<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[turbo size chart (borrowed from nasioc)]]></title><description><![CDATA[<p dir="auto">during the FS downtime I started looking at the other forums on the net and came across this little piece of info curtousy of nasioc.  Thought it might have some interesting info for those who'd like to have a general idea of what turbo can flow how much at 14.7 psi (granted, some of these are very capable of much higher psi, but this should be a decent reference point)</p>
<p dir="auto">**[b]Stock Turbo       360 CFM at 14.7 PSI<br />
T3  60 trim       400 CFM at 14.7 PSI<br />
IHI VF 24         423 CFM at 14.7 PSI<br />
STOCK  HYBRID     430 CFM at 14.7 PSI<br />
IHI VF-22         435 CFM at 14.7 PSI<br />
SR 30	          435 CFM at 14.7 PSI<br />
T04E 40 trim      460 CFM at 14.7 PSI<br />
Small 16G         505 CFM at 14.7 PSI<br />
PE 1820           510 CFM at 14.7 PSI<br />
Large 16G         550 CFM at 14.7 PSI<br />
SR 40	          595 CFM at 14.7 PSI<br />
18G               600 CFM at 14.7 PSI<br />
20G               650 CFM at 14.7 PSI<br />
SR 50             710 CFM at 14.7 PSI<br />
GT-30             725 CFM at 14.7 PSI<br />
60-1              725 CFM at 14.7 PSI<br />
GT-35R            820 CFM at 14.7 PSI<br />
T72               920 CFM at 14.7 PSI  &lt;-- Note you would have to spin a 2.0 L<br />
engine at about 14,000 rpm to flow this much air.</p>
<p dir="auto">IHI VF 24         388 CFM at 18   PSI<br />
T3 60 trim        410 CFM at 20   PSI<br />
IHI VF-22         460 CFM at 18.0 PSI<br />
AVO 320HP         465 CFM at 17.5 PSI<br />
T04E 40 trim      465 CFM at 22   PSI<br />
Large 16G         470 CFM at 22   PSI<br />
SR 30             490 CFM at 22   PSI<br />
Small 16G         490 CFM at 22   PSI<br />
AVO 400HP         580 CFM at 17.5 PSI<br />
PE 1820           580 CFM at 22   PSI<br />
AVO 450HP         650 CFM at 20.0 PSI<br />
AVO 500HP         725 CFM at 23.0 PSI<br />
SR 50             770 CFM at 22   PSI<br />
GT-30             790 CFM at 22   PSI<br />
60-1              800 CFM at 22   PSI<br />
GT-35R            880 CFM at 22   PSI<br />
T72              1000 CFM at 22   PSI  &lt;-- note you would have to run a 2.0 L engine<br />
at &gt;40 PSI boost to flow this much **[/b]</p>
<p dir="auto">Sorry to have an on topic post for a change, i'll try and not let that happen again for a while</p>
]]></description><link>https://fargostreet.com/topic/3641/turbo-size-chart-borrowed-from-nasioc</link><generator>RSS for Node</generator><lastBuildDate>Wed, 27 May 2026 21:36:27 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/3641.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 11 Aug 2005 01:03:13 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to turbo size chart (borrowed from nasioc) on Thu, 11 Aug 2005 15:46:56 GMT]]></title><description><![CDATA[<p dir="auto">So a small 16g flows better than a large 16g at 22 psi?  It really doesn't matter as it will be out by the end of the year anyways.</p>
]]></description><link>https://fargostreet.com/post/61981</link><guid isPermaLink="true">https://fargostreet.com/post/61981</guid><dc:creator><![CDATA[[[global:guest]]]]></dc:creator><pubDate>Thu, 11 Aug 2005 15:46:56 GMT</pubDate></item><item><title><![CDATA[Reply to turbo size chart (borrowed from nasioc) on Thu, 11 Aug 2005 14:57:34 GMT]]></title><description><![CDATA[<p dir="auto">Ok wow, that's a huge difference.  Thx Dave.  Now I know, and knowing is half the battle...... yo joe bitches!</p>
]]></description><link>https://fargostreet.com/post/61978</link><guid isPermaLink="true">https://fargostreet.com/post/61978</guid><dc:creator><![CDATA[Sweet-WRX-Lovin]]></dc:creator><pubDate>Thu, 11 Aug 2005 14:57:34 GMT</pubDate></item><item><title><![CDATA[Reply to turbo size chart (borrowed from nasioc) on Thu, 11 Aug 2005 14:52:44 GMT]]></title><description><![CDATA[<p dir="auto">It helps a lot, depending on the size of the shot of course.  Without nitrous it takes me about 5 seconds to spool at the line.  With nitrous it takes less than a half of a second.</p>
<p dir="auto">Sweet-WRX-Lovin wrote:<br />
How much of a difference though does it make using NOS to spool up the big turbas? Just curious.</p>
]]></description><link>https://fargostreet.com/post/61976</link><guid isPermaLink="true">https://fargostreet.com/post/61976</guid><dc:creator><![CDATA[DaveH]]></dc:creator><pubDate>Thu, 11 Aug 2005 14:52:44 GMT</pubDate></item><item><title><![CDATA[Reply to turbo size chart (borrowed from nasioc) on Thu, 11 Aug 2005 14:50:57 GMT]]></title><description><![CDATA[<p dir="auto">How much of a difference though does it make using NOS to spool up the big turbas?  Just curious.</p>
]]></description><link>https://fargostreet.com/post/61975</link><guid isPermaLink="true">https://fargostreet.com/post/61975</guid><dc:creator><![CDATA[Sweet-WRX-Lovin]]></dc:creator><pubDate>Thu, 11 Aug 2005 14:50:57 GMT</pubDate></item><item><title><![CDATA[Reply to turbo size chart (borrowed from nasioc) on Thu, 11 Aug 2005 14:09:41 GMT]]></title><description><![CDATA[<p dir="auto">I'd be willing to disprove those T72 numbers as well.  If I decide to change anything this winter, I think a PT71GTQ might be in order.  Seems to be the sweet spot turbo for all of the street car Hondas.</p>
<p dir="auto">I know of one Honda running Dave's turbo too, and from what I read he seems to be happy.</p>
]]></description><link>https://fargostreet.com/post/61966</link><guid isPermaLink="true">https://fargostreet.com/post/61966</guid><dc:creator><![CDATA[integra_gsr98]]></dc:creator><pubDate>Thu, 11 Aug 2005 14:09:41 GMT</pubDate></item><item><title><![CDATA[Reply to turbo size chart (borrowed from nasioc) on Thu, 11 Aug 2005 13:00:20 GMT]]></title><description><![CDATA[<p dir="auto">according to the poster on Nasioc, they were compiled using information gathered from the manufacturers tech sheets.</p>
]]></description><link>https://fargostreet.com/post/61958</link><guid isPermaLink="true">https://fargostreet.com/post/61958</guid><dc:creator><![CDATA[[[global:guest]]]]></dc:creator><pubDate>Thu, 11 Aug 2005 13:00:20 GMT</pubDate></item><item><title><![CDATA[Reply to turbo size chart (borrowed from nasioc) on Thu, 11 Aug 2005 07:00:21 GMT]]></title><description><![CDATA[<p dir="auto">im pretty sure its just an estimate</p>
]]></description><link>https://fargostreet.com/post/61945</link><guid isPermaLink="true">https://fargostreet.com/post/61945</guid><dc:creator><![CDATA[[[global:guest]]]]></dc:creator><pubDate>Thu, 11 Aug 2005 07:00:21 GMT</pubDate></item><item><title><![CDATA[Reply to turbo size chart (borrowed from nasioc) on Thu, 11 Aug 2005 05:20:57 GMT]]></title><description><![CDATA[<p dir="auto">Where did they come up w/ these figures?  They seem pretty a little off if you ask me. There are so many variances in each turbo.  You pick up about 40cfm alone going from a E cover to a S cover.</p>
]]></description><link>https://fargostreet.com/post/61936</link><guid isPermaLink="true">https://fargostreet.com/post/61936</guid><dc:creator><![CDATA[PSI2HI]]></dc:creator><pubDate>Thu, 11 Aug 2005 05:20:57 GMT</pubDate></item><item><title><![CDATA[Reply to turbo size chart (borrowed from nasioc) on Thu, 11 Aug 2005 03:39:19 GMT]]></title><description><![CDATA[<p dir="auto">ok so what im understanding is that these turbos work ideally at these certain cubic feet per minute? Cubic feet per minute thats what a CFM is right?</p>
]]></description><link>https://fargostreet.com/post/61888</link><guid isPermaLink="true">https://fargostreet.com/post/61888</guid><dc:creator><![CDATA[theoblivious]]></dc:creator><pubDate>Thu, 11 Aug 2005 03:39:19 GMT</pubDate></item><item><title><![CDATA[Reply to turbo size chart (borrowed from nasioc) on Thu, 11 Aug 2005 02:55:33 GMT]]></title><description><![CDATA[<p dir="auto">nah, just build it to F1 standards and you'll be fine</p>
]]></description><link>https://fargostreet.com/post/61882</link><guid isPermaLink="true">https://fargostreet.com/post/61882</guid><dc:creator><![CDATA[[[global:guest]]]]></dc:creator><pubDate>Thu, 11 Aug 2005 02:55:33 GMT</pubDate></item><item><title><![CDATA[Reply to turbo size chart (borrowed from nasioc) on Thu, 11 Aug 2005 02:53:35 GMT]]></title><description><![CDATA[<blockquote>
T72               920 CFM at 14.7 PSI  &lt;-- Note you would have to spin a 2.0 L engine at about 14,000 rpm to flow this much air.</p>
<p dir="auto">shit.. there goes that idea...</p>
]]></description><link>https://fargostreet.com/post/61881</link><guid isPermaLink="true">https://fargostreet.com/post/61881</guid><dc:creator><![CDATA[amicheze]]></dc:creator><pubDate>Thu, 11 Aug 2005 02:53:35 GMT</pubDate></item></channel></rss>
