i think that is the throwout bearing...someone with a little more expertise back me up or put me to shame...</p>
]]></description><link>https://fargostreet.com/post/2306</link><guid isPermaLink="true">https://fargostreet.com/post/2306</guid><dc:creator><![CDATA[PSiedTSi]]></dc:creator><pubDate>Wed, 04 Aug 2004 23:06:40 GMT</pubDate></item><item><title><![CDATA[Reply to Clutch squeak on Wed, 04 Aug 2004 20:57:30 GMT]]></title><description><![CDATA[<p dir="auto">All the time: in and out of gear, while driving, and at idle.</p>
]]></description><link>https://fargostreet.com/post/2303</link><guid isPermaLink="true">https://fargostreet.com/post/2303</guid><dc:creator><![CDATA[Schwanger]]></dc:creator><pubDate>Wed, 04 Aug 2004 20:57:30 GMT</pubDate></item><item><title><![CDATA[Reply to Clutch squeak on Wed, 04 Aug 2004 20:19:27 GMT]]></title><description><![CDATA[<p dir="auto">spueals while driving?  or while idling in/out of gear?  a little more info please</p>
]]></description><link>https://fargostreet.com/post/2301</link><guid isPermaLink="true">https://fargostreet.com/post/2301</guid><dc:creator><![CDATA[out there]]></dc:creator><pubDate>Wed, 04 Aug 2004 20:19:27 GMT</pubDate></item></channel></rss>
