<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[550hp V-8 hunter!!]]></title><description><![CDATA[<p dir="auto">A buddy of mine from the twin cities is sellin this due to money problems!<br />
pics----<br />
<a href="http://www.dsmtuners.com/gallery/showgallery.php?cat=500&amp;ppuser=1095" rel="nofollow ugc">http://www.dsmtuners.com/gallery/showgallery.php?cat=500&amp;ppuser=1095</a></p>
<p dir="auto">Enough power to go mid 10's</p>
<p dir="auto">Engine:</p>
<ul>
<li>G4CS (2.4L) block (stroked)</li>
<li>Ross 9:1 Pistons</li>
<li>Eagle H-beam rods</li>
<li>Cometic HP headgasket</li>
<li>Clevite bearings</li>
<li>Mild port/cleaned up 1g head</li>
<li>Crower valve springs</li>
<li>ARP headstuds</li>
<li>Comp “Severe” Cams (101200 grind)</li>
</ul>
<p dir="auto">Forced Induction components:</p>
<ul>
<li>Forced Performance FPT67 turbo (67mm compressor, P trim exhaust wheel in a .82 a/r T3 housing)</li>
<li>Straight Line Specialties “race core” w/ Buschur 2.5 inch IC pipes</li>
<li>Magnus Sheetmetal Intake Manifold</li>
<li>DN Performance tubular T3 exhaust manifold</li>
<li>Greddy Type R bov</li>
<li>Elite Autosport manual boost controller</li>
<li>Innovative Turbo 42mm wastegate</li>
<li>Custom 3” turboback exhaust</li>
</ul>
<p dir="auto">Engine Management and Fuel Supply:</p>
<ul>
<li>AEM EMS</li>
<li>3.5 bar MAP sensor</li>
<li>PTE 880cc injectors</li>
<li>255 lph walbro fuel pump</li>
</ul>
<p dir="auto">Drivetrain/Suspension:</p>
<ul>
<li>Shepherd Racing rebuilt transmission with some extras</li>
<li>ACT 2900 pressure plate with street disc</li>
<li>ACT Streetlite Flywheel</li>
<li>16” wheels wrapped in Nitto 555Rs</li>
<li>Sprint Springs</li>
</ul>
<p dir="auto">$$$11,000.00</p>
]]></description><link>https://fargostreet.com/topic/344/550hp-v-8-hunter</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 12:17:06 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/344.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 31 Aug 2004 04:34:04 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to 550hp V-8 hunter!! on Sun, 26 Sep 2004 20:40:39 GMT]]></title><description><![CDATA[<p dir="auto">God damn!  That's some good shit there.  He obviously figured out where he was losing power.</p>
]]></description><link>https://fargostreet.com/post/6336</link><guid isPermaLink="true">https://fargostreet.com/post/6336</guid><dc:creator><![CDATA[treimche]]></dc:creator><pubDate>Sun, 26 Sep 2004 20:40:39 GMT</pubDate></item><item><title><![CDATA[Reply to 550hp V-8 hunter!! on Sun, 26 Sep 2004 01:53:21 GMT]]></title><description><![CDATA[<p dir="auto">saw that on tuners, thats just plain SIC</p>
]]></description><link>https://fargostreet.com/post/6292</link><guid isPermaLink="true">https://fargostreet.com/post/6292</guid><dc:creator><![CDATA[nd_dsm]]></dc:creator><pubDate>Sun, 26 Sep 2004 01:53:21 GMT</pubDate></item><item><title><![CDATA[Reply to 550hp V-8 hunter!! on Sun, 26 Sep 2004 01:36:46 GMT]]></title><description><![CDATA[<p dir="auto">Cher's graph.</p>
<p dir="auto"><img src="/assets/uploads/legacy/attachments/102/Cher%20617.jpg" alt="Cher 617.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://fargostreet.com/post/6290</link><guid isPermaLink="true">https://fargostreet.com/post/6290</guid><dc:creator><![CDATA[PSI2HI]]></dc:creator><pubDate>Sun, 26 Sep 2004 01:36:46 GMT</pubDate></item><item><title><![CDATA[Reply to 550hp V-8 hunter!! on Sat, 25 Sep 2004 23:55:56 GMT]]></title><description><![CDATA[<blockquote>
Are you sure this is the same car you're talking about?  There's another dude from the cities that's got a coser to 700WHP 2.4 7 bolt powered Eclipse.</p>
<p dir="auto">Same car, new power.</p>
<p dir="auto">As well Shane made 664whp.</p>
]]></description><link>https://fargostreet.com/post/6284</link><guid isPermaLink="true">https://fargostreet.com/post/6284</guid><dc:creator><![CDATA[PSI2HI]]></dc:creator><pubDate>Sat, 25 Sep 2004 23:55:56 GMT</pubDate></item><item><title><![CDATA[Reply to 550hp V-8 hunter!! on Sat, 25 Sep 2004 23:23:57 GMT]]></title><description><![CDATA[<p dir="auto">Are you sure this is the same car you're talking about?  There's another dude from the cities that's got a coser to 700WHP 2.4 7 bolt powered Eclipse.</p>
]]></description><link>https://fargostreet.com/post/6282</link><guid isPermaLink="true">https://fargostreet.com/post/6282</guid><dc:creator><![CDATA[treimche]]></dc:creator><pubDate>Sat, 25 Sep 2004 23:23:57 GMT</pubDate></item><item><title><![CDATA[Reply to 550hp V-8 hunter!! on Sat, 25 Sep 2004 05:25:07 GMT]]></title><description><![CDATA[<blockquote>
troy it did make over 500 hp and still running.. hahah</p>
<p dir="auto">He just posted a new dyno plot today.</p>
<p dir="auto">617 hp now ... not too bad.</p>
]]></description><link>https://fargostreet.com/post/6255</link><guid isPermaLink="true">https://fargostreet.com/post/6255</guid><dc:creator><![CDATA[Purple_94GT]]></dc:creator><pubDate>Sat, 25 Sep 2004 05:25:07 GMT</pubDate></item><item><title><![CDATA[Reply to 550hp V-8 hunter!! on Fri, 17 Sep 2004 06:50:37 GMT]]></title><description><![CDATA[<p dir="auto">troy it did make over 500 hp and still running.. hahah</p>
]]></description><link>https://fargostreet.com/post/5471</link><guid isPermaLink="true">https://fargostreet.com/post/5471</guid><dc:creator><![CDATA[SmitEvo]]></dc:creator><pubDate>Fri, 17 Sep 2004 06:50:37 GMT</pubDate></item><item><title><![CDATA[Reply to 550hp V-8 hunter!! on Fri, 17 Sep 2004 04:41:01 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">StangerBanger96 wrote:<br />
V8???<br />
V8 Hunter</p>
]]></description><link>https://fargostreet.com/post/5466</link><guid isPermaLink="true">https://fargostreet.com/post/5466</guid><dc:creator><![CDATA[PSiedTSi]]></dc:creator><pubDate>Fri, 17 Sep 2004 04:41:01 GMT</pubDate></item><item><title><![CDATA[Reply to 550hp V-8 hunter!! on Fri, 17 Sep 2004 02:09:06 GMT]]></title><description><![CDATA[<p dir="auto">V8???</p>
]]></description><link>https://fargostreet.com/post/5461</link><guid isPermaLink="true">https://fargostreet.com/post/5461</guid><dc:creator><![CDATA[StangerBanger96]]></dc:creator><pubDate>Fri, 17 Sep 2004 02:09:06 GMT</pubDate></item><item><title><![CDATA[Reply to 550hp V-8 hunter!! on Fri, 17 Sep 2004 01:08:59 GMT]]></title><description><![CDATA[<blockquote>
No it's more like doing someone a favor by not letting them buy a 2.4 motor that everyone in the world knows is going to blow up.  Nothing against the seller, just the motor.</p>
<p dir="auto">bah, stop being so bitter about the 4g64 just because yours had issues:)</p>
]]></description><link>https://fargostreet.com/post/5458</link><guid isPermaLink="true">https://fargostreet.com/post/5458</guid><dc:creator><![CDATA[95TsiAWD]]></dc:creator><pubDate>Fri, 17 Sep 2004 01:08:59 GMT</pubDate></item><item><title><![CDATA[Reply to 550hp V-8 hunter!! on Thu, 16 Sep 2004 23:39:13 GMT]]></title><description><![CDATA[<p dir="auto">No it's more like doing someone a favor by not letting them buy a 2.4 motor that everyone in the world knows is going to blow up.  Nothing against the seller, just the motor.</p>
]]></description><link>https://fargostreet.com/post/5453</link><guid isPermaLink="true">https://fargostreet.com/post/5453</guid><dc:creator><![CDATA[treimche]]></dc:creator><pubDate>Thu, 16 Sep 2004 23:39:13 GMT</pubDate></item><item><title><![CDATA[Reply to 550hp V-8 hunter!! on Thu, 16 Sep 2004 07:15:04 GMT]]></title><description><![CDATA[<p dir="auto">Troy thats a cock block...</p>
<p dir="auto">lol</p>
]]></description><link>https://fargostreet.com/post/5431</link><guid isPermaLink="true">https://fargostreet.com/post/5431</guid><dc:creator><![CDATA[SmitEvo]]></dc:creator><pubDate>Thu, 16 Sep 2004 07:15:04 GMT</pubDate></item><item><title><![CDATA[Reply to 550hp V-8 hunter!! on Fri, 10 Sep 2004 06:32:40 GMT]]></title><description><![CDATA[<p dir="auto">I wouldn't bother wasting the time or money on the block.  Not to cock block him, but he's very lucky if his 2.4 motor doesn't blow up!  Maybe I'm just not a fan of the 2.4 anymore</p>
]]></description><link>https://fargostreet.com/post/4577</link><guid isPermaLink="true">https://fargostreet.com/post/4577</guid><dc:creator><![CDATA[treimche]]></dc:creator><pubDate>Fri, 10 Sep 2004 06:32:40 GMT</pubDate></item><item><title><![CDATA[Reply to 550hp V-8 hunter!! on Sun, 05 Sep 2004 07:09:31 GMT]]></title><description><![CDATA[<blockquote>
he may part out his car!</p>
<p dir="auto">If he does, let me know asap. <a href="mailto:matpatte@nemontel.net" rel="nofollow ugc">matpatte@nemontel.net</a></p>
<p dir="auto">I would be interested in just the shortblock.'</p>
]]></description><link>https://fargostreet.com/post/4230</link><guid isPermaLink="true">https://fargostreet.com/post/4230</guid><dc:creator><![CDATA[95TsiAWD]]></dc:creator><pubDate>Sun, 05 Sep 2004 07:09:31 GMT</pubDate></item><item><title><![CDATA[Reply to 550hp V-8 hunter!! on Sat, 04 Sep 2004 03:46:59 GMT]]></title><description><![CDATA[<p dir="auto">he may part out his car!</p>
]]></description><link>https://fargostreet.com/post/4175</link><guid isPermaLink="true">https://fargostreet.com/post/4175</guid><dc:creator><![CDATA[SmitEvo]]></dc:creator><pubDate>Sat, 04 Sep 2004 03:46:59 GMT</pubDate></item><item><title><![CDATA[Reply to 550hp V-8 hunter!! on Thu, 02 Sep 2004 16:11:23 GMT]]></title><description><![CDATA[<p dir="auto">so is there any chance of him parting out pieces of the engine at all?</p>
]]></description><link>https://fargostreet.com/post/3996</link><guid isPermaLink="true">https://fargostreet.com/post/3996</guid><dc:creator><![CDATA[nd_dsm]]></dc:creator><pubDate>Thu, 02 Sep 2004 16:11:23 GMT</pubDate></item><item><title><![CDATA[Reply to 550hp V-8 hunter!! on Wed, 01 Sep 2004 16:31:23 GMT]]></title><description><![CDATA[<p dir="auto">ya thats was him beating a R6</p>
]]></description><link>https://fargostreet.com/post/3912</link><guid isPermaLink="true">https://fargostreet.com/post/3912</guid><dc:creator><![CDATA[SmitEvo]]></dc:creator><pubDate>Wed, 01 Sep 2004 16:31:23 GMT</pubDate></item><item><title><![CDATA[Reply to 550hp V-8 hunter!! on Tue, 31 Aug 2004 20:20:18 GMT]]></title><description><![CDATA[<p dir="auto">Also isnt that the guy that just posted a vid of him killing an R6?</p>
]]></description><link>https://fargostreet.com/post/3813</link><guid isPermaLink="true">https://fargostreet.com/post/3813</guid><dc:creator><![CDATA[95TsiAWD]]></dc:creator><pubDate>Tue, 31 Aug 2004 20:20:18 GMT</pubDate></item><item><title><![CDATA[Reply to 550hp V-8 hunter!! on Tue, 31 Aug 2004 20:19:45 GMT]]></title><description><![CDATA[<p dir="auto">Is he willing to sell the shortblock, just block, crank, rods, pistons?</p>
]]></description><link>https://fargostreet.com/post/3812</link><guid isPermaLink="true">https://fargostreet.com/post/3812</guid><dc:creator><![CDATA[95TsiAWD]]></dc:creator><pubDate>Tue, 31 Aug 2004 20:19:45 GMT</pubDate></item><item><title><![CDATA[Reply to 550hp V-8 hunter!! on Tue, 31 Aug 2004 19:37:35 GMT]]></title><description><![CDATA[<p dir="auto">Nice setup indeed.  I have a feeling hes probably gonna get alot of offers for around 5k.   I've got a few friends around here though that might be interested, ill get back to you.</p>
]]></description><link>https://fargostreet.com/post/3807</link><guid isPermaLink="true">https://fargostreet.com/post/3807</guid><dc:creator><![CDATA[nd_dsm]]></dc:creator><pubDate>Tue, 31 Aug 2004 19:37:35 GMT</pubDate></item><item><title><![CDATA[Reply to 550hp V-8 hunter!! on Tue, 31 Aug 2004 17:54:24 GMT]]></title><description><![CDATA[<p dir="auto">hell of a setup... but good luck selling a 1G for 11,000 bucks...</p>
]]></description><link>https://fargostreet.com/post/3792</link><guid isPermaLink="true">https://fargostreet.com/post/3792</guid><dc:creator><![CDATA[btleier]]></dc:creator><pubDate>Tue, 31 Aug 2004 17:54:24 GMT</pubDate></item><item><title><![CDATA[Reply to 550hp V-8 hunter!! on Tue, 31 Aug 2004 07:29:12 GMT]]></title><description><![CDATA[<p dir="auto">Damn thats alot of money.  But holy shit thats alot of car, nice car man.</p>
]]></description><link>https://fargostreet.com/post/3773</link><guid isPermaLink="true">https://fargostreet.com/post/3773</guid><dc:creator><![CDATA[Bryce]]></dc:creator><pubDate>Tue, 31 Aug 2004 07:29:12 GMT</pubDate></item></channel></rss>
