<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[weird idle, help me out]]></title><description><![CDATA[<p dir="auto">i got a question ive got a 93 ford probe gt and sometimes after i run it hard my idle drops to bout 900 then back up to 1500 idk what problem is.</p>
]]></description><link>https://fargostreet.com/topic/3318/weird-idle-help-me-out</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 02:41:50 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/3318.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 12 Jul 2005 04:20:59 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to weird idle, help me out on Wed, 13 Jul 2005 22:45:11 GMT]]></title><description><![CDATA[<p dir="auto">alright i think im goin now to fix my f'ed up probe</p>
]]></description><link>https://fargostreet.com/post/57639</link><guid isPermaLink="true">https://fargostreet.com/post/57639</guid><dc:creator><![CDATA[93Pgt]]></dc:creator><pubDate>Wed, 13 Jul 2005 22:45:11 GMT</pubDate></item><item><title><![CDATA[Reply to weird idle, help me out on Wed, 13 Jul 2005 14:24:55 GMT]]></title><description><![CDATA[<p dir="auto">thats way high! IACV, check it out!</p>
]]></description><link>https://fargostreet.com/post/57532</link><guid isPermaLink="true">https://fargostreet.com/post/57532</guid><dc:creator><![CDATA[Joel]]></dc:creator><pubDate>Wed, 13 Jul 2005 14:24:55 GMT</pubDate></item><item><title><![CDATA[Reply to weird idle, help me out on Wed, 13 Jul 2005 04:24:15 GMT]]></title><description><![CDATA[<p dir="auto">my car usually idles at about 1300 to 1500 and i thought it was high but idk ill try this stuff if its still boggin ill go get it checked<br />
thanks</p>
]]></description><link>https://fargostreet.com/post/57442</link><guid isPermaLink="true">https://fargostreet.com/post/57442</guid><dc:creator><![CDATA[93Pgt]]></dc:creator><pubDate>Wed, 13 Jul 2005 04:24:15 GMT</pubDate></item><item><title><![CDATA[Reply to weird idle, help me out on Wed, 13 Jul 2005 02:58:02 GMT]]></title><description><![CDATA[<p dir="auto">well my car turned out to just be a wire I didnt know existed wasn't hooked up,  wound up payign 60 bucks for a diagnostic.    so I can't help ya with an easy fix.</p>
<p dir="auto">But I would say check for vaccumm leaks, i'm quickly finding out that fords run more vaccum lines then the chevy's i'm used to so it is pretty easy for one of those to have a leak and cause lots of problems.  hit all the lines with carbcleaner or something and if it changes the idle then you know you have a leak, if not check to make sure it isn't just set wrong (like barry was saying)   good luck!</p>
]]></description><link>https://fargostreet.com/post/57406</link><guid isPermaLink="true">https://fargostreet.com/post/57406</guid><dc:creator><![CDATA[lord_deastofact]]></dc:creator><pubDate>Wed, 13 Jul 2005 02:58:02 GMT</pubDate></item><item><title><![CDATA[Reply to weird idle, help me out on Tue, 12 Jul 2005 21:45:59 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">93Pgt wrote:<br />
<p dir="auto">What does it normally idle at when the engine is warmed up? If it's idling above 900 normally then you have it set wrong. It should be idling at about 750-800 RPM.</p>
<p dir="auto">Joel, if you think you know what his problem is, why didn't you post it?</p>
<p dir="auto">Things to check are possible vacuum leaks, the TPS, Idle Air Control solenoid, and the adjustment screws for affecting the throttle body plate.</p>
]]></description><link>https://fargostreet.com/post/57338</link><guid isPermaLink="true">https://fargostreet.com/post/57338</guid><dc:creator><![CDATA[pin]]></dc:creator><pubDate>Tue, 12 Jul 2005 21:45:59 GMT</pubDate></item><item><title><![CDATA[Reply to weird idle, help me out on Tue, 12 Jul 2005 20:17:18 GMT]]></title><description><![CDATA[<p dir="auto">this is true.  but some of the electronics might be the same generic ford parts.</p>
]]></description><link>https://fargostreet.com/post/57318</link><guid isPermaLink="true">https://fargostreet.com/post/57318</guid><dc:creator><![CDATA[lord_deastofact]]></dc:creator><pubDate>Tue, 12 Jul 2005 20:17:18 GMT</pubDate></item><item><title><![CDATA[Reply to weird idle, help me out on Tue, 12 Jul 2005 19:38:32 GMT]]></title><description><![CDATA[<p dir="auto">cept he has a completly different car than you. He has a 2g probe. 89-92 is the only way to go baby! f2t power!</p>
]]></description><link>https://fargostreet.com/post/57315</link><guid isPermaLink="true">https://fargostreet.com/post/57315</guid><dc:creator><![CDATA[Joel]]></dc:creator><pubDate>Tue, 12 Jul 2005 19:38:32 GMT</pubDate></item><item><title><![CDATA[Reply to weird idle, help me out on Tue, 12 Jul 2005 16:36:52 GMT]]></title><description><![CDATA[<p dir="auto">very nice joel, no wonder why you got rid of yours.   but yeah I have a 90 probe gt and it had a similar problem, I was pretty sure it was just a bad idler but never caused any serious problems so I just left it.  Though mines in the shop right now and i'll let you know if they figure out what was doing that.</p>
<p dir="auto">But joels right, these cars are just trouble.</p>
]]></description><link>https://fargostreet.com/post/57294</link><guid isPermaLink="true">https://fargostreet.com/post/57294</guid><dc:creator><![CDATA[lord_deastofact]]></dc:creator><pubDate>Tue, 12 Jul 2005 16:36:52 GMT</pubDate></item><item><title><![CDATA[Reply to weird idle, help me out on Tue, 12 Jul 2005 15:23:49 GMT]]></title><description><![CDATA[<blockquote>
i got a question ive got a 93 ford probe gt and sometimes after i run it hard my idle drops to bout 900 then back up to 1500 idk what problem is.<br />
I know exactly what your problem is...</p>
<p dir="auto">...ive got a 93 ford probe gt ...</p>
]]></description><link>https://fargostreet.com/post/57286</link><guid isPermaLink="true">https://fargostreet.com/post/57286</guid><dc:creator><![CDATA[Joel]]></dc:creator><pubDate>Tue, 12 Jul 2005 15:23:49 GMT</pubDate></item><item><title><![CDATA[Reply to weird idle, help me out on Tue, 12 Jul 2005 11:35:50 GMT]]></title><description><![CDATA[<p dir="auto">take it to a shop, it could be many problems and may take hours to figure out.</p>
]]></description><link>https://fargostreet.com/post/57278</link><guid isPermaLink="true">https://fargostreet.com/post/57278</guid><dc:creator><![CDATA[ticklemedaly]]></dc:creator><pubDate>Tue, 12 Jul 2005 11:35:50 GMT</pubDate></item></channel></rss>
