<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[F1 engine test]]></title><description><![CDATA[<p dir="auto">All I can say is "WOW"</p>
<p dir="auto"><a href="http://www.westtexasrc.com/user/onroad_car.wmv" rel="nofollow ugc">Link</a></p>
]]></description><link>https://fargostreet.com/topic/2968/f1-engine-test</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 07:34:24 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/2968.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 09 Jun 2005 12:32:27 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to F1 engine test on Fri, 10 Jun 2005 18:44:46 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">stephen bradley wrote:</p>
<ul>
<li>Maximum engine speed is 19,200 rpm.</li>
</ul>
<p dir="auto">shit dsms can rev that high too...a guy at devils run seems to think its a common thing to rev into 5 digits with a dsm that has a backseat full of "nitro"</p>
]]></description><link>https://fargostreet.com/post/51957</link><guid isPermaLink="true">https://fargostreet.com/post/51957</guid><dc:creator><![CDATA[PSiedTSi]]></dc:creator><pubDate>Fri, 10 Jun 2005 18:44:46 GMT</pubDate></item><item><title><![CDATA[Reply to F1 engine test on Fri, 10 Jun 2005 14:19:21 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">Schwanger wrote:<br />
This isn't an F1 it's a Formula SAE car.  It uses an I4 motorcycle engine.  I think this car used a Honda F4i motor.</p>
<p dir="auto">First F4i engine I have seen using two headers with that big of collectors... I think you might be incorrect, take another look.</p>
]]></description><link>https://fargostreet.com/post/51927</link><guid isPermaLink="true">https://fargostreet.com/post/51927</guid><dc:creator><![CDATA[91nbtsi]]></dc:creator><pubDate>Fri, 10 Jun 2005 14:19:21 GMT</pubDate></item><item><title><![CDATA[Reply to F1 engine test on Fri, 10 Jun 2005 14:12:39 GMT]]></title><description><![CDATA[<p dir="auto">Old motor 03 but you get the idea.<br />
Output of the BMW P83 is over 900 bhp.</p>
<ul>
<li>In a race, engine speed is limited to 19,000 rpm.</li>
<li>Idle speed is 4,000 rpm.</li>
<li>The engine weighs less than 90 kilograms.</li>
<li>It completes a distance of 500 kilometres before undergoing revision.<br />
Total production of the BMW P83 is 200 units, ten of which the team takes<br />
to each race.</li>
<li>Before being phased out the engine will have received 1,388 upgrade<br />
modifications.</li>
<li>It comprises around 5,000 individual components, 1,000 of them different.<br />
The air intake volume is 1,995 cubic metres per hour.</li>
<li>Maximum piston acceleration is 10,000g.</li>
<li>Piston speed peaks at 40 metres per second and averages 25 metres per<br />
second.</li>
<li>Exhaust temperatures of up to 950 degrees are reached.</li>
<li>Maximum air temperature in the pneumatic system is 250 degrees.</li>
<li>The ultra-high-speed 130R turn at Suzuka with its lateral load of 4g poses<br />
the greatest challenge to the oil system.</li>
<li>The BMW P83 endured the highest full-throttle proportion on the Monza<br />
circuit at 73 per cent per lap.</li>
<li>At the Monaco Grand Prix, the transmission and engine have to withstand<br />
an average 3,100 gear changes.</li>
<li>The engine block and cylinder head are made of cast aluminium and are<br />
manufactured at the BMW Formula One foundry in Landshut using a<br />
special thin-wall casting method.</li>
<li>BMW Munich handles, among other things the manufacture of the<br />
crankshaft (steel), camshaft (case-hardened steel) and camshaft covers, as<br />
well as processing of the cylinder head and crankcase. The oil system and<br />
engine electronics also stem from BMW Munich</li>
</ul>
]]></description><link>https://fargostreet.com/post/51925</link><guid isPermaLink="true">https://fargostreet.com/post/51925</guid><dc:creator><![CDATA[stephen bradley]]></dc:creator><pubDate>Fri, 10 Jun 2005 14:12:39 GMT</pubDate></item><item><title><![CDATA[Reply to F1 engine test on Fri, 10 Jun 2005 13:58:08 GMT]]></title><description><![CDATA[<p dir="auto">This isn't an F1 it's a Formula SAE car.  It uses an I4 motorcycle engine.  I think this car used a Honda F4i motor.</p>
]]></description><link>https://fargostreet.com/post/51923</link><guid isPermaLink="true">https://fargostreet.com/post/51923</guid><dc:creator><![CDATA[Schwanger]]></dc:creator><pubDate>Fri, 10 Jun 2005 13:58:08 GMT</pubDate></item><item><title><![CDATA[Reply to F1 engine test on Thu, 09 Jun 2005 23:57:34 GMT]]></title><description><![CDATA[<p dir="auto">///\  What he said ///\</p>
]]></description><link>https://fargostreet.com/post/51812</link><guid isPermaLink="true">https://fargostreet.com/post/51812</guid><dc:creator><![CDATA[Sweet-WRX-Lovin]]></dc:creator><pubDate>Thu, 09 Jun 2005 23:57:34 GMT</pubDate></item><item><title><![CDATA[Reply to F1 engine test on Thu, 09 Jun 2005 23:27:32 GMT]]></title><description><![CDATA[<p dir="auto">I will take two of them <img src="https://fargostreet.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f642.png?v=40430adaedb" class="not-responsive emoji emoji-android emoji--slightly_smiling_face" style="height:23px;width:auto;vertical-align:middle" title=":)" alt="🙂" /></p>
]]></description><link>https://fargostreet.com/post/51803</link><guid isPermaLink="true">https://fargostreet.com/post/51803</guid><dc:creator><![CDATA[stephen bradley]]></dc:creator><pubDate>Thu, 09 Jun 2005 23:27:32 GMT</pubDate></item><item><title><![CDATA[Reply to F1 engine test on Thu, 09 Jun 2005 19:22:30 GMT]]></title><description><![CDATA[<p dir="auto">If you have the big bucks, you can buy used Ferrari parts from Michael and Rubin's car at Ferrari's f1 website.</p>
]]></description><link>https://fargostreet.com/post/51746</link><guid isPermaLink="true">https://fargostreet.com/post/51746</guid><dc:creator><![CDATA[legacy-user-33]]></dc:creator><pubDate>Thu, 09 Jun 2005 19:22:30 GMT</pubDate></item><item><title><![CDATA[Reply to F1 engine test on Thu, 09 Jun 2005 16:09:59 GMT]]></title><description><![CDATA[<p dir="auto">that was sweet</p>
]]></description><link>https://fargostreet.com/post/51726</link><guid isPermaLink="true">https://fargostreet.com/post/51726</guid><dc:creator><![CDATA[PSiedTSi]]></dc:creator><pubDate>Thu, 09 Jun 2005 16:09:59 GMT</pubDate></item><item><title><![CDATA[Reply to F1 engine test on Thu, 09 Jun 2005 16:00:11 GMT]]></title><description><![CDATA[<p dir="auto">Freakin awesome. So much technology. Inconel headers are sexy as hell.</p>
<p dir="auto">Here is another video you might like<br />
<a href="http://a1204.v67532.c6753.g.vm.akamaistream.net/7/1204/6753/4017d069/medcost.download.akamai.com/6753/viry_rs24/viry_rs24_220.wmv" rel="nofollow ugc">RIGHT CLICK SAVE AS!</a></p>
]]></description><link>https://fargostreet.com/post/51725</link><guid isPermaLink="true">https://fargostreet.com/post/51725</guid><dc:creator><![CDATA[94NDTA]]></dc:creator><pubDate>Thu, 09 Jun 2005 16:00:11 GMT</pubDate></item><item><title><![CDATA[Reply to F1 engine test on Thu, 09 Jun 2005 15:47:55 GMT]]></title><description><![CDATA[<p dir="auto">if that dosent put a smile on your face there is something wrong!</p>
]]></description><link>https://fargostreet.com/post/51717</link><guid isPermaLink="true">https://fargostreet.com/post/51717</guid><dc:creator><![CDATA[slow90gsx]]></dc:creator><pubDate>Thu, 09 Jun 2005 15:47:55 GMT</pubDate></item><item><title><![CDATA[Reply to F1 engine test on Thu, 09 Jun 2005 12:47:39 GMT]]></title><description><![CDATA[<p dir="auto">I think I have seen that before, that is awesome.  Sounds a little rev happy:)</p>
]]></description><link>https://fargostreet.com/post/51693</link><guid isPermaLink="true">https://fargostreet.com/post/51693</guid><dc:creator><![CDATA[91nbtsi]]></dc:creator><pubDate>Thu, 09 Jun 2005 12:47:39 GMT</pubDate></item></channel></rss>
