<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[I would like everyone&#x27;s opinion]]></title><description><![CDATA[<p dir="auto">If you had $250,000, no more and no less, what car(s) would you buy? Would you lay it all on a Ferrari F430 or a few Evos and S2000s? I would like everyone's opinion on this one.</p>
]]></description><link>https://fargostreet.com/topic/3684/i-would-like-everyone-s-opinion</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 02:11:40 GMT</lastBuildDate><atom:link href="https://fargostreet.com/topic/3684.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 14 Aug 2005 05:55:32 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to I would like everyone&#x27;s opinion on Wed, 07 Sep 2005 03:46:39 GMT]]></title><description><![CDATA[<blockquote>
My money is FIRMLY on the Koenigsegg CCR</p>
<p dir="auto"><img src="http://www.koenigsegg.com/graphics/techdata_ccr_side.jpg" alt="legacy image" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="http://www.koenigsegg.com/graphics/techdata_ccr_sideopen.jpg" alt="legacy image" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="http://www.koenigsegg.com/graphics/techdata_ccr_front.jpg" alt="legacy image" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="http://www.koenigsegg.com/graphics/techdata_ccr_back.jpg" alt="legacy image" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="http://www.koenigsegg.com/graphics/headline_techdata_ccr.gif" alt="legacy image" class=" img-fluid img-markdown" /><br />
<img src="http://www.koenigsegg.com/thecars/graphics/spacer.gif" alt="legacy image" class=" img-fluid img-markdown" /><br />
<strong>Performance</strong></p>
<p dir="auto">Acceleration: 0-100 km/h (0–62 mph) 3.2 seconds<br />
Top speed: 395+ km/h (242+ mph)<br />
Standing quartermile: 9 seconds, end speed 235 km/h (146 mph)<br />
Braking distance: 31 m (100–0 km/h)<br />
Lateral g-force: 1.3 g<br />
Fuel consumption: Highway travel: 13 l/100 km<br />
Combined: 17 l/100 km</p>
<p dir="auto"><strong>Body</strong></p>
<p dir="auto">Two-door, two-seater with removable hardtop stowable under the front boot lid. 	The body is made of preimpregnated carbonfibre/kevlar and lightweight hard-foam 	sandwich reinforcements.</p>
<pre><code>  **Dimensions**
</code></pre>
<p dir="auto">Ground clearance: 100 mm (3.9 inch)<br />
Fuel capacity: 80 litres (17.6 gallons)<br />
Luggage compartment: 120 litres (26.4 gallons)<br />
Dry weight: 1180 kg</p>
<p dir="auto"><strong>Areodynamics</strong></p>
<p dir="auto">Cd. 0.297. Frontal area 1.825 m2. Completely flat underside of chassis. 	Venturi tunnels at the rear of chassis/body.</p>
<p dir="auto"><strong>Chassis</strong></p>
<p dir="auto">Semi monocoque made of preimpregnated carbonfibre and with honeycomb reinforcements for added stiffness.<br />
Front and rear suspension: Double wishbones, adjustable VPS custom racing shock absorbers, pushrod operated. Anti-roll bar. Electronically adjustable ride height.</p>
<p dir="auto"><strong>Brakes</strong></p>
<p dir="auto">Front brakes: Ventilated discs Ø 362 mm, 32 mm wide. 6 piston light alloy calipers. Power assisted. Koenigsegg Advanced Control system.<br />
Rear brakes: Ventilated discs Ø 362 mm, 32 mm wide. 6 piston light alloy calipers. Power assisted. Koenigsegg Advanced Control syste</p>
<p dir="auto"><strong>Wheels</strong></p>
<p dir="auto">Koenigsegg magnesium alloy wheels with centre locking.<br />
Front: 19” x 9.5”<br />
Rear: 20” x 12.5”</p>
<p dir="auto"><strong>Tyres</strong></p>
<p dir="auto">Michelin Pilot Sport 2. Unidirectional with asymmetric tread pattern.<br />
Front: 255/35–19” (Y)<br />
Rear: 335/30–20” (Y)</p>
<p dir="auto"><strong>Steering</strong></p>
<p dir="auto">Rack and pinion power assisted steering. 2.7 turns lock to lock. Turning circle: 11 metres.</p>
<p dir="auto"><strong>Engine</strong> (<a href="http://www.koenigsegg.com/thecars/engineering.asp?engineering=12" rel="nofollow ugc">click for more info about the CCR engineering specifics</a>)</p>
<p dir="auto">Type: V8 cast aluminium, 4 valves per cylinder, double overhead camshafts. Cam cover of carbonfibre.<br />
Displacement: 4.700 cm3.<br />
Compression: 8.6:1<br />
Weight: 215 kg<br />
Lubrication system: Dry sump with unique oil spray piston cooling. Oil cooler.<br />
Oil: SAE 10W60 fully synthetic racing.<br />
Oil tank capacity: 12 litres (2.64 gallons)<br />
Induction system: Sequential, multipoint fuel injection. Dual Rotrex centrifugal compressors with 1.4 max boost pressure. Intercooler.<br />
Fuel: 98 RON unleaded.<br />
Ignition system: Direct coil on plug. Transistorised.<br />
Power output: 806 bhp at 6.900 rpm.<br />
Maximum torque: 920 Nm (678 ftlb) at 5.700 rpm.<br />
Maximum rpm: 7.600 rpm.</p>
<p dir="auto"><strong>Transmission</strong></p>
<p dir="auto">Specially developed 6-speed gearbox by Cima. Incorporated internal oil pump and oil cooler. Torque sensitive, limited slip differential.<br />
Clutch: Dual Plate, organic or cintered Ø 215 mm (8.46 inch). Oil-cooled and electronically operated.</p>
<p dir="auto"><strong>Equipment</strong></p>
<p dir="auto">In standard mode the car is very well equipped with many items that competitors have as options. Many customers, however, want to further equip the car. Therefore we can offer a list of customer options which should fulfil every demand.</p>
<p dir="auto">Standard equipment</p>
<p dir="auto"><img src="http://www.koenigsegg.com/graphics/dot_grey.gif" alt="legacy image" class=" img-fluid img-markdown" /> Aluminium rear light casings<br />
<img src="http://www.koenigsegg.com/graphics/dot_grey.gif" alt="legacy image" class=" img-fluid img-markdown" /> Detachable roof panel<br />
<img src="http://www.koenigsegg.com/graphics/dot_grey.gif" alt="legacy image" class=" img-fluid img-markdown" /> Climate control<br />
<img src="http://www.koenigsegg.com/graphics/dot_grey.gif" alt="legacy image" class=" img-fluid img-markdown" /> Electric rear view mirrors<br />
<img src="http://www.koenigsegg.com/graphics/dot_grey.gif" alt="legacy image" class=" img-fluid img-markdown" /> Leather interior<br />
<img src="http://www.koenigsegg.com/graphics/dot_grey.gif" alt="legacy image" class=" img-fluid img-markdown" /> Central locking<br />
<img src="http://www.koenigsegg.com/graphics/dot_grey.gif" alt="legacy image" class=" img-fluid img-markdown" /> Electrical windows<br />
<img src="http://www.koenigsegg.com/graphics/dot_grey.gif" alt="legacy image" class=" img-fluid img-markdown" /> Alarm with immobilizer<br />
<img src="http://www.koenigsegg.com/graphics/dot_grey.gif" alt="legacy image" class=" img-fluid img-markdown" /> Toolkit<br />
<img src="http://www.koenigsegg.com/graphics/dot_grey.gif" alt="legacy image" class=" img-fluid img-markdown" /> Driver side airbag<br />
<img src="http://www.koenigsegg.com/graphics/dot_grey.gif" alt="legacy image" class=" img-fluid img-markdown" /> Power steering<br />
<img src="http://www.koenigsegg.com/graphics/dot_grey.gif" alt="legacy image" class=" img-fluid img-markdown" /> Hydraulic ride height control<br />
<img src="http://www.koenigsegg.com/graphics/dot_grey.gif" alt="legacy image" class=" img-fluid img-markdown" /> Servo assisted brakes<br />
<img src="http://www.koenigsegg.com/graphics/dot_grey.gif" alt="legacy image" class=" img-fluid img-markdown" /> ABS<br />
<img src="http://www.koenigsegg.com/graphics/dot_grey.gif" alt="legacy image" class=" img-fluid img-markdown" /> Traction control<br />
<img src="http://www.koenigsegg.com/graphics/dot_grey.gif" alt="legacy image" class=" img-fluid img-markdown" /> Stereo with CD-player<br />
<img src="http://www.koenigsegg.com/graphics/dot_grey.gif" alt="legacy image" class=" img-fluid img-markdown" /> Tyre pressure sensors<br />
<img src="http://www.koenigsegg.com/graphics/dot_grey.gif" alt="legacy image" class=" img-fluid img-markdown" /> Car cover</p>
<p dir="auto">Customer options</p>
<p dir="auto"><img src="http://www.koenigsegg.com/graphics/dot_grey.gif" alt="legacy image" class=" img-fluid img-markdown" /> Custom Color Leather Interior<br />
<img src="http://www.koenigsegg.com/graphics/dot_grey.gif" alt="legacy image" class=" img-fluid img-markdown" /> Custom Paint Color<br />
<img src="http://www.koenigsegg.com/graphics/dot_grey.gif" alt="legacy image" class=" img-fluid img-markdown" /> Parking Sensors<br />
<img src="http://www.koenigsegg.com/graphics/dot_grey.gif" alt="legacy image" class=" img-fluid img-markdown" /> GPS Navigation<br />
<img src="http://www.koenigsegg.com/graphics/dot_grey.gif" alt="legacy image" class=" img-fluid img-markdown" /> Sequentially operated gearbox<br />
<img src="http://www.koenigsegg.com/graphics/dot_grey.gif" alt="legacy image" class=" img-fluid img-markdown" /> Rearview Camera<br />
<img src="http://www.koenigsegg.com/graphics/dot_grey.gif" alt="legacy image" class=" img-fluid img-markdown" /> Fitted Luggage</p>
<p dir="auto">Whats not to love?</p>
<p dir="auto">yes the CCR is a great car, and top speed wise you are probably correct, it would be a stretch for the Viper to reach that speed without carefully designed aerodynamics, but for the $250000 price ceiling, the Viper gets my money.</p>
<p dir="auto">if I had unlimited resources I'd get a Bugatti Veyron. Quad turbo W16! 987 SAE HP. Projected top speed (with specially developed tires) 253mph.</p>
]]></description><link>https://fargostreet.com/post/66962</link><guid isPermaLink="true">https://fargostreet.com/post/66962</guid><dc:creator><![CDATA[3_Series]]></dc:creator><pubDate>Wed, 07 Sep 2005 03:46:39 GMT</pubDate></item><item><title><![CDATA[Reply to I would like everyone&#x27;s opinion on Wed, 07 Sep 2005 03:37:11 GMT]]></title><description><![CDATA[<p dir="auto">Well me, I always try to lean toward something a little different, something you don't see every day. It's a name we all know and love but it's type that's rarely seen.<br />
Two words: "Oldschool" Skyline <img src="https://fargostreet.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f604.png?v=40430adaedb" class="not-responsive emoji emoji-android emoji--smile" style="height:23px;width:auto;vertical-align:middle" title=":D" alt="😄" /></p>
<p dir="auto"><img src="http://www.works-y3f.com/m_cars/3_jpn/nissan/GTR/GC10/m/m02.jpg" alt="legacy image" class=" img-fluid img-markdown" /> <img src="http://www.works-y3f.com/m_cars/3_jpn/nissan/GTR/GC10/m/m07.jpg" alt="legacy image" class=" img-fluid img-markdown" /> <img src="http://www.works-y3f.com/m_cars/3_jpn/nissan/GTR/GC10/m/m11.jpg" alt="legacy image" class=" img-fluid img-markdown" /></p>
<p dir="auto">Plus I'm sure I'd a few bucks left to build a garage to keep it in.</p>
]]></description><link>https://fargostreet.com/post/66960</link><guid isPermaLink="true">https://fargostreet.com/post/66960</guid><dc:creator><![CDATA[ichibankilla]]></dc:creator><pubDate>Wed, 07 Sep 2005 03:37:11 GMT</pubDate></item><item><title><![CDATA[Reply to I would like everyone&#x27;s opinion on Wed, 07 Sep 2005 03:29:45 GMT]]></title><description><![CDATA[<p dir="auto">Ariel Atom... just because...</p>
<p dir="auto">With whatever's left over I think I'd try to find a FIA Rally-Spect WRC Evo 6.5...  Either that or just import an Evo 6 TME and drop a few grand into that and buy a normal evo for a daily driver...</p>
<p dir="auto">Or the Koenigsegg... yeah... that'd be sweet...</p>
<p dir="auto">P.S. Anyone seen the Top Gear where he drove the Atom?  A-freaking-mazing...</p>
]]></description><link>https://fargostreet.com/post/66958</link><guid isPermaLink="true">https://fargostreet.com/post/66958</guid><dc:creator><![CDATA[SaxGopher]]></dc:creator><pubDate>Wed, 07 Sep 2005 03:29:45 GMT</pubDate></item><item><title><![CDATA[Reply to I would like everyone&#x27;s opinion on Wed, 07 Sep 2005 03:19:08 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">nissankingcab wrote:<br />
well the 255mph figure is theoretical of course, but i wouldn't bet against a car with 1000hp/1100tq if you give it enough pavement.</p>
<p dir="auto">My money is FIRMLY on the Koenigsegg CCR</p>
<pre><code>Acceleration: 0-100 km/h (0–62 mph) 3.2 seconds
</code></pre>
<pre><code>Two-door, two-seater with removable hardtop stowable under the front boot lid. 	The body is made of preimpregnated carbonfibre/kevlar and lightweight hard-foam 	sandwich reinforcements.
 	**Dimensions**
Dry weight: 1180 kg
</code></pre>
<pre><code>Cd. 0.297. Frontal area 1.825 m2. Completely flat underside of chassis. 	Venturi tunnels at the rear of chassis/body.
</code></pre>
<pre><code>Semi monocoque made of preimpregnated carbonfibre and with honeycomb reinforcements for added stiffness.
</code></pre>
<p dir="auto">Front and rear suspension: Double wishbones, adjustable VPS custom racing shock absorbers, pushrod operated. Anti-roll bar. Electronically adjustable ride height.</p>
<pre><code>Koenigsegg magnesium alloy wheels with centre locking.
Front: 19” x 9.5”
Rear: 20” x 12.5”
</code></pre>
<pre><code>Michelin Pilot Sport 2. Unidirectional with asymmetric tread pattern.
</code></pre>
<pre><code>Rack and pinion power assisted steering. 2.7 turns lock to lock. Turning circle: 11 metres.
</code></pre>
<pre><code>Type: V8 cast aluminium, 4 valves per cylinder, double overhead camshafts. Cam cover of carbonfibre.
Compression: 8.6:1
Weight: 215 kg
</code></pre>
<p dir="auto">Induction system: Sequential, multipoint fuel injection. Dual Rotrex centrifugal compressors with 1.4 max boost pressure. Intercooler.<br />
<pre><code>Standard equipment
![legacy image](http://www.koenigsegg.com/graphics/dot_grey.gif) Aluminium rear light casings
![legacy image](http://www.koenigsegg.com/graphics/dot_grey.gif) Detachable roof panel
![legacy image](http://www.koenigsegg.com/graphics/dot_grey.gif) Climate control
![legacy image](http://www.koenigsegg.com/graphics/dot_grey.gif) Electric rear view mirrors
![legacy image](http://www.koenigsegg.com/graphics/dot_grey.gif) Leather interior
![legacy image](http://www.koenigsegg.com/graphics/dot_grey.gif) Central locking
![legacy image](http://www.koenigsegg.com/graphics/dot_grey.gif) Electrical windows
![legacy image](http://www.koenigsegg.com/graphics/dot_grey.gif) Alarm with immobilizer
![legacy image](http://www.koenigsegg.com/graphics/dot_grey.gif) Toolkit
![legacy image](http://www.koenigsegg.com/graphics/dot_grey.gif) Driver side airbag
![legacy image](http://www.koenigsegg.com/graphics/dot_grey.gif) Power steering
![legacy image](http://www.koenigsegg.com/graphics/dot_grey.gif) Hydraulic ride height control
![legacy image](http://www.koenigsegg.com/graphics/dot_grey.gif) Servo assisted brakes
![legacy image](http://www.koenigsegg.com/graphics/dot_grey.gif) ABS
![legacy image](http://www.koenigsegg.com/graphics/dot_grey.gif) Traction control
![legacy image](http://www.koenigsegg.com/graphics/dot_grey.gif) Stereo with CD-player
![legacy image](http://www.koenigsegg.com/graphics/dot_grey.gif) Tyre pressure sensors
![legacy image](http://www.koenigsegg.com/graphics/dot_grey.gif) Car cover
Customer options
![legacy image](http://www.koenigsegg.com/graphics/dot_grey.gif) Custom Color Leather Interior
![legacy image](http://www.koenigsegg.com/graphics/dot_grey.gif) Custom Paint Color
![legacy image](http://www.koenigsegg.com/graphics/dot_grey.gif) Parking Sensors
![legacy image](http://www.koenigsegg.com/graphics/dot_grey.gif) GPS Navigation
![legacy image](http://www.koenigsegg.com/graphics/dot_grey.gif) Sequentially operated gearbox
![legacy image](http://www.koenigsegg.com/graphics/dot_grey.gif) Rearview Camera
![legacy image](http://www.koenigsegg.com/graphics/dot_grey.gif) Fitted Luggage
</code></pre>
]]></description><link>https://fargostreet.com/post/66951</link><guid isPermaLink="true">https://fargostreet.com/post/66951</guid><dc:creator><![CDATA[[[global:guest]]]]></dc:creator><pubDate>Wed, 07 Sep 2005 03:19:08 GMT</pubDate></item><item><title><![CDATA[Reply to I would like everyone&#x27;s opinion on Wed, 07 Sep 2005 02:59:56 GMT]]></title><description><![CDATA[<p dir="auto">well the 255mph figure is theoretical of course, but i wouldn't bet against a car with 1000hp/1100tq if you give it enough pavement.</p>
]]></description><link>https://fargostreet.com/post/66945</link><guid isPermaLink="true">https://fargostreet.com/post/66945</guid><dc:creator><![CDATA[3_Series]]></dc:creator><pubDate>Wed, 07 Sep 2005 02:59:56 GMT</pubDate></item><item><title><![CDATA[Reply to I would like everyone&#x27;s opinion on Wed, 07 Sep 2005 02:59:56 GMT]]></title><description><![CDATA[<p dir="auto">I'd keep my car, New shelby gt500, new ford gt  There is enough there for parts and research work on I'd say 7 shelby's (any year)in restorable condition from the 60's.</p>
]]></description><link>https://fargostreet.com/post/66946</link><guid isPermaLink="true">https://fargostreet.com/post/66946</guid><dc:creator><![CDATA[[[global:guest]]]]></dc:creator><pubDate>Wed, 07 Sep 2005 02:59:56 GMT</pubDate></item><item><title><![CDATA[Reply to I would like everyone&#x27;s opinion on Wed, 07 Sep 2005 02:56:10 GMT]]></title><description><![CDATA[<p dir="auto">That car isnt real... the world record holder for top speed is the Koenigsagg CCR with 242mph. I have the Car and Driver with it in there... such a kick ass car!</p>
]]></description><link>https://fargostreet.com/post/66941</link><guid isPermaLink="true">https://fargostreet.com/post/66941</guid><dc:creator><![CDATA[Flowcus]]></dc:creator><pubDate>Wed, 07 Sep 2005 02:56:10 GMT</pubDate></item><item><title><![CDATA[Reply to I would like everyone&#x27;s opinion on Wed, 07 Sep 2005 02:24:18 GMT]]></title><description><![CDATA[<p dir="auto"><a href="http://www.hennesseyperformance.com/hennesseyperformance/ItemDetail.php?Item_ID=238&amp;cart=cSucdLyp&amp;DoThis=Dodge+Viper+SRT+Coupe+%282006%29&amp;ActionReq=Where" rel="nofollow ugc">Hennessey Venom 1000 Twin Turbo SRT Coupe</a> (225,000)<br />
top speed 255mph! rest would be for gas.</p>
]]></description><link>https://fargostreet.com/post/66921</link><guid isPermaLink="true">https://fargostreet.com/post/66921</guid><dc:creator><![CDATA[3_Series]]></dc:creator><pubDate>Wed, 07 Sep 2005 02:24:18 GMT</pubDate></item><item><title><![CDATA[Reply to I would like everyone&#x27;s opinion on Wed, 07 Sep 2005 01:51:47 GMT]]></title><description><![CDATA[<p dir="auto">I would get.......</p>
<p dir="auto">1969 camaro Z28 RS/SS Copo</p>
<p dir="auto">That would put me about 750,000 over budget lol jk</p>
<p dir="auto">For real I would buy a</p>
<p dir="auto">1970 trans am (50,000)<br />
1970 GTO Judge (70,000)<br />
1067 Camaro RS/SS 454 (100,000)<br />
and the last 30,000 I would just have for extra money</p>
]]></description><link>https://fargostreet.com/post/66913</link><guid isPermaLink="true">https://fargostreet.com/post/66913</guid><dc:creator><![CDATA[LightEmUp]]></dc:creator><pubDate>Wed, 07 Sep 2005 01:51:47 GMT</pubDate></item><item><title><![CDATA[Reply to I would like everyone&#x27;s opinion on Wed, 07 Sep 2005 01:50:19 GMT]]></title><description><![CDATA[<blockquote>
"I'd have sex with two girls at the same time!"<br />
-Lawrence, Office Space</p>
<p dir="auto">I was going to say that same thing..</p>
<p dir="auto">I would throw some money at my car..probably quite a bit</p>
<p dir="auto">then,</p>
<p dir="auto">M3 + bling bling<br />
evo/sti + tons of tires and brakes<br />
F350 + "banks" and chrome<br />
GTI R32 + a TON of money<br />
boat + ski rope<br />
jet ski + trailer<br />
CBR + helmet and band aides</p>
]]></description><link>https://fargostreet.com/post/66912</link><guid isPermaLink="true">https://fargostreet.com/post/66912</guid><dc:creator><![CDATA[24valvenotak]]></dc:creator><pubDate>Wed, 07 Sep 2005 01:50:19 GMT</pubDate></item><item><title><![CDATA[Reply to I would like everyone&#x27;s opinion on Wed, 07 Sep 2005 01:42:10 GMT]]></title><description><![CDATA[<p dir="auto">Import a Subaru Impreza STi Spec-C set it up for Tarmac Rally racing.</p>
<p dir="auto">Fully enclosed race trailer with generator and tools.</p>
<p dir="auto">2005 Dodge Cummins turbo diesel with Banks Siderwinder kit</p>
<p dir="auto">And the rest would be for fixing the subaru, paying for fuel, and my trips around the country to different races. ( the money would run out, but having an STi spec-C doing tarmac rally racing... your going to grab some sponsors somewhere )</p>
]]></description><link>https://fargostreet.com/post/66910</link><guid isPermaLink="true">https://fargostreet.com/post/66910</guid><dc:creator><![CDATA[Flowcus]]></dc:creator><pubDate>Wed, 07 Sep 2005 01:42:10 GMT</pubDate></item><item><title><![CDATA[Reply to I would like everyone&#x27;s opinion on Wed, 07 Sep 2005 01:17:41 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">bluejays wrote:<br />
nissan skyline ztune and bam its gone<br />
nice car but there was only 20 made if road and track is right</p>
]]></description><link>https://fargostreet.com/post/66904</link><guid isPermaLink="true">https://fargostreet.com/post/66904</guid><dc:creator><![CDATA[KA-T_240]]></dc:creator><pubDate>Wed, 07 Sep 2005 01:17:41 GMT</pubDate></item><item><title><![CDATA[Reply to I would like everyone&#x27;s opinion on Tue, 06 Sep 2005 23:47:12 GMT]]></title><description><![CDATA[<p dir="auto">I cant believe only one person mentioned a Skyline....... at least he picked the best one you could get..... for shame...</p>
<p dir="auto">99 Skyline GT-R + Mods 200,000 AKA Fun Car<br />
05 Evo + mods 50,000 AKA Daily Driver<br />
Done.</p>
]]></description><link>https://fargostreet.com/post/66886</link><guid isPermaLink="true">https://fargostreet.com/post/66886</guid><dc:creator><![CDATA[imprttuner2]]></dc:creator><pubDate>Tue, 06 Sep 2005 23:47:12 GMT</pubDate></item><item><title><![CDATA[Reply to I would like everyone&#x27;s opinion on Mon, 15 Aug 2005 14:14:30 GMT]]></title><description><![CDATA[<p dir="auto">Make my car fast <img src="https://fargostreet.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f604.png?v=40430adaedb" class="not-responsive emoji emoji-android emoji--smile" style="height:23px;width:auto;vertical-align:middle" title=":D" alt="😄" /></p>
]]></description><link>https://fargostreet.com/post/62665</link><guid isPermaLink="true">https://fargostreet.com/post/62665</guid><dc:creator><![CDATA[YellowEvo]]></dc:creator><pubDate>Mon, 15 Aug 2005 14:14:30 GMT</pubDate></item><item><title><![CDATA[Reply to I would like everyone&#x27;s opinion on Mon, 15 Aug 2005 14:00:29 GMT]]></title><description><![CDATA[<p dir="auto">BMW M5   with some dinan parts<br />
finish the lude<br />
buy another lude...</p>
<p dir="auto">then chill.</p>
]]></description><link>https://fargostreet.com/post/62664</link><guid isPermaLink="true">https://fargostreet.com/post/62664</guid><dc:creator><![CDATA[illudr]]></dc:creator><pubDate>Mon, 15 Aug 2005 14:00:29 GMT</pubDate></item><item><title><![CDATA[Reply to I would like everyone&#x27;s opinion on Mon, 15 Aug 2005 13:27:15 GMT]]></title><description><![CDATA[<p dir="auto">"I'd have sex with two girls at the same time!"<br />
]]></description><link>https://fargostreet.com/post/62660</link><guid isPermaLink="true">https://fargostreet.com/post/62660</guid><dc:creator><![CDATA[HandoEX]]></dc:creator><pubDate>Mon, 15 Aug 2005 13:27:15 GMT</pubDate></item><item><title><![CDATA[Reply to I would like everyone&#x27;s opinion on Mon, 15 Aug 2005 10:07:52 GMT]]></title><description><![CDATA[<p dir="auto">nissan skyline ztune and bam its gone</p>
]]></description><link>https://fargostreet.com/post/62654</link><guid isPermaLink="true">https://fargostreet.com/post/62654</guid><dc:creator><![CDATA[bluejays]]></dc:creator><pubDate>Mon, 15 Aug 2005 10:07:52 GMT</pubDate></item><item><title><![CDATA[Reply to I would like everyone&#x27;s opinion on Mon, 15 Aug 2005 07:30:29 GMT]]></title><description><![CDATA[<p dir="auto">i would put it in the bank and only take some out when my car breaks......so like every other week...</p>
]]></description><link>https://fargostreet.com/post/62642</link><guid isPermaLink="true">https://fargostreet.com/post/62642</guid><dc:creator><![CDATA[Parker]]></dc:creator><pubDate>Mon, 15 Aug 2005 07:30:29 GMT</pubDate></item><item><title><![CDATA[Reply to I would like everyone&#x27;s opinion on Mon, 15 Aug 2005 06:28:07 GMT]]></title><description><![CDATA[<p dir="auto">used kenworth with a hauler $125,000<br />
geo metro or 1985 civic wagon<br />
wissota late model<br />
the rest would be fuel money</p>
]]></description><link>https://fargostreet.com/post/62637</link><guid isPermaLink="true">https://fargostreet.com/post/62637</guid><dc:creator><![CDATA[h22d_hatch]]></dc:creator><pubDate>Mon, 15 Aug 2005 06:28:07 GMT</pubDate></item><item><title><![CDATA[Reply to I would like everyone&#x27;s opinion on Mon, 15 Aug 2005 05:41:13 GMT]]></title><description><![CDATA[<p dir="auto">Not too shabby of a car.</p>
]]></description><link>https://fargostreet.com/post/62622</link><guid isPermaLink="true">https://fargostreet.com/post/62622</guid><dc:creator><![CDATA[[[global:guest]]]]></dc:creator><pubDate>Mon, 15 Aug 2005 05:41:13 GMT</pubDate></item><item><title><![CDATA[Reply to I would like everyone&#x27;s opinion on Mon, 15 Aug 2005 05:29:52 GMT]]></title><description><![CDATA[<blockquote>
there's a pimp one that rolls through the mall parking lot everyone and a while when i was there. I think either he just keeps them REALLY REALLY clean or he got the stock chromes redipped in some high grade shit, cuz they are SHINY!</p>
<p dir="auto">really?  I can't say as though I've even seen more than a half dozen of them around the FM, much less a modified one.</p>
<p dir="auto">browsing...</p>
<p dir="auto"><img src="http://www.edmunds.com/media/2001/sema/lincoln_ls_se/lincoln.ls.sportedition.500.jpg" alt="legacy image" class=" img-fluid img-markdown" /><br />
f'in HOT</p>
<p dir="auto">Date Posted 11-08-2001</p>
<p dir="auto">Lincoln LS Sport Edition</p>
<p dir="auto">What is it?<br />
Lincoln LS "Sport Edition"</p>
<p dir="auto">What's special about it?<br />
With 350 horsepower and 350 pound-feet of torque emanating from its supercharged V8, this is one serious LS. A revised engine computer and a performance intake system help the blown V8 achieve its lofty horsepower numbers without an increase to its 3.9-liter displacement.</p>
<p dir="auto">The car sits slightly lower than stock and features Bilstein shocks and upgraded antiroll bars for better control. Aluminum alloy 19-inch wheels wrapped in Z-rated high-performance tires further contribute to the custom look of this hot rod Lincoln.</p>
<p dir="auto">Why should you care?<br />
In its current guise, the standard LS is nothing more than a boulevard cruiser with nice wheels and a smooth, but not overly powerful, V8. This version shows that the LS can be a real high-performance machine, given the right parts. With a facelift due next year, we can only hope that future "sport" models will look as good and have as much horsepower as this show version. — Ed Hellwig<br />
<a href="http://www.streetsports.com/Photos/Vehicles/Ford-Lincoln/LS/LS%20Images/Front_quarter.jpg" rel="nofollow ugc">http://www.streetsports.com/Photos/Vehicles/Ford-Lincoln/LS/LS%20Images/Front_quarter.jpg</a><br />
wow<br />
too bad it didn't make production.</p>
]]></description><link>https://fargostreet.com/post/62615</link><guid isPermaLink="true">https://fargostreet.com/post/62615</guid><dc:creator><![CDATA[dubbsy]]></dc:creator><pubDate>Mon, 15 Aug 2005 05:29:52 GMT</pubDate></item><item><title><![CDATA[Reply to I would like everyone&#x27;s opinion on Mon, 15 Aug 2005 04:49:25 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">dubbsy wrote:<br />
ooo, good taste in pimp rides.</p>
<p dir="auto">I'll take mine with the V8 in black with 18" dished chrome wheels.<br />
And a black 2003 Marauder.</p>
<p dir="auto">Dammit, can we up this to $300k?<br />
]]></description><link>https://fargostreet.com/post/62603</link><guid isPermaLink="true">https://fargostreet.com/post/62603</guid><dc:creator><![CDATA[Joel]]></dc:creator><pubDate>Mon, 15 Aug 2005 04:49:25 GMT</pubDate></item><item><title><![CDATA[Reply to I would like everyone&#x27;s opinion on Mon, 15 Aug 2005 04:35:40 GMT]]></title><description><![CDATA[<blockquote>
Lexus IS 430 (Around $70,000) Only 1 Made.<br />
Lincoln Blackwood ($75,000)<br />
Hayabusa ( 20,000)<br />
fast/reliable DSM (50,000)<br />
And probably a couple cheaper DD's<br />
A Hayabusa is not $20k.</p>
]]></description><link>https://fargostreet.com/post/62597</link><guid isPermaLink="true">https://fargostreet.com/post/62597</guid><dc:creator><![CDATA[[[global:guest]]]]></dc:creator><pubDate>Mon, 15 Aug 2005 04:35:40 GMT</pubDate></item><item><title><![CDATA[Reply to I would like everyone&#x27;s opinion on Mon, 15 Aug 2005 03:49:46 GMT]]></title><description><![CDATA[<blockquote>
40,000 - Lincoln LS w/ lotsa of I.C.E., big chrome wheels.</p>
<p dir="auto">ooo, good taste in pimp rides.</p>
<p dir="auto">Dammit, can we up this to $300k?</p>
]]></description><link>https://fargostreet.com/post/62589</link><guid isPermaLink="true">https://fargostreet.com/post/62589</guid><dc:creator><![CDATA[dubbsy]]></dc:creator><pubDate>Mon, 15 Aug 2005 03:49:46 GMT</pubDate></item></channel></rss>
