<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[FS: HKS EVC EZ II Boost Controller]]></title><description><![CDATA[<p dir="auto">Like the title says HKS EVC II Boost Controller. It has never been installed, brand new in the box. Retail from HKS is $445.00. Asking $350.00  shipped or pickup<br />
For an immediate response call me, 701-306-4660  Zach<br />
Pic off HKS web site.<br />
<img src="http://www.boostcontroller.com/products/EC45003BK002large.jpg" alt="legacy image" class=" img-fluid img-markdown" /></p>
<p dir="auto"><a href="http://www.hksusa.com/products/more.asp?id=1822" rel="nofollow ugc">Link To Boost Controller on HKS Website</a></p>
<p dir="auto">HKS description and features</p>
<p dir="auto">The EVC EZ II is the most simplified version of HKS’ electronic boost controllers, but still utilizes the same proven stepping motor as the EVC. With the same "state of the art" closed loop stepping motor, you are insured the same accurate and stable boost levels.  Boost pressure will rise faster and earlier in each gear and be maintained without fear of over-boosting. Also the EVC EZ II is capable of being upgrade to a full EVC unit by simply adding an EVC Display unit. --- Like the EVC, the EVC EZ II can allow for boost levels to be raised up to 100% above the turbo actuator or wastegate’s base boost setting, and cannot lower boost levels bellow the base boost setting.</p>
<p dir="auto">Feature and Benefits:</p>
<p dir="auto">COMPACT DESIGN</p>
<p dir="auto">The new ¼ DIN control unit and stepping motor are all compact in design, making for easier installation and mounting inside the cockpit and in the engine compartment.</p>
<p dir="auto">INTELLIGENT STEPPING MOTOR</p>
<p dir="auto">A CPU is imbedded into the stepping motor. This creates more direct and accurate control as the CPU virtually eliminates lag time between the stepping motor and control module. Thereby increasing linear boost control and stability.</p>
<p dir="auto">HIGH BOOST CAPABILITY</p>
<p dir="auto">A wide range of boost control is possible, from stock boost all the way up to 250 kPa (2.5 bar / 36.25 psi).</p>
<p dir="auto">EASY BOOST SET-UP</p>
<p dir="auto">2 individual boost levels can be easily set by simply turning the volume knobs of the control module.</p>
<p dir="auto">2 MODE BOOST SETTING FUNCTION</p>
<p dir="auto">Separate A and B boost level settings can be tuned according to the user’s preference and can be switched via the control module or display unit.</p>
<p dir="auto">STOCK BOOST RETURN FUNCTION</p>
<p dir="auto">When the EVC is turned off, the boost level setting will automatically return to stock (baseline boost).</p>
<p dir="auto">UPGRADEABLE</p>
<p dir="auto">By adding an EVC Display unit user's will upgrade their EVC EZ II to a full EVC unit with all the additional features; Scramble Boost, Digital/Analog Boost Display, Warning Function and etc.</p>
<p dir="auto">WASTEGATE SELECTION FUNCTION</p>
<p dir="auto">Can be used with either internal (swing valve) or external (poppet style) wastegates.</p>
]]></description><link>https://fargostreet.com/topic/3176/fs-hks-evc-ez-ii-boost-controller</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 13:22:37 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/3176.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 27 Jun 2005 17:47:04 GMT</pubDate><ttl>60</ttl></channel></rss>
