<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Boost controlling]]></title><description><![CDATA[<p dir="auto">Well I have never had to use a boost controler before, cuz my turbo now had a differnt actuator that runs the correct boost.  Anyways, I want to know what I should get, there are a ton of them.  Adv/Dis adv of the boost controllers.  I can spend up to 400 bucks if there is a reason too, but if there isn't then I won't.  I have an external wastegate with a 9psi Spring in it and I want to increase the boost to 18psi and that is it... but I don't want boost spikes and or drops in boost for any reason.  Just want to run this boost and leave it there.  Is there better contorlers for quicker spool or is that just a bunch of crap, and if you know alot about this, try to explain how differnt ones work.  They range from like 50-400.  Thanks in advance for any information.</p>
]]></description><link>https://fargostreet.com/topic/3491/boost-controlling</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 02:11:08 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/3491.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 25 Jul 2005 17:32:21 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Boost controlling on Mon, 25 Jul 2005 21:27:53 GMT]]></title><description><![CDATA[<p dir="auto">A TIAL 38mm is plenty big for the turbo you plan on using.</p>
]]></description><link>https://fargostreet.com/post/59979</link><guid isPermaLink="true">https://fargostreet.com/post/59979</guid><dc:creator><![CDATA[PSI2HI]]></dc:creator><pubDate>Mon, 25 Jul 2005 21:27:53 GMT</pubDate></item><item><title><![CDATA[Reply to Boost controlling on Mon, 25 Jul 2005 21:08:51 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">TRE wrote:<br />
better to go with higher boost than lower boost?</p>
<p dir="auto">Haha, duh!  No, depends on what you are turboing, what turbo, etc.  Lets hear some details.  But definately a tial is the way to go.</p>
]]></description><link>https://fargostreet.com/post/59973</link><guid isPermaLink="true">https://fargostreet.com/post/59973</guid><dc:creator><![CDATA[91nbtsi]]></dc:creator><pubDate>Mon, 25 Jul 2005 21:08:51 GMT</pubDate></item><item><title><![CDATA[Reply to Boost controlling on Mon, 25 Jul 2005 21:05:33 GMT]]></title><description><![CDATA[<p dir="auto">better to go with higher boost than lower boost?</p>
]]></description><link>https://fargostreet.com/post/59971</link><guid isPermaLink="true">https://fargostreet.com/post/59971</guid><dc:creator><![CDATA[TRE]]></dc:creator><pubDate>Mon, 25 Jul 2005 21:05:33 GMT</pubDate></item><item><title><![CDATA[Reply to Boost controlling on Mon, 25 Jul 2005 20:51:12 GMT]]></title><description><![CDATA[<blockquote>
One more thing what is this thing about wastegate creep or whatever it is called, do i need to worry about that?  Worry about my wastegate not allowing my turbo to spool as fast or is that more for non external wastegated turbo set ups?</p>
<p dir="auto">Go with the Tial 38mm with the 18.xx spring.  What are you putting this on?  You mentioned a 1.3l engine, you will not have to worry about creep with a 38mm gate at ~18psi.  This would be a perfect setup for you.</p>
]]></description><link>https://fargostreet.com/post/59969</link><guid isPermaLink="true">https://fargostreet.com/post/59969</guid><dc:creator><![CDATA[91nbtsi]]></dc:creator><pubDate>Mon, 25 Jul 2005 20:51:12 GMT</pubDate></item><item><title><![CDATA[Reply to Boost controlling on Mon, 25 Jul 2005 20:11:42 GMT]]></title><description><![CDATA[<p dir="auto">One more thing what is this thing about wastegate creep or whatever it is called, do i need to worry about that?  Worry about my wastegate not allowing my turbo to spool as fast or is that more for non external wastegated turbo set ups?</p>
]]></description><link>https://fargostreet.com/post/59963</link><guid isPermaLink="true">https://fargostreet.com/post/59963</guid><dc:creator><![CDATA[TRE]]></dc:creator><pubDate>Mon, 25 Jul 2005 20:11:42 GMT</pubDate></item><item><title><![CDATA[Reply to Boost controlling on Mon, 25 Jul 2005 20:02:09 GMT]]></title><description><![CDATA[<p dir="auto">sounds like a plan, they have a 17.4 psi spring so I think i will go with that, they also have a 18.84 psi spring.... My fuel is set for 18psi but then i am going to fine tune just a bit, witch spring should i go with?</p>
]]></description><link>https://fargostreet.com/post/59961</link><guid isPermaLink="true">https://fargostreet.com/post/59961</guid><dc:creator><![CDATA[TRE]]></dc:creator><pubDate>Mon, 25 Jul 2005 20:02:09 GMT</pubDate></item><item><title><![CDATA[Reply to Boost controlling on Mon, 25 Jul 2005 19:58:47 GMT]]></title><description><![CDATA[<p dir="auto">Size wise the tial's are usually smaller than the turbonetics wastegates actually.</p>
]]></description><link>https://fargostreet.com/post/59959</link><guid isPermaLink="true">https://fargostreet.com/post/59959</guid><dc:creator><![CDATA[integra_gsr98]]></dc:creator><pubDate>Mon, 25 Jul 2005 19:58:47 GMT</pubDate></item><item><title><![CDATA[Reply to Boost controlling on Mon, 25 Jul 2005 19:52:08 GMT]]></title><description><![CDATA[<p dir="auto">I would like to know for fit, not for boost control, I know both will be fine for flow cuz I'll be pushin 300hp at the max, I think my 1.3L block can only handle 340 before it is about to break.</p>
]]></description><link>https://fargostreet.com/post/59958</link><guid isPermaLink="true">https://fargostreet.com/post/59958</guid><dc:creator><![CDATA[TRE]]></dc:creator><pubDate>Mon, 25 Jul 2005 19:52:08 GMT</pubDate></item><item><title><![CDATA[Reply to Boost controlling on Mon, 25 Jul 2005 19:46:12 GMT]]></title><description><![CDATA[<p dir="auto">bigger=less chance of boost creep and most likely better control...</p>
]]></description><link>https://fargostreet.com/post/59951</link><guid isPermaLink="true">https://fargostreet.com/post/59951</guid><dc:creator><![CDATA[PSiedTSi]]></dc:creator><pubDate>Mon, 25 Jul 2005 19:46:12 GMT</pubDate></item><item><title><![CDATA[Reply to Boost controlling on Mon, 25 Jul 2005 19:45:34 GMT]]></title><description><![CDATA[<p dir="auto">Size Difference Anyone?</p>
]]></description><link>https://fargostreet.com/post/59950</link><guid isPermaLink="true">https://fargostreet.com/post/59950</guid><dc:creator><![CDATA[TRE]]></dc:creator><pubDate>Mon, 25 Jul 2005 19:45:34 GMT</pubDate></item><item><title><![CDATA[Reply to Boost controlling on Mon, 25 Jul 2005 19:45:13 GMT]]></title><description><![CDATA[<p dir="auto">well i figure i could sell the other wastegate on ebay for about 75-100 and i was going to spend like 50 on a boost controller... and the tial is about 275 with the spring I need.  so about 100-150 extra dollars see my thinking lol</p>
]]></description><link>https://fargostreet.com/post/59949</link><guid isPermaLink="true">https://fargostreet.com/post/59949</guid><dc:creator><![CDATA[TRE]]></dc:creator><pubDate>Mon, 25 Jul 2005 19:45:13 GMT</pubDate></item><item><title><![CDATA[Reply to Boost controlling on Mon, 25 Jul 2005 19:31:48 GMT]]></title><description><![CDATA[<p dir="auto">Tial 38mm should only be 250 some dollars if I remember right.<br />
Check w/ straight line for an actual price.</p>
]]></description><link>https://fargostreet.com/post/59946</link><guid isPermaLink="true">https://fargostreet.com/post/59946</guid><dc:creator><![CDATA[integra_gsr98]]></dc:creator><pubDate>Mon, 25 Jul 2005 19:31:48 GMT</pubDate></item><item><title><![CDATA[Reply to Boost controlling on Mon, 25 Jul 2005 19:30:53 GMT]]></title><description><![CDATA[<p dir="auto">hum... size wise is there a difference? like will I have a clearance issue with the tial one? cuz this is premade and stuff.  Rock steady huh, sounds like the ticket, it will be an extra 150 from what I can tell.  so... could maybe do it.</p>
]]></description><link>https://fargostreet.com/post/59945</link><guid isPermaLink="true">https://fargostreet.com/post/59945</guid><dc:creator><![CDATA[TRE]]></dc:creator><pubDate>Mon, 25 Jul 2005 19:30:53 GMT</pubDate></item><item><title><![CDATA[Reply to Boost controlling on Mon, 25 Jul 2005 19:11:39 GMT]]></title><description><![CDATA[<p dir="auto">That's a 35/38mm flange.  Boost control w/ just a WG spring, especially a tial WG, is ROCK STEADY.</p>
]]></description><link>https://fargostreet.com/post/59941</link><guid isPermaLink="true">https://fargostreet.com/post/59941</guid><dc:creator><![CDATA[integra_gsr98]]></dc:creator><pubDate>Mon, 25 Jul 2005 19:11:39 GMT</pubDate></item><item><title><![CDATA[Reply to Boost controlling on Mon, 25 Jul 2005 18:57:28 GMT]]></title><description><![CDATA[<p dir="auto">how accurate are those tial wastegate springs? if i get one that is 17-18psi is it going to be right on the nuts?  one more thing, is there going to be wastegate creep without a boost controller?</p>
]]></description><link>https://fargostreet.com/post/59930</link><guid isPermaLink="true">https://fargostreet.com/post/59930</guid><dc:creator><![CDATA[TRE]]></dc:creator><pubDate>Mon, 25 Jul 2005 18:57:28 GMT</pubDate></item><item><title><![CDATA[Reply to Boost controlling on Mon, 25 Jul 2005 18:47:06 GMT]]></title><description><![CDATA[<p dir="auto"><a href="http://i4.photobucket.com/albums/y105/streetcivicsi/T3manifold2.jpg" rel="nofollow ugc">http://i4.photobucket.com/albums/y105/streetcivicsi/T3manifold2.jpg</a>  there is a picture of the manifold</p>
]]></description><link>https://fargostreet.com/post/59923</link><guid isPermaLink="true">https://fargostreet.com/post/59923</guid><dc:creator><![CDATA[TRE]]></dc:creator><pubDate>Mon, 25 Jul 2005 18:47:06 GMT</pubDate></item><item><title><![CDATA[Reply to Boost controlling on Mon, 25 Jul 2005 18:46:13 GMT]]></title><description><![CDATA[<p dir="auto">just trying to use what i have I guess ya know...</p>
]]></description><link>https://fargostreet.com/post/59922</link><guid isPermaLink="true">https://fargostreet.com/post/59922</guid><dc:creator><![CDATA[TRE]]></dc:creator><pubDate>Mon, 25 Jul 2005 18:46:13 GMT</pubDate></item><item><title><![CDATA[Reply to Boost controlling on Mon, 25 Jul 2005 18:44:59 GMT]]></title><description><![CDATA[<p dir="auto">I want a tial wastegate, but I already have the turbonetics one, ... is there anything wrong with the turbonetics one?  Any info would be great... I am having nick weld a flange on there anyways for the turbo I'm sure it wouldnt be too hard to reweld a flange on there for a tial wastegate... just more money for no reason ya know...  but ya give me some info</p>
]]></description><link>https://fargostreet.com/post/59921</link><guid isPermaLink="true">https://fargostreet.com/post/59921</guid><dc:creator><![CDATA[TRE]]></dc:creator><pubDate>Mon, 25 Jul 2005 18:44:59 GMT</pubDate></item><item><title><![CDATA[Reply to Boost controlling on Mon, 25 Jul 2005 18:32:53 GMT]]></title><description><![CDATA[<p dir="auto">What is the flange like?  Maybe you will be better suited w/ a TiAL wastegate.  I have never been a fan of turbonetics wastegates.</p>
]]></description><link>https://fargostreet.com/post/59918</link><guid isPermaLink="true">https://fargostreet.com/post/59918</guid><dc:creator><![CDATA[integra_gsr98]]></dc:creator><pubDate>Mon, 25 Jul 2005 18:32:53 GMT</pubDate></item><item><title><![CDATA[Reply to Boost controlling on Mon, 25 Jul 2005 18:07:03 GMT]]></title><description><![CDATA[<p dir="auto">can't they dont make one, I have a turbonetics evolution wastegate</p>
]]></description><link>https://fargostreet.com/post/59914</link><guid isPermaLink="true">https://fargostreet.com/post/59914</guid><dc:creator><![CDATA[TRE]]></dc:creator><pubDate>Mon, 25 Jul 2005 18:07:03 GMT</pubDate></item><item><title><![CDATA[Reply to Boost controlling on Mon, 25 Jul 2005 18:06:18 GMT]]></title><description><![CDATA[<p dir="auto">If you dont plan on ever changing boost whatsoever, just get an 18 psi spring for the WG.</p>
]]></description><link>https://fargostreet.com/post/59913</link><guid isPermaLink="true">https://fargostreet.com/post/59913</guid><dc:creator><![CDATA[integra_gsr98]]></dc:creator><pubDate>Mon, 25 Jul 2005 18:06:18 GMT</pubDate></item><item><title><![CDATA[Reply to Boost controlling on Mon, 25 Jul 2005 18:05:48 GMT]]></title><description><![CDATA[<p dir="auto">well once it is set I don't plan on changing it.... that is what i was trying to say... is there certin contorlers that have better responce or lack boost spikes or will a simple boost controler do that for me no problem?</p>
<p dir="auto">What are the advantages of the electronic boost controlers?</p>
]]></description><link>https://fargostreet.com/post/59912</link><guid isPermaLink="true">https://fargostreet.com/post/59912</guid><dc:creator><![CDATA[TRE]]></dc:creator><pubDate>Mon, 25 Jul 2005 18:05:48 GMT</pubDate></item><item><title><![CDATA[Reply to Boost controlling on Mon, 25 Jul 2005 18:05:44 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">Bad93ex wrote:<br />
Just save your money and pick up a SLS MBC.  Cheap and effective.<br />
he said he has 400 to spend for boost problems...SLS mbcs are like 40 bucks, i dont think he needs to save</p>
]]></description><link>https://fargostreet.com/post/59911</link><guid isPermaLink="true">https://fargostreet.com/post/59911</guid><dc:creator><![CDATA[STiSchucky]]></dc:creator><pubDate>Mon, 25 Jul 2005 18:05:44 GMT</pubDate></item><item><title><![CDATA[Reply to Boost controlling on Mon, 25 Jul 2005 18:01:46 GMT]]></title><description><![CDATA[<blockquote>
Just save your money and pick up a SLS MBC.  Cheap and effective.</p>
<p dir="auto">True, but if you want to be able to make real time adjustments and change the boost settings from inside the car,  an ebc might be better.</p>
]]></description><link>https://fargostreet.com/post/59907</link><guid isPermaLink="true">https://fargostreet.com/post/59907</guid><dc:creator><![CDATA[[[global:guest]]]]></dc:creator><pubDate>Mon, 25 Jul 2005 18:01:46 GMT</pubDate></item></channel></rss>
