<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[question on primer :0]]></title><description><![CDATA[<p dir="auto">so i decided to keep the crx for now and i fixed all the rust and actually painted her with spray cans... *No it didn't turn out like shit  <img src="https://fargostreet.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f609.png?v=40430adaedb" class="not-responsive emoji emoji-android emoji--wink" style="height:23px;width:auto;vertical-align:middle" title=";)" alt="😉" /> the question i have is that i used omega automotive sanding primer... with lacquer... now doesn't lacquer absorb water? so that means that i'll have to clear coat it or what? or would the omega shit be good enough?</p>
]]></description><link>https://fargostreet.com/topic/2660/question-on-primer-0</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 21:54:53 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/2660.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 12 May 2005 19:59:16 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to question on primer :0 on Wed, 18 May 2005 21:40:15 GMT]]></title><description><![CDATA[<p dir="auto">if you want to keep the primerd look just reshoot it with some epoxy primer</p>
]]></description><link>https://fargostreet.com/post/48362</link><guid isPermaLink="true">https://fargostreet.com/post/48362</guid><dc:creator><![CDATA[itdrags]]></dc:creator><pubDate>Wed, 18 May 2005 21:40:15 GMT</pubDate></item><item><title><![CDATA[Reply to question on primer :0 on Fri, 13 May 2005 22:55:30 GMT]]></title><description><![CDATA[<p dir="auto">It depends on if you have single stage paint or not. If you do shoot 2 coats wait about 1 week because single stage is softer, then buff in a sealer. If its not single stage: prime, shoot, then wet sand.</p>
]]></description><link>https://fargostreet.com/post/47437</link><guid isPermaLink="true">https://fargostreet.com/post/47437</guid><dc:creator><![CDATA[[[global:guest]]]]></dc:creator><pubDate>Fri, 13 May 2005 22:55:30 GMT</pubDate></item><item><title><![CDATA[Reply to question on primer :0 on Thu, 12 May 2005 20:18:45 GMT]]></title><description><![CDATA[<p dir="auto">But a good sealer/glaze over the primer, it will stop bleedthrough....but you might be a little beyond that already.</p>
]]></description><link>https://fargostreet.com/post/47220</link><guid isPermaLink="true">https://fargostreet.com/post/47220</guid><dc:creator><![CDATA[seanjohn]]></dc:creator><pubDate>Thu, 12 May 2005 20:18:45 GMT</pubDate></item><item><title><![CDATA[Reply to question on primer :0 on Thu, 12 May 2005 20:00:37 GMT]]></title><description><![CDATA[<p dir="auto">I would prime, paint, and clear it anyways.....that way the paint might make it through a North Dakota winter.</p>
]]></description><link>https://fargostreet.com/post/47218</link><guid isPermaLink="true">https://fargostreet.com/post/47218</guid><dc:creator><![CDATA[24valvenotak]]></dc:creator><pubDate>Thu, 12 May 2005 20:00:37 GMT</pubDate></item></channel></rss>
