<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[93 TSI AWD for sale, lots of mods]]></title><description><![CDATA[<p dir="auto">I'm just posting this for a friend since he doesn't have enough posts to post here.</p>
<p dir="auto">1993 Eagle Talon TSi AWD<br />
Engine:<br />
6 Bolt Conversion<br />
1g "Big Rods" with 2g (8.5 : 1 )<br />
ARP Rod Bolts<br />
ARP Main Studs<br />
ARP Head Studs<br />
MLS Headgasket<br />
Punishment Racing 02 Sensor Housing w/dump tube<br />
3" Stainless Steel Turboback Buschur Racing Exhaust<br />
Aeromotive Adjustable Fuel pressure regulator<br />
-6 AN Fuel lines from filter to rail and rail to regulator<br />
EVO III 16G Turbo<br />
Dejon Tool Intake Pipe<br />
2g MAS<br />
Energy Suspension Motor Mounts<br />
Cold Fusion Single Fogger wet nitrous kit (never been used in this vehicle just installed)<br />
Walbro 255lph HP fuel pump<br />
FIC 650cc Injectors<br />
Revised lifters<br />
Removed balance shafts</p>
<p dir="auto">Driveline:<br />
Greddy Shift knob<br />
Symborski Shift kit<br />
Speed Designs shifter cable bushings<br />
ACT 2600lb Clutch<br />
ACT Streetlite Flywheel</p>
<p dir="auto">Electronics:<br />
Autometer 30/30 Boost gauge-Phantom series<br />
Autometer Oil Pressure gauge-Phantom Series<br />
Autometer EGT gauge w/TRE probe-Phantom Series<br />
Autometer A/F ratio gauge-Phantom Series<br />
Autometer Electronics Nitrous pressure gauge-Phantom series<br />
DSMLink V2 Engine Management<br />
Sony CD Player</p>
<p dir="auto">Suspension:<br />
KYB AGX Adjustable Shocks<br />
Ground Control Coilovers<br />
DME Camber kit (not installed)<br />
Front/Rear strut tower bars.<br />
<strong>Car will be sold with STOCK 16" Gunmetal wheels</strong></p>
<p dir="auto">The good...it has a fresh paint job, black with bright white pearl in it, shaved rear wiper and antenna.   It has 128,xxx miles on the chassis, 1000 miles on the rebuilt motor.</p>
<p dir="auto">The bad...paint job is not flawless there are some defects but it is in better condition then when i got it.   It has an oil leak that i beleive is coming from the oil filter housing, its a minor leak i check the oil regulalry.   Right now it has a fuel leak you will need to repair, the filter is messed up it needs a new fuel filter and some hardline repair.</p>
<p dir="auto">Please just email <a href="mailto:tonyberg@bitz.net" rel="nofollow ugc">tonyberg@bitz.net</a> with questions and for pics of this car.  Like I said it's not my car, just helping someone out.  If it helps, the car is located in Minot.</p>
]]></description><link>https://fargostreet.com/topic/3100/93-tsi-awd-for-sale-lots-of-mods</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 00:32:29 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/3100.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 21 Jun 2005 01:27:46 GMT</pubDate><ttl>60</ttl></channel></rss>
